19th August 2017, 21:08 | #44861 | Link |
I confirm no more crashes for me with build 0.92.1b !
Noted for NNEDI, I will try NGU.
19th August 2017, 21:33 | #44863 | Link | |
So it's only fucked in the nvidia control panel. It pretty much crashes every time when I move MPC-HC from my main monitor to my TV screen while a video is playing. It doesn't crash when pausing the video before dragging it over, so not really a big deal but it would still be nice if it could be fixed. Crash report attached. |
19th August 2017, 21:52 | #44864 | Link | ||
Sorry for not being clear enough. I'll try to be as precise as possible in my next answers.
I am 100% sure that the mode summoned by FSE is the custom one (vastly improved frame drop frequency). Quote:
The custom modes in the nvidia control panel were created by madvr. Once I check the checkbox in front of them, they are available to select through the nvidia selection box, in the custom section. So if I changed the display using the nvidia control panel to that custom mode and launch a 23p file without triggering a display mode change, it is correctly using the new custom mode. Otherwise, switching to 23p either by using the standard windows display settings or using the madvr display mode switcher uses the standard 23p mode. So my two posts aren't contradictory, but complementary : the first one gives an example of how I was able to trigger the custom mode using the FSE trick (without fiddling in the nvidia cpl), and the second one shows that I can directly summon the same custom mode through the nvidia cpl, but that the same custom mode won't be called by the windows display settings or madvr display mode switcher. So I am able to use the custom mode, but not without using roundabout ways each time. (This is really a b***h to explain )
OS: Win10 1703 GPU: GTX 1070 (latest stable drivers) Monitor: LG OLED55B6V TV / Yamaha RX-A860 AVR Media setup: MPC-BE x64, madvr, lav filters (nightly) |
19th August 2017, 21:53 | #44865 | Link | |
Also the "Display Modes" now only appears once rather than twice on the display connected to the AVR (but "Custom Modes" still flashes on and off). Last edited by jmonier; 19th August 2017 at 22:07. |
19th August 2017, 21:54 | #44866 | Link | |
19th August 2017, 22:20 | #44868 | Link |
In testing a resolution on my secondary monitor, the secondary monitor becomes the main monitor and the original main monitor is disconnected (leaving me with one working monitor). I have to go back to "Screen Resolution" and extend the desktop to the other (disconnected) monitor to fix it.
19th August 2017, 22:35 | #44869 | Link | |
It is 10-bit for me if I set my display to 10 bit.
madVR options explained Last edited by Asmodian; 19th August 2017 at 22:38. |
19th August 2017, 22:41 | #44870 | Link | |
I only have 8 bit there, using full range RGB. The LG 4K is a 10 bit native panel as far as I know.
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
19th August 2017, 23:18 | #44871 | Link | ||||||||||
The 8bit problem was also reported by another user to me via email, but I can't seem to be able to reproduce it on my PC. Can you maybe try to find out if it's caused by any specific madVR settings? Or maybe it happens with some videos but not all or something like that? Quote:
You need to activate D3D11 presentation in madVR, and in the display properties in madVR set your display to 10bit. |
19th August 2017, 23:29 | #44872 | Link |
Thanks madshi but won't that just be compressed then when the image is leaving the graphics card by the Nvidia setting of 8 bit? I thought it was necessary to set the output correctly as well.
19th August 2017, 23:34 | #44874 | Link | ||
Anyway, with all the improvements made to windowed mode (10bit support) and DXVA11, using a 32bit player and reclock is still a viable option if you tolerate the audio resampling until I get to format (it now handles those pesky 60fps HDR demo clips without a hitch). Thanks for your help ! Edit : as a side note, after adding the 23p custom mode through madvr, the nvidia cpl lists the mode under the custom section under "3840*2160, progressive, 24hz", but the 23hz remains in the "Ultra HD, HD, SD" section under "4k x 2k, 3840*2160, 23hz" (24hz is gone from the dropbox).
OS: Win10 1703 GPU: GTX 1070 (latest stable drivers) Monitor: LG OLED55B6V TV / Yamaha RX-A860 AVR Media setup: MPC-BE x64, madvr, lav filters (nightly) Last edited by mitchmalibu; 19th August 2017 at 23:39. |
19th August 2017, 23:47 | #44875 | Link |
madshi
If I use Spline AR in image upscaling, in chromatic upscaling which filter i can use, for best video quality 576i 50 frs to 1080p 50 frs. Can I use the latest version of madVR, even with my small graphics card? thank you so much Last edited by dvd1; 20th August 2017 at 01:36. |
20th August 2017, 00:45 | #44877 | Link | |
I suppose that I can set up the custom resolutions while working with a single monitor and then go back to the dual monitor afterwards, but that seems unwieldy. I'm still at the beginning of the learning curve, though. |
20th August 2017, 01:09 | #44878 | Link | |
It's again the secondary monitor set to: 1080p23, 1080p50, 1080p59 (removing the values doesn't help) via hdmi through AVR to TV with Nvidia 1060. |
20th August 2017, 01:17 | #44879 | Link |
Facing crashs with MPC-HC and MPC-BE.
Opening any mkv file, on the first display (120Hz BenQ) and then going to fullscreen (which automatically open the video on the second display (LG LED TV @ HDMI 60Hz) both MPCs crash. I have to open any of the MPC,have to drag the file to the second display, then go to fullscreen, then drag the file to there. That way I dont face crash. Sorry about my English :x Using GTX 1070 (driver 382.53) Windows 10 LTSB x64 Last versions of MPC-BR and MPC-HC LAV Nightly Last version madvr Well, it looks like that D3D11, at Lav Video Decoder (Nightly) the culprit. Is that hardware related, driver ? What s the benefits of using D3D11 instead of copyback ? Last edited by vanschneidermann; 20th August 2017 at 01:20. Reason: add info |
20th August 2017, 01:44 | #44880 | Link | |
Went back to 0.92.1 and it's working ok again, minus the random crashes. UPDATE: Deleted settings and uninstalled and installed 0.92.1 and then 0.92.1b and it seems ok. Don't know why it was crashing like that. Hope it doesn't pop up again. Last edited by AngelGraves13; 20th August 2017 at 01:47. |
