Old 31st December 2018, 16:24   #54041  |  Link
Damien147
The only benefit for 8 bit panels and fullscreen exclusive mode is the removal of unwanted pop up messages from win.Am I right?
Damien147 is offline   Reply With Quote
Old 31st December 2018, 17:26   #54042  |  Link
clsid
You can also use Quiet Hours / Focus Assist to hide notifications.
Old 31st December 2018, 17:40   #54043  |  Link
Damien147
Indeed.I am just trying to find out if fullscreen exclusive mode has any + or - for me.Win 10 and 8 bit panel here.Is it suggested to stay with fullscreen windowed in my occasion?
Old 31st December 2018, 17:50   #54044  |  Link
brazen1
They are the same, but one is automatic and the other isn't.
I don't think auto engage vs manual is the only difference when using NV HDR vs OS HDR.
OS HDR does not apply at display level through any player or software. NV HDR does. This means the display is not going to enter an HDR mode that auto adjusts settings like contrast and backlight because it doesn't passthrough anything to the display other than the desktop faux HDR.
Old 31st December 2018, 17:52   #54045  |  Link
jkauff
I seem to remember madshi saying that fullscreen windowed is the way to go with Win 10.
Old 31st December 2018, 17:56   #54046  |  Link
brazen1
Use FSE for frame packed MVC 3D.
Use FSE for UHD HDR.
Use FSW for everything else.
Old 31st December 2018, 18:05   #54047  |  Link
Damien147
I see.Fullscreen windowed for me then.Thanks guys.
Old 31st December 2018, 18:25   #54048  |  Link
Asmodian
Focus Assist does not play well with madVR. Oddly it causes studder if any aspect of it is enabled.
madVR options explained
Old 1st January 2019, 02:38   #54049  |  Link
XTrojan
Some people back in the thread said that OS HDR doesnt't send metadata.
Then there's also NV HDR sending 12bit image while OS HDR maxes out at 10?
XTrojan is offline   Reply With Quote
Old 1st January 2019, 02:49   #54050  |  Link
madVR is limited to 10 bit output no matter what.
the GPU driver is limited to 12 bit for the usual refreshrates/resolutions.
the HDR NV API or the HDR OS API have nothing todo with this.
Old 1st January 2019, 04:44   #54051  |  Link
XTrojan
I see. I just saw 12Bit output when NV HDR API was enabled.
I tested both APIs and can't really tell a difference between the two APIs (If Windows api ignores metadata). My TV is limited to 400 nits ( Samsung JS9000 ). Anyone can test both APIs with a higher brightness TV to confirm if there's a difference?
Old 1st January 2019, 11:27   #54052  |  Link
ikarad
Why?
ikarad is offline   Reply With Quote
Old 1st January 2019, 12:44   #54053  |  Link
actarusfleed
Originally Posted by actarusfleed View Post
I imagine that the "2.35:1 35mm film" sign tells me that black bar detection is actived ...
The strange thing is that I still have black bar detection also if I change "hardware decoder to use" to none or D3D11.
Is it not only a feature of DXVA2 copyback?
happy new year.
Anyone can tell me something about this?
I want to know if it's possible to have black bar detection also without copyback.
thank you
actarusfleed is offline   Reply With Quote
Old 1st January 2019, 13:55   #54054  |  Link
el Filou
el Filou's Avatar
You have to think about it the other way: black bar detection doesn't work with 'native' GPU decoding (e.g. DXVA2 Native, or D3D11 with Automatic setting). It works in all other decoding modes.
Old 1st January 2019, 17:08   #54055  |  Link
brazen1
Originally Posted by ikarad View Post
Why?
One typical real world example why FSW is better than FSE that you can test yourself (and I hope no one is offended for the somewhat OT post):
You can probably recreate this by just right clicking your mouse in the player field but here is exactly my method and why it affects me:
Set FSW in madVR by turning off FSE.
Play a title.
Bring up the madVR OSD.
You will see 'D3D11 fullscreen windowed'.
I have mapped keystroke 'C' to assign 'player menu (long) for MPC-HC/BE in the players 'keys' options. During playback when I press it, I have access to the players menu to navigate and select any option. I use it for subtitle selection mainly. This key also matches the context menu in KODI fwiw when harmonizing remote control functions. You can just press 'C' on your keyboard once you entered that keystroke value in MPC keys option if it doesn't match the 'menu' button on your remote for some odd reason.
So, during playback without interrupting, I press the menu key on my remote once and the MPC menu overlays on top of the title in progress allowing me to navigate with the directional keys to what I desire and all is perfect.
Now set FSE in madVR.
Play a title.
You will see 'exclusive' mode.
Press 'C'. You will notice the screen flicker a couple times. This is because it's trying to come out of FSE and go into FSW. The menu interaction only works in FSW.
Ultimately, it isn't going to go into FSW, you'll be returned to your movie in progress, without the menu displaying and managed to do nothing but create black screen flashes for nothing and miss what was playing during the fiasco.
You can fiddle doing this procedure if you time the button pressing 'C' multiple times and if you time it just right, eventually it will switch. Once it has finally come out of FSE and into FSW you will notice madVR OSD shows it's not in FSE anymore and has switched to FSW and you can finally access the menu you've been struggling to navigate to. Once you've made your selection in the MPC menu it has to come out of FSW and back to FSE which exhibits more screen flashes and once again interrupts playback of the movie in progress. It's really a mess tbh.
I think the best thing to do is use FSW vs FSE when you can. I'd use it for all file types except UHD HDR and 3D MVC requires FSE in my environment. So, I set up profiles to make the selection automatic.
Happy new year!
Old 1st January 2019, 21:58   #54056  |  Link
etc6849
MadVR not entering fullscreen exclusive mode
Long time user of this wonderful renderer. I'm using it with JRiver.
For some reason when I upgraded my GPU to an Nvidia RTX 2080 Ti, MadVR will periodically refuse to go into FSE, and instead uses Windowed mode (despite the correct settings being used). This is always fixed by a reboot.
I think I have this narrowed down to this item from the logs:
00018740.081 Render D3D11 fullscreen windowed (8 bit)
00018740.081 Render covered by some windows
00018740.083 Render madVR window [madVR] {0,0,3840,2160}
00018741.395 Render covered by explorer.exe window [ThumbnailDeviceHelperWnd] {0,0,1,1}
I "think" that MadVR sees this ThumbnailDeviceHelper window (hidden from the windows user), and then subsequently does not enter fullscreen exclusive mode?
This is verified by rebooting my PC which gets rid of this hidden explorer.exe window and then all works correctly and FSE works. But, of course this is windows we are talking about and the helper window randomly reappears...?!?
If someone can shed light on this hidden window and how to stop it in Windows 10 LTSC that would be great. MadVR logs and system info are found here:
https://drive.google.com/open?id=1lz...y6Eli5TK1cQ58S
NVIDIA System Information report created on: 01/01/2019 15:41:55
System name: THEATER
[Display]
Operating System: Windows 10 Enterprise LTSC 2019, 64-bit
DirectX version: 12.0
GPU processor: GeForce RTX 2080 Ti
Driver version: 417.35
Driver Type: Standard
Direct3D API version: 12
Direct3D feature level: 12_1
CUDA Cores: 4352
Core clock: 1650 MHz
Memory data rate: 14.00 Gbps
Memory interface: 352-bit
Memory bandwidth: 616.00 GB/s
Total available graphics memory: 44011 MB
Dedicated video memory: 11264 MB GDDR6
System video memory: 0 MB
Shared system memory: 32747 MB
Video BIOS version: 90.02.17.00.7D
IRQ: Not used
Bus: PCI Express x8 Gen3
Device Id: 10DE 1E07 23873842
Part Number: G150 0032
[Components]
nvui.dll 8.17.14.1735 NVIDIA User Experience Driver Component
nvxdplcy.dll 8.17.14.1735 NVIDIA User Experience Driver Component
nvxdbat.dll 8.17.14.1735 NVIDIA User Experience Driver Component
nvxdapix.dll 8.17.14.1735 NVIDIA User Experience Driver Component
NVCPL.DLL 8.17.14.1735 NVIDIA User Experience Driver Component
nvCplUIR.dll 8.1.940.0 NVIDIA Control Panel
nvCplUI.exe 8.1.940.0 NVIDIA Control Panel
nvWSSR.dll 25.21.14.1735 NVIDIA Workstation Server
nvWSS.dll 25.21.14.1735 NVIDIA Workstation Server
nvViTvSR.dll 25.21.14.1735 NVIDIA Video Server
nvViTvS.dll 25.21.14.1735 NVIDIA Video Server
nvLicensingS.dll 6.14.14.1735 NVIDIA Licensing Server
NVSTVIEW.EXE 7.17.14.1735 NVIDIA 3D Vision Photo Viewer
NVSTTEST.EXE 7.17.14.1735 NVIDIA 3D Vision Test Application
NVSTRES.DLL 7.17.14.1735 NVIDIA 3D Vision Module
nvDispSR.dll 25.21.14.1735 NVIDIA Display Server
NVMCTRAY.DLL 25.21.14.1735 NVIDIA Media Center Library
nvDispS.dll 25.21.14.1735 NVIDIA Display Server
PhysX 09.18.0907 NVIDIA PhysX
NVCUDA.DLL 25.21.14.1735 NVIDIA CUDA 10.0.132 driver
nvGameSR.dll 25.21.14.1735 NVIDIA 3D Settings Server
nvGameS.dll 25.21.14.1735 NVIDIA 3D Settings Server
etc6849 is offline   Reply With Quote
Old 2nd January 2019, 12:03   #54057  |  Link
albur
The OSD says the GPU can't keep up, so I don't know what the problem would be. Try reducing your setting for chroma upscaling and see if the rendering times come down. There must be some sort of bottleneck causing those rendering times. fullscreen exclusive mode isn't reliable on Windows 10. That is most likely the issue.
Thank you, without the exclusive mode it working if i start in windowed mode and then i go fullscreen, if i launch directly in fullscreen i have the same issue but i quit fullscreen and go fullscreen again and it works. I don't know what can be happening. Only happens with 3D MVC mkvs
albur is offline   Reply With Quote
Old 2nd January 2019, 14:01   #54058  |  Link
Dreamject
Have a problem for playing at ~1.5 speed - have a lot of dropped frames. But GPU and CPU does not loaded on 100%, it's about 70-80%. How to fix that?
Using potplayer
My config: Win10 x64, i7, hd4000, laptpo
Dreamject is offline   Reply With Quote
Old 2nd January 2019, 14:12   #54059  |  Link
v0lt
@Dreamject
Perhaps one of the cores is fully occupied. Or there are limitations on the speed of "video memory". I hope your memory works in dual channel mode?
Old 2nd January 2019, 15:49   #54060  |  Link
Dreamject
Originally Posted by v0lt View Post
@Dreamject
Sorry i've created theme, but it makes me crazy %).
Now I have 4+2 gb .
I disabled every image improvement, actually I deprove video (enabled such thing as nearest neighbor. OK, gpu load is about 50%, but it still show me dropped frames. EVR-CP or OpenGL mode, instead, shows 0 dropped frames...
