28th February 2019, 14:35 | #55021 | Link | |
28th February 2019, 18:18 | #55022 | Link |
Welp I spoke too soon, I'm still getting 4.9% or so of clock deviation on every file I play, 1080p or 4k. I did a clean install of NVidia 416.95 drivers and my refresh rate is still reporting as 62.95254Hz for my Sony projector.
My hardware setup is PC>Denon 6300H>Projector so I can't really change that, also nuking Windows and shotgunning the whole install is not an option really either. Surely there is a more surgical approach I can take to chasing down this issue???? Windows 10 x64 1070ti 416.95 Kodi 17 DSPlayer MadVR 0.92.17 LAV 0.70.2.81-git Passthru audio No reclock Last edited by griffind; 28th February 2019 at 18:23. |
28th February 2019, 18:42 | #55023 | Link |
Just wanted to write this to thank Madshi for all the work. I finally found the optimal settings for 4k and started using a 3dlut file which I ramdomly found in a guide which works fantastically well for shadows.
It really looks amazing and I am very thankful for this renderer, it's superbly done. Idling about 65% with a 2070 rtx. What I love is the sharpness it's really astounding how crisp the quality is, the smoothness of light and shadows. I have yet to fix full rgb since my reciever don't support it, but still looks incredible. Thanks man it's now very pleasing to watch 4k! Last edited by maxkill; 28th February 2019 at 18:52. |
28th February 2019, 20:04 | #55029 | Link |
My guess is "Any Source" is gonna be "Any HDMI Source". So it's gonna be a small box you put between your TV and an HDMI source and it's gonna tonemap.
OR Re-encoding software that applies madvr's tonemapping and outputs to a file instead of the screen. |
28th February 2019, 20:05 | #55030 | Link |
I know it's very early, but can anyone comment on 2160p upscaling performance with the new GTX 1660 Ti, using 720p and 1080p sources?
Suspect NGU is out of the question - is this card capable of 60FPS smoothmotion Lanczos/Jinc/XBR etc? Building a second HTPC and don't want to break the bank with a 1080/2080 card. Thanks! Last edited by cokeefe; 28th February 2019 at 20:07. |
28th February 2019, 21:02 | #55032 | Link |
Thanks for the heads up, madshi. The prospect of being able to apply madvr tone mapping to any source is rather exciting!
28th February 2019, 21:28 | #55035 | Link |
Angel of Night
If someone would like to offer a constructive idea for improvement, instead of accusing one of the most respected developers this forum's ever had of being a spammer and scammer (of what?), let's have it. Accusations, insults, and trolling are not welcome here (nor is trolling back, for some of you).
So let's take a moment to breathe, assume good faith, and approach this in a calmer manner. Madshi, maybe redirecting to a page that says "Thank you for signing up for the newsletter; click here to take an optional short user survey so I can better understand how you use the software." |
28th February 2019, 21:43 | #55036 | Link | |
X Cinema Projectionist NZ
Ive had the NX9 for about 3 weeks, I set the 1080Ti card to RGB 0-255 12bits and madvr to the same. I noticed weeks ago that my NX9 wouldnt display when I set it to RGB, however it only worked if I left it on Auto. I thought it was odd as in the past I had my X9900 set to RGB and everything was fine, I believe if all in the chain is set to RGB, the proj should be in RGB, is that correct? I have a feeling now that since Im using 12bit and auto on the NX9 that Im now doing a conversion to 422 which I believe isnt good.... Am I ok with how I have the card/madvr/NX9 setup at the moment or should I be changing everything to 8bit until JVC fix this? Thank you manni... Last edited by 70MM; 28th February 2019 at 21:46. |
28th February 2019, 22:27 | #55038 | Link | |
28th February 2019, 22:49 | #55039 | Link | |
But in order to remove any reason for user complaints, I've decided to delete my earlier post which linked to the newsletter/survey. I think my target audience for the newsletter is probably reading other forums, anyway. So it's not a big loss for me to lose the post/links here. I'll keep this thread focused on the madVR software. |
