4th April 2009, 09:31 | #241 | Link |
HDConvertToX author
please try again
i am at home now, and i use linux, so i compile on a virtual machine, and maybe the upload got corrupted when uploading from virtual to my site... BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
4th April 2009, 10:23 | #243 | Link |
Something you may want to consider for a future release:
The Stream PAR now indicates the PAR of the source. When I do an anamorphic encode of a non-anamorphic source, the PAR (=SAR in x.264) actually changes. The same is true when I enter a new value as Widht or Height which will also affect the PAR. I suggest to dispaly the recalculated PAR and add it to the command line of the encoder, i.e. in case of x.264 it would be like --sar x:y. And a minor issue: When selecting a subtitle, the NONE should automatically get deselected. |
4th April 2009, 10:32 | #244 | Link | ||
HDConvertToX author
BHH
4th April 2009, 11:52 | #245 | Link |
Mux Subtitles in MP4/MKV file: What if I select m2ts as container? Will the subtitles be lost?
When I select as Audio Options ac3/448kbps/6(5.1) the original dts hi-res audio gets encoded at 640kbps (using libav) rather than my specified 448kbps. Is this a bug? Finally, It would like to be able to enter crf values with 1 decimal, e.g. 22.5, because differences in file size using integer steps only can be significant. Last edited by Sharc; 4th April 2009 at 13:02. |
4th April 2009, 13:19 | #246 | Link |
HDConvertToX author
@Sharc
update hdc in m2ts now is possible to mux SRT subtitle (even language tag is reported.. but i cannot test it) about ac3 bitrate i cannot set it, eac3to use 640 (bitrate will be disabled in next update) BHH
4th April 2009, 14:07 | #247 | Link | |
ac3 bitrate downconversion to from 640 to 448 kbps: Hmmm, I think this can be done with libAften. Maybe you will think about including it in the HDC2X package .... |
4th April 2009, 14:14 | #248 | Link |
Suggestions:
- when set SAP, value for X to be 720 after Analyze and for NMT 1920. Many times these are the values, but sometimes don't. If the source is SD, to not offer an upscaled value. If is good this ideea, to put back the SAP and NMT options on "crop & resize" tab. - in workfolder.txt to write D:\HDC\ - in !README.txt to add more advices like: try to use only one hidden file for each option - also try to rename profile.txt to something like HDConvertToX_profile.txt because when user want to make some cleanup in hdc folder is possible to delete it. - in the future, to include HD Streams Extractor if possible Crop is working better now. Deinterlace test seems to never end D:\Temp>"C:\Program Files\HDConvertToX\applications\PgcDemux.exe" -pgc 1 -nocell t -nolog -noaud -nosub -nom2v -vob "H:\VIDEO_TS\VTS_02_0.IFO" "D:\Temp\" D:\Temp>"C:\Program Files\HDConvertToX\applications\dgindex.exe" -FO=0 -OM=0 -YR =2 -AIF=[d:\temp\vts_01_1.vob] -OF=[D:\Temp\movie] -exit -minimize DGIndex started but seems to do nothing. I can't see the file: "vts_01_1.vob" in my working folder. enjoy, Mtz Last edited by Mtz; 4th April 2009 at 14:21. |
4th April 2009, 15:55 | #249 | Link |
HDConvertToX author
update hdc
now it respect ac3 bitrate (libaften is already present in \applications folder) @Sharc my knowledge of m2ts is quite limited. please update HDC , in this update pgs extracted from m2ts CAN be remuxed on m2ts too @MTZ take point, thanks! BHH
4th April 2009, 16:10 | #251 | Link |
HDConvertToX author
please report any problem
i haven't BD to test BHH
4th April 2009, 16:26 | #252 | Link |
I got a weird problem.
HDConvertToX v.0.7.155.1333 report Input File: f:\video_ts\vts_04_1.vob Codec Video: mpeg Width: 720 Heigh: 480 Framerate: 29.970 Framecount: 196213 Duration(hh:mm:ss): 1:49:7 Aspect Ratio: 1.7778 Resized resolution: 720 / 336 Crop Left: 0 Crop Top: 40 Crop Right: 0 Crop Bottom: 40 Start Hidden Options -> Activate Hidden Option: X264 in MP4 Activate Hidden Option: AC3 Audio Activate Hidden Option: Mod16 -> End Hidden Options Start Video Configuration -> Encoding Settings: X264 in M2TS NMT Compatibility: On Encoding Preset: 7 Final Size: 18 Priority: idle Denoise Level: Super Light Set Manual Bitrate: Force DirectShowSource: Off Deinterlace: Telecine -> End Video Configuration Start Audio Configuration -> Audio Codec: AC3 Audio Audio Bitrate/Quality: 320 Audio Channels: Original MP3 Mode: abr SpeedUP: Off SlowDonw: Off Normalize: On -> End Audio Configuration Start Audio Tracks Selected -> 80: English (AC3 6ch, 0xBD 0x80) [0] -> End Audio Tracks Selected Start Subtitles Tracks Selected -> Mux Subtitle in MP4/MKV file: On Encrust Subtitle in Video file: Off -> End Subtitles Tracks Selected Start Advanced AviSynth -> Basic Filter: NONE QMF Filter: NONE MVDegrain: NONE FreeAVS String: ColorMatrix: On GreyScale: Off -> End Advanced AviSynth Start Queue -> "E:\Programs\HDConvertToX\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[f:\video_ts\vts_04_1.vob] -OF=[E:\Programs\HDConvertToX\temp\movie] -exit -minimize "E:\Programs\HDConvertToX\applications\eac3to.exe" "f:\video_ts\vts_04_1.vob" 2: "E:\Programs\HDConvertToX\temp\hdencodertoxvid-pid2.ac3" -normalize "E:\Programs\HDConvertToX\applications\PgcDemux.exe" -pgc 1 -nocellt -nolog -noaud -sub -nom2v -novob "F:\VIDEO_TS\VTS_04_0.IFO" "E:\Programs\HDConvertToX\temp" "E:\Programs\HDConvertToX\applications\x264.exe" --crf 18 --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 3 --mixed-refs --trellis 0 --ref 3 --filter -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --weightb --b-adapt 1 --no-chroma-me --8x8dct --aud --nal-hrd --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --output "E:\Programs\HDConvertToX\temp\hdconverttox_vts_04_1.h264" "E:\Programs\HDConvertToX\temp\hdconverttox_vts_04_1.avs" --level 4.0 "E:\Programs\HDConvertToX\applications\tsMuxeR.exe" "E:\Media\Movies\DVD\Comedy\School of Rockmeta" "E:\Media\Movies\DVD\Comedy\School of Rock.MP4" -> End Queue AviSynth Script -> E:\Programs\HDConvertToX\temp\hdconverttox_vts_04_1.avs #HDConvertToX Avisynth Script # #Input File = f:\video_ts\vts_04_1.vob #Original Resolution = 720x480 #Aspect Ratio = 1.7778 #Frame rate =29.970 #Number of Frames = 196213 #Lenght (hour:minutes:seconds) = 1:49:7 #Display Aspect Ratio = 2.1334 #Aspect Error = -0.4432 # #Resized resolution = 720 / 336 #Crop Left = 0 #Crop Top = 40 #Crop Right = 0 #Crop Bottom = 40 # LoadPlugin("E:\Programs\HDConvertToX\filters\AddGrainC.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\autocrop.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\ColorMatrix.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\Decomb.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\degrainmedian.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\DGAVCDecode.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\DGDecode.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\DirectShowSource.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\EEDI2.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\FFMS2.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\FFT3DFilter.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\FluxSmooth.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\frfun7.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\gradfun2db.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\hqdn3d.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\mt_masktools-25.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\mvtools.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\mvtools2.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\RemoveDirtS.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\RemoveGrainS.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\RepairS.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\SangNom.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\TBilateral.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\TDeint.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\TIVTC.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\TTempSmooth.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\UnDot.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\UnFilter.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\VSFilter.dll") Import("E:\Programs\HDConvertToX\filters\BlindDeHalo3_mt2.avsi") Import("E:\Programs\HDConvertToX\filters\Deblock_QED_MT2.avsi") Import("E:\Programs\HDConvertToX\filters\GradFun2DBmod.v1.3.avsi") Import("E:\Programs\HDConvertToX\filters\Lem.avsi") Import("E:\Programs\HDConvertToX\filters\LSFmod.v1.7.avsi") Import("E:\Programs\HDConvertToX\filters\MCTemporalDenoise.v1.2.02.avsi") Import("E:\Programs\HDConvertToX\filters\QMLF_3_motions.avsi") Import("E:\Programs\HDConvertToX\filters\QMLF_5_motions.avsi") Import("E:\Programs\HDConvertToX\filters\QMLF_7_motions.avsi") Import("E:\Programs\HDConvertToX\filters\QMLF_9_motions.avsi") Import("E:\Programs\HDConvertToX\filters\seesaw.avsi") Import("E:\Programs\HDConvertToX\filters\spresso.avsi") #Source File mpeg2source("E:\Programs\HDConvertToX\temp\movie.d2v") #Insert Deinterlacer tfm(last,d2v="E:\Programs\HDConvertToX\temp\movie.d2v").tdecimate() #Applying Resizing GaussResize(720,336,0,40,-0,-40,p=75) #Insert Filters As Requested ColorMatrix(d2v="E:\Programs\HDConvertToX\temp\movie.d2v") hqdn3d(1) -> End AviSynth Script EDIT: Figured it out. tsmuxer won't mux MP4. When I analyzed the file I had x264 in MP4 selected. I set my output file name (School of Rock.MP4), then I reset my output to x264 in m2ts, but the output save extension didn't update itself. I got the file muxed by changing the extension in the tsmuxer line above. Last edited by Crono141; 4th April 2009 at 16:34. |
4th April 2009, 16:32 | #253 | Link | |
HDConvertToX author
and hdc will respect your output file name for manually muxing launch TSmuxer GUI and use it EDIT: in next update evn if you specify a wrong extension, in muxing HDC will correct it BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 4th April 2009 at 16:38. |
4th April 2009, 18:18 | #254 | Link |
HDConvertToX v.0.7.155.1333 report Input File: e:\rippeddvd\mainmovie\school_of_rock_16x9\video_ts\vts_01_1.vob Codec Video: mpeg Width: 720 Heigh: 480 Framerate: 29.970 Framecount: 196213 Duration(hh:mm:ss): 1:49:7 Aspect Ratio: 1.7778 Resized resolution: 720 / 336 Crop Left: 0 Crop Top: 40 Crop Right: 0 Crop Bottom: 40 Start Hidden Options -> Activate Hidden Option: NMT Activate Hidden Option: X264 in MP4 Activate Hidden Option: Coding Tech. AAC Audio Activate Hidden Option: Mod16 -> End Hidden Options Start Video Configuration -> Encoding Settings: X264 in MP4 NMT Compatibility: On Encoding Preset: 7 Final Size: 18 Priority: idle Denoise Level: Super Light Set Manual Bitrate: Force DirectShowSource: Off Deinterlace: Telecine -> End Video Configuration Start Audio Configuration -> Audio Codec: Coding Tech. AAC Audio Audio Bitrate/Quality: 192 Audio Channels: Original MP3 Mode: abr SpeedUP: Off SlowDonw: Off Normalize: On -> End Audio Configuration Start Audio Tracks Selected -> 80: English (AC3 6ch, 0xBD 0x80) [0] -> End Audio Tracks Selected Start Subtitles Tracks Selected -> Mux Subtitle in MP4/MKV file: On Encrust Subtitle in Video file: Off -> End Subtitles Tracks Selected Start Advanced AviSynth -> Basic Filter: NONE QMF Filter: NONE MVDegrain: NONE FreeAVS String: ColorMatrix: On GreyScale: Off -> End Advanced AviSynth Start Queue -> "E:\Programs\HDConvertToX\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[e:\rippeddvd\mainmovie\school_of_rock_16x9\video_ts\vts_01_1.vob] -OF=[E:\Programs\HDConvertToX\temp\movie] -exit -minimize "E:\Programs\HDConvertToX\applications\eac3to.exe" "e:\rippeddvd\mainmovie\school_of_rock_16x9\video_ts\vts_01_1.vob" 2: stdout.wav -down16 -resampleto48000 -normalize | "E:\Programs\HDConvertToX\applications\enc_aacPlus.exe" - "E:\Programs\HDConvertToX\temp\hdencodertoxvid-pid2.aac" --cbr 192000 --rawpcm 48000 6 16 "E:\Programs\HDConvertToX\applications\PgcDemux.exe" -pgc 1 -nocellt -nolog -noaud -sub -nom2v -novob "E:\RippedDVD\MainMovie\SCHOOL_OF_ROCK_16X9\VIDEO_TS\VTS_01_0.IFO" "E:\Programs\HDConvertToX\temp" "E:\Programs\HDConvertToX\applications\x264.exe" --crf 18 --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 3 --mixed-refs --trellis 0 --ref 3 --filter -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --weightb --b-adapt 1 --no-chroma-me --8x8dct --aud --nal-hrd --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --output "E:\Programs\HDConvertToX\temp\hdconverttox_vts_01_1.h264" "E:\Programs\HDConvertToX\temp\hdconverttox_vts_01_1.avs" --level 4.0 "E:\Programs\HDConvertToX\applications\Chapter\ChapterXtractor.exe" "E:\RippedDVD\MainMovie\SCHOOL_OF_ROCK_16X9\VIDEO_TS\VTS_01_0.IFO" "E:\Programs\HDConvertToX\temp\chapters.txt" -p5 "E:\Programs\HDConvertToX\applications\mp4box.exe" -add "E:\Programs\HDConvertToX\temp\hdconverttox_vts_01_1.h264" -fps 23.976 -add "E:\Programs\HDConvertToX\temp\hdencodertoxvid-pid2.aac":lang=eng -chap "E:\Programs\HDConvertToX\temp\chapters.txt" "E:\Media\Movies\DVD\Comedy\School of Rock.mp4" -> End Queue AviSynth Script -> E:\Programs\HDConvertToX\temp\hdconverttox_vts_01_1.avs #HDConvertToX Avisynth Script # #Input File = e:\rippeddvd\mainmovie\school_of_rock_16x9\video_ts\vts_01_1.vob #Original Resolution = 720x480 #Aspect Ratio = 1.7778 #Frame rate =29.970 #Number of Frames = 196213 #Lenght (hour:minutes:seconds) = 1:49:7 #Display Aspect Ratio = 2.1334 #Aspect Error = -0.4432 # #Resized resolution = 720 / 336 #Crop Left = 0 #Crop Top = 40 #Crop Right = 0 #Crop Bottom = 40 # LoadPlugin("E:\Programs\HDConvertToX\filters\AddGrainC.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\autocrop.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\ColorMatrix.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\Decomb.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\degrainmedian.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\DGAVCDecode.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\DGDecode.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\DirectShowSource.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\EEDI2.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\FFMS2.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\FFT3DFilter.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\FluxSmooth.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\frfun7.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\gradfun2db.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\hqdn3d.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\mt_masktools-25.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\mvtools.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\mvtools2.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\RemoveDirtS.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\RemoveGrainS.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\RepairS.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\SangNom.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\TBilateral.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\TDeint.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\TIVTC.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\TTempSmooth.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\UnDot.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\UnFilter.dll") LoadPlugin("E:\Programs\HDConvertToX\filters\VSFilter.dll") Import("E:\Programs\HDConvertToX\filters\BlindDeHalo3_mt2.avsi") Import("E:\Programs\HDConvertToX\filters\Deblock_QED_MT2.avsi") Import("E:\Programs\HDConvertToX\filters\GradFun2DBmod.v1.3.avsi") Import("E:\Programs\HDConvertToX\filters\Lem.avsi") Import("E:\Programs\HDConvertToX\filters\LSFmod.v1.7.avsi") Import("E:\Programs\HDConvertToX\filters\MCTemporalDenoise.v1.2.02.avsi") Import("E:\Programs\HDConvertToX\filters\QMLF_3_motions.avsi") Import("E:\Programs\HDConvertToX\filters\QMLF_5_motions.avsi") Import("E:\Programs\HDConvertToX\filters\QMLF_7_motions.avsi") Import("E:\Programs\HDConvertToX\filters\QMLF_9_motions.avsi") Import("E:\Programs\HDConvertToX\filters\seesaw.avsi") Import("E:\Programs\HDConvertToX\filters\spresso.avsi") #Source File mpeg2source("E:\Programs\HDConvertToX\temp\movie.d2v") #Insert Deinterlacer tfm(last,d2v="E:\Programs\HDConvertToX\temp\movie.d2v").tdecimate() #Applying Resizing GaussResize(720,336,0,40,-0,-40,p=75) #Insert Filters As Requested ColorMatrix(d2v="E:\Programs\HDConvertToX\temp\movie.d2v") hqdn3d(1) -> End AviSynth Script x264 [error]: constant rate-factor is incompatible with 2pass. x264 [error]: x264_encoder_open failed I specified 1 pass quality crf 18 in the gui. Not sure why its trying to do 2pass encoding. |
4th April 2009, 18:41 | #255 | Link |
HDConvertToX author
please redownload HDC
the problem is with chapter extraction BHH
4th April 2009, 19:41 | #256 | Link |
I want to convert 1080p to 720p (4480 MB). I choose x264 2 pass x264BetterQuality, 1280*544, convert original AC3 640 to 320 kbps and the final result is a mkv 4833 MB instead 4480 MB. I tried two times and the final size is far away from 4480 MB .
HDConvertToX v.0.7.164.1380 report Input File: g:\mymovie1080p.mkv Codec Video: avc Width: 1920 Heigh: 816 Framerate: 23.976 Framecount: 201178 Duration(hh:mm:ss): 2:19:51 Aspect Ratio: 2.3529 Resized resolution: 1280 / 544 Crop Left: 0 Crop Top: 0 Crop Right: 0 Crop Bottom: 0 Start Hidden Options -> -> End Hidden Options Start Video Configuration -> Encoding Settings: X264 in MKV NMT Compatibility: On Encoding Preset: 6 Final Size: 4480 Priority: idle Denoise Level: None Set Manual Bitrate: Force DirectShowSource: Off Deinterlace: none -> End Video Configuration Start Audio Configuration -> Audio Codec: AC3 Audio Audio Bitrate/Quality: 320 Audio Channels: Original MP3 Mode: abr SpeedUP: Off SlowDonw: Off Normalize: Off -> End Audio Configuration Start Audio Tracks Selected -> 2: ac3, 5.1 channels, 640kbps, 48khz -> End Audio Tracks Selected Start Subtitles Tracks Selected -> Mux Subtitle in MP4/MKV file: On Encrust Subtitle in Video file: Off -> End Subtitles Tracks Selected Start Advanced AviSynth -> Basic Filter: NONE QMF Filter: NONE MVDegrain: NONE FreeAVS String: ColorMatrix: On GreyScale: Off -> End Advanced AviSynth Start Queue -> "D:\Kituri programe\Video\Matroska\HDConvertToX\applications\x264.exe" --pass 2 --bitrate 4196 --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 3 --mixed-refs --trellis 1 --ref 3 --filter -1,-1 --subme 6 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --weightb --b-adapt 1 --partitions p8x8,b8x8,i8x8 --8x8dct --aud --nal-hrd --aq-mode 1 --aq-strength 1 --psy-rd 1.0:1.0 --output "D:\Kituri programe\Video\Matroska\HDConvertToX\temp\hdconverttox_mymovie1080p.h264" "D:\Kituri programe\Video\Matroska\HDConvertToX\temp\hdconverttox_mymovie1080p.avs" --level 4.0 "D:\Kituri programe\Video\Matroska\HDConvertToX\applications\mkvmerge.exe" -o "D:\Kituri programe\Video\Matroska\HDConvertToX\hdconverttox_full_mymovie1080p.mkv" --default-duration 0:23.976fps --aspect-ratio -1:2.3529 "D:\Kituri programe\Video\Matroska\HDConvertToX\temp\hdconverttox_mymovie1080p.h264" "D:\Kituri programe\Video\Matroska\HDConvertToX\temp\hdencodertoxvid-pid2.ac3" -> End Queue AviSynth Script -> D:\Kituri programe\Video\Matroska\HDConvertToX\temp\hdconverttox_mymovie1080p.avs #HDConvertToX Avisynth Script # #Input File = g:\mymovie1080p.mkv #Original Resolution = 1920x816 #Aspect Ratio = 2.3529 #Frame rate =23.976 #Number of Frames = 201178 #Lenght (hour:minutes:seconds) = 2:19:51 #Display Aspect Ratio = 2.3529 #Aspect Error = -0.0017 # #Resized resolution = 1280 / 544 #Crop Left = 0 #Crop Top = 0 #Crop Right = 0 #Crop Bottom = 0 # LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\AddGrainC.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\autocrop.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\ColorMatrix.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\Decomb.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\degrainmedian.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\DGAVCDecode.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\DGDecode.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\DirectShowSource.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\EEDI2.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\FFMS2.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\FFT3DFilter.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\FluxSmooth.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\frfun7.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\gradfun2db.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\hqdn3d.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\mt_masktools-25.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\mvtools.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\mvtools2.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\RemoveDirtS.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\RemoveGrainS.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\RepairS.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\SangNom.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\TBilateral.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\TDeint.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\TIVTC.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\TTempSmooth.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\UnDot.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\UnFilter.dll") LoadPlugin("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\VSFilter.dll") Import("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\BlindDeHalo3_mt2.avsi") Import("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\Deblock_QED_MT2.avsi") Import("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\GradFun2DBmod.v1.3.avsi") Import("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\Lem.avsi") Import("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\LSFmod.v1.7.avsi") Import("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\MCTemporalDenoise.v1.2.02.avsi") Import("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\QMLF_3_motions.avsi") Import("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\QMLF_5_motions.avsi") Import("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\QMLF_7_motions.avsi") Import("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\QMLF_9_motions.avsi") Import("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\seesaw.avsi") Import("D:\Kituri programe\Video\Matroska\HDConvertToX\filters\spresso.avsi") #Source File AVCSource("D:\Kituri programe\Video\Matroska\HDConvertToX\temp\movie.dga") #Applying Resizing GaussResize(1280,544,0,0,-0,-0,p=60) #Insert Filters As Requested ColorMatrix(mode="Rec.709->Rec.601") -> End AviSynth Script |
4th April 2009, 19:45 | #257 | Link |
HDConvertToX author
sorry pal but bitrate computing is far from perfect
i must work on it EDIT: try latest build, i have fixed the bitrate of AC3 audio, and so bitrate video should be better computed! meantime you can use a bitrate calculator (as from megui) and use on HDC the bitrate computed BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 4th April 2009 at 19:54. |
4th April 2009, 20:01 | #258 | Link |
Life's clearer in 4K UHD
AC3 in MP4
Hi Buzz,
I've just noticed that you are using MP4Box v0.4.5.0. If you upgrade to 0.4.6.0, HDConvertToX should be able to mux AC3 audio into the .MP4 container
4th April 2009, 20:32 | #260 | Link |
HDConvertToX author
@SMD
but it will broken compatibility with NMT ? @Crono141 please post a new report BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
