Old 18th October 2011, 20:48   #13261  |  Link
Originally Posted by colinhunt View Post
A most peculiar bug with Miramax's A Quiet American. Did a Full Backup. Selecting Play Movie in Main Menu...
on Original Disc: Miramax logo is shown, followed by the movie.
on Backup: SMPTE color bars are shown for 35 seconds, followed by post-production company title screen describing the contents of the master tape. This is followed by the Miramax logo and the movie. I would have expected audio to be severely out-of-sync because of this, but no, audio sync is fine.
Movie is in file 00000.m2ts. Playing it with MPC-HC reveals that SMPTE color bars and master tape info text screen are both included in the 00000.m2ts. For some reason they are skipped on the original, but not on Full Backup.
Hmmm.... I can't seem to find a blu-ray version of "The Quiet American" for sale at any of the standard places (like Amazon)... where'd you get it? I'm thinking it may not have been released in the U.S. yet.
Old 18th October 2011, 22:34   #13262  |  Link
colinhunt
It's from Amazon.com... but I checked after reading your post, and can't find it there any longer. It's possible Miramax has recalled the disc because the authoring appears to be a bit messed up. Not only does the movie file contain the extra bits at the beginning, there are also odd extra bits after the movie. It's like the authoring shop has delivered a work-in-progress version to the factory. False alarm, in other words!
Old 18th October 2011, 22:52   #13263  |  Link
sonate
To JDobbs
Remember this
C:\Documents and Settings\Administrator>c:\accessories\BD_Reb\tools\wavi.exe "D:
\BD REB WORK FOLDER\WORKFILES\AUD_00001_4352.AVS" - | c:\accessories\BD_Reb\tool
s\aften.exe -v 1 -b 640 -readtoeof 1 - "D:\BD REB WORK FOLDER\WORKFILES\AUD_00001_4352.AC3"
Question, when the HD audio is converted into PCM by WAVI.exe, can I assume it's buffered to some degree
before it is fed into Aften.exe. If so, the memory allocation size, temporary destination and transfer rates between programs across the pipe, are those parameters set by BD reb code or determined dynamically by windows?
sonate is offline   Reply With Quote
Old 18th October 2011, 23:43   #13264  |  Link
Originally Posted by sonate View Post
Remember this
It's actually converted to PCM by AVISYNTH via NicAudio.dll. If there is buffering it would be inherent to the pipe and is likely very, very small. BD-RB doesn't set it. The output of WAVI is simply streamed to AFTEN.
You can break that up into two commands, first WAVI and then AFTEN, for example:
\BD REB WORK FOLDER\WORKFILES\AUD_00001_4352.AVS" test.wav
s\aften.exe -v 1 -b 640 test.wav "D:\BD REB WORK FOLDER\WORKFILES\AUD_00001_4352.AC3"
Old 19th October 2011, 05:38   #13265  |  Link
sonate
To J Dobbs
Thanks JD, I'm going to run the job again this time as a movie only to save a little time. Once it gets to the point where aften fails, I'll split the commands and paste the first half into the cmd prompt after making the appropriate changes in path and file name if necessary.
If I read right AUD_00001_4352.AVS" test.wav will be generated in the work folder.
edited....
OK I realized I don't need to wait for the video encode to test it since the A/V streams were extracted and AUD_00001_4352.AVS exists as a valid file in the workfiles folder and I would be essentially waiting for the audio.bat file to be created.
Inputting into the cmd window :
C:\Documents and Settings\Administrator>C:\Documents and Settings\Administrator>
c:\accessories\BD_Rebuilder\tools\wavi.exe "D:\BD REB WORK FOLDER\WORKFILES\AUD_
'C:\Documents' is not recognized as an internal or external command,
operable program or batch file.
And if I remove the "C:\Documents and Settings\Administrator>" so it isn't referenced twice in the path, this happens and results in wavi.exe being overwritten or corrupted.
C:\Documents and Settings\Administrator>c:\accessories\BD_Rebuilder\tools\wavi.e
xe "D:\BD REB WORK FOLDER\WORKFILES\AUD_00001_4352.AVS" test.wav
Access is denied.
Unless I'm completely in left field, am I wrong to think it fails before the pipe?
Old 19th October 2011, 05:52   #13266  |  Link
setarip_old
setarip_old's Avatar
@jdobbs
Looks like the Blu-ray version of "The Quiet American" was released on 9/19/11 in the UK (Amazon UK):
http://www.blu-raydefinition.com/rev...ay-review.html
Old 19th October 2011, 15:07   #13267  |  Link
colinhunt
I do buy from US, UK, DE and FR Amazons but I'm fairly certain this one didn't come from UK... although yeah, I could be wrong.
edit: Yup, my mistake, it's the UK version.
Old 20th October 2011, 00:09   #13268  |  Link
KillingTime
Im not sure if this is a bug or a feature request, so feel free to move it if necessary.
When you're backing up a rip that has some pixelation (ie data stream errors), BDRebuilder produces backups that freeze at the point of original data stream error.
I understand that you can't overcome missing data, but if the errors are at the beginning of the movie, BDRebuilder continues until the very end without reporting errors. If the end result is going to be unplayable, then it would be better to exit at the point of error, and save x hours of encoding.
A better solution would be to somehow drop the frames that are causing the problem, so the end result is still playable (albeit with some jumps), but that's a feature request if the funtionality isn't in the current design spec.
I should point out that most of my BDs are second hand and have the odd scratch or two on the data side. New discs pose no problem. I've noticed that BDs are much more prone to any kind of dirt than DVDs. I don't think it's my BD reader(s) as they all echo the same trend.
FYI. I've tried products like TSDoctor, and VideoReDo on damaged rips, but so far I've not managed to fix a single rip (these products are still in beta). The original rips will play with a bit of pixelation, and you can get to the end of the movie, so the streams aren't that far gone. Not sure what the ultimate solution is apart from just buying another BD.
KillingTime is offline   Reply With Quote
Old 20th October 2011, 04:48   #13269  |  Link
@KillingTime
I've never experienced that problem, and I've done an extremely large number of discs. Unfortunately, though, even if I wanted to address it, there's really not a lot I could do. I can't even think of a way I could intervene and even know that the error is there. The actions taken during decoding (frame serving) and encoding are really something out of BD Rebuidler's control. The frame serviing is done by AVISYNTH, FFDSHOW and HAALI, and the encoding is done by X264.
I guess the bottom line is that when you feed garbage in -- you are going to get garbage out. It's just a question of what kind of garbage.
Old 20th October 2011, 19:38   #13270  |  Link
Tongariro
Transformers 3 True HD audio Sync issue
I was trying to do full back-up to Transformers 3 With Keep HD is on. the result is that the audio is 2 out of sync from chapter 3. this is really weird becuse the movie starts O.K but after few chapter the audio start to slip up.
the Movie was ripped by anyDvd.
i also tried to keep all audio stream (not just the True HD one) with the same result.
by now i did dozens of movie with no problems. this is my first problem for a long time.
using 39.01 latest version
the True HD is very importent to me thats why i want to keep it untouched.
THANKS
Tongariro is offline   Reply With Quote
Old 20th October 2011, 22:34   #13271  |  Link
xterminater
jdobbs... I tried to do a back up of the lion king bluray but it was oversized! Here's the log info:
From The_lion_king.inf:
[Status]
LABEL=THE_LION_KING
VERSION=v0.39.01 (beta)
SOURCE_SIZE=37133036171
SOURCE_VIDEO_SIZE=36596189184
TARGET_SIZE=8422162432
REDUCTION=.215468211877304
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=eng;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=-1
QUICK=0
ENCODE_STEP=0
COMPLETED=51
REBUILD_COMPLETE=1
[00008]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=4800232
RATE=3383
NSIZE=4687872
FLINK=-1
MLINK=-1
[00009]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=34420
RATE=1023
NSTART=27000000
NEND=27009384
NSIZE=49152
FLINK=0
MLINK=0
[00011]
AUDIO=10
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=159689125
RATE=4600
NSTART=27000000
NEND=37088640
NSIZE=156524544
FLINK=0
MLINK=0
[00020]
AUDIO=1
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=50698974
RATE=3224
NSIZE=50061312
FLINK=-1
MLINK=-1
[00021]
AUDIO=1
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=42795669
RATE=3223
NSIZE=42233856
FLINK=-1
MLINK=-1
[00084]
AUDIO=101
PGS=1001000
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=5441626758
RATE=5735
NSTART=27000000
NEND=265659360
NSIZE=5335388160
FLINK=0
MLINK=0
[00087]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=139442367
RATE=3233
NSTART=27000000
NEND=38875680
NSIZE=136427520
FLINK=0
MLINK=0
[00088]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=19145326
RATE=4770
NSTART=27000000
NEND=28251360
NSIZE=19537920
FLINK=0
MLINK=0
[00089]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=98923697
RATE=4769
NSTART=27000000
NEND=33468480
NSIZE=97499136
FLINK=0
MLINK=0
[00090]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=212478437
RATE=4770
NSTART=27000000
NEND=40891680
NSIZE=209178624
FLINK=0
MLINK=0
[00091]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=137095204
RATE=4770
NSTART=27000000
NEND=35962560
NSIZE=134971392
FLINK=0
MLINK=0
[00092]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=36379032
RATE=4768
NSTART=27000000
NEND=29378880
NSIZE=36722688
FLINK=0
MLINK=0
[00093]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=20432096
RATE=4776
NSTART=27000000
NEND=28333440
NSIZE=20054016
FLINK=0
MLINK=0
[00096]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=823951987
RATE=4495
NSTART=27000000
NEND=80115840
NSIZE=807432192
FLINK=0
MLINK=0
[00097]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=10107493
RATE=4772
NSTART=27000000
NEND=27659520
NSIZE=10020864
FLINK=0
MLINK=0
[00098]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=13558735
RATE=4774
NSTART=27000000
NEND=27885600
NSIZE=13424640
FLINK=0
MLINK=0
[00099]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=25955142
RATE=4777
NSTART=27000000
NEND=28693440
NSIZE=25632768
FLINK=0
MLINK=0
[00100]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=17407129
RATE=4774
NSTART=27000000
NEND=28136160
NSIZE=17387520
FLINK=0
MLINK=0
[00101]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=9874498
RATE=4770
NSTART=27000000
NEND=27645120
NSIZE=9787392
FLINK=0
MLINK=0
[00102]
AUDIO=10
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=107985359
RATE=4624
NSTART=27000000
NEND=33791040
NSIZE=105676800
FLINK=0
MLINK=0
[00106]
AUDIO=10
PGS=10
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=40684149
RATE=3484
NSTART=27000000
NEND=30425760
NSIZE=39462912
FLINK=0
MLINK=0
[00112]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=2648
NSTART=27000000
NEND=27001440
NSIZE=12288
FLINK=0
MLINK=0
[00117]
AUDIO=1
PGS=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1598266717
RATE=4502
NSTART=27000000
NEND=129890880
NSIZE=1561651200
FLINK=0
MLINK=0
[00118]
AUDIO=10
PGS=01
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=39732311
RATE=3565
NSTART=27000000
NEND=30280320
NSIZE=39075840
FLINK=0
MLINK=0
[00119]
AUDIO=10
PGS=10
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=48431242
RATE=3489
NSTART=27000000
NEND=31073760
NSIZE=47204352
FLINK=0
MLINK=0
[00120]
AUDIO=01
PGS=10
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=48418003
RATE=3463
NSTART=27000000
NEND=31099680
NSIZE=47382528
FLINK=0
MLINK=0
[00121]
AUDIO=1
PGS=1
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=29164122
RATE=3382
NSTART=27000000
NEND=29520000
NSIZE=28188672
FLINK=0
MLINK=0
[00122]
AUDIO=1
PGS=1
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=27345171
RATE=3385
NSTART=27000000
NEND=29361600
NSIZE=26984448
FLINK=0
MLINK=0
xterminater is offline   Reply With Quote
Old 20th October 2011, 22:35   #13272  |  Link
xterminater
Here's the bdrb log:
[22:06:05] BD Rebuilder v0.39.01 (beta)
  - Source:  THE_LION_KING
  - Input BD size: 34.58 GB
  - Approximate total content: [03:20:11.398]
  - Target BD size: 7.84 GB
  - Windows Version: 6.1 [7601]
  - MOVIE and MENUS mode enabled
  - Auto Quality: High Quality (Default), Two Pass
- Resuming from previously started job.
[22:06:10] PHASE ONE, Encoding
 - [22:06:10] Blanking: VID_00022 (17 of 52)
 - [22:06:10] Blanking: VID_00072 (18 of 52)
 - [22:06:10] Blanking: VID_00073 (19 of 52)
 - [22:06:10] Blanking: VID_00075 (20 of 52)
 - [22:06:10] Blanking: VID_00076 (21 of 52)
 - [22:06:10] Blanking: VID_00078 (22 of 52)
 - [22:06:10] Blanking: VID_00079 (23 of 52)
 - [22:06:11] Blanking: VID_00081 (24 of 52)
 - [22:06:11] Processing: VID_00084 (25 of 52)
 - [22:06:11] Reencoding video [VID_00084]
   - Rate/Length: 23.976fps, 127,158 frames
   - Bitrate: 5,735 Kbs
 - [22:06:11] Reencoding: VID_00084, Pass 2 of 2
 - [04:00:56] Video Encode complete
 - [04:00:57] Reencoding audio tracks (if req'd)
 - [04:00:57] Multiplexing M2TS
 - [04:06:10] Processing: VID_00087 (26 of 52)
 - [04:06:10] Extracting A/V streams [VID_00087]
 - [04:06:40] Reencoding video [VID_00087]
   - Rate/Length: 23.976fps, 6,328 frames
   - Bitrate: 3,233 Kbs
 - [04:06:40] Reencoding: VID_00087, Pass 1 of 2
 - [04:11:53] Reencoding: VID_00087, Pass 2 of 2
 - [04:23:17] Video Encode complete
 - [04:23:17] Reencoding audio tracks (if req'd)
 - [04:23:18] Multiplexing M2TS
 - [04:23:29] Processing: VID_00088 (27 of 52)
 - [04:23:29] Extracting A/V streams [VID_00088]
 - [04:23:33] Reencoding video [VID_00088]
   - Rate/Length: 23.976fps, 667 frames
   - Bitrate: 4,770 Kbs
 - [04:23:33] Reencoding: VID_00088, Pass 1 of 2
 - [04:24:09] Reencoding: VID_00088, Pass 2 of 2
 - [04:25:50] Video Encode complete
 - [04:25:50] Reencoding audio tracks (if req'd)
 - [04:25:50] Multiplexing M2TS
 - [04:25:52] Processing: VID_00089 (28 of 52)
 - [04:25:52] Extracting A/V streams [VID_00089]
 - [04:26:06] Reencoding video [VID_00089]
   - Rate/Length: 23.976fps, 3,447 frames
   - Bitrate: 4,769 Kbs
 - [04:26:06] Reencoding: VID_00089, Pass 1 of 2
 - [04:30:10] Reencoding: VID_00089, Pass 2 of 2
 - [04:40:01] Video Encode complete
 - [04:40:01] Reencoding audio tracks (if req'd)
 - [04:40:01] Multiplexing M2TS
 - [04:40:04] Processing: VID_00090 (29 of 52)
 - [04:40:04] Extracting A/V streams [VID_00090]
 - [04:40:33] Reencoding video [VID_00090]
   - Rate/Length: 23.976fps, 7,402 frames
 - [04:40:34] Reencoding: VID_00090, Pass 1 of 2
 - [04:48:42] Reencoding: VID_00090, Pass 2 of 2
 - [05:10:56] Video Encode complete
 - [05:10:56] Reencoding audio tracks (if req'd)
 - [05:10:56] Multiplexing M2TS
 - [05:11:02] Processing: VID_00091 (30 of 52)
 - [05:11:02] Extracting A/V streams [VID_00091]
 - [05:11:30] Reencoding video [VID_00091]
   - Rate/Length: 23.976fps, 4,776 frames
 - [05:11:31] Reencoding: VID_00091, Pass 1 of 2
 - [05:16:27] Reencoding: VID_00091, Pass 2 of 2
 - [05:30:38] Video Encode complete
 - [05:30:38] Reencoding audio tracks (if req'd)
 - [05:30:38] Multiplexing M2TS
 - [05:30:42] Processing: VID_00092 (31 of 52)
 - [05:30:42] Extracting A/V streams [VID_00092]
 - [05:30:48] Reencoding video [VID_00092]
   - Rate/Length: 23.976fps, 1,268 frames
   - Bitrate: 4,768 Kbs
 - [05:30:48] Reencoding: VID_00092, Pass 1 of 2
 - [05:31:58] Reencoding: VID_00092, Pass 2 of 2
 - [05:35:09] Video Encode complete
 - [05:35:09] Reencoding audio tracks (if req'd)
 - [05:35:09] Multiplexing M2TS
 - [05:35:11] Processing: VID_00093 (32 of 52)
 - [05:35:11] Extracting A/V streams [VID_00093]
 - [05:35:15] Reencoding video [VID_00093]
   - Rate/Length: 23.976fps, 711 frames
   - Bitrate: 4,776 Kbs
 - [05:35:15] Reencoding: VID_00093, Pass 1 of 2
 - [05:35:58] Reencoding: VID_00093, Pass 2 of 2
 - [05:37:43] Video Encode complete
 - [05:37:43] Reencoding audio tracks (if req'd)
 - [05:37:43] Multiplexing M2TS
 - [05:37:44] Processing: VID_00096 (33 of 52)
 - [05:37:44] Extracting A/V streams [VID_00096]
 - [05:39:38] Reencoding video [VID_00096]
   - Rate/Length: 29.970fps, 35,376 frames
   - Bitrate: 4,495 Kbs
 - [05:39:38] Reencoding: VID_00096, Pass 1 of 2
 - [06:15:55] Reencoding: VID_00096, Pass 2 of 2
 - [08:04:59] Video Encode complete
 - [08:04:59] Reencoding audio tracks (if req'd)
 - [08:04:59] Multiplexing M2TS
 - [08:05:31] Processing: VID_00097 (34 of 52)
 - [08:05:31] Extracting A/V streams [VID_00097]
 - [08:05:33] Reencoding video [VID_00097]
   - Rate/Length: 23.976fps, 352 frames
   - Bitrate: 4,772 Kbs
 - [08:05:34] Reencoding: VID_00097, Pass 1 of 2
 - [08:05:55] Reencoding: VID_00097, Pass 2 of 2
 - [08:06:43] Video Encode complete
 - [08:06:43] Reencoding audio tracks (if req'd)
 - [08:06:43] Multiplexing M2TS
 - [08:06:44] Processing: VID_00098 (35 of 52)
 - [08:06:44] Extracting A/V streams [VID_00098]
 - [08:06:47] Reencoding video [VID_00098]
   - Rate/Length: 23.976fps, 472 frames
   - Bitrate: 4,774 Kbs
 - [08:06:47] Reencoding: VID_00098, Pass 1 of 2
 - [08:07:15] Reencoding: VID_00098, Pass 2 of 2
 - [08:08:22] Video Encode complete
 - [08:08:22] Reencoding audio tracks (if req'd)
 - [08:08:22] Multiplexing M2TS
 - [08:08:23] Processing: VID_00099 (36 of 52)
 - [08:08:23] Extracting A/V streams [VID_00099]
 - [08:08:28] Reencoding video [VID_00099]
   - Rate/Length: 23.976fps, 903 frames
   - Bitrate: 4,777 Kbs
 - [08:08:28] Reencoding: VID_00099, Pass 1 of 2
 - [08:09:25] Reencoding: VID_00099, Pass 2 of 2
 - [08:11:42] Video Encode complete
 - [08:11:42] Reencoding audio tracks (if req'd)
 - [08:11:42] Multiplexing M2TS
 - [08:11:44] Processing: VID_00100 (37 of 52)
 - [08:11:44] Extracting A/V streams [VID_00100]
 - [08:11:48] Reencoding video [VID_00100]
   - Rate/Length: 23.976fps, 606 frames
 - [08:11:48] Reencoding: VID_00100, Pass 1 of 2
 - [08:12:25] Reencoding: VID_00100, Pass 2 of 2
 - [08:13:54] Video Encode complete
 - [08:13:54] Reencoding audio tracks (if req'd)
 - [08:13:54] Multiplexing M2TS
 - [08:13:55] Processing: VID_00101 (38 of 52)
 - [08:13:55] Extracting A/V streams [VID_00101]
 - [08:13:57] Reencoding video [VID_00101]
   - Rate/Length: 23.976fps, 344 frames
 - [08:13:57] Reencoding: VID_00101, Pass 1 of 2
 - [08:14:17] Reencoding: VID_00101, Pass 2 of 2
 - [08:15:06] Video Encode complete
 - [08:15:06] Reencoding audio tracks (if req'd)
 - [08:15:06] Multiplexing M2TS
 - [08:15:07] Processing: VID_00102 (39 of 52)
 - [08:15:07] Extracting A/V streams [VID_00102]
 - [08:15:23] Reencoding video [VID_00102]
   - Rate/Length: 23.976fps, 3,619 frames
   - Bitrate: 4,624 Kbs
 - [08:15:23] Reencoding: VID_00102, Pass 1 of 2
 - [08:18:20] Reencoding: VID_00102, Pass 2 of 2
 - [08:25:33] Video Encode complete
 - [08:25:33] Reencoding audio tracks (if req'd)
 - [08:25:33] Multiplexing M2TS
 - [08:25:36] Processing: VID_00106 (40 of 52)
 - [08:25:36] Extracting A/V streams [VID_00106]
 - [08:25:43] Reencoding video [VID_00106]
   - Rate/Length: 23.976fps, 1,826 frames
   - Bitrate: 3,484 Kbs
 - [08:25:43] Reencoding: VID_00106, Pass 1 of 2
 - [08:27:08] Reencoding: VID_00106, Pass 2 of 2
 - [08:31:09] Video Encode complete
 - [08:31:09] Reencoding audio tracks (if req'd)
 - [08:31:09] Multiplexing M2TS
 - [08:31:11] Blanking: VID_00107 (41 of 52)
 - [08:31:11] Processing: VID_00112 (42 of 52)
 - [08:31:11] Extracting A/V streams [VID_00112]
 - [08:31:12] Reencoding video [VID_00112]
   - Rate/Length: 23.976fps, 1 frames
 - [08:31:12] Reencoding: VID_00112, Pass 1 of 1
 - [08:31:12] Video Encode complete
 - [08:31:12] Reencoding audio tracks (if req'd)
 - [08:31:12] Multiplexing M2TS
 - [08:31:13] Blanking: VID_00113 (43 of 52)
 - [08:31:13] Blanking: VID_00114 (44 of 52)
 - [08:31:13] Blanking: VID_00115 (45 of 52)
 - [08:31:13] Processing: VID_00117 (46 of 52)
 - [08:31:13] Extracting A/V streams [VID_00117]
 - [08:34:50] Reencoding video [VID_00117]
   - Rate/Length: 29.970fps, 68,526 frames
   - Bitrate: 4,502 Kbs
 - [08:34:50] Reencoding: VID_00117, Pass 1 of 2
 - [09:40:50] Reencoding: VID_00117, Pass 2 of 2
 - [12:39:02] Video Encode complete
 - [12:39:02] Reencoding audio tracks (if req'd)
 - [12:39:02] Multiplexing M2TS
 - [12:40:15] Processing: VID_00118 (47 of 52)
 - [12:40:15] Extracting A/V streams [VID_00118]
 - [12:40:31] Reencoding video [VID_00118]
   - Rate/Length: 23.976fps, 1,748 frames
   - Bitrate: 3,565 Kbs
 - [12:40:32] Reencoding: VID_00118, Pass 1 of 2
 - [12:42:15] Reencoding: VID_00118, Pass 2 of 2
 - [12:46:07] Video Encode complete
 - [12:46:07] Reencoding audio tracks (if req'd)
 - [12:46:07] Multiplexing M2TS
 - [12:46:08] Processing: VID_00119 (48 of 52)
 - [12:46:08] Extracting A/V streams [VID_00119]
 - [12:46:16] Reencoding video [VID_00119]
   - Rate/Length: 23.976fps, 2,171 frames
   - Bitrate: 3,489 Kbs
 - [12:46:16] Reencoding: VID_00119, Pass 1 of 2
 - [12:47:58] Reencoding: VID_00119, Pass 2 of 2
 - [12:51:57] Video Encode complete
 - [12:51:57] Reencoding audio tracks (if req'd)
 - [12:51:57] Multiplexing M2TS
 - [12:51:59] Processing: VID_00120 (49 of 52)
 - [12:51:59] Extracting A/V streams [VID_00120]
 - [12:52:07] Reencoding video [VID_00120]
   - Rate/Length: 23.976fps, 2,185 frames
   - Bitrate: 3,463 Kbs
 - [12:52:07] Reencoding: VID_00120, Pass 1 of 2
 - [12:53:53] Reencoding: VID_00120, Pass 2 of 2
 - [12:57:54] Video Encode complete
 - [12:57:54] Reencoding audio tracks (if req'd)
 - [12:57:54] Multiplexing M2TS
 - [12:57:56] Processing: VID_00121 (50 of 52)
 - [12:57:56] Extracting A/V streams [VID_00121]
 - [12:58:01] Reencoding video [VID_00121]
   - Rate/Length: 23.976fps, 1,343 frames
   - Bitrate: 3,382 Kbs
 - [12:58:01] Reencoding: VID_00121, Pass 1 of 2
 - [12:59:18] Reencoding: VID_00121, Pass 2 of 2
 - [13:02:07] Video Encode complete
 - [13:02:07] Reencoding audio tracks (if req'd)
 - [13:02:07] Multiplexing M2TS
 - [13:02:09] Processing: VID_00122 (51 of 52)
 - [13:02:09] Extracting A/V streams [VID_00122]
 - [13:02:13] Reencoding video [VID_00122]
   - Rate/Length: 23.976fps, 1,259 frames
   - Bitrate: 3,385 Kbs
 - [13:02:13] Reencoding: VID_00122, Pass 1 of 2
 - [13:03:16] Reencoding: VID_00122, Pass 2 of 2
 - [13:05:43] Video Encode complete
 - [13:05:43] Reencoding audio tracks (if req'd)
 - [13:05:43] Multiplexing M2TS
 - [13:05:44] Blanking: VID_00123 (52 of 52)
[13:05:44]PHASE ONE complete
[13:05:44]PHASE TWO - Rebuild Started
 - [13:05:44] Rebuilding BD file Structure
[13:06:58] - Encode and Rebuild complete
 - WORKFILES folder removed.
[13:06:59]JOB: THE_LION_KING finished.
It came out to 8.89GB ... All my other back up were fine beside this one, and other one was oversized too! But we'll take care of this one first!
Old 21st October 2011, 01:10   #13273  |  Link
THANKS
I have that movie and I'll do some testing. But I'm pretty sure I've backed it up without any issues. What are you using to play it back?
Old 21st October 2011, 17:54   #13274  |  Link
Tongariro
I tried with my pc (Cyber) , with Panasonic bd-85 and with samsung c6900 all with the same result (yes i have 4 BD player in my house).
Old 21st October 2011, 18:42   #13275  |  Link
Capsbackup
I did a full backup to BD-25 of Transformers 3, kept the HD audio, and the audio was perfectly in sync. This was region 1 for me.
Was there pre-processing? Was the blanking option used?
Old 21st October 2011, 19:22   #13276  |  Link
I just finished testing it as well. It came out perfect on my Sony BD-S360 and two Samsung Players.
Old 21st October 2011, 22:32   #13277  |  Link
@aquanash
Finally got around to ordering "Hobo with a Shotgun" so I can test out the sync issue you reported. I should be getting it in the next couple of days. I'll let you what I find.
This is definitely a weird one. I'm not having the exact same problem as you (sync issues) -- but definitely a problem. I can't get either DirectshowSources() or NicAudio to recognize the demuxed audio stream.
Old 21st October 2011, 23:20   #13278  |  Link
JJB
I did Hobo to BD25,BD5 and DVD5 and had no sync issues with any. WinXP with LAVF always selected.
JJB is offline   Reply With Quote
Old 22nd October 2011, 01:42   #13279  |  Link
Ch3vr0n
I just finished a full BD-25 in blank mode of transformers 3 myself. Skipped ahead to see for any sync issues. 90min in, audio still perfectly in sync
Old 22nd October 2011, 03:35   #13280  |  Link
had-z
THANKS
I do the full backup of TF3 perfectly, the only difference with my backup is i do it without the HD Audio (Core only, i never preserve the HD audio), seems like you have an issue with the tools required for bdrebuilder, the first backup i do with bdrebuilder was TF2 and i find the same issue that you describe (sync issue with the second audio track, in that backup i preserved the HD audio, because that was my first backup and i created only for test purposes, another issue with that backup was a pixelation i some scene changes, like 5 times during the movie), all that problems were solved with a fresh install of the tools and unistalling codec packs.
Cheers!
had-z is offline   Reply With Quote
