Old 25th October 2011, 01:54   #13341  |  Link
setarip_old
setarip_old's Avatar
@jdobbs, @drmih
I may be mistaken, but I don't believe Universal uses DTS Express for its "UControl/PIP" activity...
Old 25th October 2011, 02:19   #13342  |  Link
Originally Posted by SquallMX View Post
Tested Ridley Scott's Robin Hood Latin America Blu-ray (PiP and Multiangle):
  • TotalMedia Theater 5 plays everything OK
  • PowerDVD 11 don't play the PiP Audio
  • PlayStation 3 plays PiP audio and video but with occasional hiccups, and skips the first 2-3 seconds of each M2TS with PiP causing temporal freezing even during normal viewing
  • Media Player Classic Home Cinema can not render the M2TS files
  • BDInfo reports the M2TS files with PiP as corrupted or encrypted
Even in this alpha stage is more compatible than DVDFab solution .
Hmm... BDINFO says the M2TS is corrupt, eh? That might be a place to look. Does it say how it is corrupted?
Old 25th October 2011, 02:21   #13343  |  Link
@jdobbs, @drmih
It does on at least some... I've been testing using Universal's "Scorpion King" with DTS-Express and U-Control.
Old 25th October 2011, 02:38   #13344  |  Link
setarip_old
@jdobbs
Silly me - maybe my grandkids are right about this "age thing".
As you know, I recently tested "American Graffiti" for DTS Express performance ;>}
Old 25th October 2011, 03:19   #13345  |  Link
Hmmm... I just ran BDINFO on a couple of discs I'm testing and it's not finding anything corrupted.
Are you sure your source isn't corrupted or encrypted before running?
Old 25th October 2011, 03:22   #13346  |  Link
Capsbackup
Tried another test of Wanted, which is also a Universal title with U-Control and DTS-Express, but this time I kept all audio files. Same result as first test on my S360, no audio is heard.
It does play the secondary audio correctly with TMT3, but no secondary audio is heard with PowerDVD9.
Old 25th October 2011, 03:44   #13347  |  Link
SquallMX
Special SeeD
Nope, here the scan of my original disc:
http://home.squallmx.operaunite.com/...N_HOOD_G52.txt
Here the one created by rebuilder:
http://home.squallmx.operaunite.com/...%20(BD-25).txt
I can upload M2TS files if that is helpful.
SquallMX is offline   Reply With Quote
Old 25th October 2011, 04:07   #13348  |  Link
That log doesn't even indicate that the DTS-Express has been reintegrated. What version of Robin Hood is this? Kevin Costner, Animated, Errol Flynn, Russell Crowe?
Old 25th October 2011, 04:18   #13349  |  Link
SquallMX
Special SeeD
Is the 2010 version with Russell Crowe.
DTS Express is indicated on the log of the Rebuilder BD-25:
DISC INFO:
Disc Title:     ROBIN_HOOD_G52
Disc Size:      24,443,466,966 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 2:35:48 (h:m:s)
Total Bitrate:          0.00 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec                   Bitrate             Description
MPEG-4 AVC Video        0 kbps              1080p / 23.976 fps / 16:9
* MPEG-4 AVC Video      0 kbps              480p / 23.976 fps / 16:9
AUDIO:
Codec                           Language        Bitrate         Description
DTS Audio                       English         0 kbps          5.1 / 48 kHz
DTS Audio                       Portuguese      0 kbps          5.1 / 48 kHz
DTS Audio                       Spanish         0 kbps          5.1 / 48 kHz
* DTS Express                   English         0 kbps          2.0 / 48 kHz
SUBTITLES:
Presentation Graphics           English         0.000 kbps
Presentation Graphics           Portuguese      0.000 kbps
Presentation Graphics           Czech           0.000 kbps
Presentation Graphics           Hungarian       0.000 kbps
Presentation Graphics           Spanish         0.000 kbps
Presentation Graphics           Polish          0.000 kbps
Presentation Graphics           Thai            0.000 kbps
Presentation Graphics           Turkish         0.000 kbps
Presentation Graphics           Croatian        0.000 kbps
Presentation Graphics           Greek           0.000 kbps
Presentation Graphics           Romanian        0.000 kbps
Presentation Graphics           Slovenian       0.000 kbps
* Presentation Graphics         English         0.000 kbps
* Presentation Graphics         Portuguese      0.000 kbps
* Presentation Graphics         Spanish         0.000 kbps
* Presentation Graphics         Polish          0.000 kbps
* Presentation Graphics         Russian         0.000 kbps
* Presentation Graphics         Greek           0.000 kbps
Here the Rebuilder INF and LOG:
http://admin.home.squallmx.operaunit...-REBUILDER.LOG
http://admin.home.squallmx.operaunit...N_HOOD_G52.INF
I will try again on other machine.
Old 25th October 2011, 05:37   #13350  |  Link
Yes... it appears to be in the MPLS but not in the stream. It looks like something went wrong in that one. I'll give it a go.
Old 25th October 2011, 08:15   #13351  |  Link
SquallMX
Special SeeD
Interesting... if I keep all the audio tracks the resulting M2TS plays fine on MPC-HC and is detected properly on BDInfo.
http://home.squallmx.operaunite.com/...nt/50138A.m2ts (use download manager)
But if I only keep some tracks (English, Portuguese and Spanish) the resulting file is detected as corrupted on BDInfo and dont play on MPC-HC:
http://home.squallmx.operaunite.com/...ent/50138.m2ts (use download manager)
Old 25th October 2011, 12:07   #13352  |  Link
colinhunt
Hopefully someone else out there will try it on a PS3 so we can judge better whether it is the BD-RE that is the issue or something in the muxing.
Ran a Full Backup of Stand By Me last night, using Highest (Very Slow) quality setting; all other settings were the same. Burned it on a BD-R and played it on a PS3 Slim. Playback was interrupted by a "This Disc is invalid" error message exactly like it was on the BD-RE disc after approx. 1 minute of flawless playback.
Old 25th October 2011, 19:03   #13353  |  Link
colinhunt
Did a Full Backup of Animal House (EU, Universal); Very Fast, 1-pass CRF to BD25. Same thing happened as with Risky Business: PiP video is riddled with artefacts. Like Risky Business, Animal House original is VC-1 for both main feature and Secondary video. Something else I just noticed while playing Animal House: with U-Control activated but no PiP on screen, I could not rewind the movie. Pressing the rewind button on the remote simply paused the image for a second before movie resumed normally. Hammering the rewind button several times confused the player which suddenly skipped all the way to the end of the disc.
Old 25th October 2011, 21:17   #13354  |  Link
setarip_old
@colinhunt
1) With a burned disc copy or a hard drive copy?
2) What player?
Old 25th October 2011, 21:45   #13355  |  Link
colinhunt
Both. Tested first on PowerDVD11 over LAN, then burned on a BD-RE.
2) What player?
Philips 9500, Philips 3000 and LG BX580. Rewinding actually works on the LG but main video shows same kind of picture break-up artefacts as the secondary video. If there was main video glitching on the other two stand-alones, I didn't notice it.
edit: Played the BD-RE on a Sony S550 a moment ago. Glitches in both main and secondary video, and PiP audio is not playing even when HDMI audio output is set for Mix instead of Direct.
Old 25th October 2011, 22:43   #13356  |  Link
drmih
It is slightly concerning about the glitches as I noted this on The Mummy but was concentrating on the PiP functionality.
Old 25th October 2011, 23:57   #13357  |  Link
color43
I used the new DTS Express switch to backup Star Trek The Original Series season 1 disc 1. The disc uses seamless branching and has a PIP for commentary. The PIP commentary with DTS-E audio plays fine on my Sony BDP-S370 player.
There are two minor issues though
1. The discs use two angles to show the updated special effects and the original footage. If I have the PIP commentary ON and change the angle, it causes my player to either freeze up or skip to another scene. This doesn't happen on the original in the exact same spot.
2. I burned a BD-R using ImgBurn and it reported some messages about the M2TS files I haven't seen before:
These are really minor though, I can finally backup my Star Trek Blu-rays with the PIP audio commentary intact, thanks JDOBBS.
I 10:18:25 Write Speed Successfully Set! - Effective: 17,980 KB/s (4x)
I 10:18:25 Advanced Settings - Force HT: No, Online HT: No, OverSpeed: No, SmartBurn: Yes
I 10:18:51 Filling Buffer... (40 MB)
I 10:18:52 Writing LeadIn...
I 10:18:53 Writing Session 1 of 1... (1 Track, LBA: 0 - 12080927)
I 10:18:53 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 12080927)
I 10:19:21 M2TS File: \BDMV\STREAM\00003.m2ts
I 10:19:21 Reset CPI flag in 149 packets (00: 479597, 01: 149, 10: 0, 11: 0, Total: 479746, Bad Sync: 0)
I 10:20:02 M2TS File: \BDMV\STREAM\00008.m2ts
I 10:20:02 Reset CPI flag in 1077 packets (00: 1236797, 01: 1077, 10: 0, 11: 0, Total: 1237874, Bad Sync: 0)
I 10:20:12 M2TS File: \BDMV\STREAM\00009.m2ts
I 10:20:12 Reset CPI flag in 323 packets (00: 978331, 01: 323, 10: 0, 11: 0, Total: 978654, Bad Sync: 0)
I 10:21:50 M2TS File: \BDMV\STREAM\00014.m2ts
I 10:21:50 Reset CPI flag in 7882 packets (00: 5397008, 01: 7882, 10: 0, 11: 0, Total: 5404890, Bad Sync: 0)
I 10:23:09 M2TS File: \BDMV\STREAM\00021.m2ts
I 10:23:09 Reset CPI flag in 169 packets (00: 635205, 01: 169, 10: 0, 11: 0, Total: 635374, Bad Sync: 0)
I 10:24:14 M2TS File: \BDMV\STREAM\00023.m2ts
I 10:24:14 Reset CPI flag in 4369 packets (00: 4456654, 01: 4369, 10: 0, 11: 0, Total: 4461023, Bad Sync: 0)
I 10:41:50 Synchronising Cache...
I 10:41:53 Closing Track...
I 10:41:54 Finalising Disc...
color43 is offline   Reply With Quote
Old 26th October 2011, 00:49   #13358  |  Link
drmih
I've just tried the following to bd-re (I always use the Highest Quality setting for encoding):
Terminator 2 - Ultimate Edition -> Problematic blocking on main movie. Only Panasonic handles PiP with audio. Samsung and Sony just show image with no audio.
Harry Potter 7-1 -> PiP only worked correctly on Panasonic. On Samsung there was strange popping on audio before PiP occurred. When the PiP happened, the audio was garbled and PiP was in wrong position (top left rather than bottom right). On Sony it was the usual case of PiP with no audio.
Old 26th October 2011, 09:03   #13359  |  Link
colinhunt
So far the glitching has been limited to discs that use VC-1 for both main and secondary video... right?
Old 26th October 2011, 10:40   #13360  |  Link
colinhunt
Did a quick Full Backup of Battle: Los Angeles (CEE) using 1-pass CRF and "Faster" preset. Playing the BD-RE on a Philips 9500 right now; PiP video and audio are fine. The player has some problems reading a BD-RE (my 9500 won't play most BD-R discs...) which is causing some pauses in the movie. I'll verify on another player later today the pauses are not in the encode.
