Old 16th August 2012, 14:47   #15481  |  Link
Originally Posted by sfcav View Post
I've seen several comments in various posts on PredictAndEncode errors, but not the one I'm getting.
I have a captured mpg file that plays fine and is clean by TSDoctor, but when I try to shrink it with BD-RB I get the above error as soon as Reencoding starts. I've tested two RB versions (0.39.01 and 0.39.02) and get the same error. I've successfully used BD-RB with similar files in the past so why it's happening now is a mystery (at least to me).
Thoughts?
Here's the log file:
[14:34:29] BD Rebuilder v0.39.02 (beta)
- Source: AVCHD
- Input BD size: 4.16 GB
- Approximate total content: [00:42:26.725]
- Target BD size: 1.17 GB
- Windows Version: 5.1 [2600]
- Quality: High Quality (Default), Two Pass
- Audio Settings: AC3=0 DTS=1 HD=1 Kbs=640
[14:34:30] PHASE ONE, Encoding
- [14:34:30] Processing: VID_00000 (1 of 1)
- [14:34:30] Extracting A/V streams [VID_00000]
- Extracting video streams [VID_00000]
- Extracting audio streams [VID_00000]
- [14:38:10] Reencoding video [VID_00000]
- [14:38:10] PredictAndEncode() 00006 2803
[14:52:27] - Aborted by user request
It's been a few months since this was posted, but I ran into this error recently while testing and thought I'd post an answer.
You get this error when the source stream was encoded at a framerate that is not allowed in Blu-ray. Acceptable framerates are: 23.976, 24, 25, 29.97, 50, 59.94 -- even then some are only compliant with certain frame sizes.
This is one more example of why I don't accept bug reports on preprocessed sources -- but I'll change the code so the source will be rejected rather than failure at this point.
Old 17th August 2012, 07:40   #15482  |  Link
hifreak
I tried to encode Jaws first I used Dvdfab to remove protection and then in BD Rebuilder to encode. The movie is DTS HD 7.1, but when it is finished in BD Rebuilder it is DTS HD 5.1. Have I done something wrong in my settings?
Settings:
MODE=2
ENCODE_QUALITY=2
AUTO_QUALITY=0
TARGET_SIZE=23500
VERSION=0.41.0.1
AUTO_BURN=2
ONEPASS_ENCODING=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=1
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=1
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
DGDECNV=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23500
Rebuild:
[08-15-12] BD Rebuilder v0.41.01 (beta)
[07:20:38] Source: JAWS PLAYLIST_00000
- Input BD size: 29,77 GB
- Approximate total content: [02:03:54.635]
- Target BD size: 22,95 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- Resuming from previously started job.
[07:20:40] PHASE ONE, Encoding
- [07:20:40] Processing: VID_50309 (1 of 1)
- [07:20:40] Reencoding video [VID_50309]
- Rate/Length: 23,976fps, 178.253 frames
- Bitrate: 22.933 Kbs
- [07:20:40] Reencoding: VID_50309, Pass 2 of 2
- [13:51:36] Video Encode complete
- [13:51:36] Processing audio tracks
[13:51:36]PHASE ONE complete
[13:51:36]PHASE TWO - Rebuild Started
- [13:51:36] Rebuilding BD file Structure
[14:10:46] - Encode and Rebuild complete
[14:10:46] Writing BD structure to ISO file
- ImgBurn completed successfully
[14:29:20] JOB: JAWS finished.
hifreak is offline   Reply With Quote
Old 17th August 2012, 09:11   #15483  |  Link
aneurysm
Settings:
MODE=2
ENCODE_QUALITY=2
AUTO_QUALITY=0
TARGET_SIZE=23500
VERSION=0.41.0.1
AUTO_BURN=2
ONEPASS_ENCODING=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=1
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=1
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
DGDECNV=0
AUDIO_TRACK_LIMIT=1
Rebuild:
Then you need to select "KEEP HD AUDIO for BD25" in the settings
aneurysm is offline   Reply With Quote
Old 17th August 2012, 09:39   #15484  |  Link
hifreak
OK Thanks never was a problem before maybe I unchecked it sometimes I will try that what you say
Old 17th August 2012, 13:27   #15485  |  Link
Nothing has changed in that area in a long time... the audio should be simply extracted and remuxed. You could take a look at the .META files for the demuxing. If they don't say "down-to-dts" in the demux description for the audio track, they are being kept completely intact.
Old 18th August 2012, 04:46   #15486  |  Link
ihmcjacky
Originally Posted by ihmcjacky View Post
For the latest version of bd-rebuilder, I still facing the following 2 problems
1) - [21:44:16] CopyDirStructure() 00052 1200
- [21:44:18] CopyDirStructure() 00052 1200
when the file encoding and rebuilding is nearly finished, (I am sure the original file works fine)
2) [BD Rebuilder an error 2501][Selected source is not BD format] appears if the language and region is not set to English
Thanks for the attention
Any feedback on this?
ihmcjacky is offline   Reply With Quote
Old 18th August 2012, 08:06   #15487  |  Link
Adbear
I'm assuming it's being ignored until you post up a full logfile as asked when you posted the first time
Adbear is offline   Reply With Quote
Old 19th August 2012, 10:25   #15488  |  Link
lauguru
Hello
I've noticed a bug when converting mpeg2 files in some trailers sony discs, the mpeg2 file remains after the rebuild BD25, not become h264.
my confg:
[Options]
VERSION=0.41.0.1
MODE=0
MULTIPROCESS=4
ENCODE_QUALITY=3
ONEPASS_ENCODING=0
AUTO_QUALITY=0
TARGET_SIZE=24995
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=1
RESIZE_1080=0
DEINTERLACE=1
SD_TO_1080=1
CONVERT_WIDE=1
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=1
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
DGDECNV=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=24995
PRIORITY_CLASS=1
QUICK_EXTRAS=0
AUTO_BURN=0
lauguru is offline   Reply With Quote
Old 19th August 2012, 13:20   #15489  |  Link
Adbear
I would assume that's because those trailers don't get processed and therefore just get passed straight through with no re-encoding
Old 19th August 2012, 14:01   #15490  |  Link
lauguru
but should re-encode mpeg2 video, no? well maybe not recognize the file structures.
Old 19th August 2012, 15:03   #15491  |  Link
BD Rebuilder tries to save time by ignoring smaller files that will have little or no impact and passing them through intact. You get get around that by setting the minimum M2TS size (see HIDDENOPTS.TXT). But doing so really doesn't accomplish much... MPEG-2 is completely compatible with the blu-ray standard too.
Old 19th August 2012, 15:46   #15492  |  Link
lauguru
MIN_M2TS_SIZE=1 n = minimum size required for BD-RB processing in MB, default is 100
By dialing 1, then encode all mpeg2 files, right?
Old 19th August 2012, 16:05   #15493  |  Link
Adbear
Why bother, there's no need to re-encode them
Old 19th August 2012, 16:18   #15494  |  Link
lauguru
mb to get some more for the BD25 .... it will be very little extra space, but it's something. q I do not care take longer to encode.
Old 19th August 2012, 16:22   #15495  |  Link
Adbear
The space saved will be so negligible it's not worth it, it won't get you a better quality main movie from what you save, it will just give you a little bit more empty space on the disc
Old 19th August 2012, 16:32   #15496  |  Link
lauguru
I know, but hey, if I can save 50mb, some more space for the main movie or the extras.
Old 19th August 2012, 18:04   #15497  |  Link
Adbear
Not really, 50MB will make no difference to the quality, maybe if you were saving a GB or 2 then that might make a difference, but 50MB or so won't
Old 19th August 2012, 18:10   #15498  |  Link
lauguru
say 50mb, but will be more likely to say something!, have not tried it yet but it is certainly one way to improve a little more, but the final quality, the human eye does not see
Old 19th August 2012, 18:14   #15499  |  Link
Adbear
OK, waste your time, it will make either no or so little difference that it's not worth it. I doubt it will even effect the encoding bitrate unless you get 100's of MB's out of it
Old 19th August 2012, 18:17   #15500  |  Link
lauguru
I'll tell you the results. Thanks for answering
