#223 | Link |
I'll donate soon, when i got everything set up on my end. But about the buying of the coffee and milk, i hear there are big problems concerning gas delivery in your country. I do hope everything is all right @ your end !
#224 | Link |
Programmer (or just 教务长)
![]() ![]() My plasma TV and av receiver emit enough heat to keep my room warm ![]() ![]() |
#225 | Link |
Tested two clips
1280x548 1920x816 With Apply standard height to video NOT selected after selecting track 1 in menu it played track 1 then track 2 then when back to menu Same tracks again only difference Apply standard height to video selected after selecting track 1 in menu it played track 1 then track 2 then it played track 1 again also I noticed in the mpls clpi files it changed "1B51" to "1B01" and "1B61" to "1B01", since one is a 720p and the other 1080p should both have been changed to "1B01"? |
#226 | Link |
You probably meant that it changes 1b01 to 1b51 for 720 and to 1b61 for 1080.
First 8bits of 01 are for vertical resolution, so 3 for 480p 7 for 576p 5 for 720p and 6 for 1080p Checkbox should not impact playback order. I'll look into it. |
#227 | Link | |
![]() Thx also for your efforts |
#228 | Link |
Tomorrow I'll release version 1.4.
Features added: * mpeg2/ts/m*ts file import * no green bar with mkvs that are not avchd compliant (still video is topside aligned). * I'll try to add SSA subtitle support * PS3 compatibility check with warnings Thanks to all of you for all your efforts to bring multiAVCHD to a decent end-user bugfree level. --- Thinking of an extension to current title count... New version will allow: * 20 TOP MENU selectable titles If all titles are AVCHD compliant (and no BLACK video-buffer-fill is used) then * another 20 selectable titles within player's menu, or * another 20 (minus) AVCHD non-compliant withing player's menu So if you have 40 compliant files/folders you will be able to access first 20 from menu and next 20 from 'direct-go-to-title' in you player menu. If you have some number of compliant and some non-compliant AVCHD files, then you'll be able to access a total of: 40 - compliant - (non-compliant * 2 ). This should be sufficient for most of you - having 40 avchd-ok folders or 20ok and 10not_ok ![]() Last edited by deank; 8th January 2009 at 21:45. |
#230 | Link |
Some request:
- tsMuxeR does not add subtitles if first starts at 00:00:00,000... can you fix? - I'd like to save window position on exit - I'd like to see the changelog after multiAVCHD restart, because the upgrade start too quickly (or create/download changelog.txt) |
#232 | Link |
[25/12/2008] build 27 - Added mkv support. Major update. Fixed STOP button. [26/12/2008] build 30 - Proper handling of already multiAVCHD folders [26/12/2008] build 31 - DVD/BD folder type compatibility fixed! (thanks to zoner) [27/12/2008] build 41 - tsMuxer options, INI file and MOVE option added! [27/12/2008] build 44 - Autoupdate added! [27/12/2008] build 46 - Added tsmuxer font option BOLD [28/12/2008] build 50 - 20 titles in top menu. Re-download! [28/12/2008] build 52 - Destination folder added! [29/12/2008] build 67 - Progress bar and bugfixes! [29/12/2008] build 68 - Consistency check! [29/12/2008] build 74 - Sequental playback and skip top menu selection in SETTINGS TAB. [31/12/2008] build 77 - Cut start/end (seconds) and Force High@4.1 level added in tsMuxer tab. [01/01/2009] build 82 - Serious bugfixes. UPDATE! [02/01/2009] build 84 - Support for multiple SRT subtitles. [02/01/2009] build 86 - Interface update. [03/01/2009] build 92 - Buffered copy/progress indicator. Error reporting. [04/01/2009] build 99 - Added *TS files import and drag/drop to media tab. [04/01/2009] build 101 - Added drag&drop to program window. [05/01/2009] build 104 - Lite version / static menu options. [06/01/2009] build 116 - Custom color/family option in tsMuxer. [07/01/2009] build 120 - Multiple audiotracks in tsMuxer tab. [08/01/2009] build 126 - Chapters in tsMuxer tab. [08/01/2009] build 129 - Setting compliant vertical resolution in tsMuxer tab. [09/01/2009] build 144 - 40 titles. 20 from top menu and 20 selectable, windows positions save. |
#233 | Link |
deank, before you miss this; Look at the follwing thread, i might be of interest to you (it's at the top of the topic-list now, but it might go down) !
http://forum.doom9.org/showthread.php?t=144126 |
#234 | Link |
Just for the sake of testing, I tried this with a couple of 300MB 720p short tv episode. I got 4 titles (2 blanks, 2 300mb PS3 compliant m2ts). Resulting BDMV and CERTIFICATE folders are burnt into CD-R with ImgBurn, UDF 2.50. The PS3 won't recognize the media (CD-R) at all.
Same Folders, applied 8.3 naming for USB, and when USB goes into PS3 port, it plays as AVCHD... strange. Maybe AVCHD on CD-R is not allowed by PS3.
HD n00b |
#236 | Link |
On my way to office, i created a BDMV with black bars. The folder is now in my laptop, haven't burnt it yet to check on PS3. Currently downloading AVCHD player (PowerDVD version something) to see if it can play BDMV folder on harddisk as AVCHD. Will let you know when I get the result. Hey, Deank, since i have no paypal (country restriction), I'm looking for other way to donate. As sending coffee is not an option
![]() cheers, robshot
HD n00b |
