18th February 2020, 19:59 | #7401 | Link |
Pig on the wing
I just did a very quick test myself, encoded my Hot Fuzz testclip with --hist-scenecut and it looks like the default settings are way off. 1220 frames of which 251 were I-frames .. The normal encode would have 12 I-frames (max keyint 480), which looks about the correct amount of true scene changes there.
18th February 2020, 21:17 | #7402 | Link |
How do I retrieve version 3.3+3 via git? I only get version 3.3+1 via git pull origin master (in MSYS2) and the TortoiseGit Revision Graph (in Windows) tells me this is the HEAD.
18th February 2020, 23:14 | #7403 | Link | |
(IDK anything about any VCS, so I have no idea if this is as expected or not-- but my point being, the latest files at the moment will be tagged 3.3+1.) |
19th February 2020, 02:15 | #7404 | Link | |
Sent from my SM-T837V using Tapatalk |
19th February 2020, 08:08 | #7405 | Link |
Let's assume those are the tiny differences between Git and Mercurial, regarding the counting of version numbers and patch increments. Hard to compare "the same build" then ...
_ PS: In previous versions I was used to reading only CMake output on the console while x265 is built. Now, suddenly, make clutters the output by reporting verbosely that it is e.g. entering and leaving directories. May that be a new default behaviour of make, of the shell, or of the media-autobuild suite having set an environment variable in a way that it changes the output also in interactive shell mode? x265 3.3+1-g396395b2b Last edited by LigH; 19th February 2020 at 10:55. |
19th February 2020, 13:29 | #7406 | Link |
SuperVirus
LigH's latest build of x265.exe says:
version = 3.3+1-g396395b2b whereas the latest build of x265.exe by http://msystem.waw.pl/x265/ says: version = 3.3+1-g554c887ac But according to the page https://bitbucket.org/multicoreware/x265/commits/ , those commit numbers don't exist. |
19th February 2020, 14:24 | #7407 | Link |
You are looking in the Mercurial repository, while I got the sources via Git instead (the hash has a g prefix). Try: https://bitbucket.org/multicoreware/x265_git/commits/ (note the x265_git)
Apparently, merges don't increase the patch count for Git; they did in Mercurial, though. Last edited by LigH; 19th February 2020 at 14:29. |
19th February 2020, 16:26 | #7409 | Link | |
SuperVirus
19th February 2020, 16:55 | #7410 | Link |
Pig on the wing
Yes, that's what it does. It looks like motion and camera movement confuses it a lot. It also doesn't respect the min-keyint setting, which I have at 5 but places I-frames right next to each other.
19th February 2020, 19:53 | #7411 | Link | |
Sounds like time for a bug report to MCW. Min-keyint NEEDS to be respected. Putting in a non-IDR I-frame is okay more often. Have you tried raising the threshold value? |
19th February 2020, 20:40 | #7412 | Link | |
Pig on the wing
I could try and file a report tomorrow and also play with the threshold value. I only made one test with the default values to see what happens.
19th February 2020, 21:18 | #7413 | Link | |
20th February 2020, 15:42 | #7415 | Link | |
SuperVirus
Blame cehoyos
Maybe you'd better ask directly to the maintainers of MSYS2, or perhaps to the MABS people... the [##%] Building etc message format is "induced" (so to speak) by CMake, ¿maybe they have changed something in their latest release? I'm using version 3.15.2, FWIW. My MSYS2 environment is "old" as well, its release date is *checks notes* 2016/Oct/25 And I stopped executing the command "pacman -Syuu" ages ago for a good reason. |
20th February 2020, 16:04 | #7416 | Link |
The cmake messages were all I was used to see. Now I see additional make messages; I guess there are two most possible reasons: a) the current make version is so verbose by default now; b) something in the MSYS2 environment changed, and I am not sure if MABS may have caused that.
Now it looks like this to me: |
20th February 2020, 22:18 | #7417 | Link |
結城有紀
Just so you know that Git and Mercurial are not similar at all. They have HUGE differences and I'd rather think they are completely, totally, different kinds of DVCS. Git has a completely different design, different flexibility, different concepts, etc. than HG. If you apply your knowledge from one tool onto the other you'll likely get lost.
One of the biggest difference is anything you do to the HG repository has side effects. For example, creating a branch and making some commits in HG will permanently leave records, such as affecting commit revision numbers, and leaving a permanent branch that, while hidden, cannot be deleted. In Git, branches and commits can be deleted or changed as you wish. Syncing others' work no longer creates diversity between repositories. Conflicts can be resolved in a nicer way. The Git command line, however, was pretty hard to use. It's inconsistent in many ways. I always recommend people to stick to a great GUI and only use command lines for occasional batch process. Depending on your role it could be very difficult to work on Git CLI. For example, my mod has 4 branches, all of them being rebased frequently, so `git pull` won't work on any of them, and you have to stick to the low level way of `git fetch` and then rebase what you have onto the branches, or use `git checkout` or `git reset` (dangerous) to update current branch reference. If you are a downstream modder (who takes my patches and integrates into your own mod) you'll likely be transplanting commits across projects and branches. Things get complicated very quick. I'm kinda surprised to read that many replies talking about Git. Hopefully you'd get used to its concept soon.
Projects x265 - Yuuki-Asuna-mod Download / GitHub TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median Last edited by MeteorRain; 20th February 2020 at 22:21. |
21st February 2020, 08:31 | #7418 | Link |
I noticed that MABS has a quite elaborate helper routine handling Git. So I shall preferably trust its update results. Thank you for your remark, MeteorRain.
And thanks for this workaround parameter, HolyWu. Last edited by LigH; 21st February 2020 at 08:48. |
21st February 2020, 17:41 | #7419 | Link | |
Have you tried higher threshold values? The algorithm does not look at motion, only on colors and texture. They differ a lot when you have a strong scene cut, but low thresholds can result in it false positives. |
21st February 2020, 18:37 | #7420 | Link |
x265 v3.3+2-gbe2d82093 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.2.0)
https://bitbucket.org/multicoreware/x265_git/commits/branch/master |
