17th January 2018, 22:41 | #48421 | Link | |
Speaking of that, does anyone know how to get 8K VP9 60 fps play smooth with MadVR, which setting to change, I have tried everything...please note that it plays smooth in EVR, just would like to avoid switching between MadVR and EVR... Last edited by mytbyte; 17th January 2018 at 22:46. |
17th January 2018, 22:59 | #48422 | Link |
Did you select VP9 in LAV video filter?
Side note: DID YOU GUYS SEE THE NYSE TODAY!
17th January 2018, 23:04 | #48423 | Link | |
GeForce 390.65 "Fixed CVE-2017-5753 Computer systems with microprocessors utilizing speculative execution and branch prediction may allow unauthorized disclosure of information to an attacker with local user access via a side-channel analysis." The driver is good because it supports Nvidia HDR API again and also it no longer names receivers with a dynamic number or letter after them so speaker settings are no longer lost. This is the best Nvidia driver for HTPC for a long time so I would recommend updating to it. Edit - If your on AMD Vega it is not susceptible to either Meltdown or Spectre because it doesn't perform speculative execution. Last edited by Sideeffect; 17th January 2018 at 23:08. |
17th January 2018, 23:16 | #48424 | Link | |
However, any driver is, since driver code runs on the CPU and has kernel acccess. So any critical driver should be hardened against Spectre attacks with code changes and compiler improvements. This is exactly what NVIDIA did, they protected their driver from being used as a platform to perform a Spectre attack. The graphics hardware itself is unaffected.
17th January 2018, 23:21 | #48425 | Link | |
P.S. the GPU video decoder and 3D graphs in windows task manager are almost at full swing, as well as VRAM but there is maybe 1 fps/minute...render queue is empty Last edited by mytbyte; 17th January 2018 at 23:56. |
17th January 2018, 23:41 | #48426 | Link | |
18th January 2018, 00:15 | #48428 | Link |
I haven't updated to the 390.65 driver yet, because I wasn't sure if they had fixed the bug with custom resolutions not being able to select 12-bit. The last driver not broken in this regard was 385.28. Is this fixed now?
18th January 2018, 01:00 | #48429 | Link |
I don't understand how to get HDR to work. I have an LG OLED and the latest W10 update, fully supporting HDR10. Exclusive fullscreen is checked, and HDR passthrough is enabled.
When I launch a 4K HDR rip, there's no HDR and it looks washed out. If I enable HDR in windows, everything looks terrible, and the movie still doesn't look right. What am I missing? Last edited by tyrindor; 18th January 2018 at 01:12. |
18th January 2018, 01:01 | #48430 | Link | |
Once you've selected 12bits in another mode, 12bits is working in custom res (at least here in 4K23p 12bits 4:4:4) even if you can't select it (greyed out) in the custom res. Once selected, the custom res will switch automatically between RGB 8bits at 60p and RGB 12bits below 50p, even if the selection for bit depth is greyed out.
18th January 2018, 02:45 | #48431 | Link |
AMD or Nvidia? If Nvidia don't use exclusive fullscreen. Do not enable Windows' HDR mode. Make sure you are using driver 390.65. Set madVR to passthrough HDR.
Some rips seem to be made incorrectly so LAV does not pass HDR data to madVR (this reminds me, make sure you are actually decoding with a new LAV).
madVR options explained |
18th January 2018, 02:54 | #48432 | Link | |
Also 3D doesn't work for me either, i've had it working in the past. I have LAV 3d drivers installed and 3d enabled but when i go into fullscreen mode with 3d enabled then MPC-BE crashes. Last edited by tyrindor; 18th January 2018 at 03:56. |
18th January 2018, 03:32 | #48433 | Link |
Few tips for 3D to work on nvidia, if this doesnt work we will go deeper into the issue.
Do these only before playing a 3D file. - Enable stereoscopic 3D in nvidia control panel (run wizard if its the first time). - Enable fullscreen exculsive in madvr - Enable 3D in madvr This should get 3D working on your setup. If it works we can set everything up to do the above automatically using profiles. |
18th January 2018, 03:59 | #48434 | Link | |
I think Win10 Fall update might have broken it completely. Before I had to disable DX11 fullscreen or I'd crash, but now if I disable that exclusive fullscreen doesn't work at all (even for 2D content). I searched around and other people had this same problem with the fall update. Last edited by tyrindor; 18th January 2018 at 04:29. |
18th January 2018, 04:17 | #48435 | Link |
JVC Control from MadVR
For those who might be interested, I've put together a quick How To guide to control the JVC from MadVR in order to select a specific calibration using the now fixed external command line with custom profiles. It's a pack with six python files, six batch files and a short PDF.
It works fine, except when coming back, my "after" calibration doesn't seem to work but I don't have the time to debug right now. Here you go: http://www.avsforum.com/forum/24-dig...l#post55519234 Happy to report that I can now launch the nVidia 3D batch files to enable/disable 3D using the same external commands, and it works great. Thanks Madshi for fixing this, it's super useful. Now if only we could find a way to fix the frame drops in 3D for nVidia users, it would be great. I couldn't get anywhere with CRU in 1080p23FP I'm afraid.
18th January 2018, 04:24 | #48436 | Link |
Madshi, wanted to let you know I'm a very happy person right now. I've got everything dialed in at full->full->full 12 bit now including 3D. I'm also able to downscale 4K HDR->1080p SDR which looks fantastic. And I'm able to upscale DVD's to 1080p which also looks fantastic. All on my 1060 with the 390 driver and 0.9.11. I should probably leave well enough alone until I get a 4K OLED. LOL
18th January 2018, 04:28 | #48437 | Link | |
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 18th January 2018 at 04:34. |
18th January 2018, 04:30 | #48438 | Link | |
18th January 2018, 04:35 | #48439 | Link |
Samurai make sure you give HDR the full quality SDR treatment by selecting convert to HDR to SDR with pixel shader math and selecting preserve hue in high quality. 1060 could handle that.
Can anyone comment on whether let madVR decide actually does this automatically if there's enough headroom? Last edited by ryrynz; 18th January 2018 at 04:46. |
18th January 2018, 05:03 | #48440 | Link |
So I have both HDR and 3D working perfectly on fall update with the latest madvr and nvidia 390.65. Those steps I mentioned are only for 3D. Other files will probably crash with stereoscopic enabled in nvidia cp. As I said, all this can be automated once we have your 3D working.
Does your nvidia correctly go into 3D resolution when stereoscopic is enabled and you select a 3D resolution in nvidia cp for your desktop? |
