2nd February 2009, 04:37 | #961 | Link | |
James
Vista SP1 32-bit w/4GB RAM AMD Athlon 64 X2 4400+ @ 2.23GHz nVidia GeForce 8400GS w/512MB RAM |
2nd February 2009, 04:55 | #962 | Link | |
There is a thread here about authoring for the Panasonic standalone... maybe someone there can help you further? James
2nd February 2009, 09:16 | #963 | Link | |
also, once the extras are encoded using libav I can abort, set it to a faster codec and restart doing the main movie (which it does last)? |
2nd February 2009, 16:09 | #964 | Link |
Ok, I was out-of-town for a while and couldn't respond...
For the folks having PS3 skipping problems -- is that on BD-25, BD-9, BD-5 or all? Which encoder quality setting are you using? Also, could someone try using the setting "ENCODE_QUALITY=6" and see if the skipping goes away. That uses the original command line that was in v0.17... That would at least eliminate the X264 settings. Thanks. Last edited by jdobbs; 2nd February 2009 at 16:14. |
2nd February 2009, 18:16 | #965 | Link | |
http://forum.doom9.org/showthread.ph...18#post1215718 It works with newer Nvidia cards only (!) and is not supported by BD-RB. So I guess there are still certain VC-1 files - sometimes found in the Extras of VC-1 BDs - for which BD-RB will fail. IIRC there has been a post stating that the SONIC decoder might also work. |
2nd February 2009, 18:45 | #966 | Link |
Crash on custom target size
Long time lurker, first time poster, love the forum, great topic.
Thanks to the wealth of information within this thread, I've successfully made backups of at least a dozen of my movies, no problems! I've done both BD9s and BD5s. I always use "movie only", ultra high quality 2 pass, and audio is untouched. The quality is amazing, even on the BD5s. It's funny how a 25gb BD can look good at BD5 while an 8gb DVD looks terrible at DVD5. Anyways, lately, encountered a couple problems, not sure if they're bugs though: 1. The last three rebuilds, all of them at BD9, play in a narrow format on my Sammy BD-P2500. The first 10-12 backups all played flawlessly (as long as I remember to enable "Stricter AVCHD"), but the last three are messed up. I get big sidebars on my 16:9 DLP. The movies play fine on my PC using Classic Media Player at the proper wide aspect ratio of 2.35:1. I checked my HT setup by testing some previous backups, no problem, so I know my config is good. The only way I can fix it is to switch my BD player to output 720p and "format" the TV to "wide expand", but then the movie is obviously cropped and PQ is down. Like I said, this probably isn't a bug, but maybe someone knows what the dealio is. 2. All of my builds come up short of their intended media capacity, for example, a BD9 build will be anywhere from 300MB to a full GB less than the available size of the disc. BD5's also come up short between 300 and 400 MB. So I thought I try to manually adjust the size, just by 100MB to see if that helped. The 2nd pass finishes okay, but then my PC bluescreens during the rebuilding phase. The first time I did this was on a BD5, PC crashed towards the end of the rebuild. The second time was on a BD9, PC crashed before anything was written to the BD structure. BTW, I'm using Vista 64bit and libavcodec. Here's the logged error: Code:
----------------------- [21:47:17] BD Rebuilder v0.18.7 (beta) - Source: THE MATRIX - Input BD size: 8.08 GB - Approximate total content: [02:16:17.770] - Target BD size: 7.72 GB - MOVIE-ONLY mode enabled [21:47:17] PHASE ONE, Encoding - [21:55:31] Reencoding: VID_00001 (1 of 1) [07:51:10]PHASE ONE complete [07:51:10]PHASE TWO - Rebuild Started - [07:51:10] Rebuilding BD file Structure Code:
[Options] MODE=1 QUICK_EXTRAS=0 PRIORITY_CLASS=1 RESIZE=0 ENCODE_QUALITY=3 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all TRELLIS=1 COLOR_BOOST=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AVCHD=1 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 TARGET_SIZE=8010 MINIMIZE_TO_TRAY=1 [Paths] SOURCE_PATH=E:\BD WORKFLOW - BD FORMAT\THE MATRIX\ WORKING_PATH=F:\BD WORKFLOW - OUTPUT\THE MATRIX\ |
2nd February 2009, 19:20 | #967 | Link | |
2nd February 2009, 19:44 | #968 | Link | |
I can try the encode quality 6 tonite on one of those that did skip. Will let you know the result, probably tommorrow morning snce I am currently half way thru re-doing XFiles at the moment.
MBK |
2nd February 2009, 19:57 | #969 | Link | |
I have found exactly the same problem again on a different disc, also a Disney one. National Treasure 2. This time tested with newest version 0.18.7. Keep all languages (audio + subs). Interesting: The same trailer on right click in PowerDVD->Audio - before the main movie: Only shows "German" as Language, English Audio is played - when chosen the trailer from popup menu later: English, German and other lanuages to choose, and german is played The INF file: Code:
[Status] LABEL=NATIONAL_TREASURE VERSION=v0.18.7 (beta) SOURCE_SIZE=47156211631 SOURCE_VIDEO_SIZE=47036030976 TARGET_SIZE=24117248000 REDUCTION=.510184784877883 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all BACKUP_MODE=0 QUICK=0 PASS=0 COMPLETED=48 REBUILD_COMPLETE=1 [00013] M2TS_TARGET=68089245 RATE=7199 AUDIO=1 NSIZE=66349056 FLINK=0 MLINK=0 [00014] M2TS_TARGET=56065014 RATE=7191 AUDIO=1 NSIZE=54417408 FLINK=0 MLINK=0 [00015] M2TS_TARGET=467258604 RATE=7231 AUDIO=1 NSIZE=454121472 FLINK=0 MLINK=0 [00016] M2TS_TARGET=25562462 RATE=7133 AUDIO=1 NSIZE=24999936 FLINK=0 MLINK=0 [00017] M2TS_TARGET=85821538 RATE=7236 AUDIO=1 NSIZE=82710528 FLINK=0 MLINK=0 [00018] M2TS_TARGET=42539322 RATE=7205 AUDIO=1 NSIZE=41299968 FLINK=0 MLINK=0 [00019] M2TS_TARGET=173016019 RATE=7266 AUDIO=1 NSIZE=166987776 FLINK=0 MLINK=0 [00020] M2TS_TARGET=31094987 RATE=7147 AUDIO=1 NSIZE=30148608 FLINK=0 MLINK=0 [00021] M2TS_TARGET=166217125 RATE=7296 AUDIO=1 NSIZE=163608576 FLINK=0 MLINK=0 [00022] M2TS_TARGET=23283625 RATE=7139 AUDIO=1 NSIZE=22364160 FLINK=0 MLINK=0 [00023] M2TS_TARGET=15531821 RATE=7192 AUDIO=1 NSIZE=14665728 FLINK=0 MLINK=0 [00024] M2TS_TARGET=37987918 RATE=7170 AUDIO=1 NSIZE=36907008 FLINK=0 MLINK=0 [00025] M2TS_TARGET=108854397 RATE=7187 AUDIO=1 NSIZE=104306688 FLINK=0 MLINK=0 [00026] M2TS_TARGET=22346387 RATE=7176 AUDIO=1 NSIZE=21817344 FLINK=0 MLINK=0 [00027] M2TS_TARGET=33724896 RATE=7234 AUDIO=1 NSIZE=34344960 FLINK=0 MLINK=0 [00028] M2TS_TARGET=335647191 RATE=7250 AUDIO=1 NSIZE=329066496 FLINK=0 MLINK=0 [00029] M2TS_TARGET=450808353 RATE=7132 AUDIO=1 NSIZE=440838144 FLINK=0 MLINK=0 [00030] M2TS_TARGET=654041678 RATE=7193 AUDIO=1 NSIZE=627511296 FLINK=0 MLINK=0 [00031] M2TS_TARGET=646894847 RATE=7187 AUDIO=1 NSIZE=624500736 FLINK=0 MLINK=0 [00032] M2TS_TARGET=578789929 RATE=7135 AUDIO=1 NSIZE=564676608 FLINK=0 MLINK=0 [00033] M2TS_TARGET=453394378 RATE=7177 AUDIO=1 NSIZE=431892480 FLINK=0 MLINK=0 [00034] M2TS_TARGET=304310841 RATE=7196 AUDIO=1 NSIZE=293824512 FLINK=0 MLINK=0 [00035] M2TS_TARGET=688832330 RATE=7163 AUDIO=1 NSIZE=672970752 FLINK=0 MLINK=0 [00036] M2TS_TARGET=172229241 RATE=7149 AUDIO=1 NSIZE=167479296 FLINK=0 MLINK=0 [00037] M2TS_TARGET=145463102 RATE=7200 AUDIO=1 NSIZE=141029376 FLINK=0 MLINK=0 [00038] M2TS_TARGET=60497304 RATE=7198 AUDIO=1 NSIZE=57686016 FLINK=0 MLINK=0 [00039] M2TS_TARGET=80304685 RATE=7262 AUDIO=1 NSIZE=76621824 FLINK=0 MLINK=0 [00040] M2TS_TARGET=16447117 RATE=7215 AUDIO=1 NSIZE=15489024 FLINK=0 MLINK=0 [00041] M2TS_TARGET=100344025 RATE=7277 AUDIO=1 NSIZE=97683456 FLINK=0 MLINK=0 [00408] M2TS_TARGET=83370300 RATE=10667 AUDIO=1 NSIZE=80252928 FLINK=0 MLINK=0 [00416] M2TS_TARGET=16815927692 RATE=13776 AUDIO=10011001 NSIZE=16659800064 FLINK=0 MLINK=0 [00417] M2TS_TARGET=80709045 RATE=8008 AUDIO=1 NSIZE=79454208 FLINK=-1 MLINK=-1 [00418] M2TS_TARGET=61353043 RATE=8646 AUDIO=1 NSIZE=59621376 FLINK=-1 MLINK=-1 [00419] M2TS_TARGET=54648186 RATE=7194 AUDIO=1 NSIZE=55099392 FLINK=-1 MLINK=-1 [00420] M2TS_TARGET=51538687 RATE=8880 AUDIO=1 NSIZE=51339264 FLINK=-1 MLINK=-1 [00421] M2TS_TARGET=9566724 RATE=11264 AUDIO=1 NSIZE=8558592 FLINK=0 MLINK=0 [00424] M2TS_TARGET=138927513 RATE=7139 AUDIO=111 NSIZE=132999168 FLINK=0 MLINK=0 [00425] M2TS_TARGET=132260271 RATE=6712 AUDIO=111 NSIZE=128458752 FLINK=0 MLINK=0 [00426] M2TS_TARGET=8450815 RATE=8186 AUDIO=111 NSIZE=9056256 FLINK=0 MLINK=0 [00427] M2TS_TARGET=181222337 RATE=7006 AUDIO=111 NSIZE=181807104 FLINK=0 MLINK=0 [00428] M2TS_TARGET=8482161 RATE=8219 AUDIO=111 NSIZE=9031680 FLINK=0 MLINK=0 [00429] M2TS_TARGET=147745073 RATE=7393 AUDIO=111 NSIZE=143517696 FLINK=0 MLINK=0 [00430] M2TS_TARGET=8491565 RATE=8229 AUDIO=111 NSIZE=9621504 FLINK=0 MLINK=0 [00431] M2TS_TARGET=8463353 RATE=8199 AUDIO=111 NSIZE=9289728 FLINK=0 MLINK=0 [00432] M2TS_TARGET=8773676 RATE=7177 AUDIO=111 NSIZE=8294400 FLINK=0 MLINK=0 [00433] M2TS_TARGET=8463353 RATE=8199 AUDIO=111 NSIZE=9179136 FLINK=0 MLINK=0 [00506] M2TS_TARGET=113506107 RATE=11988 AUDIO=111111 NSIZE=106555392 FLINK=0 MLINK=0 [00507] M2TS_TARGET=29769062 RATE=7662 AUDIO=1 NSIZE=23267328 FLINK=0 MLINK=0 |
2nd February 2009, 20:12 | #970 | Link | |
2nd February 2009, 20:19 | #971 | Link | |
I've got a couple more "rebuilds" to burn tonight (one for sure, the other may take until tomorrow to finish), both with unmodified output sizes (BD9). I'll let you know how they turn out. |
2nd February 2009, 21:26 | #973 | Link | |
The reason I asked for the ENCODE_QUALITY=6 setting is because that would enable exactly the same X264 settings as were in use for v0.17.13. |
2nd February 2009, 21:42 | #974 | Link | |
Aging Video Hobbyist
Then I demuxed the raw vc1 track and libavcodec still failed on it, but Sonic worked, at least for display--but I still couldn't make a graph that would work with Avisynth as input to x264... |
2nd February 2009, 21:44 | #975 | Link |
I'll run Pride and Glory through again with the ENCODE_QUALITY=6 setting. I should be a good test, since I know for certain there isn't a problem with the original decrypted output from AnyDVD. I'll be using the most recent version 18.7.
2nd February 2009, 22:22 | #976 | Link | |
I got skipping on Encode_Quality=6 doing BD-9 & BD-5. |
2nd February 2009, 23:29 | #977 | Link |
Then I'm at a loss as to what is causing it if it is within BD-RB. It is using exactly the same encoding and muxing parameters as was used in previous versions. I did update the X264.EXE release with that version also. You may want to try the newer version of BD-RB with the X264.EXE from v0.17.13 just to see if that might be the issue.
Could you please send me the LASTCMD.TXT, INF and INI files used for the encoding? Send to dvd-rb@dvd-rb.com Last edited by jdobbs; 2nd February 2009 at 23:34. |
2nd February 2009, 23:52 | #978 | Link |
I noticed that when the source is a Bluray remux (only movie) not fullBluRay is not possible to resume the second pass. Although not change anything Only press backup and abort. After several hours it is sad to see that all work is not productive. It is possible to manually make a resume?
2nd February 2009, 23:59 | #979 | Link | |
Jdobbs: Do you think it is the same issue I'm having with my denon player? It was working with v0.17.3 and not working with v0.18. The other difference I did was that I selected "good" as encoder setting in v0.18. Anything I can try or send you? |
3rd February 2009, 00:03 | #980 | Link | |
I may add an option in which the chapters are encoded individually. That way you could exit/resume at shorter intervals. The other option is to set the encode so that it is using IDLE PRIORITY under the ENCODER SETTINGS menu and then select MINIMIZE TO TRAY under the FILE menu. That way you can let it run while using your computer and it will only use unused processor time -- letting other applications have priority. But when you aren't using your computer for something else, it will run at a speed comparible to what you'd get get with a higher priority. That's how I usually run mine. |
