26th August 2019, 22:25 | #17281 | Link | |
27th August 2019, 16:26 | #17283 | Link |
ByteShare
Newer QTGMC v3.358s
Supports KNLMeansCL as a denoiser and 16B There are some bug fixes as well but from testing I'm not seeing much of a difference if using just using Medium preset. http://avisynth.nl/index.php/QTGMC Last edited by byteshare; 27th August 2019 at 20:58. |
28th August 2019, 01:25 | #17284 | Link |
Check windows anti-virus/malware while using L-smash
I've noticed that in windows 10, running Ripbot in D.E. mode, that windows built-in antivirus and anti-malware is scanning the chunks as they're sent to each server while using L-Smash. And I switched L-smash to ffms2 looks like my encodes are back to acceptable completion times (120-150 fps first pass, 30-34 fps second pass) across 4 PC's
Edit - I would also note all computers, and the bandwidth usage spikes when intercepted by the scanner, scanner does it's thing and then ripbot shows it's encoding and the bandwidth drops to normal 60-110 megabits per second Last edited by PLOPZA; 28th August 2019 at 01:32. |
29th August 2019, 21:03 | #17285 | Link |
So I just got hit by the random frames bug and I'm using DE. Seems to happen a couple of seconds after a minute mark for 2-5 seconds. I looked at a 4K and HD encode I did with MDegrain2 and at first glance, it seems fine. I have a 3h:17m source that I ran MDegrain2 on and at the 13 minute mark, random frames occur for about 2-10 seconds. It happens to most of the minute marks after that. Going to run the same source through again without the MDegrain2 and see what happens.
29th August 2019, 22:32 | #17286 | Link | |
ByteShare
29th August 2019, 22:47 | #17287 | Link |
Also what codec is used in source video?
30th August 2019, 13:14 | #17288 | Link |
From the m2ts source: Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : 27 Duration : 3 h 17 min Bit rate mode : Variable Maximum bit rate : 38.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive The second run through without MDegrain2 shows no random frames at least at first glance as I looked at a couple dozen minute mark locations where the randomness occurred before. The decoder was LSmash. #VideoSource LoadPlugin("C:\Program Files\RipBot264\Tools\AviSynth plugins\lsmash\LSMASHSource.dll") I'm encoding to x265. Last edited by Ryushin; 30th August 2019 at 13:21. Reason: Added detail. |
30th August 2019, 13:58 | #17290 | Link | |
2nd September 2019, 01:43 | #17291 | Link |
I've finally found out why the encoding client couldn't find the index file it was looking for. First, I went back to v 1.24 to confirm my test files hadn't got corrupted since I had already encoded them before with it. Everything worked smoothly and that when I noticed the message "Indexing file, please wait" right after demuxing. I then was able to encode with no problems. Afterwards, I upgraded to 1.25.0, and retested. The message never appeared, only "Gathering information, please wait". Task manager showed ffprobe.exe running. When I tried to run the encoding client, the missing index file message appeared again. I then opened the job folder and spotted IndexStreams.cmd . Running it created the missing index file. For some reason, Ripbot is skipping creating an index file, even when the decoder is set to ffms.
I found another bug in the encoding client. In 1.24, I had 4 servers created in the settings tab and it activated and ran all of them with no problems. In the newest version, I had to manually activate and connect each server. On the plus side, Atak's code improvement actually dropped the cpu usage down to where I could activate a 5th server on my Threadripper. For the record, my first test file is a game capture with UtVideo as the video codec,1080p60 and PCM as audio. My second file is from my camcorder, with 1080p60 and Dolby 5.1 audio. |
5th September 2019, 13:28 | #17292 | Link |
Resizing Video
Hi Atak,
So I've been assuming something and it came back to bit me and I'm wondering if it is by design or not. So I make 720p versions of all my 4K/HD sources to store on mobile devices and for streaming. So I normally I just select the "HD Ready 1280x720" option creating the small version. The behavior I just noticed is that it will add borders to make it 16x9 when I have a video that is already cropped. When I first started doing this, I don't remember it behaving in this way. I thought it was the 1280 or the 720 to scale the video to it's longest dimension. I.e. 2.4:1 - 1920x960 becomes 1280x640 and 4:3 - 1440x1080 becomes 960x720. Now to get the behavior I want, I have to select Custom [X,XX:1]. It's easier If I select HD Ready first and then select Custom so I don't need to type in the dimension. Can a option be added to not add borders when resizing video? |
5th September 2019, 13:50 | #17293 | Link |
use Custom preset with aspect ratio in brackets (for example Custom [2,40:1])
5th September 2019, 15:21 | #17294 | Link |
That will only work on sources that are exactly that aspect ratio. I was looking for a more general solution that I can just select HD Ready and it will scale the video appropriately without adding borders that were not there before.
7th September 2019, 13:18 | #17296 | Link | |
Atak, quick question. I purchased a BD of the old Scooby Doo series. I tried to make h265 encodes of the first disc. I normally don't do h265 because my computer is older and takes forever, but these are short episodes so I thought I'd try. I get the following error on each episode.
Edit: I just noticed too that there's no audio picked up in RipBot, even though the file has a stereo track. Could this be another 1.25 bug? Last edited by stryker412; 7th September 2019 at 13:24. |
7th September 2019, 13:22 | #17297 | Link |
Have you checked that chapters.txt file?
7th September 2019, 13:44 | #17298 | Link | ||
Yes
8th September 2019, 16:00 | #17300 | Link |
Here is a copy of the error log I got:
E:\>"C:\Program Files (x86)\RipBot264\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "E:\Temp\RipBot264temp\job9\job9.avs" -strict -1 -f yuv4mpegpipe - | "C:\Program Files (x86)\RipBot264\tools\x265\x265_x64.exe" --colorprim bt709 --transfer bt709 --colormatrix bt709 --pass 1 --bitrate 2320 --stats "E:\Temp\RipBot264temp\job9\job9.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 172056 --sar 1:1 --profile main10 --output-depth 10 --ctu 32 --no-slow-firstpass --y4m --output NUL - y4m [info]: 1920x800 fps 24000/1001 i420p8 sar 1:1 unknown frame count raw [info]: output file: NUL x265 [info]: HEVC encoder version 3.1+14-f08461fdae33 x265 [info]: build info [Windows][MSVC 1900][64 bit] 10bit+8bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [info]: Main 10 profile, Level-4 (Main tier) x265 [info]: Thread pool created using 4 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 2 / wpp(25 rows) x265 [info]: Coding QT: max CU size, min CU size : 32 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : dia / 57 / 2 / 1 x265 [info]: Keyframe min / max / scenecut / bias: 24 / 240 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 1 / off / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : ABR-2320 kbps / 0.60 x265 [info]: tools: rd=2 psy-rd=2.00 early-skip rskip signhide tmvp b-intra x265 [info]: tools: fast-intra strong-intra-smoothing lslices=5 deblock sao x265 [info]: tools: stats-write x265 [info]: frame I: 2080, Avg QP:20.15 kb/s: 14026.26 x265 [info]: frame P: 39753, Avg QP:21.44 kb/s: 4995.98 x265 [info]: frame B: 130223, Avg QP:25.09 kb/s: 1219.70 x265 [info]: Weighted P-Frames: Y:7.9% UV:6.7% x265 [info]: consecutive B-frames: 9.2% 4.1% 6.6% 26.3% 53.8% encoded 172056 frames in 18344.01s (9.38 fps), 2247.02 kb/s, Avg QP:24.18 E:\>"C:\Program Files (x86)\RipBot264\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "E:\Temp\RipBot264temp\job9\job9.avs" -strict -1 -f yuv4mpegpipe - | "C:\Program Files (x86)\RipBot264\tools\x265\x265_x64.exe" --colorprim bt709 --transfer bt709 --colormatrix bt709 --pass 2 --bitrate 2320 --stats "E:\Temp\RipBot264temp\job9\job9.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 172056 --sar 1:1 --profile main10 --output-depth 10 --ctu 32 --y4m --output "E:\Temp\RipBot264temp\video.265" - y4m [info]: 1920x800 fps 24000/1001 i420p8 sar 1:1 unknown frame count raw [info]: output file: E:\Temp\RipBot264temp\video.265 x265 [info]: HEVC encoder version 3.1+14-f08461fdae33 x265 [info]: build info [Windows][MSVC 1900][64 bit] 10bit+8bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [info]: Main 10 profile, Level-4 (Main tier) x265 [info]: Thread pool created using 4 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 2 / wpp(25 rows) x265 [info]: Coding QT: max CU size, min CU size : 32 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 3 x265 [info]: Keyframe min / max / scenecut / bias: 24 / 240 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / off / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : ABR-2320 kbps / 0.60 x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip signhide tmvp b-intra x265 [info]: tools: strong-intra-smoothing lslices=5 deblock sao stats-read x265 [info]: frame I: 2080, Avg QP:19.54 kb/s: 16468.27 x265 [info]: frame P: 39753, Avg QP:22.03 kb/s: 5039.21 x265 [info]: frame B: 130223, Avg QP:25.85 kb/s: 1261.56 x265 [info]: Weighted P-Frames: Y:4.3% UV:3.6% x265 [info]: consecutive B-frames: 9.2% 4.1% 6.6% 26.3% 53.8% encoded 172056 frames in 19715.15s (8.73 fps), 2318.21 kb/s, Avg QP:24.89 E:\>"C:\Program Files (x86)\RipBot264\tools\mkvtoolnix\mkvmerge.exe" -o "E:\New Rips\Ripbot\Olympus Has Fallen.mkv" --compression 0:none --title "Olympus Has Fallen" --default-duration 0:24000/1001fps "E:\Temp\RipBot264temp\video.265" --compression 0:none --language 0:eng "E:\Temp\RipBot264temp\job9\Encoded_Audio_1.ac3" --default-track 0:yes --forced-track 0:yes --language 0:eng -s 0 -D -A "E:\Temp\RipBot264temp\job9\6_subtitles_English_FORCED_1080.sup" --default-track 0:no --language 0:eng -s 0 -D -A "E:\Temp\RipBot264temp\job9\6_subtitles_English_1080.sup" --chapters "E:\Temp\RipBot264temp\job9\chapters.txt" --attachment-mime-type image/jpeg --attachment-description Cover --attachment-name Cover --attach-file "E:\Temp\RipBot264temp\job9\cover.jpg" mkvmerge v37.0.0 ('Leave It') 64-bit Error: The file 'E:\Temp\RipBot264temp\job9\Encoded_Audio_1.ac3' could not be opened for reading: open file error. ------------------------- Elapsed Time: 10h:34m:44s |
