7th January 2013, 22:16 | #16461 | Link | |
Programmer
I think with these rental version they sometimes cripple the content via the menu or sometimes even remove the content streams even off the rental disc. Makes buying used Blurays a landmine now. At least the retail shop gohastings does separate their used sales so you know if there is a chance its a rental. So then I thought maybe I can get the extended version via BD Rebuilder and I did a movie only and selected playlist for the 130 minute. But the output was a stream that had the PIP video commentary but it was the 130 minute stream and their was no audio. I wonder if playlists on retail version are same cause I see some commenting on this title as it having the extended cut as playlist 801 where my used version only has a 450 playlist for extended and I think this 450 playlist is for the insight mode PIP commentary version of 130 minute runtime. What exactly is on the extended cut - is it only a tagged on alternate ending? Or is more added thoroughout the movie? No spoilers please Last edited by jfcarbel; 8th January 2013 at 11:04. |
9th January 2013, 02:28 | #16462 | Link |
this kept happening to me for Up, now Green Lantern, same settings, any ideas??
[01/08/13] BD Rebuilder v0.42.08 (beta) [11:51:57] Source: GREEN_LANTERN_BD01_00101 - Input BD size: 23.59 GB - Approximate total content: [02:03:39.453] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, 640Kbs DD5.1 - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [11:51:57] PHASE ONE, Encoding - [11:51:57] Processing: VID_00150 (1 of 22) - [11:51:57] Extracting A/V streams [VID_00150] - [11:57:34] Reencoding video [VID_00150] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 20,415 frames - [11:57:34] Reencoding: VID_00150, Pass 1 of 1 - [12:20:13] Video Encode complete - [12:20:13] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [12:24:05] Processing: VID_00122 (2 of 22) - [12:24:05] Extracting A/V streams [VID_00122] - [12:24:16] Reencoding video [VID_00122] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,756 frames - [12:24:16] Reencoding: VID_00122, Pass 1 of 1 - [12:28:33] Video Encode complete - [12:28:33] Processing: VID_00102 (3 of 22) - [12:28:33] Extracting A/V streams [VID_00102] - [12:28:47] Reencoding video [VID_00102] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 5,417 frames - [12:28:47] Reencoding: VID_00102, Pass 1 of 1 - [12:36:07] Video Encode complete - [12:36:07] Processing: VID_00103 (4 of 22) - [12:36:07] Extracting A/V streams [VID_00103] - [12:36:24] Reencoding video [VID_00103] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,019 frames - [12:36:24] Reencoding: VID_00103, Pass 1 of 1 - [12:44:53] Video Encode complete - [12:44:53] Processing: VID_00151 (5 of 22) - [12:44:53] Extracting A/V streams [VID_00151] - [12:45:09] Reencoding video [VID_00151] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,273 frames - [12:45:09] Reencoding: VID_00151, Pass 1 of 1 - [12:53:04] Video Encode complete - [12:53:04] Processing: VID_00105 (6 of 22) - [12:53:04] Extracting A/V streams [VID_00105] - [12:53:17] Reencoding video [VID_00105] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 5,242 frames - [12:53:17] Reencoding: VID_00105, Pass 1 of 1 - [12:59:02] Video Encode complete - [12:59:02] Processing: VID_00106 (7 of 22) - [12:59:02] Extracting A/V streams [VID_00106] - [12:59:49] Reencoding video [VID_00106] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 22,201 frames - [12:59:49] Reencoding: VID_00106, Pass 1 of 1 - [13:24:24] Video Encode complete - [13:24:24] Processing: VID_00107 (8 of 22) - [13:24:24] Extracting A/V streams [VID_00107] - [13:24:31] Reencoding video [VID_00107] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,970 frames - [13:24:31] Reencoding: VID_00107, Pass 1 of 1 - [13:26:52] Video Encode complete - [13:26:52] Processing: VID_00108 (9 of 22) - [13:26:52] Extracting A/V streams [VID_00108] - [13:27:14] Reencoding video [VID_00108] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 9,653 frames - [13:27:14] Reencoding: VID_00108, Pass 1 of 1 - [13:37:57] Video Encode complete - [13:37:57] Processing: VID_00109 (10 of 22) - [13:37:57] Extracting A/V streams [VID_00109] - [13:38:04] Reencoding video [VID_00109] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,027 frames - [13:38:04] Reencoding: VID_00109, Pass 1 of 1 - [13:40:25] Video Encode complete - [13:40:25] Processing: VID_00110 (11 of 22) - [13:40:25] Extracting A/V streams [VID_00110] - [13:40:34] Reencoding video [VID_00110] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,086 frames - [13:40:34] Reencoding: VID_00110, Pass 1 of 1 - [13:43:53] Video Encode complete - [13:43:53] Processing: VID_00111 (12 of 22) - [13:43:53] Extracting A/V streams [VID_00111] - [13:44:11] Reencoding video [VID_00111] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,906 frames - [13:44:11] Reencoding: VID_00111, Pass 1 of 1 - [13:53:44] Video Encode complete - [13:53:44] Processing: VID_00112 (13 of 22) - [13:53:44] Extracting A/V streams [VID_00112] - [13:54:28] Reencoding video [VID_00112] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 21,159 frames - [13:54:28] Reencoding: VID_00112, Pass 1 of 1 - [14:17:36] Video Encode complete - [14:17:36] Processing: VID_00113 (14 of 22) - [14:17:36] Extracting A/V streams [VID_00113] - [14:17:44] Reencoding video [VID_00113] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,626 frames - [14:17:44] Reencoding: VID_00113, Pass 1 of 1 - [14:20:11] Video Encode complete - [14:20:11] Processing: VID_00114 (15 of 22) - [14:20:11] Extracting A/V streams [VID_00114] - [14:20:20] Reencoding video [VID_00114] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,864 frames - [14:20:20] Reencoding: VID_00114, Pass 1 of 1 - [14:23:14] Video Encode complete - [14:23:14] Processing: VID_00115 (16 of 22) - [14:23:14] Extracting A/V streams [VID_00115] - [14:23:21] Reencoding video [VID_00115] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,953 frames - [14:23:21] Reencoding: VID_00115, Pass 1 of 1 - [14:25:40] Video Encode complete - [14:25:40] Processing: VID_00116 (17 of 22) - [14:25:40] Extracting A/V streams [VID_00116] - [14:26:11] Reencoding video [VID_00116] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 13,054 frames - [14:26:11] Reencoding: VID_00116, Pass 1 of 1 - [14:41:23] Video Encode complete - [14:41:23] Processing: VID_00117 (18 of 22) - [14:41:23] Extracting A/V streams [VID_00117] - [14:41:31] Reencoding video [VID_00117] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,131 frames - [14:41:31] Reencoding: VID_00117, Pass 1 of 1 - [14:43:35] Video Encode complete - [14:43:35] Processing: VID_00118 (19 of 22) - [14:43:35] Extracting A/V streams [VID_00118] - [14:43:53] Reencoding video [VID_00118] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,838 frames - [14:43:53] Reencoding: VID_00118, Pass 1 of 1 - [14:52:39] Video Encode complete - [14:52:39] Processing: VID_00119 (20 of 22) - [14:52:39] Extracting A/V streams [VID_00119] - [14:52:44] Reencoding video [VID_00119] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,844 frames - [14:52:44] Reencoding: VID_00119, Pass 1 of 1 - [14:54:49] Video Encode complete - [14:54:49] Processing: VID_00120 (21 of 22) - [14:54:49] Extracting A/V streams [VID_00120] - [14:55:25] Reencoding video [VID_00120] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 16,671 frames - [14:55:25] Reencoding: VID_00120, Pass 1 of 1 - [15:15:28] Video Encode complete - [15:15:28] Processing: VID_00152 (22 of 22) - [15:15:28] Extracting A/V streams [VID_00152] - [15:15:50] Reencoding video [VID_00152] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 10,784 frames - [15:15:50] Reencoding: VID_00152, Pass 1 of 1 - [15:24:02] Video Encode complete [15:24:02]PHASE ONE complete [15:24:02]PHASE TWO - Rebuild Started - [15:24:02] Building ALTERNATE OUTPUT Structure [15:26:48] - Failed to REBUILD |
9th January 2013, 22:15 | #16463 | Link |
Now, I know the latest version is 0.42.08 and I'm still on 0.42.07, but since this issue has plagued BD-RB for ages I'm fairly certain it hasn't been fixed in 0.42.08. Could almost make a wager on it. Anyhoo...
It's "the PCM audio of a very small source file cannot be reencoded into AC3" issue again. And it's always the same: a very small .M2TS file, containing two identical PCM tracks, with stream ids 4352 and 4353. BD-RB quits with "ERROR in attempt to reencode audio (AFTEN) [AUD_00000_4352.AVS]" in the log. Usually it manages to encode the first .WAV file, stream id 4352, and conks out when trying to encode 4353. I usually solve the problem by making a copy of the AUD_00000_4352.AC3 and renaming it AUD_00000_4353.AC3, then Restart Backup and Resume. This happened yesterday on "Die Screaming, Marianne". Today, trying to make a Full Backup of "Baron Blood", BD-RB stopped at the first of two audio .wav files. No AC3 files were created, in other words, so nothing to copy and rename. Want to hear something odd? When I run audio.bat which resides in WORKFILES directory, the result is a perfect AC3 file. I edited the .bat file and replaced instances of 4352 with 4353, ran the .bat and got another perfect AC3 file. OK, I thought, problem solved: just Restart and Resume. But BD-RB refuses to Resume, even though the two AC3 files are already in the WORKFILES directory. It still attemps to reencode the audio, not realizing it no longer needs to. Ideas, suggestions? Thanks. |
10th January 2013, 07:09 | #16465 | Link |
Anybody else get this problem with Ted Unrated? Original disc and rip play back perfectly fine, BDRB encode does not. Some of the film is normal, other parts like the end credits not so much...
[01/09/13] BD Rebuilder v0.42.08 (beta) [00:19:24] Source: TED_DOM_00801 - Input BD size: 27.52 GB - Approximate total content: [01:52:15.228] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, 448Kbs DD5.1 - Automatic cropping of borders enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [00:19:27] PHASE ONE, Encoding - [00:19:27] Processing: VID_00368 (1 of 33) - [00:19:27] Reencoding video [VID_00368] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,922 frames - [00:19:27] Reencoding: VID_00368, Pass 1 of 1 - [00:22:18] Video Encode complete - [00:22:18] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [00:25:53] Processing: VID_00401 (2 of 33) - [00:25:53] Extracting A/V streams [VID_00401] - [00:25:58] Reencoding video [VID_00401] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 639 frames - [00:25:59] Reencoding: VID_00401, Pass 1 of 1 - [00:26:51] Video Encode complete - [00:26:51] Processing: VID_00370 (3 of 33) - [00:26:51] Extracting A/V streams [VID_00370] - [00:27:09] Reencoding video [VID_00370] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 5,159 frames - [00:27:09] Reencoding: VID_00370, Pass 1 of 1 - [00:33:57] Video Encode complete - [00:33:57] Processing: VID_00402 (4 of 33) - [00:33:57] Extracting A/V streams [VID_00402] - [00:34:03] Reencoding video [VID_00402] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 926 frames - [00:34:03] Reencoding: VID_00402, Pass 1 of 1 - [00:35:10] Video Encode complete - [00:35:10] Processing: VID_00372 (5 of 33) - [00:35:10] Extracting A/V streams [VID_00372] - [00:35:17] Reencoding video [VID_00372] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 883 frames - [00:35:17] Reencoding: VID_00372, Pass 1 of 1 - [00:36:19] Video Encode complete - [00:36:19] Processing: VID_00403 (6 of 33) - [00:36:19] Extracting A/V streams [VID_00403] - [00:36:29] Reencoding video [VID_00403] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,686 frames - [00:36:29] Reencoding: VID_00403, Pass 1 of 1 - [00:40:34] Video Encode complete - [00:40:34] Processing: VID_00374 (7 of 33) - [00:40:34] Extracting A/V streams [VID_00374] - [00:41:08] Reencoding video [VID_00374] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 9,186 frames - [00:41:08] Reencoding: VID_00374, Pass 1 of 1 - [00:52:35] Video Encode complete - [00:52:35] Processing: VID_00404 (8 of 33) - [00:52:35] Extracting A/V streams [VID_00404] - [00:52:41] Reencoding video [VID_00404] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,067 frames - [00:52:41] Reencoding: VID_00404, Pass 1 of 1 - [00:54:22] Video Encode complete - [00:54:22] Processing: VID_00376 (9 of 33) - [00:54:22] Extracting A/V streams [VID_00376] - [00:54:33] Reencoding video [VID_00376] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,570 frames - [00:54:33] Reencoding: VID_00376, Pass 1 of 1 - [00:58:31] Video Encode complete - [00:58:31] Processing: VID_00405 (10 of 33) - [00:58:31] Extracting A/V streams [VID_00405] - [00:58:37] Reencoding video [VID_00405] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 911 frames - [00:58:37] Reencoding: VID_00405, Pass 1 of 1 - [00:59:49] Video Encode complete - [00:59:49] Processing: VID_00378 (11 of 33) - [00:59:49] Extracting A/V streams [VID_00378] - [01:00:03] Reencoding video [VID_00378] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,569 frames - [01:00:03] Reencoding: VID_00378, Pass 1 of 1 - [01:05:15] Video Encode complete - [01:05:15] Processing: VID_00406 (12 of 33) - [01:05:15] Extracting A/V streams [VID_00406] - [01:05:23] Reencoding video [VID_00406] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,664 frames - [01:05:23] Reencoding: VID_00406, Pass 1 of 1 - [01:07:53] Video Encode complete - [01:07:53] Processing: VID_00380 (13 of 33) - [01:07:53] Extracting A/V streams [VID_00380] - [01:08:04] Reencoding video [VID_00380] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,558 frames - [01:08:04] Reencoding: VID_00380, Pass 1 of 1 - [01:11:32] Video Encode complete - [01:11:32] Processing: VID_00407 (14 of 33) - [01:11:32] Extracting A/V streams [VID_00407] - [01:11:39] Reencoding video [VID_00407] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,107 frames - [01:11:39] Reencoding: VID_00407, Pass 1 of 1 - [01:13:34] Video Encode complete - [01:13:35] Processing: VID_00382 (15 of 33) - [01:13:35] Extracting A/V streams [VID_00382] - [01:13:55] Reencoding video [VID_00382] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 5,467 frames - [01:13:55] Reencoding: VID_00382, Pass 1 of 1 - [01:23:53] Video Encode complete - [01:23:53] Processing: VID_00408 (16 of 33) - [01:23:53] Extracting A/V streams [VID_00408] - [01:23:59] Reencoding video [VID_00408] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 606 frames - [01:23:59] Reencoding: VID_00408, Pass 1 of 1 - [01:24:56] Video Encode complete - [01:24:56] Processing: VID_00384 (17 of 33) - [01:24:56] Extracting A/V streams [VID_00384] - [01:25:06] Reencoding video [VID_00384] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,192 frames - [01:25:06] Reencoding: VID_00384, Pass 1 of 1 - [01:28:21] Video Encode complete - [01:28:21] Processing: VID_00409 (18 of 33) - [01:28:21] Extracting A/V streams [VID_00409] - [01:28:26] Reencoding video [VID_00409] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 553 frames - [01:28:26] Reencoding: VID_00409, Pass 1 of 1 - [01:29:09] Video Encode complete - [01:29:09] Processing: VID_00386 (19 of 33) - [01:29:09] Extracting A/V streams [VID_00386] - [01:29:22] Reencoding video [VID_00386] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,953 frames - [01:29:22] Reencoding: VID_00386, Pass 1 of 1 - [01:35:40] Video Encode complete - [01:35:40] Processing: VID_00410 (20 of 33) - [01:35:40] Extracting A/V streams [VID_00410] - [01:35:45] Reencoding video [VID_00410] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 491 frames - [01:35:45] Reencoding: VID_00410, Pass 1 of 1 - [01:36:22] Video Encode complete - [01:36:22] Processing: VID_00387 (21 of 33) - [01:36:22] Extracting A/V streams [VID_00387] - [01:36:55] Reencoding video [VID_00387] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 12,780 frames - [01:36:55] Reencoding: VID_00387, Pass 1 of 1 - [01:54:37] Video Encode complete - [01:54:37] Processing: VID_00411 (22 of 33) - [01:54:37] Extracting A/V streams [VID_00411] - [01:54:44] Reencoding video [VID_00411] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,322 frames - [01:54:44] Reencoding: VID_00411, Pass 1 of 1 - [01:56:19] Video Encode complete - [01:56:19] Processing: VID_00418 (23 of 33) - [01:56:19] Extracting A/V streams [VID_00418] - [01:56:39] Reencoding video [VID_00418] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 6,332 frames - [01:56:39] Reencoding: VID_00418, Pass 1 of 1 - [02:05:04] Video Encode complete - [02:05:04] Processing: VID_00417 (24 of 33) - [02:05:04] Extracting A/V streams [VID_00417] - [02:05:18] Reencoding video [VID_00417] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,921 frames - [02:05:18] Reencoding: VID_00417, Pass 1 of 1 - [02:11:19] Video Encode complete - [02:11:19] Processing: VID_00391 (25 of 33) - [02:11:19] Extracting A/V streams [VID_00391] - [02:11:33] Reencoding video [VID_00391] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,366 frames - [02:11:33] Reencoding: VID_00391, Pass 1 of 1 - [02:18:21] Video Encode complete - [02:18:21] Processing: VID_00413 (26 of 33) - [02:18:21] Extracting A/V streams [VID_00413] - [02:18:28] Reencoding video [VID_00413] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,263 frames - [02:18:28] Reencoding: VID_00413, Pass 1 of 1 - [02:20:50] Video Encode complete - [02:20:50] Processing: VID_00393 (27 of 33) - [02:20:50] Extracting A/V streams [VID_00393] - [02:22:03] Reencoding video [VID_00393] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 29,683 frames - [02:22:03] Reencoding: VID_00393, Pass 1 of 1 - [03:12:17] Video Encode complete - [03:12:17] Processing: VID_00414 (28 of 33) - [03:12:17] Extracting A/V streams [VID_00414] - [03:12:22] Reencoding video [VID_00414] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 467 frames - [03:12:22] Reencoding: VID_00414, Pass 1 of 1 - [03:13:10] Video Encode complete - [03:13:10] Processing: VID_00395 (29 of 33) - [03:13:10] Extracting A/V streams [VID_00395] - [03:14:00] Reencoding video [VID_00395] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 20,280 frames - [03:14:00] Reencoding: VID_00395, Pass 1 of 1 - [03:45:22] Video Encode complete - [03:45:22] Processing: VID_00415 (30 of 33) - [03:45:22] Extracting A/V streams [VID_00415] - [03:45:30] Reencoding video [VID_00415] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,470 frames - [03:45:30] Reencoding: VID_00415, Pass 1 of 1 - [03:47:52] Video Encode complete - [03:47:52] Processing: VID_00397 (31 of 33) - [03:47:52] Extracting A/V streams [VID_00397] - [03:48:44] Reencoding video [VID_00397] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 20,624 frames - [03:48:44] Reencoding: VID_00397, Pass 1 of 1 - [04:23:29] Video Encode complete - [04:23:29] Processing: VID_00416 (32 of 33) - [04:23:29] Extracting A/V streams [VID_00416] - [04:23:38] Reencoding video [VID_00416] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,067 frames - [04:23:38] Reencoding: VID_00416, Pass 1 of 1 - [04:26:36] Video Encode complete - [04:26:36] Processing: VID_00399 (33 of 33) - [04:26:36] Extracting A/V streams [VID_00399] - [04:27:01] Reencoding video [VID_00399] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,800 frames - [04:27:01] Reencoding: VID_00399, Pass 1 of 1 - [04:28:07] Video Encode complete [04:28:07]PHASE ONE complete [04:28:07]PHASE TWO - Rebuild Started - [04:28:07] Building ALTERNATE OUTPUT Structure [04:39:30] - Encode and Rebuild complete - WORKFILES folder removed. [04:39:30] JOB: TED_DOM finished. Code:
[Status] LABEL=TED_DOM VERSION=v0.42.08 (beta) SOURCE_SIZE=29545414656 SOURCE_VIDEO_SIZE=29545414656 TARGET_SIZE=8422162432 REDUCTION=.285058190249148 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP= BACKUP_MODE=1 MOVIEONLY_TYPE=6 USE_LAVF=-1 INSTANCES=1 DGDECNV=0 QUICK=0 ENCODE_STEP=0 REBUILD_COMPLETE=1 COMPLETED=33 [00368] AUDIO=10000 PGS=00000 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=100395360 SPLITS=1 NSIZE=0 FLINK=-1 MLINK=0 [00401] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=33427173 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00370] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=267825460 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00402] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=47128356 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00372] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=45207073 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00403] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=139004918 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00374] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=527359805 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00404] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=53990331 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00376] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=131617524 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00405] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=46961973 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00378] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=182273194 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00406] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=86825532 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00380] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=131074590 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00407] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=55683933 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00382] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=289847533 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00408] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=30966460 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00384] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=111467695 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00409] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=28246539 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00386] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=205339100 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00410] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=25719273 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00387] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=659486985 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00411] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=67176603 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00418] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=324875483 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00417] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=201908112 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00391] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=225632543 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00413] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=65201027 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00393] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1548746817 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00414] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=23780476 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00395] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1040685661 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00415] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=77536120 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00397] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=1074928985 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00416] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=109287205 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 [00399] VIDEO2=0 V2MBRATE=0 M2TS_TARGET=462554594 SPLITS=1 AUDIO=10000 NSIZE=0 FLINK=-1 MLINK=0 Code:
- Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [4422], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - BD Rebuilder v0.42.0.8, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok Last edited by HatchetMan; 10th January 2013 at 07:13. |
10th January 2013, 17:32 | #16469 | Link | |
If this happened to me I would first suspect some corruption of the original rip. I'd try cleaning the disc and ripping again. Even though the rip might play OK, there might be a slight glitch that gets through without posting an error amd is hard to see but causes trouble with the rebuild. It's happened to me -- not a green screen but a frozen image. |
11th January 2013, 05:44 | #16472 | Link |
It was the autocrop filter once again that was at fault. I redid it all forgetting to set that because it had very small black bars top & bottom I wanted removed. The result was perfect, except for the black bars that didn't get removed. Such a great feature when it works...
11th January 2013, 11:08 | #16473 | Link |
Save Existing Project Bug
When I try to save to an existing project (overwrite) I get this error:
Run-time error '9': Subscript out of range with version 0.42.08 on windows 8 Pro. Edit: This only happens when source path is empty. Last edited by AGKnotUser; 11th January 2013 at 11:14. |
11th January 2013, 16:30 | #16474 | Link | |
12th January 2013, 20:52 | #16476 | Link |
I admit to being a novice and this could be something other than a bug, but here are my results from my first attempt. The source info from the readme that came with the download:
Video #0 ID : 4113 (0x1011) MenuID/String : 1 (0x1) Codec : AVC Codec/Family : AVC Codec/Info : Advanced Video Codec Codec profile : Main@L4.0 Codec settings, CABAC : Yes Codec_Settings_RefFrames : 4 Width : 1280 pixels Height : 720 pixels Display Aspect ratio : 16/9 Frame rate : 59.940 fps Chroma : 4:2:0 Interlacement : Progressive Language : English Audio #0 ID : 4352 (0x1100) MenuID/String : 1 (0x1) Codec : AC3 Bit rate mode : CBR Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Rear: L R, LFE Sampling rate : 48.0 KHz Video0 delay : 17ms Language : English And the BD_RB log results: [01/12/13] BD Rebuilder v0.42.08 (beta) [13:21:44] Source: THE_ROLLING_STONES_–_ONE_MORE_SHOT_LIVE_2012_(HD)_00000 - Input BD size: 5.06 GB - Approximate total content: [02:35:25.520] - Target BD size: 4.36 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Auto Quality: High Quality (Default), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [13:21:50] PHASE ONE, Encoding - [13:21:50] Processing: VID_00000 (1 of 1) - [13:21:50] Extracting A/V streams [VID_00000] - [13:35:00] Reencoding video [VID_00000] - Error: Video framerate is illegal/unknown. [13:35:00] - Failed video encode, aborted Any help in getting past this point would be appreciated.
TheTooleMan |
12th January 2013, 21:44 | #16478 | Link |
I haven't seen "HD" in any blu-ray disc title. OBVIOUSLY it would be HD. I doubt very seriously that they'd use that scheme Must be an import, eh?
13th January 2013, 02:11 | #16480 | Link |
The input size would be highly irregular, but I'd hardly call that conclusive I've seen BD discs that were no larger than 11Gb. Which would make the input Video stream smaller.
Since it has a substantial run time though (2.5+hrs), I would highly doubt it's original.
Only one rooster, need be in the hen house... Last edited by omegaman7; 13th January 2013 at 02:15. |
