Old 4th November 2019, 22:28   #6841  |  Link
Klaus1189
I cannot find a problem of syntax of the file, but for grammar mistakes I can not help because I don’t understand that language
Please check the new translation when a nightly build is available if every new string is correct and no typo is in the translation. I must also say, well done many translated strings, I know how time consuming that is but MPC-BE is worth every minute I spent for the translation. Coded with passion for perfection by the devs
Old 4th November 2019, 23:34   #6842  |  Link
s0meone_new
Yes, yes and YES!
Tomorrow it will be completely ready.
Cool?
Please check it out: https://www105.zippyshare.com/v/KgEfERMY/file.html
90% it will be complete tomorrow.
s0meone_new is offline   Reply With Quote
Old 5th November 2019, 21:46   #6843  |  Link
Liisachan
李姗倩 Lǐ Shān Qiàn
Liisachan's Avatar
mp4 source filter: minor problem
When MP4 has 2 or more cover arts, [Shift]+[F10] -> resources shows only one (the first?) embedded file, if the internal MP4/MOV source filter is enabled in MPC-BE. If the internal filter is disabled (MPC-BE + LAV) or MPC-HC is used, you can see all embedded files via [Shift]+[F10].
Not a big problem at all; happened to notice.
Sample MP4 (55 KiB) with 2 cover arts (PNG, Jpeg)
Liisachan is offline   Reply With Quote
Old 6th November 2019, 00:01   #6844  |  Link
s0meone_new
Hungarian translation finished!
https://www101.zippyshare.com/v/pSDLUE88/file.html
Old 6th November 2019, 06:05   #6845  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Thanks - fixed
Old 6th November 2019, 13:03   #6846  |  Link
v0lt
@s0meone_new
Thank. Updated in r4885.
Old 7th November 2019, 00:04   #6847  |  Link
s0meone_new
where is the r4885 installer available? I can't verify it.
Old 7th November 2019, 00:09   #6848  |  Link
Wait, they will update. Beta links a page or two back.
Old 7th November 2019, 12:45   #6849  |  Link
Liisachan
李姗倩 Lǐ Shān Qiàn
Liisachan's Avatar
Originally Posted by Aleksoid1978 View Post
Thanks - fixed
Tested 4885 with a sample MP4 (no video, silent audio + 3 cover arts in BMP/PNG/JPG). Everything works fine! Thanks
But I have 2 questions:
1) dataType 0x1b (for BMP) seems undocumented. do we really have to support non-standard BMP cover arts? It won't hurt though...
2) does the GETU32(db->GetData()) check in MP4Splitter.cpp necessary? I'm guessing something like this might be simpler and quicker:
if (dataType == 0x0d) { /* jpeg */ }
else if (dataType == 0x0e) { /* png */ }
else if (dataType == 0x1b) { /* bmp */ } // if to be supported at all
Old 7th November 2019, 14:01   #6850  |  Link
Aleksoid1978
Why it for you ?
Old 7th November 2019, 14:11   #6851  |  Link
Liisachan
李姗倩 Lǐ Shān Qiàn
Liisachan's Avatar
Why it for you ?
I'm not sure if I'm understanding correctly, but currently we're reading the first 4 bytes "sync" from the image data, and we decide it's JPEG if (sync & 0x00ffffff) == 0x00FFD8FF, and it's PNG if sync == MAKEFOURCC(0x89, 'P', 'N', 'G').
Isn't it faster and cleaner to just use the variable dataType, without actually peeking into the image raw data?
Old 8th November 2019, 00:46   #6852  |  Link
s0meone_new
I checked the Hungarian translation in r4885. I fixed some things.
https://www77.zippyshare.com/v/3FVSmk2u/file.html
Old 8th November 2019, 09:48   #6853  |  Link
Aleksoid1978
ffmpeg also with checking data type - also check first bytes from data
Old 8th November 2019, 14:04   #6854  |  Link
Grimsdyke
Is 'jump to: frame' currently broken ?? No problems with HC.
Would it be possible to also implement a 'frame backwards' function ??
Old 8th November 2019, 14:20   #6855  |  Link
control arrow key left.
huhn is online now   Reply With Quote
Old 8th November 2019, 15:17   #6856  |  Link
Liisachan
李姗倩 Lǐ Shān Qiàn
Liisachan's Avatar
I guess there is some historical reason, then. Checking the image data helps if the tagging tool is broken and doesn't write the atom flag properly (0x0d for Jpeg, 0x0e for PNG). Probably ffmpeg devs had such broken samples and decided that they couldn't trust the atom flag.
Not a big problem Everything is working for me anyway. Thanks again!
Old 9th November 2019, 06:52   #6857  |  Link
v0lt
@s0meone_new
Thank. Updated in r4887.
Old 9th November 2019, 08:16   #6858  |  Link
s0meone_new
v0lt:
Thank. I checked it. The last fix:
https://www55.zippyshare.com/v/YaSx3d1q/file.html
Thanks for everything. All the best.
Old 9th November 2019, 16:47   #6859  |  Link
Klaus1189
I beg for a new Nightly build of MPC Video Renderer, mine is several days old
Old 9th November 2019, 19:20   #6860  |  Link
v0lt
@Klaus1189
MPCVideoRenderer-v0.3.3.934_git2019.11.08-e04319e was uploaded yesterday.
@s0meone_new
Translation updated in r4889.
MPCVideoRenderer-v0.3.3.936_git2019.11.09-3dcf99a
