Old 5th January 2019, 14:50   #4381  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
In what sense is it bad practice? I mean, I'm already "abusing" the video frame by passing non-video data (although it is pixel-to-pixel related, more or less). I don't think that there being a more formal alternative which Avisynth+ doesn't have is really an objection, per se.
What are hints, and how are they implemented?
wonkey_monkey is offline
Old 5th January 2019, 14:52   #4382  |  Link
pinterf
Nekopanda fork (Avisynth Neo a.k.a Avs CUDA) implemented frame properties.
pinterf is offline
Old 6th January 2019, 00:19   #4383  |  Link
StainlessS
StainlessS's Avatar
Dont know much about this (I'm sure someone will correct if wrong), but think that the hints are 64 bits encoded in LSB (Least Significant Bit) of the top LHS row of 64 pixels. [what they represent, I dont know, I guess is implementation defined (maybe in luma channel only, dont know)].
EDIT: Methinks that DGIndex embeds some hint stuff, maybe see source. (also TFM I think).
EDIT: Here from DGindex source (looks like only storing 32 bits of colorimetry data there [with additional 32 bits of magic number to signify valid hint]).
Utilities.h
bool PutHintingData(unsigned char *video, unsigned int hint);
bool GetHintingData(unsigned char *video, unsigned int *hint);
#define HINT_INVALID 0x80000000
#define PROGRESSIVE  0x00000001
#define IN_PATTERN   0x00000002
#define COLORIMETRY  0x0000001C
#define COLORIMETRY_SHIFT  2
Utilities.cpp
#include <windows.h>
#define MAGIC_NUMBER (0xdeadbeef)
	unsigned char *p;
	unsigned int i, magic_number = MAGIC_NUMBER;
	bool error = false;
	p = video;
	for (i = 0; i < 32; i++)
		*p &= ~1;
		*p++ |= ((magic_number & (1 << i)) >> i);    // 1st 32 bits of Magic number validity flag
		*p &= ~1;
		*p++ |= ((hint & (1 << i)) >> i);            // 2nd 32 bits of colorimetry data
	return error;
	unsigned char *p;
	unsigned int i, magic_number = 0;
	bool error = false;
	p = video;
		magic_number |= ((*p++ & 1) << i);
	if (magic_number != MAGIC_NUMBER)
		error = true;
	else
		*hint = 0;
			*hint |= ((*p++ & 1) << i);
	return error;
AvisynthAPI.cpp
PVideoFrame __stdcall MPEG2Source::GetFrame(int n, IScriptEnvironment* env)
	int gop, pct;
	char Matrix_s[40];
	unsigned int raw;
	unsigned int hint;
	else if (m_decoder.info == 3)
		hint = 0;
		if (m_decoder.FrameList[raw].pf == 1) hint |= PROGRESSIVE;
		hint |= ((m_decoder.GOPList[gop]->matrix & 7) << COLORIMETRY_SHIFT);
		PutHintingData(frame->GetWritePtr(PLANAR_Y), hint);
EDIT: The hint encoder/decoder would be in the duplicated DGDecode.dll source.
EDIT: GetHintingData() seems not to be used in DGIndex source code, (probably some duplication in DGDecode::Mpeg2Source).
I sometimes post sober.
StainlessS is offline
Old 6th January 2019, 03:07   #4384  |  Link
wonkey_monkey
Ah, then not an option in this case as changing any bits would break it. I could add another row, but that seems wrong somehow, since the video (more or less) represents pixel data. I went with the GetAudio route and it works well.
Old 7th January 2019, 17:26   #4385  |  Link
TheFluff
Excessively jovial fellow
Is a usseless option.
Who know the ChannelMask of a audio are the decoders, do you know any decoder (ffms2.dll, LSMASHSource.dll, NicAudio.dll, ...) than set ChannelMask to the appropiate value?
There are any audio encoder/player, than accept avs input, than use that global variable if defined?
Also, if there are two, or more, audios processed at same time, how we can distinguise both?
The ChannelMask must be a property of each audio clip.
FFMS sets the script variable FFCHANNEL_LAYOUT which contains the dwChannelMask. You can get one variable per clip using the varprefix option if you like.
Before I go ahead and do this, can anyone raise any objections to the idea of using an audio channel to pass metadata? My filter passes data through the video frame, but it also needs to send a few bytes of metadata with it, so my plan is to override GetAudio and just paste those bytes into the buffer. The other filter in the partnership will then call GetAudio to get the metadata.
Good idea? Bad idea?
num_audio_samples is a 64-bit integer. It's like it was made to use as an arbitrary pointer! Distinguishing a valid pointer from any other arbitrary integer is left as an exercise for the reader.
Seriously though, putting arbitrary data in the audio stream is dumb but about par for the course by Avisynth plugin coding standards. I'm pretty sure it's been done before by other plugins. You could serialize the data and put it in a script variable, but it's not really worth the effort.
TheFluff is offline
Old 7th January 2019, 17:51   #4386  |  Link
Stereodude
This script crashes for me using AVSynth+ when loading it in VD2 x64 once LEN is somewhere between 15900-16000. It will crash loading it in AVSmeter (x64) as well when LEN is a slightly lower frame number. I think there's some sort of internal overflow. I was using r2700, but I've since upgraded to r2772. Both do the same thing. There's no popup or error message. VD2x64 just disappears. AVSmeter (x64) just kicks back to the command prompt after getting to the "prescanning script..." message very briefly.
Using the x86 version of AVIsynth+ allows LEN to be larger than the x64 version, but fails by 19000.
LEN2=103848
LEN=15900
A=BlankClip(Length=LEN2, height=786, width=1920, Pixel_type="YV12",COLOR=$FF0000).ShowFrameNumber
B=BlankClip(Length=LEN2, height=786, width=1920, Pixel_type="YV12",COLOR=$00FF00).ShowFrameNumber
Z = A.BlankClip(Length=0)
frame=0
while( frame < LEN) {
for(n=2, 958, 2) {
	Z = Z ++ stackhorizontal(stackhorizontal(A.crop(0,0,n,-0),B.crop(n,0,960,-0)),A.crop(960+n,0,-0,-0)).trim(frame,end=frame)
	frame = frame + 1
	if ( frame == LEN) { Return Z }
for(n=958, 2, -2) {
	frame = frame + 1
Return Z
My computer is running Windows 10 Pro and has 32GB of RAM.
Stereodude is offline
Old 7th January 2019, 19:56   #4387  |  Link
pinterf
LEN2=103848
LEN=15900
frame=0
for(n=2, 958, 2) {
	frame = frame + 1
for(n=958, 2, -2) {
	frame = frame + 1
Return Z
Finally it fails in Splice::GetFrame.
0xC0000005: Access violation writing location 0x0000000001200000.
and
0xC00000FD: Stack overflow (parameters: 0x0000000000000001, 0x0000000001203FF0).
Loops in Avisynth are much like unrolled loops.
The filter chain of this huge while loop is looking like Splice calling previous Splice calling previous Splice calling...
Even the debugger is giving up showing the stack frame:
"Maximum number of stack frames supported by Visual Studio has been exceeded"
So I think the loops can help only when they are relatively short.
pinterf is offline
Old 7th January 2019, 20:10   #4388  |  Link
TheFluff
LEN2=103848
LEN=15900
frame=0
for(n=2, 958, 2) {
	frame = frame + 1
for(n=958, 2, -2) {
	frame = frame + 1
Return Z
Don't try to write procedural code in a functional language.
TheFluff is offline
Old 7th January 2019, 21:02   #4389  |  Link
Stereodude
Well, I'm not sure how to do what I want written in a functional language using the AVIsynth functions and plugins that are available. I guess I will have to play around with using ConditionalReader to replace the inner two for loops so that there aren't 10's of thousands of splices.
Old 7th January 2019, 21:07   #4390  |  Link
wonkey_monkey
I'd recommend rgba_rpn for this kind of thing, but the learning curve is somewhat precipitous and I've pretty much rewritten the entire thing since then so even I may not be of much help...
Actually masktools or even just Avisynth+'s expr might be better.
Old 7th January 2019, 21:21   #4391  |  Link
Stereodude
I took a brief look at masktools the other day at it and didn't seem like I could do this sort of effect using it without having a video that's the dynamic moving mask.
I'm not familiar with expr. I'll have to look into that.
Old 7th January 2019, 21:38   #4392  |  Link
wonkey_monkey
You could start with a half-white, half-black clip and use animate and pointresize to shift it left and right. I think it'll still be invoking a lot of filter instances though, so expr makes a bit more sense (although it's not as efficient as it could be in this case).
In fact, consider using expr to create a 1-pixel high sliding bar clip and then pointresize it up to full height.
Old 7th January 2019, 23:34   #4393  |  Link
Stereodude
I'll admit I've never used expr and I haven't the foggiest idea how to create that 1-pixel high sliding bar clip with it.
My original idea of replacing the for loops didn't work. Well, I should clarify that... I was able to replace the two for loops with ScriptClip + ConditionalReader (the core piece), but it seems that the use of ScriptClip + ConditionalReader multiple times in a script with the same variable names doesn't work as expected so a loop of multiple instance fails. That would only have ~109 splices instead of 103848 (presumably not crashing).
For example:
LEN=103848
mini_length=956
Asrc=BlankClip(Length=LEN, height=786, width=1920, Pixel_type="YV12",COLOR=$FF0000).ShowFrameNumber
Bsrc=BlankClip(Length=LEN, height=786, width=1920, Pixel_type="YV12",COLOR=$00FF00).ShowFrameNumber
Loop_cnt=0
A=Asrc.trim(Loop_cnt*mini_length, ((Loop_cnt+1)*mini_length-1))
B=Bsrc.trim(Loop_cnt*mini_length, ((Loop_cnt+1)*mini_length-1))
ScriptClip(A, """
ConditionalReader("slide.txt", "n", false)
Y = last
Loop_cnt = Loop_cnt + 1
ScriptClip(A, """
Z = last
return Y
#return Z
I don't understand why Y and Z are identical. If either of the two code blocks are commented out Y/Z are what is expected, or if the variable names in each block are unique (like A0, B0 in the first and A1, B1 in the second) Y & Z are what is expected. But with limitation I can't use a for or while loop to do this 109 times or even do a manual unroll with copy and paste without making every iteration unique.
slide.txt:
Type int
0	2
1	4
2	6
3	8
4	10
5	12
6	14
7	16
8	18
9	20
10	22
11	24
12	26
13	28
14	30
15	32
16	34
17	36
18	38
19	40
20	42
21	44
22	46
23	48
24	50
25	52
26	54
27	56
28	58
29	60
30	62
31	64
32	66
33	68
34	70
35	72
36	74
37	76
38	78
39	80
40	82
41	84
42	86
43	88
44	90
45	92
46	94
47	96
48	98
49	100
50	102
51	104
52	106
53	108
54	110
55	112
56	114
57	116
58	118
59	120
60	122
61	124
62	126
63	128
64	130
65	132
66	134
67	136
68	138
69	140
70	142
71	144
72	146
73	148
74	150
75	152
76	154
77	156
78	158
79	160
80	162
81	164
82	166
83	168
84	170
85	172
86	174
87	176
88	178
89	180
90	182
91	184
92	186
93	188
94	190
95	192
96	194
97	196
98	198
99	200
100	202
101	204
102	206
103	208
104	210
105	212
106	214
107	216
108	218
109	220
110	222
111	224
112	226
113	228
114	230
115	232
116	234
117	236
118	238
119	240
120	242
121	244
122	246
123	248
124	250
125	252
126	254
127	256
128	258
129	260
130	262
131	264
132	266
133	268
134	270
135	272
136	274
137	276
138	278
139	280
140	282
141	284
142	286
143	288
144	290
145	292
146	294
147	296
148	298
149	300
150	302
151	304
152	306
153	308
154	310
155	312
156	314
157	316
158	318
159	320
160	322
161	324
162	326
163	328
164	330
165	332
166	334
167	336
168	338
169	340
170	342
171	344
172	346
173	348
174	350
175	352
176	354
177	356
178	358
179	360
180	362
181	364
182	366
183	368
184	370
185	372
186	374
187	376
188	378
189	380
190	382
191	384
192	386
193	388
194	390
195	392
196	394
197	396
198	398
199	400
200	402
201	404
202	406
203	408
204	410
205	412
206	414
207	416
208	418
209	420
210	422
211	424
212	426
213	428
214	430
215	432
216	434
217	436
218	438
219	440
220	442
221	444
222	446
223	448
224	450
225	452
226	454
227	456
228	458
229	460
230	462
231	464
232	466
233	468
234	470
235	472
236	474
237	476
238	478
239	480
240	482
241	484
242	486
243	488
244	490
245	492
246	494
247	496
248	498
249	500
250	502
251	504
252	506
253	508
254	510
255	512
256	514
257	516
258	518
259	520
260	522
261	524
262	526
263	528
264	530
265	532
266	534
267	536
268	538
269	540
270	542
271	544
272	546
273	548
274	550
275	552
276	554
277	556
278	558
279	560
280	562
281	564
282	566
283	568
284	570
285	572
286	574
287	576
288	578
289	580
290	582
291	584
292	586
293	588
294	590
295	592
296	594
297	596
298	598
299	600
300	602
301	604
302	606
303	608
304	610
305	612
306	614
307	616
308	618
309	620
310	622
311	624
312	626
313	628
314	630
315	632
316	634
317	636
318	638
319	640
320	642
321	644
322	646
323	648
324	650
325	652
326	654
327	656
328	658
329	660
330	662
331	664
332	666
333	668
334	670
335	672
336	674
337	676
338	678
339	680
340	682
341	684
342	686
343	688
344	690
345	692
346	694
347	696
348	698
349	700
350	702
351	704
352	706
353	708
354	710
355	712
356	714
357	716
358	718
359	720
360	722
361	724
362	726
363	728
364	730
365	732
366	734
367	736
368	738
369	740
370	742
371	744
372	746
373	748
374	750
375	752
376	754
377	756
378	758
379	760
380	762
381	764
382	766
383	768
384	770
385	772
386	774
387	776
388	778
389	780
390	782
391	784
392	786
393	788
394	790
395	792
396	794
397	796
398	798
399	800
400	802
401	804
402	806
403	808
404	810
405	812
406	814
407	816
408	818
409	820
410	822
411	824
412	826
413	828
414	830
415	832
416	834
417	836
418	838
419	840
420	842
421	844
422	846
423	848
424	850
425	852
426	854
427	856
428	858
429	860
430	862
431	864
432	866
433	868
434	870
435	872
436	874
437	876
438	878
439	880
440	882
441	884
442	886
443	888
444	890
445	892
446	894
447	896
448	898
449	900
450	902
451	904
452	906
453	908
454	910
455	912
456	914
457	916
458	918
459	920
460	922
461	924
462	926
463	928
464	930
465	932
466	934
467	936
468	938
469	940
470	942
471	944
472	946
473	948
474	950
475	952
476	954
477	956
478	958
479	956
480	954
481	952
482	950
483	948
484	946
485	944
486	942
487	940
488	938
489	936
490	934
491	932
492	930
493	928
494	926
495	924
496	922
497	920
498	918
499	916
500	914
501	912
502	910
503	908
504	906
505	904
506	902
507	900
508	898
509	896
510	894
511	892
512	890
513	888
514	886
515	884
516	882
517	880
518	878
519	876
520	874
521	872
522	870
523	868
524	866
525	864
526	862
527	860
528	858
529	856
530	854
531	852
532	850
533	848
534	846
535	844
536	842
537	840
538	838
539	836
540	834
541	832
542	830
543	828
544	826
545	824
546	822
547	820
548	818
549	816
550	814
551	812
552	810
553	808
554	806
555	804
556	802
557	800
558	798
559	796
560	794
561	792
562	790
563	788
564	786
565	784
566	782
567	780
568	778
569	776
570	774
571	772
572	770
573	768
574	766
575	764
576	762
577	760
578	758
579	756
580	754
581	752
582	750
583	748
584	746
585	744
586	742
587	740
588	738
589	736
590	734
591	732
592	730
593	728
594	726
595	724
596	722
597	720
598	718
599	716
600	714
601	712
602	710
603	708
604	706
605	704
606	702
607	700
608	698
609	696
610	694
611	692
612	690
613	688
614	686
615	684
616	682
617	680
618	678
619	676
620	674
621	672
622	670
623	668
624	666
625	664
626	662
627	660
628	658
629	656
630	654
631	652
632	650
633	648
634	646
635	644
636	642
637	640
638	638
639	636
640	634
641	632
642	630
643	628
644	626
645	624
646	622
647	620
648	618
649	616
650	614
651	612
652	610
653	608
654	606
655	604
656	602
657	600
658	598
659	596
660	594
661	592
662	590
663	588
664	586
665	584
666	582
667	580
668	578
669	576
670	574
671	572
672	570
673	568
674	566
675	564
676	562
677	560
678	558
679	556
680	554
681	552
682	550
683	548
684	546
685	544
686	542
687	540
688	538
689	536
690	534
691	532
692	530
693	528
694	526
695	524
696	522
697	520
698	518
699	516
700	514
701	512
702	510
703	508
704	506
705	504
706	502
707	500
708	498
709	496
710	494
711	492
712	490
713	488
714	486
715	484
716	482
717	480
718	478
719	476
720	474
721	472
722	470
723	468
724	466
725	464
726	462
727	460
728	458
729	456
730	454
731	452
732	450
733	448
734	446
735	444
736	442
737	440
738	438
739	436
740	434
741	432
742	430
743	428
744	426
745	424
746	422
747	420
748	418
749	416
750	414
751	412
752	410
753	408
754	406
755	404
756	402
757	400
758	398
759	396
760	394
761	392
762	390
763	388
764	386
765	384
766	382
767	380
768	378
769	376
770	374
771	372
772	370
773	368
774	366
775	364
776	362
777	360
778	358
779	356
780	354
781	352
782	350
783	348
784	346
785	344
786	342
787	340
788	338
789	336
790	334
791	332
792	330
793	328
794	326
795	324
796	322
797	320
798	318
799	316
800	314
801	312
802	310
803	308
804	306
805	304
806	302
807	300
808	298
809	296
810	294
811	292
812	290
813	288
814	286
815	284
816	282
817	280
818	278
819	276
820	274
821	272
822	270
823	268
824	266
825	264
826	262
827	260
828	258
829	256
830	254
831	252
832	250
833	248
834	246
835	244
836	242
837	240
838	238
839	236
840	234
841	232
842	230
843	228
844	226
845	224
846	222
847	220
848	218
849	216
850	214
851	212
852	210
853	208
854	206
855	204
856	202
857	200
858	198
859	196
860	194
861	192
862	190
863	188
864	186
865	184
866	182
867	180
868	178
869	176
870	174
871	172
872	170
873	168
874	166
875	164
876	162
877	160
878	158
879	156
880	154
881	152
882	150
883	148
884	146
885	144
886	142
887	140
888	138
889	136
890	134
891	132
892	130
893	128
894	126
895	124
896	122
897	120
898	118
899	116
900	114
901	112
902	110
903	108
904	106
905	104
906	102
907	100
908	98
909	96
910	94
911	92
912	90
913	88
914	86
915	84
916	82
917	80
918	78
919	76
920	74
921	72
922	70
923	68
924	66
925	64
926	62
927	60
928	58
929	56
930	54
931	52
932	50
933	48
934	46
935	44
936	42
937	40
938	38
939	36
940	34
941	32
942	30
943	28
944	26
945	24
946	22
947	20
948	18
949	16
950	14
951	12
952	10
953	8
954	6
955	4
Old 8th January 2019, 00:55   #4394  |  Link
wonkey_monkey
X=480
blankclip(width=960,height=1080,length=X)
stackhorizontal(last,last.invert,last)
animate(last,0,X-1,"crop",0,0,1920,0,960,0,1920,0)
mask=(last+last.reverse).loop(100)
a=colorbars(width=1920,height=1080)
b=version.pointresize(1920,1080)
overlay(a,b,mask=mask)
Old 8th January 2019, 05:08   #4395  |  Link
Stereodude
X=480
There's a few minor "mistakes" in there with the motion of the mask (I had a similar mistake in my example also) and I wanted to start the mask on the other side, but I certainly wouldn't have been able to put together that combo of filters myself. Big !
I think this is corrected
X=480
blankclip(width=960,height=1080,length=X+1)
clip1=stackhorizontal(last,last.invert,last)
clip2=clip1.trim(0,X-2)
mask=(animate(clip1,0,X,"crop",960,0,1920,0,0,0,1920,0)+animate(clip2,0,X-1,"crop",2,0,1920,0,960,0,1920,0)).loop(100)
Old 19th January 2019, 23:30   #4396  |  Link
wonkey_monkey
Another stupid question, mostly out of curiosity...
I'm writing another filter which abuses GetAudio (I have my reasons!). If I call
child->GetAudio(buffer, start, 1, env)
on a clip created by filter, I get the debug output I expect (which proves that GetAudio has been called). However, if I call
child->GetAudio(buffer, start, 0, env)
my GetAudio is seemingly not called.
I'm not 100% with the fine details of classes and overloading. What is it that stops Avisynth from calling my GetAudio when count=0?
Old 20th January 2019, 00:18   #4397  |  Link
StainlessS
StainlessS's Avatar
Perhaps Audio Cache swallows the call, and does not call your upstream filter but returns immediately (no idea really).
EDIT: You got some [additional] source at all ?
Old 20th January 2019, 00:29   #4398  |  Link
wonkey_monkey
This is my GetAudio:
void __stdcall tracker::GetAudio(void* buffer, __int64 start, __int64 count, IScriptEnvironment* env) {
	debug("GetAudio: %d,%d", start, count);
	if (start == -0x5452414b) {
		switch (count) {
			case 0: {
				*((int*)buffer) = 0x5452414b;
			} break;
	} else {
		child->GetAudio(buffer, start, count, env);
and this is my call to GetAudio, in the constructor of another filter:
		int check = 0;
		child->GetAudio(&check, 0x5452414b, 0, env);
		debug("%d", check);
Edit: so does this mean there's something between calling child->GetAudio and my function actually being called, which is rejecting out-of-range values? Hmm... some thinking is required.
Old 20th January 2019, 01:29   #4399  |  Link
StainlessS
StainlessS's Avatar
Dont use %d for __int64, use %I64d, or results will be wrong:- https://docs.microsoft.com/en-us/cpp...s?view=vs-2017
Well there is some stuff in source about audio cache, but no idea how it works.
enum {
  CACHE_NOTHING=0,
  CACHE_RANGE=1,
  CACHE_ALL=2,
  CACHE_AUDIO=3,
  CACHE_AUDIO_NONE=4,
  CACHE_AUDIO_AUTO=5
EDIT: Oops yep, %I64d or eg %I64X.
Old 20th January 2019, 01:40   #4400  |  Link
wonkey_monkey
Dont use %d for __int64, use %I64, or results will be wrong:- https://docs.microsoft.com/en-us/cpp...s?view=vs-2017
%I64d - %I64 is a prefix. But it's only for debugging so truncation doesn't matter.
If I only put %I64 it crashes VirtualDub2 completely. You'd think things like (vs)printf(_s) would be a little more robust...
