7th November 2019, 05:28 | #17681 | Link |
Grumpy Old Man.
So I'm doing some more 4K encoding today, and I have been having some problems with the connection to some of the DE servers, in the other room....wasn't happening yesterday....
I got these errors, and wondering what might be causing them :- [7/11/2019 13:35:33] TCPClient7 raised exception while attempting to sent command.(Not Connected) [7/11/2019 13:35:47] TCPClient10 raised exception while attempting to sent command.(Not Connected) [7/11/2019 13:40:00] TCPClient8 raised exception while attempting to sent command.(Not Connected) [7/11/2019 13:40:00] TCPClient7 raised exception while attempting to sent command.(Not Connected) [7/11/2019 13:46:06] TCPClient12 raised exception while attempting to sent command.(Not Connected) [7/11/2019 13:46:30] TCPClient12 raised exception while attempting to sent command.(Not Connected) [7/11/2019 13:56:27] TCPClient13 raised exception while attempting to sent command.(Not Connected) [7/11/2019 13:57:53] TCPClient9 raised exception while attempting to sent command.(Not Connected) But it seems to be going OK now, I think it takes a while for the process to "warm up". Another thing I've noticed that might be associated with this, is some chunks will get to a certain %, and just stall there And with all the chunks "flashing" is some way of showing that they are processing, it's a bit hard to focus in on which ones are doing this. Not sure if the chunk "line's" are suppose to flash, but it would be a lot easier on the eyes if maybe they changed font size and/or colour, and NOT flash....just as well I'm not "epileptic". And I have a feature request for chunks....it would be handy to have a small display of how many "chunks" are being processed, instead of having to count them. And to top it off, how about some more DE servers, say another 4, at least. Need all the help I can get, and I have more pc's I could add to the 4K process. And no I don't like the idea of running separate sessions with different pc's, that really doesn't speed up my process...I just want to get it done one "system", as fast as possible !!! I do smaller basic encodes on separate pc's.
7th November 2019, 09:44 | #17683 | Link | |
7th November 2019, 10:35 | #17684 | Link | |
Grumpy Old Man.
I have to agree that it's certainly a network / cable problem, I had to swap out a patch cable yesterday, as it was dropping in & out, causing problems. Just out of interest, what 10 Gbe NIC's are you running ?? do you use RJ45 or SFP+ connections ?? I'm gradually setting up a 10 Gbe LAN, and mainly using Mellanox NIC's. (but not for RB)
7th November 2019, 13:26 | #17685 | Link | |
Then using nmap, see if the Encoding Server ports are open on your other machines. I would run command like this from Linux: nmap -p 1000,2000,3000,4000 192.168.9.7 My results look like this: nmap -p 1000,2000,3000,4000 192.168.9.7 Starting Nmap 7.80 ( https://nmap.org ) at 2019-11-07 05:22 MST Nmap scan report for taffy (192.168.9.7) Host is up (0.0023s latency). PORT STATE SERVICE 1000/tcp open cadlock 2000/tcp filtered cisco-sccp 3000/tcp filtered ppp 4000/tcp filtered remoteanything Nmap done: 1 IP address (1 host up) scanned in 1.25 seconds I'm running one Encoding Server on that client. The scan shows port 1000 as open, and the other ports as filtered. Filtered will be either there is nothing listening on those ports or a firewall has filtered them. That will at least tell you if you have some kind of network problem. |
7th November 2019, 13:39 | #17686 | Link | |
ByteShare
7th November 2019, 14:43 | #17687 | Link | |
Grumpy Old Man.
I DO have that on EVERY PC, and tbh, I don't think it works that well.
7th November 2019, 14:48 | #17688 | Link |
Do ffmpeg.exe and x26x.exe still use cpu when this happens?
7th November 2019, 22:25 | #17689 | Link | |
I use RJ45 cable and a 8 port buffalo switch (mp2008). |
8th November 2019, 00:58 | #17690 | Link | |
Grumpy Old Man.
I'm using SFP+ cables & NIC's, with a MikroTik 8 port switch. You didn't mention what NIC's you're using...
8th November 2019, 01:03 | #17691 | Link | |
Grumpy Old Man.
I wouldn't really know what I was looking for, anyway. I just watched the stalled chunk/server, for a couple of minutes, and when it hadn't progressed, I simply stopped it, and let another server take over. I DID (once) have pop error msg stating that Encoder Stalled, and I think it was in relation to FFMPEG or similar, didn't stay up for long. I'm using the very latest RB build, and I am going to update all my NIC drivers today, probably won't affect this...but good to do.
8th November 2019, 10:28 | #17693 | Link |
Grumpy Old Man.
So just a simple P2P connection between them, then.
Are you planning to expand to other pc's ?? To get the best out of 10 Gbe, you need fast drives @ both ends. I'm just starting out with 10 Gbe, and the transfer speeds vary a LOT.
8th November 2019, 21:43 | #17695 | Link | |
Got 2 SSD in Raid 0 for Encoding and processing files. It gives me 1200mb/s of read/write speed. On my nas its just 4x10GB Ironwolf disc in Raid 5 (can be expanded to 8 disc). |
9th November 2019, 00:45 | #17696 | Link | |
Grumpy Old Man.
Can't wait to check this out
9th November 2019, 11:56 | #17697 | Link | ||
I got this result: Quote:
9th November 2019, 12:10 | #17698 | Link |
You were supposed to do that test from work-pc to home-pc. (192.168.88.178)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 9th November 2019 at 12:12. |
9th November 2019, 18:52 | #17699 | Link | |
From server machine:
http://mammutmail.com/hu/download/aa...1b3c97600352e6 Last edited by mparade; 9th November 2019 at 18:56. |
9th November 2019, 19:47 | #17700 | Link |
Ask your admin for help. I guess that your vpn has been configured to block uncommon ports (1001,1002,1003 and so on). Weird stuff...
Next time use www.postimage.org site for images because that full screen adv is driving me crazy
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 9th November 2019 at 22:43. |
