29th August 2020, 08:03 | #24021 | Link |
Use a better video renderer. There are no plans to add something like this.
29th August 2020, 10:08 | #24022 | Link |
Not critical, the last couple of years the built-in PotPlayer filters have reached the level that suits me and there is a constant positive dynamics. The need to use LAV Filters, previously absolutely necessary, is constantly decreasing.
29th August 2020, 14:46 | #24023 | Link |
ангел смерти
Overlay Mixer has been deprecated since 2001; it's now 2020, it's long since time to move on. Overlay is great because you hardly have to do anything, the driver takes care of everything. But Overlay means you can't customize anything, because the driver takes care of everything.
Plus, you know, high bit depth? HDR? Shaders? Things that people might like to have in 2020, that Overlay won't give you. |
29th August 2020, 20:31 | #24026 | Link |
MPEG-4 acceleration is rather buggy, and any modern CPU can decode it without even breaking a sweat, so simply because its easier not to allow it.
31st August 2020, 22:54 | #24028 | Link |
madVR get's kinda nuts with progressive decoded 23p dvds.
the file still get's reported as 29p. with film mode it is switching to 23p "correctly" but according to the OSD it doesn't get a deinterlaced flag so why would it even care about film mode or video mode is it maybe present for 1 frame? so i just want to make sure the frame times are not wrong or something else in the first place before i bring this up to madshi. there doesn't seem to be a difference between hardware and software decode. this doesn't happen when the DVD navigator is used the file is then decoded to 29i with hard telecine. the file has been tested with direct vob file play DVD structure(DVDnavigator) and MKV remux. |
14th September 2020, 13:01 | #24029 | Link |
Hey, that idea never occured to me.
16th September 2020, 06:13 | #24032 | Link |
And for AMD Radeon RX 6000 series of course:
https://www.phoronix.com/scan.php?pa...or-AMD-VCN-3.0
21st September 2020, 22:18 | #24033 | Link |
Is it possible to implement this only for subtitles? That is, there will be no such issues with audio.
R3 3200G / Vega8 / Samsung UE40NU7100 Win11Pro 21H2 / 4K RGB 59Hz / AMD last driver MPC-HC 1.9.17 / madVR 0.92.17 / FSW / SM / 8bit Last edited by DMU; 21st September 2020 at 22:35. |
21st September 2020, 22:54 | #24034 | Link |
The same thing would happen with subtitles, and potentially even more pronounced since subtitles themselves can show for a longer time. You would switch it and only see the switch after several seconds of playback.
The current solution is the best compromise available. A tiny playback glitch when the user presses a button is not very disruptive.
2nd October 2020, 23:24 | #24035 | Link |
I hope someone could develop LAV Filters plug-in for Adobe Audition 2020. Audition doesn't import Dolby, DTS, Bink Media & old QuickTime format & the only plug-in that can do all of this is LAV Filters. Also, what MP3 & AAC decoder FFmpeg uses?
5th October 2020, 13:12 | #24037 | Link | |
https://www.audacityteam.org/ and https://manual.audacityteam.org/man/...r_windows.html |
7th October 2020, 23:30 | #24038 | Link | ||
https://src.infinitewave.ca/ Quality of Audition is so much higher than any editor in that list, even Pro Tools! Pro Tools & Audition are standard in the world like Photoshop! Last edited by PCU; 7th October 2020 at 23:51. |
8th October 2020, 07:33 | #24039 | Link |
MP3 and AAC specifications (and reference software in source) are available and detailed enough to enable developers to write their own code. For these formats, there was certainly no need to disassemble binaries.
And regarding your "standard software hype" ... Premiere used to convert YUV to RGB before applying filters; advantage to AviSynth. Your mentioned site tells little without understanding the mathematical backgrounds of each implementation. Free software can use correct and precise implementations too. And be more user friendly at the same time by not chaining the user to a sadistic payment model. Last edited by LigH; 8th October 2020 at 07:40. |
8th October 2020, 14:13 | #24040 | Link | |
What software do you recommend for editing, ripping & converting audio files, free or commercial. |
