18th August 2019, 13:38 | #561 | Link |
thx, found it later too.
Also found this https://artoriuz.github.io/mpv_upscaling.html FSRCNNX is an upscaler which seems to be similar to NGU (madvr) It can be downloaded here in glsl format: https://github.com/igv/FSRCNN-TensorFlow/releases Maybe Avisynth shader could support glsl in (a not so distant) future EDIT: Ahh finally found the diffenrence between hlsl and glsl (directx vs opengl) https://anteru.net/blog/2016/mapping...HLSL-and-GLSL/ and the future seems to be SPIR-V (vulkan)
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 18th August 2019 at 13:42. |
18th August 2019, 20:22 | #562 | Link |
I managed to make this work with some problems, this is what I have found so far:
- The default precision for ConvertToShader and ConvertFromShader is not 1, so you have to specify it. - The input has to be RGB because otherwise the shader receives YUV channels. - The first shader receives the channels as BGRA. The last shader has to return them as BGRA for RGB32 by changing the order again, or as GBRA for YV12 or YV24. - The Alpha channel can be used to pass data between the shaders, but obviously it is lost at the end. There is no need to compile the shaders. The naive luminance aproximation in the ComputeLum shader doesn't make any sense, doing it the right way compiles to less instructions. Also, these shaders run on screen space so you have to resize before (but if you don't, the effect is quite fun with low-res videos ). |
18th August 2019, 20:48 | #563 | Link | |
But the only thing I had to change was to add Precision=1 in ConvertToShader / ConvertFromShader. Basically it is exactly like the example on github now Input is yv12 and it seems to work. EDIT: But the sharpening effect is a bit too extreme and produces sometimes aliasing. NGU looks much better in the comparison. The good thing is, it's "fast".
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 18th August 2019 at 21:06. |
18th August 2019, 21:25 | #564 | Link |
It works, and the result may even be identical, but it is not correct at all. Use RGB for input and output and change the "float lum ..." line in Anime4K_ComputeLum.hlsl by this:
float lum = (c0[2] + c0[2] + c0[1] + c0[1] + c0[1] + c0[0]) / 6; |
27th August 2019, 02:29 | #566 | Link |
I can't get the Anime4k hlsl to work . "Invalid arguments to function 'Shader'" . I tried different combinations of CK's post 559, and added Precision=1 for ConvertToShader, ConvertFromShader
Can you post a full script? or whatever the "proper" way to use this ? Thanks |
27th August 2019, 04:07 | #567 | Link |
input = FFMS2("video.mkv", colorspace = "RGB32") c = ConvertToShader(input, Precision = 1) Shader(c, "Anime4K_ComputeLum.hlsl", output=2) Shader(last, "Anime4K_Push.hlsl", Clip1 = 2, output = 3) Shader(last, "Anime4K_ComputeGradient.hlsl", Clip1 = 3, output = 4) Shader(last, "Anime4K_PushGrad.hlsl", Clip1 = 4, output = 1) ExecuteShader(last, c, Precision = 3, OutputPrecision = 1) ConvertFromShader(last, Precision = 1, Format = "RGB32") |
6th September 2019, 09:20 | #569 | Link |
@MysteryX
Since I have read that you have said that the bottleneck is memory transfers, I would like to know if the intermediate results are also being transferred. I ask it because using a chain of shaders the GPU load is below 15%, so I wonder if maybe grouping some shaders into a heavier one could be useful to increase performance. |
12th October 2019, 10:32 | #570 | Link |
I'm unable to resize single planes:
ConvertToY() ResizeShader(3840,2160,"bicubic",0,0.4) Code:
CombinePlanes: source bit depth is different from 16 (C:/Program Files (x86)/AviSynth+/plugins64+/Shader.avsi, line 357) (New File (1), line 23) |
12th October 2019, 19:06 | #571 | Link |
MysteryX, (Not on-line since 27 Sept 2019),
Can you update the dead PostImage.org images in first post please. [ Easy to do, just edit the post, and change all PostImage.org to PostImage.cc ] EDIT: Actually, quite a lot of dead images in later posts too. EDIT: Same in FramerateConverter thread and its predecessor thread SVP-like frame interpolation?.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 14th October 2019 at 04:58. |
14th October 2019, 16:10 | #573 | Link |
Thanks for trying Teb.
I dont remember ever seeing the "Image Not Found or Removed" thing (unless it was deleted deliberately by user). When it first happened (maybe 12 to 18 months ago), I spend several days (3 or 4 maybe) altering several hundred url's, and I also altered some only a few days ago to restore some broken images (must have been broken for more than 12 months, they had not been deleted). Thanx again
8th December 2019, 20:50 | #574 | Link |
I'm kind of a noob when it comes to video post processing, so please bear with me.
I've got this 1080p/HDR10/HEVC-track that I'm trying to upscale(SuperResXBR) to 2160p while still maintaining the HDR10-part. Running this line: SuperResXBR(passes=5, factor=2) But when reading the github I interpret it as colormatrix bt.2020 isn't supported and that by default it will convert it to bt.709. Is this correct? And if, can someone please point me to another plugin that can achieve this? NNEDI3 maybe? |
10th December 2019, 10:22 | #575 | Link |
You can use the HDRTools plugin to convert to BT.709 and then use SuperResXBR with FormatOut = "YUV420P10". For NNEDI3 you can do the same and use NNedi3 resize 16:
https://forum.doom9.org/showthread.php?t=175488 http://avisynth.nl/index.php/Nnedi3_resize16 Edit: It seems that Nnedi3 resize 16 is no longer available but I think if you use ConvertYuv=false AviSynth Shader will cast YUV as RGB so there's no colorspace conversion and MatrixIn/MatrixOut are not used. Last edited by Alexkral; 10th December 2019 at 20:37. |
11th January 2020, 23:10 | #577 | Link |
I'm observing a very slight colour shift towards green (and I'd swear a slight drop in brightness or contrast) when using high bit depth processing in Avisynth+. This is with a Rec601 source and an AMD RX 480. Doesn't occur with standard bit depths. Any suggestions? It isn't as severe as a 601/709 shift, but it is there.
SuperResXBR(MatrixIn="Rec601") ^This works fine ConvertBits(16) SuperResXBR(MatrixIn="Rec601") ConvertBits(8, dither=-1) ^This experiences the colour shift. Dither_convert_8_to_16() SuperResXBR(MatrixIn="Rec601",lsb_in=true,lsb_out=true) DitherPost (mode=-1) ^No colour shift. Otherwise visually different results from the above. Perhaps it's something I'm doing wrong? It is very minor and could just be the nature of the beast. Last edited by markiemarcus; 12th January 2020 at 00:58. |
14th January 2020, 04:52 | #580 | Link | |
I can reproduce this; easier to see with colorbars or similar patterns fulls=true seems to "fix" it (or match the others) Code:
ConvertBits(16, fulls=true) SuperResXBR(MatrixIn="Rec601") ConvertBits(8, fulls=true, dither=-1) |
