12th June 2017, 22:22 | #44081 | Link |
Hello madshi,
Do you plan to add Enhanced EWA upscalers into madVR? http://kaba.hilvi.org/homepage/cg/ewa/Enhanced_Ewa.pdf Do you plan to add any denoiser? I know there are a lot of forms of image noise and that creating such a good denoiser is not that easy. I would like to toggle it easily with a keyboard shortcut. Last edited by sauma144; 12th June 2017 at 22:39. |
12th June 2017, 23:44 | #44082 | Link | |
Looks impressive! |
13th June 2017, 04:22 | #44084 | Link |
Hello.
I have questions to the MAdVR community. 1) How hardware-scalable is MadVR? How much the performance of MadVR depends on the CPU? For example, does it make any sense to change the 4-core Core i7 6500 to 8-core Core i7 6900K or 12-core i9-7920X? Will this provide any significant increase in overall MadVR performance and will it allow using more sophisticated algorithms? How about new AMD Risen multicore processors? Is it better or worse then i7 for MadVR? Maybe, Is it better for MadVR to use processors with a higher clock rate, rather than a large number of cores? 2) The second question: does MadVR support video cards in SLI configurations? That is, will it give any/or noticeable boost to MadVR performance by adding a second similar video card to the system? 3) Which test or test suite now most accurately represents the performance of CPU and GPU in relation to MadVR processing? Is this OpenCL benchmarks or something else? Will be grateful for the explanations and answers. |
13th June 2017, 07:23 | #44085 | Link |
I'll have a crack at these.
1) Very, it can work a Titan if you're upscaling to 4K or beyond. Very little depends on CPU, choose whatever you want it won't matter (Quad+ cores generally preferred these days) Ryzen is good, madVR is designed for mostly GPU work as GPU's are far more suited for these tasks so it really doesn't matter. 2) No. 3)Nothing I know of, Nvidia generally offers better performance for most features of madVR. At this point it's best just to ask providing information about content and display , maybe one day madVR has the ability to benchmark. |
13th June 2017, 09:15 | #44087 | Link |
Thanks for answers!
1) I already have a Titan X Pascal for MadVR, which works with i7. Typical CPU usage is 25-30% even on the heaviest algorithms. Typical content: Remux 1080p, which upscale to 4K Screen. Even Titan X is not enough for maximal algorithms, such as "Chroma Upscaling NGU-Very High + Image Upscaling NGU Very High" Even NNEDI3-256 for Chroma + NGU High for Image Upscaling is already a problem. Therefore, I want more hardware power It's a pity if my bundle of CPU and GPU is the top for MadVR for today. 2) If SLI is not supported, very sorry. What prevents MadVR from using SLI or more-than-4-core CPU? 3) If MadVR does not much depend on the processor, Maybe, a bundle of i3 + Titan X will provide the same performance as i7 + Titan X? In other words, there is no point in buying a processor more expensive than i3 for MadVR? 4) That's why it would be important to have relevant tests that will show which particular increase provides more expensive hardware and where generally reasonable CPU power limit for MadVR. |
13th June 2017, 09:32 | #44088 | Link |
That CPU usage will actually be more the AV decoding than madVR.
"Maximal algorithms" are typically bad choices without first weighing the visual benefits.. 4K is a big upscale from Full HD with things like NNEDI3 and NGU, don't underestimate the amount of work that needs to be done to do this.. scale it back, I doubt you'll notice a difference. I've said this many times.. do not use NNEDI3 256 for chroma. I have no doubt it'll be removed in future.. It's nothing but a huge waste of resources, avoid it like the plague. You don't really need more hardware power.. you need to look at what you're doing and weigh the benefits of an upgrade by first looking at the differences between what you can and can't do.. I think what prevents madVR from using SLI is that simply madshi has not spent any time on developing for it, there could be a limitation though.. If you're only using a PC for madVR only then a modern quad i3 is fine, personally I'd rather a Ryzen for the extra cores. When your using a Titan there's not really much out there that's better.. I think most would say go for a 1080Ti if you wanted to upgrade further.. but like I said, weigh it up first. You should know what you're getting before you pay for it just jumping into a Titan X or 1080Ti without knowing what it gives you is pretty silly IMO. |
13th June 2017, 11:54 | #44089 | Link | |
would be an easy test with the unscaled test images used but i don't see a way to access them. i could kind of simulate the 2x2 black white test board pattern and jinc is clearly different from EWA filtering and the new one and what it'S worth clearly superior on this pretty worthless test pattern. i had to simulate it so it is clearly not 100% the same image. and most important these paper are from "March 3, 2009" and if i remember correctly jinc is from 2012. |
13th June 2017, 13:54 | #44090 | Link |
Just wanted to pop by to say finally got Kodi and HDR metadata and the HDR trigger to work!!! Phew. Turns out that if you use the latest Kodi Dsplayer 32bit version and nvidia driver 378.92 and select passthrough using the nvidi api, it works perfect. Was previously using the latest 64 bit version of kodi dsplayer, which the above doesnt work with
Thanks again Madshi for the great work. K Win 10 x64 (16199 build) Asus GTX 1080 strix OC PS- As I suspected, no go with later drivers, so 378.92 is the one the works for HDR triggers. Last edited by oldpainlesskodi; 13th June 2017 at 15:13. |
13th June 2017, 16:01 | #44091 | Link | |
14th June 2017, 04:28 | #44092 | Link | |
14th June 2017, 07:25 | #44093 | Link | |
Oh, very good news. You can try with a Windows 10 CU and the latest nvidia drivers? Because with kodi DSPlayer 64bit + Windows 10 CU + latest nvidia drivers, don't works. I need to turn ON manually the HDR slide in windows 10 and then play a HDR film. But, if I turn OFF HDR slide in windows 10, my TV don't switch automatically into HDR mode. Thanks. |
14th June 2017, 07:31 | #44094 | Link | |
K |
14th June 2017, 07:49 | #44095 | Link |
Check the banding folks, I can make kodi dsplayer trigger HDR with 378.92 drivers but something is wrong with the output, it can pass unnoticed but with some blue skyes (Allies movie beginning or Planet Earth II intro) there is banding, I can see the steps pretty clearly (I don't if I play the same files in the TV).
If I enable the windows control panel HDR slider and then play the file everything works OK with no banding thou, don't know why. It crashes almost everytime if I don't reboot the system first, everything is very fragile at this moment with HDR.. |
14th June 2017, 10:01 | #44096 | Link | |
I can confirm that Nvidia 378.78 also partly works with Kodi Dsplayer 32bit , My LG 70UH700 will go into HDR mode but when i have watched or press stop to go menu,it won`t exit HDR mode, so all colors are washed out. i must restart computer to end HDR. i cannot install 378.92 because got errors on that driver. |
14th June 2017, 11:10 | #44097 | Link | |
Soul Seeker
14th June 2017, 14:35 | #44099 | Link | |
14th June 2017, 15:58 | #44100 | Link |
ok, now works
Kodi DSPlayer latest version 32bit, madvr latest version and nVidia driver 378.92 and windows 10 CU. But I have the same problem of dbgnu76. When I press STOP, the display remain in HDR mode. Why? Any other experience? p.s. With the latest driver of nvidia, HDR don't works |
