4th May 2011, 22:08 | #2481 | Link |
Uggg - it is 100% repleatable for me and will crash if all the following is met:
- Only Forced Subs" + "only with matching language" is checked - BD (index.bdmv) playback - Must have Subtitle Tracks File Playback is fine, BD without subs is fine.... Here is a bit of the MC Log (prob no great use) indivcating a crash in the filters. Is there any other combination of settings that I should test? Code:
0956145: 10852: Playback: CDShowFilterGraph::RenderFileEx: Start 0956145: 10852: Playback: CDShowFilterGraph::RenderFileEx: extension=mpls, bWindowsMedia=0, filename=X:\Output\Letters_From_Iwo_Jima\Letters_From_Iwo_Jima\BDMV\PLAYLIST\00000.mpls 0956145: 10852: Playback: CDShowFileRenderer::RenderFile: Start 0956145: 10852: Playback: CDShowFileRenderer::LoadSourceFilter: Start 0956145: 10852: Playback: CDShowFileRenderer::LoadSourceFilter: Failed to add user selected filter to graph 0956145: 10852: Playback: CDShowFileRenderer::LoadSourceFilter: Finish (0 ms) 0956145: 10852: Playback: CDShowFileRenderer::RenderFile: LoadSourceFilter returned 0x80004005 0956145: 10852: Playback: CDShowFileRenderer::LoadTransformFilters: Start 0956145: 10852: Playback: CDShowFileRenderer::LoadTransformFilters: Adding filter LAV Audio Decoder 0956145: 10852: Playback: CDShowFileRenderer::LoadTransformFilters: Adding filter ffdshow Video Decoder 0956161: 10852: Playback: CDShowFileRenderer::LoadTransformFilters: Finish (16 ms) 0956161: 10852: Playback: CDShowFileRenderer::RenderFile: LoadTransformFilters returned 0x0 0956161: 10852: Playback: CDShowFileRenderer::RenderFile: Rendering by automatic way 0956161: 11004: Playback: COSDWindow::Draw: Start 0956161: 11004: Playback: COSDWindow::Draw: Finish (0 ms) 0956208: 11004: Playback: COSDWindow::UpdatePosition: Start 0956208: 11004: Playback: COSDWindow::UpdatePosition: Finish (0 ms) 0956317: 11004: Playback: COSDWindow::UpdatePosition: Start 0956317: 11004: Playback: COSDWindow::UpdatePosition: Finish (0 ms) 0956333: 10852: General: TopLevelExceptionFilter: Unhandled exception -- program crashing 0956333: 10852: General: TopLevelExceptionFilter: Message: 0, wParam: 0, lParam: 0, Window class: 0956988: 11004: Playback: CBitrateMonitor::UpdateBitrate: Start 0956988: 11004: Playback: CBitrateMonitor::UpdateBitrate: Accum audio bytes 0, video bytes 0, time period 1057.980160 ms 0956988: 11004: Playback: CBitrateMonitor::UpdateBitrate: Bitrate for current period: 0, audio: 0, video 0 0956988: 11004: Playback: CBitrateMonitor::UpdateBitrate: Finish (0 ms) 0959983: 11004: Playback: CBitrateMonitor::UpdateBitrate: Start |
4th May 2011, 22:15 | #2483 | Link | |
- Set submode to "Only Forced Subs" - Only with matching language is your choice, really. - Enable "Auto-Select Forced Subtitles" (i should rename this option) - Deliver only forced subs has no influence on this setup, can remain off. BTW, which version are you using? I hope at least 0.24-67, -66 had a crash which could somehow explain yours. :P
4th May 2011, 22:27 | #2484 | Link |
@Andy - I'm ripping a True Blood episode with DTS core only right now to test with the older (non-fixed) version of LAVF Splitter so I can see if the Pio handles it ok.
@Nev - I'm building the very latest code to test after I'm done with that @jmone - I will take a look and see if I can repro your issue when I'm done. Before now I always had just only forced and matching language. I've never had an issue.
4th May 2011, 22:35 | #2485 | Link | |||
4th May 2011, 22:36 | #2486 | Link |
I figured out the crash, its ffdshows fault, MPC-HC sub renderer didn't do it.
I'll fix it.
4th May 2011, 22:38 | #2488 | Link |
No idea if Express works. And yes, 4.5.2 here.
4th May 2011, 22:42 | #2490 | Link |
@Andy - Bitstreams DTS just fine with the older version of LAVF Splitter that wasn't fixed. Looks like Pio fixed it on my 21TXH. That was nice of them.
4th May 2011, 22:55 | #2492 | Link |
Jmone, I can confirm the crash bug so we'll need to wait until Nev fixes it. I'll do a new build as soon as he does and verify it.
4th May 2011, 23:08 | #2493 | Link |
http://files.1f0.de/lavf/LAVFilters-...2-g8f67c41.zip
- DVB subs fixed - Minor mpeg-ts seeking improvements - fixed a crash with ffdshow and the new virtual forced subs stream
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 4th May 2011 at 23:11. |
5th May 2011, 01:13 | #2498 | Link | |
It was not like DTS didn't work for me 100%. I have one file that doesn't, and another did work but it switched off MCACC with DTS-HD framing. |
