Old 1st November 2017, 13:35   #2121  |  Link
Memory bandwidth hasn't really increased much over the last generations, consumer CPUs are still dual channel and the iGPU still uses that same system memory. At the same time 4K 10-bit 60fps uses around 20 times the raw memory bandwidth that your typical 1080p24 content would use.
On the other hand, running copy-back from an NVIDIA card and uploading back to that same NVIDIA card is still quite fast, even with 4K 10-bit content. So one can only conclude that the Intel GPUs are just not very good at this.
Old 1st November 2017, 13:36   #2122  |  Link
it's not easy to measure i personally never noticed anything worthwhile using CP with any of my video cards.
native is disabling a lot of possibilities which should not be generally ignored.
Old 1st November 2017, 13:37   #2123  |  Link
aufkrawall
Just look at the GPU usage reported by tools, it's very noticeable here with GTX 1070 and not too expensive scaling/processing in madVR/mpv.
Old 1st November 2017, 13:38   #2124  |  Link
you know my reports it's meaningless on all my cards in the past 4 years.
Old 2nd November 2017, 00:42   #2125  |  Link
darkrenata
Originally Posted by aufkrawall View Post
Just install the latest nightly build and select D3D11 in the video decoder settings instead of DXVA2.
DXVA2 is slower on the GPU than D3D11VA, perhaps this is also true in your case when using copyback. Doesn't hurt trying.
I tried this. Happy to report that for the 4k 60FPS content I have it playbacks flawlessly on my 1080p monitor out of my 970 decoding on the i7-8700k iGPU. I'll try my 4K display next time I turn it on but this seems pretty good so far.
Thanks for the suggestion.
darkrenata is offline   Reply With Quote
Old 11th November 2017, 04:38   #2126  |  Link
gagmani
1070 Ti does not have VP9 Profile 2 just like 1070 and 1080.
https://imgur.com/a/4b4c8
gagmani is offline   Reply With Quote
Old 11th November 2017, 19:40   #2127  |  Link
Razoola
I was thinking of getting a 1070TI, what does the loss of VP9 profile 2 mean in real terms? Does any nvidia GFX card have it?
Razoola is offline   Reply With Quote
Old 11th November 2017, 20:02   #2128  |  Link
you can't decode VP9 profile which is used on youtube HDR.
1050 ti and slower 10xx cards and there are information that state the 1080 ti can do it too
Old 12th November 2017, 06:56   #2129  |  Link
gagmani
99% youtube vp9 videos would play fine. Only 10 bit(HDR) ones would fail. Netflix playback can be problematic on HDR content.
Old 12th November 2017, 13:58   #2130  |  Link
el Filou
el Filou's Avatar
Netflix also supports HEVC so that's not a problem.
If Razoola has a powerful CPU maybe they could decode VP9 profile 2 in software?
Old 12th November 2017, 15:40   #2131  |  Link
aufkrawall
Bitrate of YT VP9 10 bit is lower than of 8 bit, so it might work with software decoding.
Old 12th November 2017, 22:30   #2132  |  Link
Razoola
I have an old i7 920 at 4Ghz and its not fast enough hence I'm looking for a new gfx card. Can the 950 do it? I understand this card has some HEVC and VP9 support but I'm not sure that includes 10bit.
Old 12th November 2017, 22:38   #2133  |  Link
as far as i remember the first card with support is the 1050 ti.
Old 12th November 2017, 22:39   #2134  |  Link
sneaker_ger
Yes, GTX 950 does HEVC 8 bit + 10 bit and VP9 8 bit but not VP9 10 bit.
Note: AFAIK it does not have the DRM features the Pascal series has. So don't expect 4K Netflix or Blu-ray to work through non-pirate/non-ripped means. I also don't know about HDR even if pirated. Power and RAM are also limited in case you want any advanced madvr features or similar.
Old 15th November 2017, 15:59   #2135  |  Link
I can confirm this, the 1080Ti indeed has VP9 10-bit support.
Old 15th November 2017, 19:58   #2136  |  Link
aufkrawall
Too bad your VP9 10 bit HW decoding patches haven't got mainlined yet in ffmpeg.
Old 15th November 2017, 23:12   #2137  |  Link
Thats because they're not actually complete. LAV uses a bunch of its own HW functions, so it wasn't really required to add the extra stuff. But maybe I should.
Old 17th November 2017, 12:05   #2138  |  Link
Razoola
I'm a little confused now. So the 1080TI has VP9 10 bit support but the 1080 and 1070TI does not? I somehow got the impression these used the same GPU so I though they would all have the same HW decoding spec.
Old 17th November 2017, 13:18   #2139  |  Link
Indeed, the underlying chip variant is what matters, and only GP102 and GP107/108 seem to support it, since both are relatively new. So that is 1080Ti (and possibly the Titan Xp) based on GP102, and the 1050 Ti and below on GP107 or 108.
The 1070 Ti, while a "new" card, is based on the exact same chip as the 1080 and 1070.
Old 17th November 2017, 13:33   #2140  |  Link
Razoola
Thanks for the clarification.
