Old 16th October 2021, 07:22   #8861  |  Link
v0lt
Originally Posted by v0lt View Post
@M.Scott
If you do not want to unpack "yt-dlp.zip" into the player folder, then you can add the path to the "yt-dlp" folder to the PATH variable.
For MPC-BE after r6606, you can specify the path to "yt-dlp.exe" in "App Paths" subkey.
for current user
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\App Paths\yt-dlp.exe]
@="C:\\Utils\\yt-dlp\\yt-dlp.exe"
for all users
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\yt-dlp.exe]
Old 17th October 2021, 15:07   #8862  |  Link
cmhrky
Save it to a .cmd file and run it as an administrator in the same folder as yt-dlp.exe.
Reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\yt-dlp.exe" /ve /t REG_SZ /d "%~dp0yt-dlp.exe" /f
cmhrky is offline   Reply With Quote
Old 18th October 2021, 13:49   #8863  |  Link
cmhrky
Unable to open subtitles in built-in YouTube support.
Old 22nd October 2021, 14:42   #8864  |  Link
v0lt
@cmhrky
Support for YouTube subtitles added by the authors is fixed in r6634.
Old 24th October 2021, 18:19   #8865  |  Link
cmhrky
Thanks @v0lt, @Aleksoid1978
What should we do for MPC-BE to open it with yt-dlp and start recording a live stream we watched? Is it possible to make an arrangement to record stream?
Old 25th October 2021, 04:31   #8866  |  Link
v0lt
I do not know if it is possible to do this. In any case, now nothing is planned.
Old 29th October 2021, 17:01   #8867  |  Link
v0lt
Starting from version 1.6.0.6646 the player cannot work on Windows Vista. This happened after updating the dav1d decoder. The reason is the use of the GetThreadGroupAffinity function in commit 9636af88.
Old 29th October 2021, 18:41   #8868  |  Link
chros
chros's Avatar
Cheers, probably no one cares about Vista
Old 2nd November 2021, 02:15   #8869  |  Link
Perenista
I am having a problem with a specific Matroska file extracted from my DVD, with help from MAKEMKV.
This is the only file that while it's playing in MPC-BE it wobbles in a frenzy manner... you can't watch at all.
I extracted 1 minute of it using MKVTOOLNIX.
https://drive.google.com/file/d/1VsL...ew?usp=sharing
MEDIAINFO: https://pastebin.com/hnWAxYZU
The funny thing is that if I use MPC-HC that same MKV is 100% fine. What is going on?
Perenista is offline   Reply With Quote
Old 2nd November 2021, 03:48   #8870  |  Link
v0lt
There is a problem with processing "3:2 pull down".
I don’t confirm. The MPC-HC 1.9.16.51 has the same problem.
Old 2nd November 2021, 13:42   #8871  |  Link
the file is softtelecine(for the most part).
when it get's deint it has some issues like the repeat flags are wrong or something
Old 2nd November 2021, 16:02   #8872  |  Link
Perenista
I noticed if we enable MPC Video Renderer the problem repeats with MPC-HC.
https://forum.doom9.org/showthread.p...64#post1952164
I did what the above link says to make it possible to watch 4K content with no GPU at the moment. So this file can be played fine with enhanced video renderer (custom presenter).
Old 4th November 2021, 07:23   #8873  |  Link
P.J
Δ
Does anyone have this problem with MPC-BE and ESET Internet Security in Windows 7 x86?
P.J is offline   Reply With Quote
Old 4th November 2021, 17:06   #8874  |  Link
v0lt
@Perenista
I ran some tests for DVD-Video with "Scan order: 2:3 Pulldown":
DVD ~ 23,976p
VOB ~ 23.976p
mkvmerge v62.0.0 ~ 23.976p
mkvmerge v8.3.0 ~ 23.976p
As a result, my video plays correctly. Now I don't know what the problem is with your video.
MediaInfo for VTS_03_1.VOB
MediaInfo for VTS_03_1.mkv
Old 4th November 2021, 22:46   #8875  |  Link
kerimcem
hello how close mpcvr deinterlacing ? vob file soft picture.
kerimcem is offline   Reply With Quote
Old 4th November 2021, 23:08   #8876  |  Link
Looks like corruption. Reinstall ESET and check your file system and hardware.
Old 5th November 2021, 04:13   #8877  |  Link
v0lt
I don’t understand you.
Old 5th November 2021, 05:00   #8878  |  Link
LenniePaz
I'm trying to switch from MPC-HC, to MPC-BE. All of my movies bitstreamed perfectly with MPC-HC, but for some reason, everything is showing PCM when I try MPC-BE. Sould we use internal or external filters with BE? What audio renderer do I choose from the drop-down box, my Denon receiver?
Sent from my SM-N975U using Tapatalk
LenniePaz is offline   Reply With Quote
Old 5th November 2021, 05:13   #8879  |  Link
v0lt
@LenniePaz
You need to set up MPC-BE in much the same way as you did in MPC-HC + LAV.
Options > Internal filters > Audio decoders > Audio decoder configuration > Pass-through (S/PDIF, HDMI)
Old 5th November 2021, 05:13   #8880  |  Link
Aleksoid1978
Aleksoid1978's Avatar
1 - Enable bitstream in internal Audio Decoder.
