11th September 2010, 17:31 | #1522 | Link | |
Thanks |
11th September 2010, 19:57 | #1525 | Link |
MrC,
Thanks quite aware and I already have..was just curious if you or a tester determined the reson for the lock-up near end of encoding (I never had those symptoms) and if it was a encoder issue, did Hank correct it. if it was not a encoder issue, what with the April release fixes it? Thanks again for your tool |
11th September 2010, 22:31 | #1526 | Link |
AVStoDVD Dev
AFAIK that issue happened only on my old Athlon 1800+ with august beta (april beta was ok, so, for safety, I went back). I did inform hank about that issue and... 0.24 Final does not hang anymore. Surely AVStoDVD 2.3.2 final will include HCenc 0.24 final.
Bye |
12th September 2010, 18:17 | #1530 | Link | |
AVStoDVD Dev
Thanks in advance Bye |
13th September 2010, 13:05 | #1531 | Link | ||
i'm doing a enc of ironman 2 now and will return with feedback.. cheers 1. couldn't with your app find and extract subs ...( error during mkvextract cycle ..ok in previous release) have to use mkvextract as stand alone and then your app found the subs without you selecting add subs option. 2. Avisynth couldn't frameserve the in-putted mkv-file.. Quote:
13th September 2010, 15:18 | #1532 | Link |
AVStoDVD Dev
@harnarn
there's a decimal separator bug (see AddBorders(0,112,1972,0,112,1972) command) to be solved with 2.3.2 final. Workaround: select "." as decimal separator in International Settings instead of "," Bye |
13th September 2010, 19:36 | #1537 | Link | ||
Iron man 2 finish
Picture QA superb but no sound not in TMT2 , not in MPHC , WMP but full functionality in dvd menues.. Used wawi+aften as encode gonna change to ffmpeg-aften full report later Last edited by harnarn; 13th September 2010 at 20:23. |
13th September 2010, 20:29 | #1538 | Link |
AVStoDVD Dev
Please post the complete log file, including the audio and authoring sections.
About subs, let me make some research because from 2.3.1 to 2.3.2 there are no changes in subtitles detection and choose routine. Thanks for the reports Bye |
13th September 2010, 20:52 | #1539 | Link | |
i will in the setup use only pre demuxed audio+sub tracks to see if this change any thing on audio out put Full report tomorrow... cheers Last edited by harnarn; 13th September 2010 at 20:59. |
14th September 2010, 06:02 | #1540 | Link | ||
new encode
And like i wrote yesterday the audio and subs was added by the manual option and pre demuxed... Cheers Last edited by harnarn; 14th September 2010 at 06:05. |
