Old 11th March 2009, 00:54   #1981  |  Link
Originally Posted by liquidskin76 View Post
Am i missing something here!
Wasn't this what we were talking about a few posts back... about x264 crashing with the error 'x264.exe has stopped working', because of the 1080i VC-1 streams.
Surely this is the same thing??
It doesn't look like it to me. If this were an "interlaced problem" I would think you'd see it in the playback -- not in X264. He hase already shown that the AVS will play back properly.
Old 11th March 2009, 00:57   #1982  |  Link
Originally Posted by archie_here View Post
"C:\BD-RBV02003\BD_Rebuilder\tools\x264.exe" "E:\WORKING\WORKFILES\VID_00141.AVS" --bitrate 3563 --level 4.1 --sar 1:1 --aud --vbv-bufsize 14500 --keyint 24 --min-keyint 1 --vbv-maxrate 17500 --filter 0,0 --subme 2 --me dia --bframes 3 --direct auto --weightb --partitions none --trellis 0 --analyse none --threads auto --thread-input --progress --no-psnr --no-ssim --stats "E:\WORKING\WORKFILES\VID_00141.AVS.264.stats" --pass 1 --output NUL
avis [error]: unsupported input format (DIB )
x264 [error]: could not open input file 'E:\WORKING\WORKFILES\VID_00141.AVS'
I am able to open the avs file in MPC and it plays fine. I also use ripBot264 and that works fine too. I wanted to try BD-Rebuiler but so far I haven't had any success. I am not sure what i am missing. I have checked all the settings and they all seem fine.
Color space maybe??? Could you post the contents of you AVS file? I've seen this before but not in this context. I sort of remember fixing it by adding a ConvertToYV12() statement into the AVS -- but that should already be there... Maybe some odd resolution???
Dark Shikari??? What else could cause this?
Old 11th March 2009, 01:08   #1983  |  Link
liquidskin76
liquidskin76's Avatar
I knew that... err, just testing you. Well done, you passed with flying colours!!!!!
liquidskin76 is offline   Reply With Quote
Old 11th March 2009, 01:34   #1984  |  Link
archie_here
#Created by BD Rebuilder - v0.20.03 (beta)
DirectshowSource("E:\FGM\35990120_FEWGOODMEN\BDMV\STREAM\00141.m2ts", fps=23.976, audio=false)
#framecount=198552,
ConvertToYV12()
^ if i change the script like this it plays on MPC, otherwise i am getting framecount invalid attribute error.
BD-Rebuilder automatically adds the framecount each time i try to run.
archie_here is offline   Reply With Quote
Old 11th March 2009, 01:35   #1985  |  Link
smnckl
@archie_here
...Clipped...
Would you by any chance be running Vista?
I am running Vista and have come across this (hilited in red) error message when X264 could not access the source referenced in the avs file, either because the path-to-source was incorrect in avs or the folder/file permissions were screwed up.
Vista SP1 32-bit w/4GB RAM
AMD Athlon 64 X2 4400+ @ 2.23GHz
nVidia GeForce 8400GS w/512MB RAM
smnckl is offline   Reply With Quote
Old 11th March 2009, 01:39   #1986  |  Link
smnckl
#framecount=198552,
ConvertToYV12()
Try leaving the sentence as
DirectshowSource("E:\FGM\35990120_FEWGOODMEN\BDMV\STREAM\00141.m2ts", fps=23.976, framecount=198552, audio=false)
which is how I believe BD-RB sets it at.
Old 11th March 2009, 03:52   #1987  |  Link
archie_here
I am using Windows XP Pro.
When I use the script created by BD-RB, I am getting not able to play the avs script in MPC and i get a script error: Directshowsource does not have a named argument "framecount" (E:\WORKING\WORKFILES\VID_00141.AVS, line 2)
If I take the framecount out, I am able to play the script on MPC without problem.
Both ways BD-RB is failing to encode like below.
http://forum.doom9.org/showpost.php?...postcount=1955
Old 11th March 2009, 03:57   #1988  |  Link
#framecount=198552,
ConvertToYV12()
I'm confused by this, I assume the "framecount=198552" is actually in the DirectShowSource() as a parameter. I thought earlier you said it plays fine in MPC??
Old 11th March 2009, 03:59   #1989  |  Link
archie_here
yes, if I comment out framecount like below.
#framecount=198552,
ConvertToYV12()
Old 11th March 2009, 06:37   #1990  |  Link
jewish
HI JDOBBS
fyi
I tried to do Kung fu Panda and x264 crashed at rencode 33.
It said there was an error with ffmpeg.
I then changed H.264 in ffdsow to ffmpeg from libavcodec and continued.
Its carrying on now. Will post results when completed.
Is there any chance you could put up snapshots of your FFDSHOW settings so i could see what all your settings are set to which decoder please?
Thanks and keep up the great work.
Brill program.
**UPDATE - it completed this time without crashing x264. So if anyone else has a problem with reencode failure you might want to try changing the setting as i did and it worked fine.
jewish is offline   Reply With Quote
Old 11th March 2009, 08:49   #1991  |  Link
GaPony
Brill program.
He mentioned that he used libavcodec for the mpeg2 and H.264/AV settings. All others would be the default settings, as FFDShow installs them.
http://forum.doom9.org/showpost.php?...postcount=1952
GaPony is offline   Reply With Quote
Old 11th March 2009, 10:20   #1992  |  Link
stef73
Originally Posted by Elesias View Post
Tried with "The Changeling", and same results : plays fine with BD-P1400 (firmware 2.0) and not with BD-35 (firmware 1.3).
Both players are european.
The Changeling is also VC1 encoded.
the changeling plays perfecly on my bd35 with 1.3 european firmware and on ps3
stef73 is offline   Reply With Quote
Old 11th March 2009, 15:05   #1993  |  Link
espinha
It happens a strange thing to me, with vista I work very weel with BD Rebuilder ( use it on 4 ou 5 to shrink to BD 25 and all work fine ).
I now format my pc and have XP64 version and when I start BDR gives this error :
[13:37:45] PHASE ONE, Encoding
- [13:37:45] Extracting audio/subs [VID_00081]
- [13:37:45] Reencoding: VID_00081 (1 of 3)
- [13:38:18] Extracting audio/subs [VID_00110]
- [13:38:21] Reencoding: VID_00110 (2 of 3)
- [13:40:29] Extracting audio/subs [VID_00011]
- Error in attempt to extract audio/subs.
[13:52:37] - Failed to retrieve audio, aborted
and simply stop.
can somebody help me please?
espinha is offline   Reply With Quote
Old 11th March 2009, 15:55   #1994  |  Link
tekmobile
Webmaster
Ive just done wanted BD25 full disc using the latest version and video 00266 is out of sync by about 1 second (Extended Scene in the Extras) its the second time ive encoded
this disc the first was with one of the initial releases of BD-RB and that encode had the exact same problem the origianal is in sync
Below is from BD Info on that playlist
        Total   Video
Title                                                           Codec   Length  Movie Size      Disc Size       Bitrate Bitrate Main Audio Track                          Secondary Audio Track
00184.MPLS                                                      MPEG-2  0:01:58 0               43,022,698,268  0.00    0.00    DD AC3 2.0 192Kbps
DISC INFO:
Disc Title:     WANTED
Disc Size:      43,022,698,268 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 0:01:58 (h:m:s)
Total Bitrate:          0.00 Mbps
Description:
VIDEO:
Codec                   Bitrate             Description
MPEG-2 Video            0 kbps              480i / 29.970 fps / 4:3
AUDIO:
Codec                           Language        Bitrate         Description
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics           English         0.000 kbps
Presentation Graphics           French          0.000 kbps
Presentation Graphics           Spanish         0.000 kbps
FILES:
Name            Time In         Length          Size            Total Bitrate
00266.M2TS      0:00:00.000     0:01:58.485     0               0
CHAPTERS:
Number          Time In         Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:01:58.485     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
STREAM DIAGNOSTICS:
File            PID             Type            Codec           Language                Seconds                 Bitrate                 Bytes           Packets
00266.M2TS      4113 (0x1011)   0x02            MPEG-2                                  0                       0                       0               0
00266.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           0                       0                       0               0
00266.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           0                       0                       0               0
00266.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           0                       0                       0               0
00266.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            0                       0                       0               0
tekmobile is offline   Reply With Quote
Old 11th March 2009, 16:41   #1995  |  Link
bobrap
Just so I got this right...if the video shows VC1 1080I, thats the interlaced problem that isn't working correctly? I just did Apocalypto (full disk) and one of the extras plays audio fine but video is gray. Rest of the disk is great.
bobrap is offline   Reply With Quote
Old 11th March 2009, 18:44   #1996  |  Link
Elesias
Looks like I'm cursed so
Elesias is offline   Reply With Quote
Old 11th March 2009, 23:51   #1997  |  Link
Biffa001
HI JDOBBS
fyi
Brill program.
just treid this and still getting the same x264.exe crash
Any other suggestions please as this excellent piece of s/w is just what I need!
Biffa001 is offline   Reply With Quote
Old 12th March 2009, 00:26   #1998  |  Link
HI JDOBBS
fyi
Brill program.
I must have missed it or forgotten. What setting did you change?
Old 12th March 2009, 01:04   #1999  |  Link
setarip_old
setarip_old's Avatar
@jdobbs
Old 12th March 2009, 01:07   #2000  |  Link
jewish
In ffdshow video decoder configuration its the first option - H.264/AVC.
I changed it from libavcodec to ffmpeg-mt.
I then continued Kung fu Panda to the end and burned to re-writable and it plays fine in my samsung 1500.
This was a full back up as I only do full disk back up to BD25.
Kind regards.
