30th May 2010, 19:03 | #8441 | Link | |
Here is the log:
[23:11:35] BD Rebuilder v0.34.01 (beta) - Source: TEST - Input BD size: 5.82 GB - Approximate total content: [02:16:50.485] - Target BD size: 23.49 GB - Windows Version: 6.1 [7600] - Resize SD to HD 720p enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448 [23:11:42] PHASE ONE, Encoding - [23:11:42] Extracting A/V streams [VID_00001] - [23:14:23] Reencoding: VID_00001 (1 of 2) - [23:14:23] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 164,056 frames - Convert: 1280x720, 59.940fps, 328,112 frames - Bitrate: 22,333 Kbs - [23:14:23] Reencoding: VID_00001, Pass 1 of 2 - [23:14:23] Reencoding: VID_00001, Pass 2 of 2 - [00:10:35] Video Encode complete - [00:10:35] Reencoding audio tracks (if req'd) - [00:11:57] Multiplexing M2TS - [00:21:34] Extracting A/V streams [VID_00002] - [00:22:47] Reencoding: VID_00002 (2 of 2) - [00:22:47] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 82,012 frames - Convert: 1280x720, 59.940fps, 164,024 frames - Bitrate: 22,367 Kbs - [00:22:47] Reencoding: VID_00002, Pass 1 of 2 - [00:22:47] Reencoding: VID_00002, Pass 2 of 2 - [00:52:55] Video Encode complete - [00:52:55] Reencoding audio tracks (if req'd) - [00:53:37] Multiplexing M2TS [00:58:15]PHASE ONE complete [00:58:16]PHASE TWO - Rebuild Started - [00:58:16] Rebuilding BD file Structure [00:58:16] - Encode and Rebuild complete - WORKFILES folder removed. [00:58:16]JOB: TEST finished. In the log I posted the .avs script for VID_00001 did not include the convertfs=true command and the result was audio out of sync and rapid playback. VID_00002 did have the convertfps=true and all was good. I then tested VID_00001 by editing the .AVS script to include convertfps=true and used MeGUI and all turned out right. Quote:
30th May 2010, 19:05 | #8442 | Link | |
So I assume that the original disc is DVD (not BD), and is in MPEG-2 format? Somehow in the preprocess it is probable that the pulldown flags are being removed and that is the source of the issue. The other possibility is that the source is in 23.976 progressive format -- which is fine for DVD but is illegal for Blu-Ray. In other words, this isn't a bug in BD-RB, but in your preparation. You may want to try using PULLDOWN.EXE against the source video in order to set the pulldown flags and make it legal. Also, if this is the case, you may also want to report to the makers of "DVD NExt Copy 4" that they accepting an incorrect format and are creating a non-compliant BD disc. Last edited by jdobbs; 30th May 2010 at 19:25. |
30th May 2010, 19:14 | #8443 | Link | |
Ok - sorry to have reported it as a bug. The original discs are DVD in MPEG-2 - I'll try pulldown.exe.
30th May 2010, 19:38 | #8445 | Link |
no spanish audio
a friend of mine is having a problem with his bdrebuilder..
everytime he make a backup .. he select the appropiate audio tracks (english, spanish, etc).. but when he burns the bluray.. it plays fine.. but only with the main audio... (normally english) any ideas? |
30th May 2010, 22:08 | #8448 | Link |
I've tried to search for this issue in-thread using a few different keywords, but I've not found anything (although I suspect it's in here somewhere/somehow)...
In many cases, when a blu-ray has some kind of subpicture (pop-up commentary, for example), the audio doesn't work on the rebuilt version. Latest example for me was Karate Kid. When I load the original into Rebuilder to set up for compression, there's an audio track called "AUD_003 (2nd) DTS-Express, Stereo, English" that cannot be activated. It loads with the red X next to it and it can't be changed. Playing back the rebuild, the video of the popup commentary shows up where it belongs, but there's no sound (presumably because of said inactive audio track). Is this still a common occurrence, or is there some known workaround at this point? |
30th May 2010, 22:19 | #8449 | Link | |
If you wish to make a duplicate AND retain the audio for the pip stream, then your only choice is to do a full 1:1 BD50 backup |
31st May 2010, 02:15 | #8451 | Link | |
For example: |
31st May 2010, 08:46 | #8453 | Link |
x264 possible bug
Ok, I finally narrowed down the cause for pass 2 encoding failures. X264 cannot read the stats file if it's not on 'local' disk! If you are running virtualbox (example) as I am and your work area is on a mapped drive, a 2 pass encode will fail at the beginning of pass 2.
x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [error]: ratecontrol_init: can't open stats file x264 [error]: x264_encoder_open failed I moved the stats file to the C: drive and executed the last command from lastcmd.txt, except the path for the stats file was modified accordingly. It worked - finally! Rob |
31st May 2010, 10:15 | #8454 | Link | ||
Programmer (or just 教务长)
31st May 2010, 19:00 | #8455 | Link | |
31st May 2010, 19:13 | #8456 | Link |
An additional note to the PS3/copy protection bug, on my trusty old Sony S350, previews, warnings, menu videos would just be black... they would play through, and I would see the menu graphical elements, but no video.
After re-burning a couple movies with that ImgBurn setting, they play like a charm! Sooo... Thanks DVDFab, you were an interesting experiment but I'll stick with AnyDVD |
