9th May 2015, 09:46 | #2741 | Link |
Hi MrC. Just reinstalled AVS2DVD today latest build and encoding a DVD at the moment I just noticed something. AVS2DVD is using HCENC 0.26 Beta, not even 0.27 and I just saw 0.28 came out yesterday
Any reasons as to this? |
9th May 2015, 10:47 | #2742 | Link |
Simple reason:
AVStoDVD installs AviSynth version 2.58 which is the latest stable version. And HCenc 0.28 needs at least AviSynth version 2.60 RC1. The latest version is 2.60 RC3, and many people agree that it can be considered stable, but MrC probably wants to wait for the release version. In the meantime you can upgrade AviSynth and HCenc yourself. Install AviSynth 2.60 RC3 over the old version, and for HCenc just extract HCenc.exe from the archive into the AVStoDVD\HCenc folder. And let us know if it works... Cheers manolito |
9th May 2015, 16:12 | #2744 | Link |
AVStoDVD Dev
Yes, actually I'm using AviSynth 2.6 RC3 without problems. But I have no hurry (no real need) to bundle it to AVStoDVD package...
About HCenc 0.28, I would wait to check its reliability and the real new benefits to DVD encoding. I have kept 0.26 so far mainly for the stability. Of course any feedbacks about these topics are very welcome Bye |
10th May 2015, 08:54 | #2745 | Link |
FWIW I just did a couple of short test encodes using HCenc 0.28 latest build from May-08-2015 under AviSynth 2.60 RC3, and everything worked just fine.
Still I don't have a clue if the improvements compared to version 0.26 have any influence on DVD compliant output. At least I could not see any difference... Cheers manolito |
19th May 2015, 13:54 | #2746 | Link |
Another small issue caused by MediaInfo...
While working on a different project I came across some MP4 files (AVC video, 6-ch AAC audio) where the number of audio channels causes a problem. I get these files from ffmpeg using the Fraunhofer libfdk-aac library. A small test sample is here: http://www44.zippyshare.com/v/erXu5G6U/file.html MediaInfo reports Channels = 2, Channels_Original = 6. Loading such a file into AVStoDVD makes AVStoDVD think that the audio has 2 channels which is definitely wrong. Forcing 6 channels takes care of it. I am not the only one having this problem. Have a look here: http://ffmpeg.gusari.org/viewtopic.php?f=11&t=1378 In the last post of this thread Zenitram explains what is happenig. Suggestion for AVStoDVD: If the "Channels_Original" entry is present, use the channel count from this entry instead of the value from the "Channels" entry. I remember there was a similar issue recently for video when there were two different values for the framerate mode (CFR or VFR), and this was fixed accordingly. Cheers manolito |
2nd June 2015, 08:09 | #2748 | Link |
Guys, I know I'm going to repeat myself but I can't find the place to set AVStoDVD to load the DVD menu (in cases of multiple videos) instead of automatically playing the first title. Can someone please tell me where to set this? Thanks and sorry for repeating myself...
3rd June 2015, 15:25 | #2750 | Link | |
Is it possible that I changed a setting in AVStoDVD causing this? |
3rd June 2015, 16:12 | #2751 | Link | |
http://i57.tinypic.com/qx56bl.jpg Cheers manolito |
6th June 2015, 20:21 | #2753 | Link |
I get this error with the new beta.
edit: is not only in beta, it is also in 2.8.1 And i only get this error, if i activeted the checkbox "Pal Speedup für NTSC zu Pal benutzen". Last edited by Mister XY; 7th June 2015 at 16:23. |
7th June 2015, 22:10 | #2755 | Link |
AVStoDVD Dev
@Mister XY
better if you upload the image to another host service (Dropbox, Tinypic, Sendspace, Mediafire, ...). And post the 2.8.2 Alpha project log file too. @SuLyMaN as already mentioned, A2D (actually BatchMux) is not capable to force the direct play of first DVD title. The option manolito was referring is just the position of the highlight when the DVD menu is loaded: option unchecked -> first title thumb is highlighted, option checked -> play all button is highlighted. Do you get the same behaviour (direct play of first title) with all the players you have tried? I mean software player (i.e. MPC-HC, VLC, WMP) and external DVD player? Anyway, if you really can't figure out, you can use PgcEdit to mod the authored DVD structure to do what you prefer upon disc insert: http://jean.laroche.free.fr/Jumping0.4.3.1/ Bye Last edited by MrC; 7th June 2015 at 22:14. Reason: PgcEdit workaround |
8th June 2015, 06:34 | #2756 | Link | ||||
8th June 2015, 08:02 | #2757 | Link |
Where found i the log if i want to create the DVD Menu? I only have a log, if i create the complete dvd.
edit: here is the Log http://pastebin.com/gs6LFBNG i have tested it with the LAv filter from AVS2DVD package (0.64,0.65), K-lite with different source filters, and every is the same. and here with coorect Menu http://pastebin.com/zTy40ERz Last edited by Mister XY; 8th June 2015 at 09:17. |
13th June 2015, 10:54 | #2759 | Link |
AVStoDVD Dev
Release 2.8.2 Alpha build 150613 is available to download
Cumulative change log from 2.8.1 - Some bugs fixed - Added .style file generation routine for SubRip hard-encoded subtitles font customization - Added auto adjustment of colour coefficients if source is using ITU-R BT.709 set (thru ColorMatrix plugin) - Added handling of MediaInfo Channel(s)_Original tag - Added auto selection of HCenc AVAMAT7 matrix for very low bitrates (below 2500 kbps) - Added Hard FrameRate Conversion option in 'Preferences'/'AviSynth' - Revised Video Encoder selection criteria in 'Preferences'/'Video' and 'Edit Title'/'Video' - Replaced PgcDemux with FFmpeg for DVD video and audio demuxing - Removed PgcDemux from Installer and NoInstall packages - Moved location of Profile.xml file from SubtitleCreator folder to Local AppData folder - Improved Profile.xml file generation routine - Improved handling of interlaced sources (added support to MBAFF and PAFF tags) - Improved bitrate calculation routine - Improved log activity - Updated main AVStoDVD icon (32, 48, 64, 256 px) - MediaInfo updated to release 0.7.74 - LAV Filters updated to release 0.65 - AviSynth updated to release 2.6.0 Bye |
