18th October 2011, 15:01 | #10161 | Link | ||
18th October 2011, 15:03 | #10162 | Link | |
18th October 2011, 15:03 | #10163 | Link | |
18th October 2011, 15:06 | #10164 | Link |
No. The option "Present several frames in advance" toggles the old path. If its on, its the new path. The OSD also lets you know about that.
18th October 2011, 15:12 | #10165 | Link | |
Brilliant. I just tested your settings. Flawless across the board. Thank you for that!
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 18th October 2011 at 15:20. |
18th October 2011, 15:14 | #10166 | Link | |
18th October 2011, 15:16 | #10167 | Link | |
18th October 2011, 15:19 | #10169 | Link | |
18th October 2011, 15:26 | #10170 | Link | |
I´ve just tested it again with the newest release of PotPlayer after I realized that MPC-HC (1.5.2.3456) worked flawless. After I´ve installed the update now everything works as expected, the switching in the D3D11 path works just fine, even after doing it 10-12 times in a row. It´s weird though, since I´m pretty sure that at some point MPC-HC didn´t work and I´m still using the same drivers and settings for everything. I always file bug reports only after having them verified with at least 2 players. Thanks for your support madshi, nice to see you back in action. @nevcairiel: Care to share your settings to prevent screen glitches without having to use the D3D11 path? I have an nvidia card, too, so they will probably work on my system, too. Thanks a lot! Last edited by iSunrise; 18th October 2011 at 15:35. |
18th October 2011, 15:31 | #10171 | Link |
I see two files when I just downloaded. Try it again or maybe try this link:
http://www.mediafire.com/?sjqq6d3a866a2d2 (I'm new to Mediafire so maybe I'm doing something wrong.) |
18th October 2011, 15:40 | #10173 | Link | |
Well, then you're lucky. |
18th October 2011, 15:42 | #10174 | Link | |
http://forum.doom9.org/showthread.ph...93#post1530093
18th October 2011, 15:53 | #10175 | Link | |
18th October 2011, 15:54 | #10176 | Link |
mmm, since madshi is around i dare o ask to add something I from the haali renderer, which was my choice before madvr hitting the .7x release.
is it possible to, when res of the video is same as the desktop to half the video window size? Using auto-zoom on mpc-hc is not the samething. If possible, if too much work scrap that. |
18th October 2011, 15:56 | #10177 | Link | |
18th October 2011, 15:57 | #10178 | Link | |
18th October 2011, 15:58 | #10179 | Link | |
18th October 2011, 16:24 | #10180 | Link | ||
