23rd October 2013, 19:52 | #20561 | Link |
huhn, don t you mean:
gpu -> hdmi -> avr gpu -> dvi-> hdmi -> beamer instead of what you are saying: gpu -> hdmi -> avr -> beamer gpu -> dvi-> hdmi -> beamer This won t work anyway. Check the specs of my card here: http://www.club-3d.com/index.php/products/reader.en/product/radeon-hd-7950-royalking.html You can see here that: Maximum Resolution analog: 2048x1536 (via Dual-Link DVI to VGA adapter) Maximum Resolution Single-Link DVI: 1920x1200 Maximum Resolution Dual-Link DVI: 2560x1600 Maximum Resolution HDMI 1.4a: 4096x3112 Maximum Resolution Mini DP 1.2: 4096x2160 Maximum Outputs Simultaneously: 4 So DVI => HDMI => beamer will have a max resolution of 2560x1600 while I need 4096x2160 |
23rd October 2013, 20:02 | #20562 | Link |
this should work anyway cause u use the dvi slot but it behavours like a hdmi slot.
i'm pretty sure all slots are display port slot read about eyefinity what its called. the card just detects what type of connect it is. so just try it out. an passive adapter works for sure in this case. Last edited by huhn; 23rd October 2013 at 20:04. |
23rd October 2013, 20:39 | #20563 | Link | |
23rd October 2013, 20:41 | #20564 | Link | |
http://www.beamershop24.nl/hdmi-kabel/oehlbach-real-matrix-hdmi-und-dvi-kabel-12-meter/ I get no sound........ @pie1394None of the 6 HDMI audio devices 'lit up'..... |
23rd October 2013, 20:43 | #20565 | Link | |
But do I just order a load of DVI=>HDMI adapters and try and see if it works? No adapter came with the card. Last edited by Guest; 25th October 2013 at 14:32. Reason: rule 4: no profanity |
23rd October 2013, 20:51 | #20566 | Link |
try the onboard for audio and amd for picture.
both normal hdmi connections. i have audio option for every connection in my nvdia control center and amd should works the same way... and on top of this i have 4 hdmi audio output devices in my sound's settings. |
23rd October 2013, 21:00 | #20567 | Link |
THX-UltraII, you need a hdmi splitter or a mini DP to hdmi active adapter.
Splitter : gpu -> hdmi -> splitter -> avr splitter -> Sony Mini DP to hdmi active adapter : gpu -> hdmi -> avr gpu -> mini DP -> active adapter -> hdmi -> Sony Last edited by djfred93; 23rd October 2013 at 21:22. |
24th October 2013, 00:30 | #20568 | Link | |
It's a slider you just have to find the most acceptable position for and I think the compromise here is worth it. I tried lower settings also and a touch less on the maxangle but the difference was too great to be worth considering. If only the areas of "real" banded content was affected more by these settings it would be great, but what I see is enabling deband changes much of the picture quite subtly (almost 50% of the image gets changed in some way by enabling debanding at the low preset) so it's no wonder things look softer. Changing maxdif down a bit brings back a touch of those steeper gradients, so yeah the debanded area will look ever so slightly less blended but remember the rest of the image gets back what would have been lost as well with smoothing as well. I wouldn't be mentioning it if I didn't think it was worth it I like debanding as much as the next guy and have been using 3kdb for quite some time. Just wondering, is with the content you feel with maxdif being a touch too low at 1.9, should this content not be better served by the medium preset? For anime I'd like to keep low on by default maybe even with 10 bit content noticeable banding doesn't happen that often (unless you have low quality content), I do however also like some of the minor blending that occurs in very minor banded areas, just not too much that it takes away the pop from the picture. Also content is just going to improve in quality as time goes on, more bitrate, HEVC etc so I'd like to be on the side of detail personally and let medium preset take care of those harder to deal with bands. I was thinking perhaps some years down the track the presets may need to be looked at again as banding becomes less of an issue. Last edited by ryrynz; 24th October 2013 at 03:09. |
24th October 2013, 06:45 | #20569 | Link |
Have you checked that your card even has onboard audio? I know my first card I though I could get audio from DVI but the card never even supported audio over HDMI. Maybe you have already done the following but I suggest going into device manager and confirming there are audio drivers installed for your GFX card. You should also make sure that audio output device is set correctly in reclock if you use it (or your media player) to force sound over the gfx card audio.
24th October 2013, 14:09 | #20570 | Link |
Another silly question.
Using a relative weaker Gpu (HD 6650m, actually have no problem on a 6750m, only difference is ddr3 vs ddr5 vram) for smooth motion on 23fps on 60hz screen, and smooth motion almost double the rendering time. Is there options to make smooth motion less "expensive'? |
24th October 2013, 16:49 | #20571 | Link |
Having "use a separate device for presentation" enabled halves my rendering time with smooth motion. But that's about all that made any significant difference.
madVR scaling algorithms chart - based on performance x quality | KCP - A (cute) quality-oriented codec pack |
24th October 2013, 16:54 | #20572 | Link | |
Like I said, other testers or madshi need to confirm that. But do you see the difference on every content? Or is there some contents where the difference is far more pronounced? If that's the case, a sample video would help. |
24th October 2013, 18:43 | #20573 | Link | |
The HDMI audio data frame is also over TMDS signal pins -- in different packet format. So does DP's audio. The regular DVI-HDMI cable does not map all HDMI signal pins or signal impedence to the card's DVI connector. So it is always detected as the DVI device. It needs the card vendor-designed adapter to use the DVI connector port as standard HDMI output --- just like the cable picture I attached previously provided with Asus Royal King card. |
24th October 2013, 19:34 | #20574 | Link | |
Audiophile
24th October 2013, 21:58 | #20575 | Link | |
yeah i put the adapter in the tv ... |
25th October 2013, 06:19 | #20577 | Link | |
As the source information says, such vendor-made adapter contains a specific I2C EEPROM wired on the I2C bus (for DDC function). So I guess it is how the GPU driver can decide if it should make such video port's function with HDMI capability or just regular DVI one. But I don't know if all ATi card manufacturers are focibly to use such feature to design the DVI connector's functions on their cards... Last edited by pie1394; 25th October 2013 at 06:25. |
25th October 2013, 10:24 | #20578 | Link |
Some nVidia cards also had audio output over DVI using a special adapter. Quite clever really but I think modern cards just have HDMI outputs instead.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
25th October 2013, 13:29 | #20579 | Link |
My only problem with HDMI is that it is not fully compatible with DisplayPort.
There are DP-HDMI adapter cables ... but: Someone told me that you may connect DP out ports with HDMI in ports, but not vice versa. I did not know before; a DP monitor connected to a HDMI graphic card reports "no signal". |
