23rd November 2008, 13:44 | #541 | Link |
Some ideas for future releases of AVDtoDVD:
I just finished testing most of the free one-click DVD conversion software, and AVStoDVD (v. 2.1.2 alpha) was among my favorites. Still I would like to see some improvements . (Please remember that I have never used the software before, so my findings kind of come from an outsider's perspective.) 1. The predefined automatic profiles take a while to get used to, but they are certainly helpful for beginners. But the high bitrate profile using QuEnc CBR should be modified. In this profile the Trellis option is always active. NOT GOOD!! In QuEnc the Trellis option mostly makes no sense at all, and the rare cases where it might acually help quality are those low bitrate encodes of complicated, hard to encode sources. Many people (including me) even think that Trellis is broken in libavcodec. To a lesser degree I also question the usefulness of the HQ option at average bit rates above 6000 kbps. 2. Luckily the automatic modes can be switched off individually for each file. For HC there is an advanced mode, but not for QuEnc. I would really like to be able to use the QuEnc VBR modes with 1 or 2 passes here and there. 3. I read that using Aften for AC3 audio conversions is already in the pipeline, so this is probably redundant. 4. The menue creating stuff using BatchMux is very nice. The only thing I miss is the option to not use thumbnails at all. Just setting width and height to 0 does not work. Maybe add a "Disable" option to the properties for thumbnails and the "Play All" button? Alright, that's my wish list. Would make an already excellent program even better.... Cheers manolito |
23rd November 2008, 15:10 | #542 | Link |
AVStoDVD Dev
Manolito, thanks for your review and suggestions. To answer I will use same numbering.
1. In QuEnc 0.75 Alpha, trellis quant is disabled and trellis checkbox is used to activate multithread encoding. It is written also in AVStoDVD help section... 2. I have forced QuEnc only for CBR encoding because I believe that HCenc is vastly superior as VBR encoder. What would be the improvement to have VBR encoding in QuEnc? From your experience, is there any movie situation in which QuEnc VBR would be preferred than HCenc VBR? 3. Will do 4. Do you mean having menues with labels only? Like FAVC menues? If I remember correctly, somebody else asked me the same feature sometimes ago... so, I will put in ToDo list BTW, many many thanks for your suggestions. I hope you will keep on looking at AVStoDVD and help its development. Bye |
23rd November 2008, 16:03 | #544 | Link | |||
Thanks MrC for looking into my suggestions!
BTW I discovered that it is possible to use custom quant matrices in QuEnc under AVStoDVD. Just run QuEnc before AVS2DVD, specify a matrix and close QuEnc. The matrix setting is retained and QuEnc actually uses this matrix under AVStoDVD. Nice! Quote:
And another thing I forgot to mention in my previous post: I tried to find a way to translate the user interface into German, but VB is not very friendly in this respect (a resource editor cannot be used here). Would you consider moving the string resources to a text file which can be easily translated? Cheers manolito |
23rd November 2008, 17:06 | #545 | Link |
DeVeDe(http://forum.doom9.org/showthread.php?t=142973) may be easy to use for a novice, but it has a known bug which produces significantly undersized encodings, this is the same for both the Linux & Windows versions(I have found even setting 5-10% oversize produces an output of between 1.8-2.3GB when used with a 7oomb quality XviD file from my own backup collection) It also only offers 1 pass encoding. As for DVD Flick I gave up on that about a year back, I found it incredibly buggy, & if you check the forum it still appears to be. Software selection is very subjective but AVStoDVD uses some of the best tools available, and is imho the leader in this particular field.
Keep it up MrC Last edited by wg; 24th November 2008 at 08:16. |
23rd November 2008, 21:10 | #546 | Link |
Hello all and offcourse MrC,
i'm new here and found this thread and program just a few days ago. First of all,great work and effort MrC and all the others. i don't know if it will work what i'm trying to do but i'm trying as we speak. I have a blue-ray backup on my hdd. I've made a new single m2ts file with 1 videostream,1 audiostream and 1 subtitle. Now i've loaded it into AVStoDVD to see if it's managable to get a DL DVD out of a blue-ray backup with ac3 and a subtitle. Maybe has someone else tried it but from what ive been reading it's more about avi's. Forgive me if i didnt read it through all the many postings. Maybe u can shine your light on this matter what i'm trying to do MrC. Keep up the good work. |
23rd November 2008, 23:38 | #547 | Link | |
24th November 2008, 00:10 | #548 | Link | |
The outcome is still not sure yet |
24th November 2008, 14:01 | #549 | Link | ||
AVStoDVD Dev
And think seriously to upgrade your system: multicore cpus really do improve video encoding time. Quote:
Bye |
24th November 2008, 14:04 | #550 | Link | |
AVStoDVD Dev
Bye |
24th November 2008, 21:24 | #551 | Link | |||
Using indexed text files for the string resources is also workable, but then the translated strings cannot be longer than the original ones. Can be quite challenging if the target language is German... And I absolutely refuse to do any translations using a hex editor on the executables... Cheers manolito |
24th November 2008, 23:00 | #552 | Link | |
here's the logfile. <23-11-2008 20:48:22> START PROCESS <> <23-11-2008 20:48:22> DVD SETTINGS DVD Titles number: 1 DVD Video Standard: PAL DVD Chapters Interval: 5 min DVD Menu: No DVD Menu DVD Size: 8100/8100 MB (100%) DVD Output Setup: DVD Folder Delete temp process files: Yes Delete working files: Yes Save Log file: Yes Output Folder: C:\Downloads\test <> <23-11-2008 20:48:22> TITLE 1 SOURCE FILES Video: D:\Downloads\!RnE - 2008.11.17 15.41.43 - bd-tm1\bd-tm1\BDMV\STREAM\00000.m2ts Info: VC-1 - 0 kbps - 1920x1080 - 16:9 - 23,976 fps - PPF - 2:16:10 hours - 196087 frames Audio: D:\Downloads\!RnE - 2008.11.17 15.41.43 - bd-tm1\bd-tm1\BDMV\STREAM\00000.m2ts Info: AC3 - 640 kbps - CBR - 48000Hz - 6ch - 2:16:18 hours Subs: D:\Downloads\!RnE - 2008.11.17 15.41.43 - bd-tm1\test\test.srt [MediaInfoLib - v0.7.7.6] <> <23-11-2008 20:48:22> AVISYNTH SCRIPT Video = DirectShowSource("D:\Downloads\!RnE - 2008.11.17 15.41.43 - bd-tm1\bd-tm1\BDMV\STREAM\00000.m2ts", convertfps=true, audio=false) Video = Video.ConvertToYV12 #Using DGPulldown to upsize FPS Video = Video.Lanczos4Resize(720,576) Audio = GetChannel(DirectShowSource("D:\Downloads\!RnE - 2008.11.17 15.41.43 - bd-tm1\bd-tm1\BDMV\STREAM\00000.m2ts", video=false), 1, 3, 2, 5, 6, 4) AudioDub(Video, Audio) <> <23-11-2008 20:48:22> START VIDEO ENCODING OPERATIONS Encoding Profile: QuEnc CBR 1-pass Target Video FileSize: 7735 MB QuEnc Parameters: -i "C:\Users\Manuel\AppData\Local\Temp\00000_0_Title_01.avs" -o "C:\Downloads\test\00000_0_Title_01.m2v" -b 7942 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close <> <24-11-2008 11:01:01> END VIDEO ENCODING OPERATIONS Created File: C:\Downloads\test\00000_0_Title_01.m2v (7742,4 MB) <> <24-11-2008 11:01:01> START TRANSCODING OPERATIONS ReJig Parameters: -size 7735 -o "C:\Downloads\test\00000_0_Title_01.ReJig.m2v" -i "C:\Downloads\test\00000_0_Title_01.m2v" -auto -close -quiet <> <24-11-2008 11:08:50> END TRANSCODING OPERATIONS Transcoding excuted on File: C:\Downloads\test\00000_0_Title_01.m2v (3137 MB) <> <24-11-2008 11:13:48> END PULLDOWN OPERATIONS DGPulldown executed on File: C:\Downloads\test\00000_0_Title_01.m2v (3137 MB) <> <24-11-2008 11:13:48> OUTPUT VIDEO INFO: Filename: 00000_0_Title_01 Filesize: 3289352430 Byte Format: MPEG Video Time: 2:16:18 hours Compression: MPEG-2 Video AvgBitRate: 3218 Resolution: 720x576 Aspect Ratio: 1.778 FPS: 25.000 Interlacement: PPF Frames: 204447 <> <24-11-2008 11:13:49> START AUDIO ENCODING OPERATIONS QuEnc (Audio) Parameters: -i "C:\Users\Manuel\AppData\Local\Temp\00000_0_Title_01.avs" -o "C:\Downloads\test\00000_0_Title_01.ac3" -priority 5 -1 -nohq -novbr -mpeg2mux novideo -audiocodec AC3 -audiobitrate 192 -auto -close <> <24-11-2008 18:38:17> END AUDIO ENCODING OPERATIONS Created File: C:\Downloads\test\00000_0_Title_01.ac3 (187,2 MB) <> <24-11-2008 18:38:17> START SUBS ENCODING OPERATIONS SubtitleCreator Parameters: "C:\Users\Manuel\AppData\Local\Temp\00000_0_Title_01.srt" -p3 -i"C:\Program Files\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.IFO" <> <24-11-2008 18:43:51> PROCESS ABORTED DURING TITLE 1 SUBS ENCODING OPERATIONS. CHECK LOG FILE <C:\DOWNLOADS\TEST\00000_0.LOG> FOR MORE INFO. <> <24-11-2008 18:43:51> Log file created by AVStoDVD Release 2.1.1 <> I'll try again to see if AVStoDVD going to the end next time. |
25th November 2008, 00:27 | #553 | Link |
Decided it was time to road test AVStoDVD Using 2.1.1 (not the latest), by doing a few movies in hopes of helping the always gracious MrC improve his baby.
First some background. Most of the AVI/MKV's floating around are 25 fps which I convert to NTSC. The 'Trim' function is a nice touch, unfortunately you cannot use it correctly without a workaround, using the enclosed viewer to determine/change the end point. For an x264 file I tried it says 219250 frames, yet the preview shows 262833. Due to the source being 25 fps but the final conversion being NTSC is at about 30 fps. I thought maybe right clicking the source from the main screen-> Preview title output, would yield the desired numbers vs. the Magnifier icon (original vs. final converted). It is the same though. Using Vdub 1.8.6 as the viewer shows the original source frames (219250), but there is no audio to help in picking a silent Start trim point (say to elimate a pop or extra logo). The workaround is to set my output to PAL, then I can pick the correct frame numbers to Start/End and hopefully I'll remember to set it back to NTSC before starting. To be truly useful the Trim function's frame count should match the Preview. In this case the Trim function should list 0 - 262833 as it's values. I wanted to remove over a minute of unneeded logos from the start and almost 7 minutes of unneeded stuff from the end. Here are specs on the file I tried to convert: Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2h 26mn Nominal bit rate : 824 Kbps Width : 720 pixels Height : 432 pixels Display aspect ratio : 2.454 Frame rate : 25.000 fps Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.106 Writing library : x264 core 65 r1028M 83baa7f Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / Video: MPEG4 Video (H264) 720x432 (265:108) 25.00fps [Video] Audio: AAC 48000Hz 6ch [Audio] A file of this length can really benefit from HCenc's 2 pass encoding. Note the AR, 2.45. For some reason it isn't being picked up. The preview shows it as full screen 16:9 with no bars. This happened on 2 files of this type that I've tried. Yet ConvertXtoDVD3 has no problems setting the correct AR. I get: Pad 0,66,0,66 DAR 238:97 (2.453) Adding these pad values "Video = Video.AddBorders(0,66,0,66)" into the script now corrects the AR (seems correct to the eye). A "Vertical Resize" of 63%. I really like the "Crop" function in how it adjusts in both directions by changing only the L/R values. To partial appease my bar hating girl friend I went with values of 32 L/R. This automatically changed the Borders to 48, narrowing the bars slightly. If I wanted to appease my grandma I could go to about a 112 L/R crop for the no bars look she craves. Needless to say, after the fiddling, the end result was lovely. I have not found this to be true, when Nero reports this, there is a problem, it is also so rare I can't remember when last I've seen it. I tend to use ImgBurn but other than the IFO/BUP 32K padding and the lack of an AUDIO_TS folder the burns seems the same. Nero Disc Quality scans also seem identical. Note I have no such messages when using Nero 7 on AVStoDVD's output. |
25th November 2008, 14:40 | #554 | Link | ||
I believe that this "reallocation" of files which Nero was trying to do is not strictly required by the DVD standard. Cheers manolito |
25th November 2008, 14:51 | #555 | Link | |
@wg
I also tried to convince DeVeDe that it should do a 2-pass encode, but no success. Adding "vpass=2" to -LAVCOPTS just resulted in an error message. Too bad... Cheers manolito |
25th November 2008, 20:22 | #556 | Link | |
Regards, ME |
26th November 2008, 13:28 | #557 | Link |
Far be it from me to engage in Nero bashing...
I have the latest update of Nero 6 installed, and I do actually use it sometimes. You may be right about Rebuilder, but in this case ummus is talking about Muxman. If you have a VIDEO_TS folder which was created by Muxman without errors (I assume that this was the case here, ummus did not mention any problems reported by Muxman), then you can be 100% sure that this VIDEO_TS folder is DVD compliant. If a burning application throws an error message while trying to burn this folder, then this application is at fault. Period. Cheers manolito |
26th November 2008, 17:36 | #558 | Link | ||||
AVStoDVD Dev
It means that, so far, I have never correctly handled PAR different from 1... except AVI DV sources that have a special treatment. MysticE: very good review! Bye Last edited by MrC; 26th November 2008 at 17:42. |
28th November 2008, 15:15 | #559 | Link |
AVStoDVD Dev
AVStoDVD 2.1.2 Alpha build 081128 is out.
Change log from previous Alpha: - Some bugs fixed (including Clip Preview frames count bug) - Added 'Settings'/'Misc'/'Unload DirectShow ActiveMovie library at runtime' option (might prevent crashes caused by quartz.dll) - Added 'Title Edit'/'Video'/'Auto BitRate Calculation'. When off video bitrate can be manually set - Added 'Menu in Black' DVD Menu template - Improved bitrate calculation routine - Improved DVD Menu highlights movements definition routine - Improved source files DAR (Display Aspect Ratio) identification and management - Improved NSIS installer package features (added components page) Any comments or bugs reports are welcomed. Bye |
28th November 2008, 18:12 | #560 | Link |
I am having a problem with the menu editor
I am using AVStoDVD 2.1.1, and ran into a problem. I was trying to change the frame for the thumbnail, and when I hit edit it opened the preview window. I selected the frame I wanted, and I don't know how to get back to the menu editor. If I hit exit it exits the whole program! Nothing else gets rid of the movie preview window! Is that part of the frame count bug in the prior post, MRC?
Also, I second the request for no thumbnail, and would like to see it extended to the movie title also. I found a JPG with the movie title in it (and it's really neat!) but if I use it I would end up with the movie title 3 times in the final menu!! The JPG one, the movie title, and the thumbnail title!! BTW thanks for the great program, this is cosmetic stuff. |
