Old 19th February 2020, 20:04   #1341  |  Link
Taurus
Taurus's Avatar
Originally Posted by MrBrownCow View Post
I can't figure out why my encodes with AAC audio keep getting an error. AC3 works fine but AAC does not. I think it has something to do with "CoreAudioToolbox 7.10.9.0" but I've followed the instructions for extracting the dll files from the itunes downloader with the make portable script and moved those dll files into the same folder as the qaac64.exe file yet i still get an error.
Folder:
staxrip\audio\qaac\QTfiles64
Thats where the quicktime files should normally be inserted.
qaac64.exe and corresponding files in the root of the quaac folder.
And make sure the path is set right in the staxrip gui:
Apps/Manage/Qaac
Set the path to the qaac folder and verify your quaac64.exe is recognized.
It's really simple.
staxrip will throw an error in case you made something wrong...
Taurus is offline
Old 19th February 2020, 21:13   #1342  |  Link
JKyle
App Digger
JKyle's Avatar
Originally Posted by Patman View Post
Short question: Does anyone use the -bStylish option of my x265 build? Or is it enough for you to see the estimated size?
I do. And I do appreciate your builds.
BTW, x265 3.3 was released two days ago and I think it's time we updated the binary builds.
Sorry about nagging you, but do you have any plan to update your binary builds?
JKyle is offline
Old 19th February 2020, 23:51   #1343  |  Link
imhh11
+1
waiting for your custom build with the estimated size. I've been using the Wolfberry google drive links just for that but it looks like he/she stopped doing new builds.
thank you
imhh11 is offline
Old 20th February 2020, 07:31   #1344  |  Link
Patman
Patman's Avatar
I'm going to update my builds tonight.
Tools for StaxRip | x264 - x265
Patman is offline
Old 20th February 2020, 16:42   #1345  |  Link
imhh11
Awesome, keep it up. thank you
imhh11 is offline
Old 20th February 2020, 20:41   #1346  |  Link
Taurus
Taurus's Avatar
@Patman:
Just out of curiousity:
What is the difference between your builds and the others?
Sorry if this has been answered somewhere along the way .
Taurus is offline
Old 20th February 2020, 21:04   #1347  |  Link
Patman
Patman's Avatar
Originally Posted by Taurus View Post
@Patman:
Hi Taurus,
there are different things ...
First, the size of the files, they are all packed. FFMPEG is a bit better adapted to Staxrip in my build and not overloaded with additional libraries. x264 and x265 are adapted in such a way that the final file size is estimated in Staxrip. The timeliness of the builds is another point. If you are intrested, try my builds
Patman is offline
Old 20th February 2020, 22:14   #1348  |  Link
JKyle
App Digger
JKyle's Avatar
@Patman:
Thanks for the timely update of your builds.
BTW, when I try to download xvid_encraw, I get the following error message:
Well, looks like we can’t go any further
The file you requested has been blocked for a violation of our Terms of Service. Still have questions, or think we've made a mistake? Please contact support for further assistance.
Any idea?
JKyle is offline
Old 20th February 2020, 22:30   #1349  |  Link
Taurus
Taurus's Avatar
@Patman:
I surely will try some of your StaxRip tools.
Thanks for the updates on many of them!
Taurus is offline
Old 20th February 2020, 22:33   #1350  |  Link
Patman
Patman's Avatar
@Patman:
Any idea?
I just tested the download and everything works fine for me.
EDIT:
filename was the reason... xvid isn't allowed... :P
Patman is offline
Old 20th February 2020, 22:50   #1351  |  Link
Taurus
Taurus's Avatar
xvid_encraw download throws the error JKyle mentioned.
Maybe try with a proxy server
Taurus is offline
Old 20th February 2020, 23:03   #1352  |  Link
JKyle
App Digger
JKyle's Avatar
It's funny but the problem is gone after @Patman changed the file name from xvid to x_v_i_d.
JKyle is offline
Old 21st February 2020, 01:08   #1353  |  Link
Magik Mark
PatMan,
Among your x265 builds (3 of them), which one is best suited for intel i9 Processors? May I ask for performance differences?
Thanks a lot!
Magik Mark is offline
Old 22nd February 2020, 16:40   #1354  |  Link
Taurus
Taurus's Avatar
Thank you!
Will have a look.
Taurus is offline
Old 22nd February 2020, 17:14   #1355  |  Link
imhh11
@Patman thanks a lot for the new builds.
Any chance for your custom build with estimated size on GCC as well? It's always slightly faster than MSVC with my i9.
imhh11 is offline
Old 22nd February 2020, 17:31   #1356  |  Link
Patman
Patman's Avatar
Hi imhh11,
I'm just testing the compilation with clang instead of gcc. If there is no big difference, I will compile the custom build in gcc. Stay tuned...
Gesendet von meinem HMA-L09 mit Tapatalk
Patman is offline
Old 22nd February 2020, 18:42   #1357  |  Link
imhh11
Thank you!
imhh11 is offline
Old 23rd February 2020, 02:48   #1358  |  Link
Patman
Patman's Avatar
Thank you!
Done...
x265M-3.3+2-...-gcc is online.
Patman is offline
Old 23rd February 2020, 12:36   #1359  |  Link
lifta19
Hi, Patman. Please build stable version of x265.
lifta19 is offline
Old 23rd February 2020, 19:55   #1360  |  Link
Patman
Patman's Avatar
Originally Posted by Magik Mark, imhh11, lifta
x265 builds
I added a stable version of x265 (3.3+1) that was compiled with GCC 9.2.0 and MSVC 1924 (VS2019). Short explanation to my builds:
x265-3.3+1 - Stable Build
x265-3.3+2 - Default Branch / Master Branch
x265M-3.3+2 - Default Branch / Master Branch with customization to display estimated file size
I recompiled all MSVC version because i optimizied the compile code. In my case, the MSVC version is almost 1.5 seconds faster with a small video file.
GCC 9.2.0
avs2pipemod[info]: writing 4115 frames of 24000/1001 fps, 720x304,
sar 0:0, YUV-420-planar-8bit progressive video.
y4m  [info]: 720x304 fps 24000/1001 i420p8 unknown frame count
raw  [info]: output file: G:\Movie\x264\test\testfile_temp\testfile_new_out.hevc
x265 [info]: HEVC encoder version 3.3+2-gbe2d82093
x265 [info]: build info [Windows][GCC 9.2.0][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x265 [info]: Main 10 profile, Level-2.1 (Main tier)
x265 [info]: Thread pool created using 16 threads
x265 [info]: Slices                              : 1
x265 [info]: frame threads / pool features       : 4 / wpp(5 rows)
x265 [warning]: Source height < 720p; disabling lookahead-slices
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge         : hex / 57 / 2 / 3
x265 [info]: Keyframe min / max / scenecut / bias  : 23 / 250 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt        : 20 / 4 / 2
x265 [info]: b-pyramid / weightp / weightb       : 1 / 1 / 0
x265 [info]: References / ref-limit  cu / depth  : 3 / off / on
x265 [info]: AQ: mode / str / qg-size / cu-tree  : 2 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress            : CRF-20.0 / 0.60
x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip mode=1 signhide tmvp
x265 [info]: tools: b-intra strong-intra-smoothing deblock sao
avs2pipemod[info]: finished, wrote 4115 frames [100%].
avs2pipemod[info]: total elapsed time is 45.134 sec.
x265 [info]: frame I:    153, Avg QP:18.30  kb/s: 3471.00
x265 [info]: frame P:   1226, Avg QP:21.36  kb/s: 1335.03
x265 [info]: frame B:   2736, Avg QP:26.01  kb/s: 433.49
x265 [info]: Weighted P-Frames: Y:2.9% UV:2.3%
x265 [info]: consecutive B-frames: 29.7% 8.7% 16.5% 23.8% 21.3%
encoded 4115 frames in 44.84s (91.78 fps), 815.03 kb/s, Avg QP:24.34
Start:    02:37:22
End:      02:38:07
Duration: 00:00:45
MSVC
x265 [info]: build info [Windows][MSVC 1924][64 bit] 10bit
avs2pipemod[info]: total elapsed time is 43.694 sec.
encoded 4115 frames in 43.43s (94.74 fps), 815.03 kb/s, Avg QP:24.34
Start:    18:57:42
End:      18:58:26
Duration: 00:00:44
Pls test and give feedback...
Patman is offline
