4th March 2019, 21:51 | #81 | Link | |
So actually the issue is that CI=True (model vmaf_b_v0.6.3.pkl) is giving lower aggregate VMAF scores than CI=False (model vmaf_v0.6.1.pkl) ! Why is that ? Surely they should be giving the same VMAF score ? Edit: There was no mix-up of the 'model' folders , btw - when I updated to v4 I replaced the VMAF.dll and 'model folder' that came with it. The above graphs amended accordingly:
Nostalgia's not what it used to be Last edited by WorBry; 5th March 2019 at 02:41. |
5th March 2019, 05:40 | #83 | Link |
I guess the VMAF Confidence Interval doc does explain why there are differences:
https://github.com/Netflix/vmaf/blob...nf_interval.md Note that the CI=False VMAF scores are within or at the limits of the CI95_High interval. Edit: btw, testing the parallel series of x265 encodes with v4 CI=True gives exactly the same pattern.
Nostalgia's not what it used to be Last edited by WorBry; 5th March 2019 at 19:35. |
11th March 2019, 10:59 | #86 | Link |
ran some control tests (same file validated to itself) via ffmpeg libvmaf and VS libvmaf to test whether both implementations return the same data.
since libvmaf only supports up to yuv444p10le, higher quality formats need to be down-converted - ffmpeg does that automatically. 4 sources used for the control tests: RGB48, yuv444p12le, yuv444p10le, yuv444p VMAF SDK 1.3.14 - Model 0.6.1 - pool: mean Code:
EXR RGB48 VMAF Note ffmpeg 98.2549 converts internally to yuv444p10le VS (1) 97.747 converted to yuv444p10le via FMTC VS (2) 97.7475 converted to yuv444p10le via resize.bicubic MP4 yuv444p12le VMAF Note ffmpeg 98.1216 converts internally to yuv444p10le VS (1) 97.7106 converted to yuv444p10le via FMTC VS (2) 97.7101 converted to yuv444p10le via resize.bicubic MP4 yuv444p10le VMAF Note ffmpeg 98.1044 no conversion needed VS 97.7144 no conversion needed MP4 yuv444p VMAF Note ffmpeg 97.7363 no conversion needed VS 97.7363 no conversion needed While it can be expected that the 16bit and 12bit sources will not return the same VMAF scores (ffmpeg internal down-conversion may not match the chosen VS conversion method), it is interesting to see that only w/ the 8-bit src the VMAF scores match. The VMAF scores of the 10-bit src (although no conversion being done) still differ. what is the reason for that ? |
11th March 2019, 22:14 | #88 | Link | |
if a 10bit ref/src is provided. up-converting an encoded/distorted clip to 10bit does not lose precision, but down-converting a 10bit ref src to 8bit to then compare to the inferior 8-bit encode loses precision/accuracy... NF does up-res a lower res encoded clip before comparing to the higher res ref/src (same logic), so this seems odd... do you have a link to where they state that they downsample the master to 8bit ? Thanks. |
13th March 2019, 04:48 | #89 | Link |
Finally got around to re-testing the Crowd Run 2160/50p x264 series that I kept from earlier tests with v3:
https://forum.doom9.org/showthread.p...16#post1865316 So this was testing with VapourSynth VMAF v4 in Model=1 mode which uses vmaf_4k_v0.6.1 by default (CI=False) and vmaf_4k_rb_v0.6.2 when set to CI=True. Now in this case CI=False and CI=True produced the exact same aggregate VMAF scores, which came as a surprise: Now how is that ? The Confidence Interval doc doesn't mention 4K models specifically but I would assume the 'rb' in 'vmaf_4k_rb_v0.6.2' means 'residue bootstrapping', in which case why is residue bootstrapping used to derive CI scores for 4K video, whereas the CI model for HD/SD (vmaf_b_v0.6.3) uses plain bootstrapping ? All rather confusing.
Nostalgia's not what it used to be Last edited by WorBry; 13th March 2019 at 14:59. |
16th March 2019, 04:12 | #90 | Link | |
I think the non-bootstrapping 4K model should have been named v0.6.2 rather than v0.6.1, as the model was released after VMAF algorithm v0.6.2. And the VMAF score won't be different between residue bootstrapping and plain bootstrapping. Only the CI-related scores will be affected. |
16th March 2019, 05:02 | #91 | Link |
OK, but still - why in the 4K (2160/50p) tests does CI=True (vmaf_4k_rb_v0.6.2) give exactly the same aggregate VMAF scores as CI=False (vmaf_4k_v0.6.1), when in the 1080/50p tests CI=True (vmaf_b_v0.6.3.pkl) gave consistently lower aggregate VMAF scores than CI=False (vmaf_v0.6.1.pkl) ?
Nostalgia's not what it used to be Last edited by WorBry; 16th March 2019 at 05:10. |
16th March 2019, 05:22 | #92 | Link | |
16th March 2019, 06:03 | #93 | Link |
So why don't they update the 'classic' non-bootstrapping HD/SD model, trained in the same environment as vmaf_b_v0.6.3, so that CI=False and CI=True produce the same aggregate VMAF scores as well? Surely it's important to have consistent outcomes ?
Nostalgia's not what it used to be Last edited by WorBry; 16th March 2019 at 06:05. |
30th March 2019, 02:35 | #96 | Link |
already posted this in another thread, but thought I'd post VMAF results here as well
from a 16-bit EXR source (15 secs, 360 frames), made nine (9) x265 encodes, all CRF 10, in these formats (using Wolfberry ffmpeg build): yuv420p, yuv422p, yuv444p, yuv420p10le, yuv422p10le, yuv444p10le, yuv420p12le, yuv422p12le, yuv444p12le VS VMAF results (sources were down-converted to yuv444p10, if higher, since that is the highest input format supported) FFMPEG VMAF results (internally converts to yuv444p10, if higher source) as you can see VMAF score indication is the same in both, but the SSIM/MS-SSIM differ... now besides that FFMPEG has that odd dip (scoring 8-bit higher than 10/12-bit), the VS VMAF results are almost flat... so does VS VMAF internally convert everything to 8-bit (although it supports up to yuv444p10 input format) ? Last edited by Iron_Mike; 30th March 2019 at 02:51. |
30th March 2019, 03:29 | #97 | Link | |
That's what HolyWu said, above - as per Netflix's source code And a difference is that ffmpeg's vmaf implementation does not |
30th March 2019, 03:33 | #98 | Link | |
30th March 2019, 07:49 | #99 | Link |
@HolyWu:
since everything gets down-converted to 8-bit internally, why are you guys not making 8-bit input mandatory in VS VMAF ? I mean the 10-bit input support is pointless, and VS VMAF already requires same format for ref/dist, so the user is already required to convert in most cases before calling VS VMAF... and btw, I mentioned this in the other thread: when I use yuv444p (8-bit) as input format (coming from RGB48le) in VS VMAF compared to using yuv444p10 (10-bit), the range of VMAF/SSIM/MS-SSIM values is compressed (closer together)... since everything gets converted to 8-bit internally anyways, the range of values should pretty much be the same... unless the result of the filters I use to down-convert to 8-bit is substantially different to what VMAF uses internally... (I use fmtc or vs.resize) alongside the other VMAF results, this is the result if I use 8-bit input w/ VS VMAF: VS VMAF results (sources were down-converted to yuv444p) Last edited by Iron_Mike; 30th March 2019 at 08:44. |
