8th December 2009, 05:04 | #6221 | Link |
Banned
I gave it a try with the new version and still EARTH_US still had the same error, and i ripped the movie twice with anydvd as always and still the same error message. never had a problem with any other movie
8th December 2009, 17:07 | #6224 | Link |
BD Rebuilder v0.31.05 (beta)
I've updated the first post of this thread with a new release of BD-RB (v0.31.05). Changes for this version:
- Added code to recognize "streams are not syncronized" errors from TSMUXER and take action to automatically workaround by extracting video/audio streams independently. This should fix it in most cases. - Build a workaround routine for movie-only encodes in which the TSMUXER output filename during A/V extract violates length restrictions and causes "Can't create output file" error. - Added new hidden option "USE_NAL_HRD=n". If set to "1" (the default) the "--nal-hrd" parameter is used in the command line. This requires an X264 build which includes the NAL-HRD patch (as is the one included with BD Rebuilder). Setting to "0" (not normally recommended) disables the "--nal-hrd" switch. - Corrected an error that could cause movie-only backups to not extract and remux properly when small enough to fit on the target and it consists of multiple parts. - Updated the included version of X264.EXE to the latest release (r1360 w/nal-hrd patch). - Other minor corrections and cosmetic fixes. Last edited by jdobbs; 8th December 2009 at 18:23. |
8th December 2009, 18:42 | #6225 | Link | |
[11:39:04] BD Rebuilder v0.31.04 (beta) - Source: NIGHT_AT_THE_MUSEUM2 - Input BD size: 19.80 GB - Approximate total content: [01:44:43.277] - Target BD size: 4.27 GB - Windows Version: 6.0 [6002] - MOVIE-ONLY mode enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [11:39:06] PHASE ONE, Encoding - [11:39:06] Extracting A/V streams [VID_00308] - Error in attempt to extract audio/subs. - Not enought buffer for parse video stream. Current frame num 34460 [11:40:03] - Failed to retrieve audio, aborted I made adjustments as someone suggested re: audio setting. same issue. I should have mentioned. This is the US version and BDRB version is 31.04 Thank you in advance for your help! |
8th December 2009, 18:45 | #6226 | Link | |
9th December 2009, 01:10 | #6228 | Link |
The org. (NOTORIOUS BIG) rip with anydvdhd plays back fine. ihave also tryed re-ripping the the disc and othe copy of the disc. i have tried all the newer versions of BD Rebuildier (0.31.05) that i have come after and still getting the following error message:
[00:14:33] BD Rebuilder v0.30.02 (beta) - Source: NOTORIOUS_BIG - Input BD size: 41.79 GB - Approximate total content: [04:48:58.370] - Target BD size: 7.72 GB - Windows Version: 5.1 [2600] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [00:14:41] PHASE ONE, Encoding - [00:14:41] Extracting A/V streams [VID_00157] - [00:14:45] Reencoding: VID_00157 (1 of 86) - [00:14:53] Extracting A/V streams [VID_00100] - [00:14:55] Reencoding: VID_00100 (2 of 86) - [00:15:00] Extracting A/V streams [VID_00308] - [00:15:03] Reencoding: VID_00308 (3 of 86) - [00:15:20] Extracting A/V streams [VID_00306] - [00:15:23] Reencoding: VID_00306 (4 of 86) - [00:15:43] Extracting A/V streams [VID_00310] - [00:15:47] Reencoding: VID_00310 (5 of 86) - [00:16:08] Extracting A/V streams [VID_00314] - [00:16:12] Reencoding: VID_00314 (6 of 86) - [00:16:37] Extracting A/V streams [VID_00352] - [00:16:41] Reencoding: VID_00352 (7 of 86) - [00:16:41] Reencoding secondary video [TRK_02] - [00:17:19] Extracting A/V streams [VID_00001] - [00:17:24] Reencoding: VID_00001 (8 of 86) - [00:17:37] Extracting A/V streams [VID_00350] - [00:17:41] Reencoding: VID_00350 (9 of 86) - [00:17:41] Reencoding secondary video [TRK_02] - [00:18:41] Extracting A/V streams [VID_00312] - [00:18:45] Reencoding: VID_00312 (10 of 86) - [00:19:17] Extracting A/V streams [VID_00313] - [00:19:22] Reencoding: VID_00313 (11 of 86) - [00:19:54] Extracting A/V streams [VID_00398] - [00:19:58] Reencoding: VID_00398 (12 of 86) - [00:21:12] Extracting A/V streams [VID_00397] - [00:21:17] Reencoding: VID_00397 (13 of 86) - [00:22:33] Extracting A/V streams [VID_00393] - [00:22:37] Reencoding: VID_00393 (14 of 86) - [00:23:54] Extracting A/V streams [VID_00370] - [00:23:59] Reencoding: VID_00370 (15 of 86) - [00:23:59] Reencoding secondary video [TRK_02] - [00:24:13] Extracting A/V streams [VID_00394] - [00:24:18] Reencoding: VID_00394 (16 of 86) - [00:25:44] Extracting A/V streams [VID_00374] - [00:25:49] Reencoding: VID_00374 (17 of 86) - [00:26:08] Extracting A/V streams [VID_00369] - [00:26:14] Reencoding: VID_00369 (18 of 86) - [00:26:14] Reencoding secondary video [TRK_02] - [00:26:34] Extracting A/V streams [VID_00340] - [00:26:41] Reencoding: VID_00340 (19 of 86) - [00:26:41] Reencoding secondary video [TRK_02] - [00:27:49] Extracting A/V streams [VID_00399] - [00:27:56] Reencoding: VID_00399 (20 of 86) - [00:29:28] Extracting A/V streams [VID_00328] - [00:29:34] Reencoding: VID_00328 (21 of 86) - [00:29:34] Reencoding secondary video [TRK_02] - [00:30:54] Extracting A/V streams [VID_00307] - [00:31:00] Reencoding: VID_00307 (22 of 86) - [00:31:44] Extracting A/V streams [VID_00003] - [00:31:52] Reencoding: VID_00003 (23 of 86) - [00:32:13] Extracting A/V streams [VID_00319] - [00:32:19] Reencoding: VID_00319 (24 of 86) - [00:32:38] Extracting A/V streams [VID_00309] - [00:32:45] Reencoding: VID_00309 (25 of 86) - [00:33:29] Extracting A/V streams [VID_00366] - [00:33:36] Reencoding: VID_00366 (26 of 86) - [00:33:36] Reencoding secondary video [TRK_02] - [00:33:59] Extracting A/V streams [VID_00364] - [00:34:04] Reencoding: VID_00364 (27 of 86) - [00:34:04] Reencoding secondary video [TRK_02] - [00:34:26] Extracting A/V streams [VID_00358] - [00:34:33] Reencoding: VID_00358 (28 of 86) - [00:34:33] Reencoding secondary video [TRK_02] - [00:34:57] Extracting A/V streams [VID_00344] - [00:35:03] Reencoding: VID_00344 (29 of 86) - [00:35:03] Reencoding secondary video [TRK_02] - [00:36:32] Extracting A/V streams [VID_00316] - [00:36:40] Reencoding: VID_00316 (30 of 86) - [00:37:32] Extracting A/V streams [VID_00359] - [00:37:38] Reencoding: VID_00359 (31 of 86) - [00:37:38] Reencoding secondary video [TRK_02] - [00:38:03] Extracting A/V streams [VID_00346] - [00:38:10] Reencoding: VID_00346 (32 of 86) - [00:38:10] Reencoding secondary video [TRK_02] - [00:39:33] Extracting A/V streams [VID_00305] - [00:39:41] Reencoding: VID_00305 (33 of 86) - [00:40:09] Extracting A/V streams [VID_00311] - [00:40:17] Reencoding: VID_00311 (34 of 86) - [00:41:14] Extracting A/V streams [VID_00330] - [00:41:22] Reencoding: VID_00330 (35 of 86) - [00:41:22] Reencoding secondary video [TRK_02] - [00:43:00] Extracting A/V streams [VID_00392] - [00:43:08] Reencoding: VID_00392 (36 of 86) - [00:45:27] Extracting A/V streams [VID_00395] - [00:45:37] Reencoding: VID_00395 (37 of 86) - [00:48:05] Extracting A/V streams [VID_00322] - [00:48:13] Reencoding: VID_00322 (38 of 86) - [00:48:13] Reencoding secondary video [TRK_02] - [00:50:16] Extracting A/V streams [VID_00355] - [00:50:24] Reencoding: VID_00355 (39 of 86) - [00:50:24] Reencoding secondary video [TRK_02] - [00:50:57] Extracting A/V streams [VID_00342] - [00:51:06] Reencoding: VID_00342 (40 of 86) - [00:51:06] Reencoding secondary video [TRK_02] - [00:53:09] Extracting A/V streams [VID_00332] - [00:53:20] Reencoding: VID_00332 (41 of 86) - [00:53:20] Reencoding secondary video [TRK_02] - [00:55:16] Extracting A/V streams [VID_00360] - [00:55:26] Reencoding: VID_00360 (42 of 86) - [00:55:26] Reencoding secondary video [TRK_02] - [00:56:03] Extracting A/V streams [VID_00338] - [00:56:13] Reencoding: VID_00338 (43 of 86) - [00:56:13] Reencoding secondary video [TRK_02] - [00:58:15] Extracting A/V streams [VID_00365] - [00:58:26] Reencoding: VID_00365 (44 of 86) - [00:58:26] Reencoding secondary video [TRK_02] - [00:59:03] Extracting A/V streams [VID_00337] - [00:59:15] Reencoding: VID_00337 (45 of 86) - [00:59:15] Reencoding secondary video [TRK_02] - [01:01:29] Extracting A/V streams [VID_00327] - [01:01:39] Reencoding: VID_00327 (46 of 86) - [01:01:39] Reencoding secondary video [TRK_02] - [01:04:20] Extracting A/V streams [VID_00367] - [01:04:32] Reencoding: VID_00367 (47 of 86) - [01:04:32] Reencoding secondary video [TRK_02] - [01:05:13] Extracting A/V streams [VID_00336] - [01:05:24] Reencoding: VID_00336 (48 of 86) - [01:05:24] Reencoding secondary video [TRK_02] - [01:08:01] Extracting A/V streams [VID_00341] - [01:08:12] Reencoding: VID_00341 (49 of 86) - [01:08:12] Reencoding secondary video [TRK_02] - [01:11:00] Extracting A/V streams [VID_00372] - [01:11:14] Reencoding: VID_00372 (50 of 86) - [01:14:27] Extracting A/V streams [VID_00347] - [01:14:40] Reencoding: VID_00347 (51 of 86) - [01:14:40] Reencoding secondary video [TRK_02] - [01:17:36] Extracting A/V streams [VID_00348] - [01:17:49] Reencoding: VID_00348 (52 of 86) - [01:17:49] Reencoding secondary video [TRK_02] - [01:20:50] Extracting A/V streams [VID_00333] - [01:21:04] Reencoding: VID_00333 (53 of 86) - [01:21:04] Reencoding secondary video [TRK_02] - [01:23:50] Extracting A/V streams [VID_00363] - [01:24:03] Reencoding: VID_00363 (54 of 86) - [01:24:03] Reencoding secondary video [TRK_02] - [01:27:07] Extracting A/V streams [VID_00315] - [01:27:22] Reencoding: VID_00315 (55 of 86) - [01:31:04] Extracting A/V streams [VID_00368] - [01:31:20] Reencoding: VID_00368 (56 of 86) - [01:31:20] Reencoding secondary video [TRK_02] - [01:34:47] Extracting A/V streams [VID_00373] - [01:35:02] Reencoding: VID_00373 (57 of 86) - [01:38:57] Extracting A/V streams [VID_00371] - [01:39:13] Reencoding: VID_00371 (58 of 86) - [01:43:07] Extracting A/V streams [VID_00396] - [01:43:24] Reencoding: VID_00396 (59 of 86) - [01:53:38] Extracting A/V streams [VID_00331] - [01:53:59] Reencoding: VID_00331 (60 of 86) - [01:53:59] Reencoding secondary video [TRK_02] - [01:57:37] Extracting A/V streams [VID_00304] - [01:57:57] Reencoding: VID_00304 (61 of 86) - [02:05:50] Extracting A/V streams [VID_00343] - [02:06:08] Reencoding: VID_00343 (62 of 86) - [02:06:08] Reencoding secondary video [TRK_02] - [02:10:33] Extracting A/V streams [VID_00324] - [02:10:54] Reencoding: VID_00324 (63 of 86) - [02:10:54] Reencoding secondary video [TRK_02] - [02:15:33] Extracting A/V streams [VID_00362] - [02:15:55] Reencoding: VID_00362 (64 of 86) - [02:15:55] Reencoding secondary video [TRK_02] - [02:20:57] Extracting A/V streams [VID_00356] - [02:21:20] Reencoding: VID_00356 (65 of 86) - [02:21:20] Reencoding secondary video [TRK_02] - [02:26:29] Extracting A/V streams [VID_00303] - [02:26:57] Reencoding: VID_00303 (66 of 86) - [02:36:57] Extracting A/V streams [VID_00334] - [02:37:23] Reencoding: VID_00334 (67 of 86) - [02:37:23] Reencoding secondary video [TRK_02] - [02:42:51] Extracting A/V streams [VID_00361] - [02:43:20] Reencoding: VID_00361 (68 of 86) - [02:43:20] Reencoding secondary video [TRK_02] - [02:50:21] Extracting A/V streams [VID_00321] - [02:50:50] Reencoding: VID_00321 (69 of 86) - [02:50:50] Reencoding secondary video [TRK_02] - [02:58:11] Extracting A/V streams [VID_00302] - [02:58:46] Reencoding: VID_00302 (70 of 86) - [03:20:26] Extracting A/V streams [VID_00301] - [03:21:04] Reencoding: VID_00301 (71 of 86) - [03:43:11] Extracting A/V streams [VID_00349] - [03:43:41] Reencoding: VID_00349 (72 of 86) - [03:43:41] Reencoding secondary video [TRK_02] - [03:51:34] Extracting A/V streams [VID_00339] - [03:52:08] Reencoding: VID_00339 (73 of 86) - [03:52:08] Reencoding secondary video [TRK_02] - [03:59:27] Extracting A/V streams [VID_00325] - [04:00:07] Reencoding: VID_00325 (74 of 86) - [04:00:07] Reencoding secondary video [TRK_02] - [04:08:56] Extracting A/V streams [VID_00351] - [04:09:35] Reencoding: VID_00351 (75 of 86) - [04:09:35] Reencoding secondary video [TRK_02] - [04:19:20] Extracting A/V streams [VID_00381] - [04:20:03] Reencoding: VID_00381 (76 of 86) - [04:20:03] Reencoding secondary video [TRK_02] - [04:31:48] Extracting A/V streams [VID_00383] - [04:32:38] Reencoding: VID_00383 (77 of 86) - [04:32:38] Reencoding secondary video [TRK_02] - [04:45:31] Extracting A/V streams [VID_00323] - [04:46:23] Reencoding: VID_00323 (78 of 86) - [04:46:23] Reencoding secondary video [TRK_02] - [04:59:49] Extracting A/V streams [VID_00354] - Error in attempt to MKVMERGE. [05:00:43] - Failed to retrieve audio, aborted |
9th December 2009, 02:28 | #6229 | Link |
@dragonknight;
This may not be related, but it seems like an awful lot of content to be backed up to a BD9. (Approximate total content: [04:48:58.370]) Have you tried to BD-25, or even just a movie only backup to BD9, just to rule out a few other potential options? |
9th December 2009, 03:58 | #6230 | Link |
Odd Problem
Trying to back up Angels and Demons.
Full Movie Back up to BD25 Code:
----------------------- [12:32:55] BD Rebuilder v0.31.05 (beta) - Source: ANGELS_AND_DEMONS - Input BD size: 41.02 GB - Approximate total content: [03:01:14.905] - Target BD size: 22.46 GB - Windows Version: 6.0 [6002] - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [12:32:56] PHASE ONE, Encoding - [12:32:56] Extracting A/V streams [VID_00530] - [12:33:06] Reencoding: VID_00530 (1 of 53) - Error in attempt to multiplex: MUX_00530.meta - H.264 stream does not contain fps field. Muxing fps=23.976 [16:37:41] - Failed to build structure, aborted Code:
- [21:21:38] Extracting A/V streams [VID_00530] - [21:21:47] Reencoding: VID_00530 (16 of 32) - [21:22:49] Extracting A/V streams [VID_00532] cwh |
9th December 2009, 15:17 | #6232 | Link | |
9th December 2009, 17:00 | #6235 | Link |
This is usually caused by there being lots of duplicate and unnecessary audio tracks in the extras. Try changing your settings to only one audio and then adding in any extra ones you need in the main movie by double clicking on them (for instance for a commentary track). Sometimes you can just continue and the output size is okay. I certainly did Mummy 4 several months ago and it was okay.
9th December 2009, 17:10 | #6236 | Link | |
Any luck w/ Night at Meuseum2? I'm still trying and still having issues. I did have an issue w/ Angels and Demons but 31.05 seems to have corrected it.
LG GGW-H20 Burner PS3 Playback Intel i7 920 Asus P6T 2X 9800 GT SLI Vista Region A Location Texas |
9th December 2009, 18:26 | #6237 | Link | |
@jdobbs
Am using Windows Vista 64b (i920CPU). When I was trying to reproduce the Full Version, there was also a pop up window, saying TSEMuxer failed and the option to "Close the Program". I was not near the computer when this happened so I can't give a timeline. In the original log file the crash appears to have happened 4 hours after reporting the inital error. So my assuption is that TSEMUX, just died when nothing was happening. I backed up Movie Only with no problem. I am going to try the full version again later today. Thanks cwh |
9th December 2009, 20:23 | #6238 | Link | |
You are having a setup issue with Haali or ffdshow. |
9th December 2009, 22:00 | #6239 | Link |
BD-Rebuilder
What happen to Iron man -----------------------
[21:44:55] BD Rebuilder v0.31.02 (beta) - Source: IRON_MAN_D1 - Input BD size: 31.15 GB - Approximate total content: [02:06:01.679] - Target BD size: 7.72 GB - Windows Version: 6.0 [6000] - MOVIE-ONLY mode enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [21:44:55] PHASE ONE, Encoding - [21:44:55] Extracting A/V streams [VID_00010] - [21:58:29] Reencoding: VID_00010 (1 of 1) - [21:58:29] Collecting video information - Video: 1920x1080, 23.976fps, 181,299 frames - Bitrate: 7,375 Kbs - [21:58:29] Reencoding: VID_00010, Pass 1 of 2 - [00:27:50] Reencoding: VID_00010, Pass 2 of 2 - Encode failed. Retrying. |
10th December 2009, 00:08 | #6240 | Link | |
