1st September 2009, 15:57 | #4542 | Link |
1st September 2009, 16:41 | #4544 | Link |
Are you sure you want to convert a complex form like your x264 form or mix WPF and WinForms in the same application? I've done some mixing too but only a small piece. I had a WinForms custom control with 350 lines code and replaced it with a WPF version achieving the same thing with only 50 lines code so I have smaller code and a little fun learning WPF. I'm looking forward to use WPF in the player I'm building.
1st September 2009, 17:50 | #4545 | Link |
Swallowed in the Sea
Honestly I don't know...I've some random ideas but I'm not sure that it's doable or not. If I jump to WPF and succeed, x264 form will change probably...In fact, all forms must be changed.
2nd September 2009, 19:27 | #4548 | Link |
got a bug with latest megui, i get the following when closing megui after i manually replaced x264.exe v1235 32bit with x264.exe v1146 32bit:
also in "update" it shows the version as v1135 still instead of reading the x264.exe to see what build it is. Hopefully you can fix these 2 bugs shortly, many thanks Last edited by hajj_3; 2nd September 2009 at 19:35. |
2nd September 2009, 20:28 | #4549 | Link |
It's bad practice to show a stack trace to the user, it's bad practice to save to a system directory and it's bad practice to require elevated privileges in order to be able doing so.
2nd September 2009, 20:37 | #4551 | Link |
0.3.1.1055 is the version of megui i am using.
as you can see in the above screenshot it says that i have x264 v1135 installed but i actually have v1146 as i manually over-wrote the x264.exe in program files\megui\tools\x264. It should report the actual version i'm using. |
4th September 2009, 23:11 | #4554 | Link | |
ASXGui Developer
5th September 2009, 03:02 | #4555 | Link |
Because labels don't have a border unless you draw one or apply a style using pinvoke.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 5th September 2009 at 09:40. |
6th September 2009, 00:01 | #4557 | Link |
I didn't notice it's that simple, last time I only saw and tested the FlatStyle property and didn't notice the BorderStyle property. Sometime the easiest things are hard to see.
development, megui, not a help thread |
