14th October 2015, 11:24 | #326 | Link |
Well I'm stuck with MeGUI x64 2237, because the newer x86 versions are simply not working for me
Index with DGindexnv -> not working AVS create from a manually created *.dgi -> crash Preview of a manually created *.avs -> crash Encode of the *.avs without preview -> crash 2237 x64 is running for years without problems, let alone the fact, that HD Stream Extractor cannot handle 3D Blurays. |
14th October 2015, 17:35 | #327 | Link |
Post your problems with more details (e.g. logs) please in the other MeGUI thread so that we may see what the problem is.
Nevertheless if you want a more recent x64 build: EDIT: See below I have only compiled it - not tested at all. Also you have to find/copy the required updated packages manually. Last edited by Zathor; 17th October 2015 at 15:36. |
16th October 2015, 19:32 | #328 | Link | |
Acid fr0g
@turment on Telegram |
17th October 2015, 16:18 | #330 | Link | |
Exception message: Could not load file or assembly 'SevenZipSharp, Version=0.64.3890.29348, Culture=neutral, PublicKeyToken=20de82c62b055c88' or one of its dependencies. The system cannot find the file specified. |
18th October 2015, 11:42 | #332 | Link |
It works for me - at least I can start it. Here is a download of my DLL files:
MeGUI x64 + DLLs |
18th October 2015, 12:52 | #333 | Link | |
Acid fr0g
The issue now is it keeps on wanting to install AVS 2.5.8 portable.
18th October 2015, 17:27 | #334 | Link |
This is expected as I have only updated the core program. the files on the update server have not been changed and I do not plan to do so atm. Update the files yourself e.g. from AviSynth+ x64. Also several filters cannot be found.
26th October 2015, 23:05 | #340 | Link |
I have updated the version on the server and in the first post to 2611. Most of the used packages have not been updated. Also you will get a message during startup that components are missing. This is because not all filters are availble in 64bit versions.
