15th May 2020, 17:52 | #1802 | Link |
@jonrodrigos
Maybe it's because you don't have a custom path to the included portable python.
15th May 2020, 18:21 | #1803 | Link |
16th May 2020, 07:01 | #1804 | Link |
For a while now I've been using Turing Nvenc my encodes (1080p) I have just got a Ryzen 3900x and was wondering if there's any settings out there I can use that would get me the same quality output but for potentially less bitrate/file sizes?
This is what I use for 1080p Blurays --vbrhq 4400 --codec h265 --preset quality --profile main10 --level 5.1 --output-depth 10 --max-bitrate 4400 --aq --aq-temporal --bref-mode each --bframes 5 --ref 15 --gop-len 240 --lookahead 32 --output-buf 32 --vpp-unsharp radius=2,weight=0.65,threshold=20 --vpp-edgelevel strength=6.0,threshold=16.0,black=0,white=0 And this for older Blurays with a lot of noise --vbrhq 4400 --codec h265 --preset quality --profile main10 --level 5.1 --output-depth 10 --max-bitrate 4400 --aq --aq-temporal --bref-mode each --bframes 5 --ref 15 --gop-len 240 --lookahead 32 --output-buf 32 --vpp-knn --vpp-unsharp radius=2,weight=0.65,threshold=20 --vpp-edgelevel strength=6.0,threshold=16.0,black=0,white=0 Should I change over to x265 or continue with Nvenc and is there anything I should change? If anyone could point me in the right direction that would be great |
16th May 2020, 19:39 | #1805 | Link |
Could someone provide me with some pointers on how to enable FFV1 version 3 encoding (-c:v ffv1 -level 3) in Staxrip, using ffmpeg of course? I can't figure out how to add it to encoding options. Using beta 2.1.1.1, btw. Thanks.
17th May 2020, 09:34 | #1810 | Link | |
17th May 2020, 09:49 | #1811 | Link |
@Arkana
Which GPU is in use?
17th May 2020, 10:28 | #1812 | Link |
Staxrip 2.1.1.1 beta stops processing on an error before writing a single frame when trying to output ProRes. Same job works fine in 2.0.8.0 Stable (edit: after it prompted to install Avisynth). I'll add what little information I can gather of the crash shortly.
Job: deinterlacing and IVTC'ing a music video. TFM() TDecimate(cycle=25,cycleR=5) DeBlock QED (defaults) VagueDeNoiser (defaults) Output to ProRes normal profile. update: Figured out why 2.1.1.1 beta throws in the towel. Avisynth+ was not installed. Odd though, I have done perhaps two dozen jobs on 2.1.1.1 and it never complained about Avisynth missing. I ran 2.0.8.0 the first time on this PC today; it told me to install Avisynth, and once I did that, 2.1.1.1 began outputting ProRes as well. (Sidetrack: Could someone shed some light on why the CPU load remains at 4% for the job mentioned above? I get 10fps out of StaxRip with that 4%. Would be awesome to get the job done faster; where's the bottleneck?) Last edited by colinhunt; 17th May 2020 at 10:44. |
17th May 2020, 10:53 | #1813 | Link |
MSVC (Microsoft Visual C) and GCC (GNU Compiler Collection) are different compilers. You are right with the statement that the methods of compiling are different. As a result, there are performance differences in the builds.
17th May 2020, 12:24 | #1814 | Link |
@colinhunt
2.1.1.3 is portable, I've not installed avisynth or fftw, tried all your configuration and it worked fine.
17th May 2020, 16:00 | #1815 | Link | |
One note: I have an AMD 3950X with 16 cores / 32 threads. I found the sweet spot to be between 12 and 16 threads when using X265. Just because you have a lot of threads does not mean you will get a speed bump beyond a certain point. |
17th May 2020, 16:03 | #1816 | Link | |
17th May 2020, 17:50 | #1818 | Link |
In the x265 dialog the Custom tab can be used for this, custom switches override GUI switches.
17th May 2020, 17:53 | #1819 | Link | |
@stax76 - I know you are busy with tons of stuff. IDK if you would want to do this, but could you add a way to setup more then just 2 audio tracks. For those rare films/etc where there is 3 or 4 of them? Also is there anyway you could add a DTS down mix to core option for the audio section? You can do this with ffmpeg via a command like this "-c:v copy -bsf:a dca_core -c:a copy" and I know there is a way to do it with mkv. Thanks! Last edited by jlw_4049; 17th May 2020 at 18:38. |
17th May 2020, 19:12 | #1820 | Link | ||
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
