Old 25th September 2022, 08:29   #19621  |  Link
Polish? Ripbot is in english. There is nothing to figure out.
PS:- is that Windows 11 I see there
Yes. Specially for you so you won't complain again that something "DOES NOT WORK" on you precious latest and greatest OS
Old 25th September 2022, 08:34   #19622  |  Link
TDS
Formally known as .......
TDS's Avatar
What is wrong with you....you just seem to be angry most of the time ??
I know RipBot is English, but all the drop down context menu's aren't !!!
Long term RipBot264 user.
RipBot264 modded builds..
TDS is offline   Reply With Quote
Old 25th September 2022, 08:37   #19623  |  Link
Problem?
Old 25th September 2022, 08:40   #19624  |  Link
TDS
TDS's Avatar
Problem?
Not a problem for you....
Have you "pulled" the video off YT ???
Glad I downloaded it .....I have figured out the translation, and now it makes sense to me.
UPDATE:- I have tried this over & over & over again, it will import & prepare the chosen file, but it won't start encoding.
Does this use DE ???, 'cause even your YT clip showed it just doing the encode the "single" way.
Old 30th September 2022, 13:44   #19625  |  Link
gabbett1
Hello, I currently have AviSynthPlus_3.7.2_20220317 installed on my computer, but every time I try to start my encoding server a popup says: AviSynth+ MT x64 not installed.
I'm currently running RipBot264 version 1.26.2
gabbett1 is offline   Reply With Quote
Old 30th September 2022, 21:33   #19626  |  Link
gabbett1
Originally Posted by TDS View Post
It seems that you haven't installed it the way RipBot needs it to be...
Go to the Avisynth install folder, from the version you've got, there should be a Libraries folder, with x64 & x86 folders within that folder.
Copy these to the RipBot Tools, Avisynth folder, into the Libraries folder, overwriting what's in there, then run the install.cmd file.
If you follow that, that should fix your problem.
Or you could use this :-
https://www.mediafire.com/file/r5q2t...raries.7z/file
Tried doing that and didn't seem to work.
Old 30th September 2022, 23:32   #19627  |  Link
TDS
TDS's Avatar
Well, that's very strange !!!
What version of Windows are you running ??
Old 1st October 2022, 14:38   #19628  |  Link
gabbett1
Originally Posted by Pauly Dunne View Post
Hi gabbett1,
You must have something odd going on there...
May I suggest you at least try this :-
https://www.mediafire.com/file/caq1q...virgin.7z/file
But I recommend you give this a try :-
https://www.mediafire.com/file/8xcys...2%2529.7z/file
Good luck
Thanks. Tried the first link and have the same issue.
I've been having all sorts of issues with this program. I can't even get my encoding server to work anymore. I'm thinking about reformatting my PC and starting from scratch. This is about the only thing I use this PC for and I can't even get the program to work right.
Old 1st October 2022, 14:59   #19629  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Well, that's frustrating !!!!
I just did a fresh setup of Windows 11 22H2, and used the second link's build, and everything ran sweet, straight off
But, the first link's build should work OK as well.
I think a fresh setup is the way to go
I can relate to the "pain" you're feeling, as most of my PC's are for RipBot, mainly.
Live every day like it's your last, because one day, it will be !! (M$B)
Old 1st October 2022, 18:59   #19630  |  Link
JThomasG
encodingserver not starting
im running on Windows 11
EncodingServer is not starting as it should
i can see the process running but window/icon wont show up and encoding will not start on this computer.
do anyone have any ideas (i know it not much to go on :\ )
edit: additional info, looking at analyse chain work under encoding server process i can see that encoding server is waiting on asus framework thread for some reason...?
manually killing the asus framework process started encoding server. Perhaps something for Developer to look at?^
/tnx
JThomasG is offline   Reply With Quote
Old 1st October 2022, 23:18   #19631  |  Link
Indeed you should Ask Asus why they block my software.
Old 2nd October 2022, 00:50   #19632  |  Link
Pauly Dunne
Grumpy Old Man.
Originally Posted by JThomasG View Post
/tnx
First off, welcome to the Forum....
Now this is all very interesting, like I said, I just installed Windows 11 22H2, and also installed all the Asus Amoury Crate, etc stuff, and I'm not having this issue, however....
I did a bit of Googling, and found this :-
https://rog.asus.com/forum/showthrea...ice-to-respond
Maybe there's a port assignment problem here, so it might depend on the IP addressing that you're using. That's my take on it, anyway.
I use 192.168.1.xxx on my home network, I use to use 192.168.0.xxx, and that led to some issues.
I was also going to suggest that it might nVidia driver's, or some Logitech driver's or even vc_redist.... but good on you for stating what YOUR problem was
Now, there are options within RipBot to be able to "set" the IP address, and the listening port, so maybe you could try that.
https://i.imgur.com/qeVyG18.jpg
Good luck.
Old 2nd October 2022, 15:27   #19633  |  Link
gabbett1
This is an "older" PC so Windows 11 is probably out. I may upgrade to Windows 10 vs what I'm running now (Win 7).
Old 3rd October 2022, 00:54   #19634  |  Link
TDS
TDS's Avatar
How old, is old ??
You CAN run W11 on an older PC, if you know what you're doing !!
You could also go for Windows 10 22H2 !
So it's interesting to know that you're having RipBot problems with Windows 7.
Old 3rd October 2022, 20:57   #19635  |  Link
gabbett1
How old, is old ??
I'm running an i7-7700k from 2017.
Old 4th October 2022, 05:20   #19636  |  Link
TDS
TDS's Avatar
Dark Theme
For all of us that prefer to use Windows 10 or 11.
Here's another crazy feature request :-
Would there be any chance that RipBot could have the option of the Windows Dark Theme, it's SO much easier on the eye's.
Old 11th October 2022, 13:19   #19637  |  Link
archiel
Issue with eac3 audio - Resolved see edit below
I am trying to do a batch run on some that have been encoded using eac3, but the audio file, as shown in the encoding settings is the wrong length / not the same length as shown via MediaInfo before demuxing. This results in the output files with mismatched Audio/Video. It does not matter whether I select an audio profile or just copy the audio stream.
if I load MediaInfo data after the file is loaded by clicking on EAC3 in Encoding settings I see
Complete name : H:\Temp\RipBot264temp\job1\1_audio_English_DEFAULT.eac3
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
File size : 64.0 MiB
Duration : 46 min 34 s
Overall bit rate mode : Constant
Overall bit rate : 192 kb/s
Audio
Format : E-AC-3
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 64.0 MiB (100%)
Service kind : Complete Main
However I just load the source file i get the following Audio data
Format : E-AC-3
Codec ID : A_EAC3
Duration : 46 min 16 s
Bit rate : 192 kb/s
Bit depth : 32 bits
Stream size : 63.6 MiB (4%)
Language : English
Edit- If I simply extract the audio file (to mka) from mvktoolnix or .eac3 via mkvextract I still see the file length changes. If I simply convert the audio in ffmpeg, then the audio length is unaffected.
I think I need to take this over to the mkvmerge forums, but is anyone is seeing his (can they replicate). If it is relevant I am running win11 22H2 pro.
The audio was fine, but the video was reporting the wrong frame rate, which resulted in an incorrect duration. At a guess the whole file had been cropped, but not on a key frame, so the first block had a different frame rate - the file showed as 24.131 instead of 23.976, the rate for the rest of the file.
Thanks, Archiel
(I did a quick search on eac3 but did not find anything, so apologies if this is already noted)
archiel is offline   Reply With Quote
Old 12th October 2022, 00:35   #19638  |  Link
TDS
TDS's Avatar
I think I need to take this over to the mkvmerge forums, but is anyone is seeing this (can they replicate). If it is relevant I am running win11 22H2 pro.
Thanks, Archiel
Interesting problem you've got there...any chance of uploading a sample or the whole file you're having problems with ??
Old 12th October 2022, 10:02   #19639  |  Link
archiel
Turns out I was trying to solve the wrong problem, but your request to upload pushed me in the right direction. The issue was not with the audio but the video! It looks as if the original files were cropped, but not on a cut frame. [Only noticed this after cropping a section to upload and comparing the MediaInfo data.]
The result was that the file framerate was reported as 24.131 instead of 23.976 (the framerate for everything after the first block) and this meant that the file duration was read as being 46:16 rather than 46:34. Forcing the framerate to 23.96 (AviSynth > Output Speed > Assume -> 23.976) meant that the files can now be processed.
Now I just need to work out how to add the frame rate change as a script to batch processing.
Old 12th October 2022, 12:30   #19640  |  Link
archiel
Changing Frame Rate
Can anyone assist in how to change the Frame Rate for a batch processing?
I know I can edit each entry manually - go to AviSynth > Output Speed and select the required FPS and it appears that the only file modified in the temp job folder is info.txt
e.g. from-------------------to
67008----------------------67008
24.131201---------------23.976023
48000----------------------48000
6---------------------------6
134154240---------------135015788
1280-----------------------1280
720-------------------------720
YV12------------------------YV12
But what do I need to add as a script to do the conversion?
