29th November 2016, 13:46 | #40961 | Link | |
http://forum.doom9.org/showthread.ph...40#post1787840 If I use SVP on top of that (which I love, because itīs miles better than smooth motion for my personal taste) then performance is much worse and you canīt go above NGU medium settings without dropping frames. |
29th November 2016, 13:53 | #40962 | Link | |
29th November 2016, 13:59 | #40963 | Link |
SmoothVideo Project (SVP)
https://www.svp-team.com/wiki/Main_Page To my taste, works much better than the interpolation settings in my TV (Auto Motion Plus = either insufficient or creates "soap opera" effect). But it takes a toll in performance, specially paired with an also resource hungry madvr (which I love btw! ) Last edited by ROKUGAN; 29th November 2016 at 14:13. |
29th November 2016, 14:32 | #40965 | Link |
no it doesn't keep SVP off and SVP and smooth motion quite different smoothmotion can't create soap opera effect and SVP want to created soap opera effect(they stated this on there page...). SVP also want to make the source more smooth than playback at the correct refresh rate. smooth motion can't be more smooth than playback at the correct refresh rate.
for example using SVP to double 23 hz to 47 hz and using smooth motion to present this at 60 hz isn't a bad idea and it avoids the problems from a 5/2 interpolations. |
29th November 2016, 14:38 | #40966 | Link |
You can keep it on, but itīs unnecessary with SVP so I keep it off. Follow this guide if you want to try it out:
http://www.overclock.net/t/1385468/s...cussion-thread |
29th November 2016, 15:53 | #40967 | Link | |
So a G-/Freesync game should be just as (un)smooth as G-/Freesynced video. Also, things in the settings that still need to be clearer: - "downscale quality" should also say what the algorithm actually is. - "chroma quality", what is this and why is it active with NNEDI3 but not NGU? - NNEDI3/NGU, "activate only if it's useful", what is being used to upscale when it's *not* useful? - When scaling using DXVA, it should say that it also handles chroma (I'm assuming that it does). |
29th November 2016, 16:08 | #40969 | Link |
http://screenshotcomparison.com/comparison/192201 (i think the glitches can be ignored, they only started when i disabled overlay to take the screens)
well i love sharpness, but even for me NGU is too destructive to even clean low res animation compared to nnedi3 i'd much rather put on a bit of edge thinning (not in screenshot) and put up with a little softness than deal with the mess NGU makes at the moment
Windows 10 // i7-8700k + GTX 1080 SLI // MPC-BE x64 + LAV + XySubFilter Last edited by zvans18; 29th November 2016 at 16:11. |
29th November 2016, 16:16 | #40970 | Link |
@madshi v0.91.3
Feedback: Overall, a well done improvement cleaning house. Really appreciate that you've kept NNEDI3 even though I have shifted to NGU as my default for all profiles. I think the simplification was done in good taste even though I usually detest the limiting of choices. Maybe a "full/expert" versus "simple/minimal" is in order to avoid needless frametime troubleshooting and satisfy those who would like more control/tuning? The downscale pulldown menu in the "image upscaling" section is the only thing I find redundant and should probably be removed. Was the "image downscaling" section ever an issue? Keep up the good work madshi. |
29th November 2016, 16:47 | #40972 | Link | |
with video though we already have finished frames and know beforehand when a frame is supposed to be shown. and according to madshi that's the whole problem. there is no API allowing you to tell when to display a frame. from what I understand with games the display sync with gsync is triggered in hardware by the completion of a frame rendering. you can't apply that to videos. Last edited by Sp00kyFox; 29th November 2016 at 20:58. |
29th November 2016, 17:39 | #40973 | Link |
Does anyone else have issues with Windows occasionally locking up to a black screen after exiting/closing a video while in fullscreen exclusive mode? This happened here or there in the past with D3D9 FSE, but with D3D11 FSE it seems to be happening more often (couple times a week). About 5% of the time after closing the player the screen will go black, and I will have to do a hard reset with the power button and reboot the pc.
As a test if I quickly cycle between windowed and FSE over and over occasionally it does the same thing and just crashes to full black screen. Windows 10 x64 HD 7770 with latest AMD drivers MPC-HC as player |
29th November 2016, 18:13 | #40974 | Link |
Kid for Today
I thought it was due to PotPlayer that I sometimes got a black screen for a second or two when closing it but creating a "madVR\DontRenderAfterStop" empty folder fixed it as far as I can tell. Prolly unrelated to your problem, though as I always was able to at least open the taskmanager and kill PotP.
29th November 2016, 18:24 | #40976 | Link | |
https://www.youtube.com/watch?v=1MuFWCgDhgE Wether you like the smoothness or not and if it's worth the extra GPU power needed (btw, I use the Intel integrated GPU on SVP and the Nvidia GTX 1080 for Madvr) is up to personal preference. In my case it's totally worth it, but many people doesn't like the smooth "videocam" effect and prefer the classic cinematic 24fps film cadence. I personally dislike the judder and find SVP to be more effective than the settings in my TV. |
29th November 2016, 19:29 | #40977 | Link |
hi all, i'm a madvr user since many years and i really love it. i use it 90% for bluray upscale to 4k TV.
i like NGU very much and i can't think about using different algos from now on. i really want to thank you madshi for your incredible job. i agree that the UI could be improved. IMHO there should be somewhere one "switch" option that allow users to switch to "basic" or "advanced" mode for the scaling section, maybe with a little hint of very few words which explains the difference in order to make it clear: the first one should be provided by default with presets for users who want to make it simple, the second one should be there in order to provide full control without limitations. i noticed that d3d11 is about 2ms slower than d3d9 (win10 x64, geforce 1070, mpc-hc). i have a question: with 91.1 if i set NGU on the same levels (say medium) for both chroma upscale and luma doubling, ctrl+j statistics only shows two NGU upscale processes (chroma, luma). if i set NGU on different levels for chroma upscale and for luma doubling, ctrl+j statistics shows three NGU upscale processes (chroma, luma, chroma). chroma doubling always disabled. 1080->2160 scaling. could someone please explain why? is it better to have only one chroma upscale process in terms of optimal performance and PQ? with 91.3 it looks like not possible to set the same NGU levels for chroma and luma. thank you! |
29th November 2016, 19:31 | #40978 | Link | |
29th November 2016, 19:45 | #40979 | Link |
_
@zvans18: You did not put the original image, so your comparison has less value. There are known case where NGU has limitations, but if you don't post original image, madshi can't analyse where his algorithm can be improved.
For those who make comparison, don't forget the original image. Edit: Good job at not doing it ispano. xD Last edited by pirlouy; 30th November 2016 at 00:33. |
29th November 2016, 20:24 | #40980 | Link |
Setup for comparisons of NGU
I know madshi has implemented a warning for SuperRes but also note this should apply to the "artifact removal" section for "reduce ringing artifacts". You will get aliasing with NGU and dehalo enabled and even stronger aliasing when dark dehalo is checked. It is also stated that dark dehalo is not recommend for anime. Just want to make sure NGU gets a fair shake when people are comparing screenshots. And yes, I agree NNEDI3 does a great job image doubling and striking a good balance. NGU already has Dehalo aka "reduce ringing artifacts" built in I believe which is causing the conflict. Aliasing inherent in the source material will of course be more obvious with NGU. That's also a good reason why NNEDI3 is a good fallback for sources where you want to hide those specific artifacts. Below is my 480p DVD source fed to Vapoursynth w/ AA processing. NGU Very High - Waifu2x - NGU w/ dehalo - NGU w/ dark dehalo NGU Very High Waifu2x NGU Very High w/ Deringing (DeHalo) NGU Very High w/ Dark Dehalo checked. |
