4th October 2010, 22:33 | #8581 | Link | |
4th October 2010, 22:53 | #8582 | Link | |
In order to run RipBot, I have to install the 32 bit version of ffdshow. |
5th October 2010, 03:57 | #8584 | Link |
I came accross frame corruption issue with v1.16.3, when compressing some video into .mkv
problem as following please try the sample video i got problem with http://www.mediafire.com/?4z2as0yjvnjoage I can even see the frame corrupted in ripbot preview feature. but when i used the old version of 1.10.8, video came out just fine. Can you please fix this? Thanks a lot~ |
5th October 2010, 06:21 | #8585 | Link | |
The Black Reaper
I will check out your sample when I get home. Update: The artifacts appears even when I open the original source file when I open it in MPC-HC, it seems that the problem lies with how ffdshowmt decode the file. The earlier version of RipBot works fine as it index the file with DGAVCIndex before encoding. Things changed since v1.13.0. Code:
v1.13.0 Added: support for x264 64bit (up to 10% faster encoding) Added: if COPY STREAM is not selected assumeFPS will also adjust audio speed (easy 25 -> 23.976 conversion) Added: custom resize profile with locked aspect ratio Added: always first VST_01_x.vob will be indexed instead of VIDEO_TS.VOB Added: language combobox for audio stream Added: support for .sup subtitles (Warning!!! Original 1080p .sup WILL NOT be visible in 720p!!!) Added: support for .ass .ssa subtitles in mkv container Added: chapter extraction from .mp4 Added: UAC manifest (from now on you don't have to disable UAC) Added: FFDshow DV decoder will be automatically enabled if necessary Added: BD-25 size Changed: Audio delay for convenient moved to Properties Changed: .ts and .m2t files will be decoded via DirectShowSource instead of DGIndex or DGAVCdec (Reason: Faster decoding with FFDshow MT) Changed: Audio from .ts and .m2t files will be demuxed in one pass Changed: A/V same length combobox removed. CUT function is now always on (Audio and Video will always have the same lenght) Changed: 'Tahoma' font to 'Consolas' (Installed by default in Windows Vista and 7) Fixed: Bug which always resets VC-1 decoder to libavcodec. Default decoder is now wmv9 (Reason: Supports interlaced material) Fixed: error 'Couldn't import DownMix2Stereo.avs' Fixed: jobs.ini will be created immediately after creating new job Update: x264 r1092M , eac3to v3.06 , Oggenc 2.85 aoTuVb5.61 , MediaInfo v0.7.10 Last edited by Lighto; 5th October 2010 at 12:52. |
5th October 2010, 07:18 | #8587 | Link |
Did you check if the original is in the same shape? I've experience an video source are bad and transfert the problem in ripbot264.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
5th October 2010, 10:01 | #8589 | Link |
I am have tried to make a .mkv from a BD, Batman The Dark Knight. It contains a Dolby TrueHD track. I tried to make a .mkv that can play on my Xtreamer.
In the latest Ripbot246 version after demuxing the videostream it only shows up 5.1 PCM that can be converted to AC3 or AAC, but I cannot choose direct stream copy. Why? Am I doing something wrong? Is there limitations to the mkv container that it cannot contain Dolby TrueHD. Otherwise it works fine, and I really like this software Atak has made! |
5th October 2010, 11:08 | #8590 | Link | |
5th October 2010, 15:58 | #8591 | Link |
н∂-ƒαиαтι¢
I encoded 3 short videos and all results are just black. No audio or video playing.
The profile used was [BASE 3.0] iPOD . iPhone . Zune Is it just me who is having this problem? EDIT: Testing another profile. |
5th October 2010, 16:01 | #8592 | Link |
н∂-ƒαиαтι¢
Yup, its gotta be the profile. Tested with PSP profile and all is working well.
EDIT1: Profile is exactly the same as it was in the old build. Maybe something has changed in the new x264 build? EDIT2: The new Simple Mobile Device profile is doing exactly the same thing. No video or audio (black). EDIT3: Encode info using iPod & Simple Mobile Device profiles: Frame rate mode: Constant Frame rate: 25.000 fps Original frame rate: 50.000 fps Encode info using PSP, BluRay & AppleTV profiles: Frame rate mode: Constant Frame rate: 25.000 fps All encodes were done with the same source file. Last edited by ~bT~; 5th October 2010 at 16:40. |
5th October 2010, 16:49 | #8593 | Link | |
The Black Reaper
Upload a sample of the video file so that Atak and the others can help you with it. Last edited by Lighto; 5th October 2010 at 17:00. |
5th October 2010, 18:20 | #8594 | Link | |
н∂-ƒαиαтι¢
5th October 2010, 23:10 | #8597 | Link |
@Atak;
Error to Report: Subtitles get a strange import; when it try to add a subtitle, it add an "_" caracter at the end of the name. If i rename it, it add another "_" at the end and get crashed ripbot264 and can't get out of the subtitles import box. I need to force close. but the error is in the import command. ***edit***IF it's demuxed with 1.16.3; 1.16.2 can't add it too... i test it with 1.16.2 right now and it works if it was demuxed by version 1.16.2. It happen sometimes in the old version, i just need to delete the job and re-create and it's corrected. But the version 1.16.3, it happen strongly! Here an video screenshot: http://rapidshare.com/files/42333347...port_error.avi Here log: job2.avs Code:
#MT #VideoSource video=DirectShowSource("D:\--= Complete =--\****HIDDEN*****.mkv",audio=false).ConvertToYV12() #Deinterlace #Decimate #Crop #Resize video=Spline36Resize(video,1280,692).Sharpen(0.2).AddBorders(0,14,0,14) #Colors #Denoise #Subtitles #AudioSource LoadPlugin("c:\Ripbot264\tools\AviSynth plugins\NicAudio\NicAudio.dll") audio=NicAC3Source("E:\Temp\RipBot264temp\job2\2_audio_French.ac3") audio=ResampleAudio(audio,48000) #DownMix Import("c:\Ripbot264\Tools\AviSynth plugins\Scripts\DownMixAudio.avs") audio=DownMix2Stereo(audio) #Delay audio=DelayAudio(audio,0) #Tempo #Normalize #AudioDub audio=ConvertAudioTo16bit(audio) AudioDub(video,audio) #Triming #AVSameLength Trim(0,154176) #ColorSpace Code:
"c:\Ripbot264\Tools\mkvtoolnix\mkvextract.exe" tracks "D:\--= Complete =--\****HIDDEN*****..mkv" 2:"E:\Temp\RipBot264temp\job2\2_audio_French.ac3" 3:"E:\Temp\RipBot264temp\job2\3_audio_English.ac3" 4:"E:\Temp\RipBot264temp\job2\4_subtitles_French.srt" 5:"E:\Temp\RipBot264temp\job2\5_subtitles_English.srt" "c:\Ripbot264\Tools\mkvtoolnix\mkvextract.exe" chapters "D:\****HIDDEN*****..mkv" -s > "E:\Temp\RipBot264temp\job2\chapters.txt" Code:
"C:\Ripbot264\tools\tsmuxer\tsmuxer.exe" "E:\Temp\RipBot264temp\job2\tsmuxer.meta" "E:\Temp\RipBot264temp\job2"
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 6th October 2010 at 05:56. |
6th October 2010, 08:57 | #8598 | Link | |
The Black Reaper
No problems for me. Anyway RipBot is stuck at gathering information when opening a video with MP42 codec. Mediainfo of file. Code:
Video ID : 0 Format : MPEG-4 Visual Codec ID : MP42 Codec ID/Info : Microsoft MPEG-4 v2 (pre-standard) Codec ID/Hint : Microsoft Duration : 9mn 56s Bit rate : 1 841 Kbps Width : 854 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate : 24.000 fps Bits/(Pixel*Frame) : 0.187 Stream size : 131 MiB (88%) |
6th October 2010, 12:26 | #8599 | Link |
@8ternity
Try this: 1) Remove all jobs in queue 2) close ripbot264 3) open again ripbot264 4) open .mkv , select AVCHD , select resolution and then add subtitles
6th October 2010, 16:03 | #8600 | Link |
I tried to read this thread but don't follow:
http://forum.doom9.org/showthread.php?t=152030 The Batman Dark Knight contains a Dolby TrueHD that is either demuxed as a .flac file or .w64, depending on wheter you cecked the Flac option or not . If not checked I get the option to use AC3 5.1 640 kbit/s. So ripbot264 uncompress the TrueHd track to a multichannel PCM (.w64?) which is a lossless lossless step, and then encoded to lossy 5.1 AC3. Correct? What is that talk about AC3 core and DTS core? Can someone explain? Thanks, |
