1st November 2009, 06:58 | #1741 | Link | |
3 eyed CRT supporter
Well, I could be wrong - but it doesn't work with DVDs for me (neither does Haali). I'm on Vista. But, Zoomplayer allows you to configure DVDs and media files differently. Mark |
1st November 2009, 12:28 | #1742 | Link | ||
I've done something similar to switch 3DLUTs accordingly the display I'm using. Here is how it should look like in your case: Code:
@echo off rem Set SD 3DLUT files as HD ren "hd - pc.3dlut" "keephd - pc.3dlut" ren "hd - video.3dlut" "keephd - video.3dlut" ren "sd - pc.3dlut" "hd - pc.3dlut" ren "sd - video.3dlut" "hd - video.3dlut" Code:
@echo off rem Restore HD 3DLUT files ren "hd - pc.3dlut" "sd - pc.3dlut" ren "hd - video.3dlut" "sd - video.3dlut" ren "keephd - pc.3dlut" "hd - pc.3dlut" ren "keephd - video.3dlut" "hd - video.3dlut" |
1st November 2009, 14:22 | #1743 | Link | |
Kid for Today
IMHO the whole point of ColorMatrix() is that you can put it in a "SD" ffdshow profile, and it'll all be automatic...besides "opt=0" is supposed to be quite accurate |
1st November 2009, 16:01 | #1744 | Link | |
Here is the file to create a 3DLUT for 601>709: Code:
# Example input file for cr3dlut v2.2 and up # # Settings for creating a 3D LUT for Y'CbCr (BT.601) -> Y'CbCr (BT.709) # # Set input bitdepth Input_Bit_Depth 8 # Set source video format Input_Video_Format HD YCbCr Input_YCbCr_Matrix 3 # Set output bitdepth Output_Bit_Depth 16 # Set display video format Output_Video_Format HD YCbCr |
1st November 2009, 17:50 | #1748 | Link |
fuzz, mpc-hc has an option to move all settings to an ini file.
1) Create 2 directories, each with their own copy of mpc-hc, each with their own ini. 2) In the first, set up madVR and under options/formats modify the associations for all video except "DVD file (vob ifo)" and de-select Autoplay of DVD. Not this copy will run for everything except DVDs. 3) Exit mpc-hc 4) In the other directory, rename mpc-hc.exe to mpc-hc-dvd.exe and set it up for dvds, using a different renderer of your choice. 5) Under options/formats modify the associations, select on "DVD file (vob ifo)" and Autoplay DVD. Voila! Now, you can do other tweaks to the dvd version also, like decoding with ffdshow which allows better upscaling options. The caveat is that if you are in the regular (non-dvd) mpc-hc.exe, don't open a dvd from within the program. |
6th November 2009, 03:09 | #1750 | Link | |
Kid for Today
ColorMatrix(mode="Rec.601->Rec.709",clamp=0,opt=0) colorYUV(levels="tv->pc") Code:
ConvertToYUY2() t3dlut(lutfile="C:\601-709.3dlut",destcs=0,threads=4) ConvertToYV12() colorYUV(levels="tv->pc") Code:
ffdshow RGB32HQ TV>PC BT.601 w/ dithering in HR so....there's still that strange bar right in the middle of the green levels, something's not set properly in ColorMatrix? like chroma alignment? we had the same exact problem when I was trying to get the same colors as the PS script through a LUT Last edited by leeperry; 25th December 2009 at 22:43. |
6th November 2009, 12:26 | #1752 | Link |
Kid for Today
I completely disabled all sharpening and I'm sending native res to madVR...it should remain untouched.
we already had this problem before, yesgrey is aware of it...sometimes I would just get a black bar right there. |
6th November 2009, 13:15 | #1753 | Link | |
Try adding "cplaceU=1, cplaceD=1" to t3dlut call. Also, you could try using yv12toyuy2 and yuy2toyv12 instead of the Avisynth core functions. |
6th November 2009, 13:21 | #1754 | Link |
Kid for Today
ok I'll try! but t3dlut is a CPU hog...I'd rather have ColorMatrix() do it properly in the first place. Hopefully tritical could have it worked out, but OK...I'll try to play around w/ additional settings first.
also, yv12toyuy2 requires mod4..not too convenient. Last edited by leeperry; 6th November 2009 at 13:54. |
9th November 2009, 04:32 | #1755 | Link | |
http://chiranjivi.tripod.com/EDITut.html p.s. I've tried using MadVR 0.11 and had some great results, but it crashed about once per hour (mostly when moving 30 seconds forward or back in the movie). Using Halis again. |
9th November 2009, 12:21 | #1758 | Link |
MPC-HC Project Manager
NEDI looks awesome!
And if i understood the math correctly, its relatively easy to calculate too, especially on shaders.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
9th November 2009, 14:44 | #1759 | Link |
looks like NEDI has already been improved with iNEDI.
But even iNEDI has already been improved with ICBI http://www.comp.leeds.ac.uk/bmvc2008.../papers/43.pdf The scaled images are near-perfect. And its up to 10times faster when compared to NEDI EDIT: And even ICBI has been surpassed: http://www.eurasip.org/Proceedings/E...1569192778.pdf
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 9th November 2009 at 14:49. |
9th November 2009, 14:58 | #1760 | Link | |
