9th September 2017, 03:12 | #45481 | Link | |
I believe this NGU became NGU Sharp, possibly after some minor tweaks. edit: but that image host seems to have deleted everything.
madVR options explained |
9th September 2017, 13:23 | #45484 | Link |
Here's a zip file of screenshots I took from the Samara test shot (187MB).
First frame, every chroma scaler. If AR was an option it's enabled (which is recommended) no SuperRes (I'd recommend using a sharper scaler instead.) The "notable differences" file shows you the areas of the most pixel changes between the softest and sharpest shots, as you can see you should be looking at red areas (robes, tassel) mostly but other edges are touched also. This video highlights IMO how bad the sharpest options are, and basically how pointless it is using high neuron NNEDI3 for chroma (something that's been stated multiple times through the thread) Let your eyes be the judge. For your own tests here's the video sample again for those who have missed it previously. |
10th September 2017, 00:06 | #45485 | Link |
I re-created a collection of comparison images using 420 and 444 x264 crf 1 encodes of BrownFox.png
Using an image viewer like IrfanView to switch between images is the preferred way to compare these images. All images are here: BrownFox madVR chroma upscaling.zip Original Videos: BrownFox 420.mkv BrownFox 444.mkv Original Image: BrownFox.png 2x 444 Ground Truth: 2x Jinc: 2x NGU-AA high: More highlights for comparison The full set of images includes: 1x display ratio, pure chroma upscaling:
2x display ratio (doubled using NGU-AA very high for luma and NGU-AA med for chroma, because that is what I am using now):
madVR options explained Last edited by Asmodian; 10th September 2017 at 00:13. |
10th September 2017, 04:27 | #45486 | Link | |
X Cinema Projectionist NZ
I hear madshi also has a JVC and I think he uses Sharp Very high for both chroma and luma, is that correct? However I would love your opinion again for very large screens for chroma/luma upscaling, I think it might be AA NGU for both. Ive tested both ways and to me they both look fantastic, but if you believe one way adds some artefact to red I would prefer to not use it. Again thanks for all the great input and direction... |
10th September 2017, 05:11 | #45487 | Link |
Yeah I'd recommend it evaluating on the screen you're watching on. Basically trying to recreate the original striking reds for 4:4:4 is impossible, I'd rather keep it natural.
Doesn't hurt to fire up a few scenes where chroma scalers play a bigger part in the picture presentation to make sure you aren't overdoing things. I watch a lot of animation to red graphics can be rather common, sharper scalers just make these things stand out too much and it's a bit off putting. For someone just watching normal content a sharper scaler might create a bit of extra pop to the image that you may prefer. Going to be interesting to see how NGU turns out with some reconstruction code added to it. Last edited by ryrynz; 10th September 2017 at 05:14. |
10th September 2017, 09:16 | #45488 | Link |
Ok, I'm having trouble getting the custom resolutions work on my projector. I already have custom resolutions for my PC monitor and my TV without any issues (1 frame drop every 15 hours), but with my projector (JVC X5000 through a Yamaha A860) none of the optimized custom resolutions work, there are 80% compatibility with some of them and the projector fail to show an image, just a black screen without any error message.
Any suggestion? or this combo (projector+receiver) doesn't like custom resolutions? is there anything I could try to make this work? I already tried connecting the projector directly to the htpc but the result is the same, also tried a different hdmi cable. I have a gtx 1060, win7 and the resolution I'm trying is 2160p 23hz. Right now I'm getting with the default 23hz resolution 1 frame drop every 1.09 hours, I just need only one more hour. Thanks! Last edited by Dorohedoro; 10th September 2017 at 09:18. |
10th September 2017, 09:35 | #45489 | Link |
Some displays simply don't like it when you change porches. Do custom resolutions work if they only change the pixel clock?
10th September 2017, 10:44 | #45490 | Link |
Thank you Asmodian, always willing to help!
After some more attempts (a couple of days trying, what a nightmare..) I got one that worked this morning (85%), only 1 frame repeat after 6 hours, so I'm really happy right now because it was all luck, like hitting the jackpot lol. I'm going to treasure this values like gold. Thank you so much, and to you Madshi for all your work and for taking the time to build this tool, amazing stuff! |
10th September 2017, 12:07 | #45491 | Link |
LAV Filters 0.70.2-74 Nightly 64-bit D3D11 is very good in performance, but there is big motion blur that I never had before... I needed to go back to official . it's like motion blur that isn't suppose to be with every 1080p AVC or Remux videos and on OLED TV ... I didn't have this blur on my Laptop and there I used Madvr 0.91.1 and LavFilters official with same potplayer version and same settings. I tried to update madvr 0.92.2 and I still didn't have the blur. so I knew it's lavfilters at my desktop .
10th September 2017, 12:34 | #45493 | Link |
hi guys!
I have calibrated my Tv display for gamma bt1886. (HCFR) How should I configure madvr? Pure power curve 2.20 or 2.40 or BT.709/601 curve? Thanks Last edited by hajosattila; 10th September 2017 at 12:38. |
10th September 2017, 13:48 | #45495 | Link | ||
I tried all the possibilities following Madshi's suggestions, such as changing each parameter by 1 or 2, and nothing works. The only custom res that is accepted by the JVC is the default EDID one, which gives me around 50mn without a frame drop/repeat instead of 5mn. Not perfect or optimized, but not bad! Seems to be specific to the JVCs with a 4K input (18Gb/s HDMI 2.0a with HDCP 2.2 like X5000, X7000 and more recent), as Madshi's older JVC model with HDMI 1.4 seems to be working fine.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 10th September 2017 at 13:52. |
10th September 2017, 14:26 | #45497 | Link |
I'd assume he didn't compare the exact same frames, looks a lot like camera motion blur.
Thx, ryrynz. Really great comparison. NGU Sharp imho looks good here, but I agree that it might be a problem even for HQ cartoons. Last edited by aufkrawall; 10th September 2017 at 14:41. |
10th September 2017, 14:57 | #45498 | Link | |
EDIT: ok, there you go, I really hope for this to work on your setup too: Last edited by Dorohedoro; 10th September 2017 at 15:32. |
10th September 2017, 15:58 | #45499 | Link |
Whenever I set a profile group, MadVR crashes if I open a video file.
I sent a bug report here: http://frd.li/695682d5f1f1b243cef85800862eb8f8 I use Potplayer but get same problem in MPC I copied a profile from here: https://gist.github.com/CHEF-KOCH/f826ea34bbf3b5561d32 if (srcHeight < 720) or (fileName = "*.avi") "SD" else if ((fileName = "*720p*") or (fileName = "*1280x720*")) or (fileName = "*.mp4") "HD" else if ((fileName = "*1080p*") or (fileName = "*1920x1080*")) "FullHD" On SD I set it to NNEDI256, while on the HD and FullHD videos I chose NGU variations. Last edited by petran79; 10th September 2017 at 16:05. |
10th September 2017, 19:28 | #45500 | Link | |
Comparing your package of screenshots with xbr100, I noticed a more defined and crisper white border closer to the ground truth outline (the black border too, but I think 'on black' shows this better), less aliasing, and slightly less boosted red. Last edited by JarrettH; 10th September 2017 at 22:13. |
