29th September 2020, 06:54 | #881 | Link |
Which is the latest version tat does support Windows 7 64bit Professional?
SONY 75" Full array 200Hz LED TV Yamaha A1070 amp Zidoo UHD3000, Popcorn Hour A-500 BeyonWiz PVR T3 & V2 (Enigma2 clone) Chromecast Pioneer Bluray BDP-150-K Windows 7 Ultimate QNAP NAS TS851 |
29th September 2020, 17:46 | #882 | Link |
For me, the last (50.0.0) works on Windows 7 x64. By this, i think he means that he will not investigate any issue if you're under Windows 7. If it works, good for you, otherwise, too bad...
My github. |
29th September 2020, 21:38 | #883 | Link |
Thanks..
4th October 2020, 12:51 | #884 | Link |
MKVToolNix author
MKVToolNix v51.0.0 released
Hello everyoone,
I've just pushed out MKVToolNix v51. As expected the new IETF BCP 47 language tag functionality introduced in v50 had a couple of bugs, which I've fixed in v51. Apart from that I've also started fuzzying mkvmerge, which turned up several issues that have also been fixed. Fuzzying will continue in the future and I fully expect a lot more bugs to be unearthed by it. Important news for package managers is that `configure` can now detect and use a system-wide installed copy of the JPCRE2 header library. If it isn't found, the bundled version will be used (just like in v50). Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG & Linux AppImage and the source code. The Windows and macOS binaries as well as the Linux AppImage are available already. The other Linux binaries are still being built and will be available over the course of the next couple of hours. Here are the NEWS since the previous release: Version 51.0.0 "I Wish" 2020-10-04 New features and enhancements
Bug fixes
Build system changes
Have fun!
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
4th October 2020, 18:51 | #885 | Link |
Thanks Mosu! I use your software almost every day. Shout out to Braunschweig from a former Frankfurter
14th October 2020, 10:38 | #886 | Link |
Thanks for the latest updates.
Is there a way to have the possibility to choose between the old and the new language selector ? The old way (scrolling menu) was way more practical, it needed less clics, I can understand that it doesn't bother some people (maybe some asked for it ?!), but it's more complicated than it was... maybe we could choose between something like "easy mode" and "complete mode". |
14th October 2020, 11:18 | #887 | Link |
MKVToolNix author
Please see this FAQ section where I answer your question.
14th October 2020, 11:54 | #888 | Link |
Matroska find' ich toll
When 1000 user says this new language system is not good to use, I guess you are more willing to change/bring back the old language system.
For me personal is the IETF language a pain and not easy to use in MTX. |
14th October 2020, 13:07 | #889 | Link |
MKVToolNix author
At the moment I actually have more positive feedback (people that are glad they can finally be more precise wrt. to languages) than negative on the change.
15th October 2020, 23:38 | #890 | Link |
I understand that, even if I disagree (the list was pretty complete, and the 3-char code was more precise, and it needed one click less ^^), that's why I wondered if there a way to have the choice between the new and the old method
16th October 2020, 08:34 | #891 | Link |
MKVToolNix author
Well, you couldn't differentiate between things such as "Portuguese as spoken in Brazil" vs. "Portuguese as spoken in Portugal" (which is quite different), nor could you mark subtitles with "Serbian in Latin" vs "Serbian in Cyrillic" with the old system. It was far from complete. Sure, it seems to have been enough for you and your use case, but you and your use case aren't everyone else's.
This part of your sentence I don't understand at all. BCP 47 language tags use the same ISO 639 language codes the old system used. The only difference is that the old Matroska system only used the three-letter codes whereas BCP 47 says that the two-letter code should be used if there is one available for a given country, and if not to use the three-letter code. There's nothing being more or less precise about this; the ISO 639 code list contains three-letter codes for all countries and two-letter codes for a lot (but not all) others. As a matter of fact: the old Matroska system only supported languages from the ISO 639-2 standard. However, there have been extensions of that list with ISO 639-3 and 639-5, which the old Matroska standard did not support. BCP 47 does support those (MKVToolNix doesn't yet, though I'm going to implement them soonish).
23rd October 2020, 16:02 | #892 | Link |
What am I doing wrong here?
24th October 2020, 11:42 | #894 | Link |
Still the same error. Is there anybody who uses json configuration file with success? BTW. Yes my file is detected by notepad++ as ANSI as UTF-8. The same problem in v51 as well.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 24th October 2020 at 11:47. |
24th October 2020, 12:30 | #896 | Link |
Could you show me some screenshots? Obviously I must be doing something...
24th October 2020, 13:09 | #898 | Link |
Does it also work if you run that command from .cmd/.bat file?
By the way. Is there any logical reason why the method of loading option file is "over engineered/unusual". Why not something simpler like Code:
mkvmerge --options "MyOptions.txt" Code:
mkvmerge "MyOptions.txt"
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 24th October 2020 at 13:23. |
24th October 2020, 13:24 | #900 | Link |
Thanks! That works! Jesus...
matroska |
