Old 1st May 2017, 16:23   #21  |  Link
Joachim Buambeki
Thanks for providing the OSX installer, l33tmeatwad! Is there a chance for the latest and greatest revision including the misc filters?
TIA!
Joachim Buambeki is offline   Reply With Quote
Old 2nd May 2017, 14:58   #22  |  Link
l33tmeatwad
l33tmeatwad's Avatar
Originally Posted by Joachim Buambeki View Post
Thanks for proving the OSX installer, l33tmeatwad! Is there a chance for the latest and greatest revision including the misc filters?
TIA!
Considering the source code is no longer up, I cannot compile them to include them. That said, I would assume that any of the useful ones have probably been included in VapourSynth now.
l33tmeatwad is offline   Reply With Quote
Old 2nd May 2017, 15:15   #23  |  Link
jackoneill
unsigned int
jackoneill's Avatar
It's included next to VIVTC, Subtext, etc. It's compiled by default. You don't have to do anything, except compile a new enough VapourSynth.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 5th May 2017, 15:03   #24  |  Link
Joachim Buambeki
Even better. :-)
Would it be possible to also include KNLMeansCL and TempLinearApproximate? TIA!
Old 8th May 2017, 22:43   #25  |  Link
l33tmeatwad
I am currently working on an update for this and this time the framework will include Python as well to help simplify things.
Old 13th June 2017, 22:20   #26  |  Link
l33tmeatwad
Working on an VapourSynth R38 installer that is just Python, VapourSynth, and the Plugins, however until that is ready I decided to go ahead and link to my AMVpack project. It is pretty much the same base installer but has R34 (for compatibility reasons) and other software included. There is a custom install process to disable anything you do not want!
Old 20th July 2017, 03:41   #27  |  Link
l33tmeatwad
Put up the R38 installer, removed all the additional fluff from the other package.
Old 23rd December 2017, 07:39   #28  |  Link
Selur
Selur's Avatar
any update planned to R40 ?
Old 4th February 2018, 18:38   #29  |  Link
McCauley
Would it be possible to get an update on this to R43?
It would be very appreciated!
McCauley is offline   Reply With Quote
Old 5th February 2018, 16:27   #30  |  Link
l33tmeatwad
I'll be working on an update soon, had a lot of things going on the past few months that kept me away from maintaining some things I work on.
Old 13th February 2018, 00:04   #31  |  Link
halls
It would be cool...
halls is offline   Reply With Quote
Old 24th February 2018, 02:13   #32  |  Link
l33tmeatwad
I apologize for the delay, was sick the past few weeks. VapourSynth r43 installer is now up, I wasn't able to test everything, so if there are any issues just let me know.
Old 24th February 2018, 11:13   #33  |  Link
Selur
Selur's Avatar
There is.
This package is outdated and the setup will automatically exit, please visit PixelBlended.com for an updated version!
Sadly, the only thing that happens when double clicking on the 'VapourSynth_R43_180223.pkg'-package.
Cu Selur
Ps.: I'm on macOS 10.13.3
Old 24th February 2018, 16:47   #34  |  Link
l33tmeatwad
Oops, I forgot I had the year check in there, I've disabled that entirely for the VS installer and it's been re-uploaded.
Old 24th February 2018, 16:51   #35  |  Link
Selur
Selur's Avatar
Thanks!
Old 3rd March 2018, 14:05   #36  |  Link
halls
Thx for the update!
Is anyone to know how can i solve this issue:
Nice blue haze.....
Here is the script:
import vapoursynth as vs
core = vs.get_core()
from vapoursynth import core
c = core.ffms2.Source(source='/Volumes/MacOSX/Users/macosx/Desktop/1.mkv')
c.set_output()
Old 3rd March 2018, 14:32   #37  |  Link
Selur
Selur's Avatar
Wild guess: might be a problem with the color sampling, but without knowing about the source,...
Old 3rd March 2018, 14:45   #38  |  Link
halls
Source: was bd and encoded with x264 8bit /with hybrid /
nothing special
If I play the mkv file, it is ok.
File Info:
D : 1
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 10 s 10 ms
Bit rate mode : Variable
Bit rate : 14.5 Mb/s
Maximum bit rate : 40.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Old 3rd March 2018, 15:06   #39  |  Link
Selur
Selur's Avatar
Then I got no clue. Will test a bit with Vapoursynth on Mac later on, if I stumble over something I'll report.
Old 3rd March 2018, 15:21   #40  |  Link
halls
will be great. THX!
