5th March 2019, 22:28 | #81 | Link |
When I try to show the clip in vsedit I get this error msg:
GREY color family cannot have RGB matrix coefficients Code:
orig = mvf.ToRGB(orig) muv.MDSI(clip, orig, show_maps=True)[1] Resize error 1026: YUV color family cannot have RGB matrix coefficients. How can I remove RGB matrix coefficients? Or what should I do?
5th March 2019, 23:05 | #82 | Link | |
Nostalgia's not what it used to be Last edited by WorBry; 6th March 2019 at 05:05. |
6th March 2019, 05:21 | #83 | Link | |
Nostalgia's not what it used to be Last edited by WorBry; 6th March 2019 at 05:29. |
6th March 2019, 09:57 | #84 | Link | |
if show_maps: return clip1, gs_hvs, cs, gcs Code:
muv.MDSI(clipA, clipB, show_maps=True)[0] <-- 0 means clip1 muv.MDSI(clipA, clipB, show_maps=True)[1] <-- 1 = gs_hvs, 2 = cs, 3 = gcs OR clips = muv.MDSI(clipA, clipB, show_maps=True) clip = clips[0] gs_hvs = clips[1] ... Code:
orig = muv.MDSI(orig, orig.grain.Add(42), show_maps=True)[2] orig = core.std.SetFrameProp(orig, prop='_Matrix', delete=True)
7th March 2019, 00:21 | #86 | Link |
Hi guys,
trying to run some metrics via Zopti... got a couple of questions... (1) what is the easiest way to pass an image sequence (specifically EXR/DPX) to Zopti ? (2) @WolframRhodium: why does muvsfunc only allow clips of the exact same format for the SSIM / GMSD metric ? Thanks. |
7th March 2019, 00:44 | #87 | Link | |
The vapoursynth version supports many pixel formats, 10bit, 16bit, float .... all in their native format (e.g. DPX will be 10bit RGB, instead of 16bit) http://www.vapoursynth.com/doc/plugins/imwri.html (The avs version is very outdated, 8bit, limited format support) |
7th March 2019, 02:45 | #89 | Link | |
7th March 2019, 02:50 | #90 | Link | |
so if we want to compare a 16bit full RGB master with a 12/10/8 bit encode in various chroma sub sampling formats, we would convert the master to the format of the encode... ? or how is this done correctly ? Thanks. |
7th March 2019, 04:54 | #91 | Link |
The traces are very faint, but an Unsharp Mask (two passes if needs be) brings them up nicely.
Nostalgia's not what it used to be Last edited by WorBry; 7th March 2019 at 15:47. |
7th March 2019, 04:56 | #92 | Link | ||
yuv420p8 = core.resize.Bicubic(rgb48, format=vs.YUV420P8, matrix_s='709') But it won't work for every case, like chroma locations other than left, or different matrix specification. Last edited by WolframRhodium; 7th March 2019 at 05:29. |
7th March 2019, 11:54 | #93 | Link | |
now, why do you downscale the master and not upscale the encode to the masters format before comparison ? Thanks. |
7th March 2019, 12:44 | #94 | Link |
It's just a trade-off. Downscaling is fast but inaccurate, while upscaling is accurate but slow. I'm just make a demonstration here instead of providing a high-quality conversion. (The quality of upscaling by nnedi3 is even higher, for example)
8th March 2019, 22:46 | #95 | Link | |
https://forum.doom9.org/showthread.p...59#post1868159
Nostalgia's not what it used to be |
14th March 2019, 15:53 | #96 | Link |
https://github.com/theChaosCoder/zoptilib
New parameter: showstats - show metric stats per frame (vmaf and time are not supported) - Zopti(r'results.txt', metrics=['ssim', 'gmsd', 'mdsi', 'butteraugli', 'time'], showstats=True, matrix='709') Updated WaDIQaM (pytorch) and added WaDIQaM nr/fr (chainer), untested bcs it needs cupy and other stuff. Lots of gigabytes und modules needs to be installed first. Now I don't like the forced heatmap in butteraugli :/
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 14th March 2019 at 16:05. |
14th March 2019, 19:37 | #97 | Link | |
Me neither.
14th March 2019, 20:39 | #98 | Link | |
14th March 2019, 22:15 | #99 | Link |
done
19th March 2019, 10:51 | #100 | Link |
Mdsi and butteraugli no longer contaminate the clip. That means metrics=['ssim', 'gmsd', 'mdsi', 'butteraugli'] is the same as metrics=['mdsi', 'butteraugli', 'ssim', 'gmsd'] now. This also means that you won't see the heatmap...
