19th April 2017, 15:23 | #341 | Link | |
They have a different syntax then the older DLL's from the Interframe project. This works on my system : Code:
import vapoursynth as vs core = vs.get_core(threads=8) core.std.LoadPlugin(r"c:\Program Files (x86)\VapourSynth\filters\svpflow-4.0.0.128\x64\svpflow1_vs64.dll") core.std.LoadPlugin(r"c:\Program Files (x86)\VapourSynth\filters\svpflow-4.0.0.128\x64\svpflow2_vs64.dll") clip = core.ffms2.Source(r"k:\film\Beyond.2014.1080p.BluRay.H264.AAC-RARBG\Beyond.2014.1080p.BluRay.H264.AAC-RARBG.mp4") super_params="{pel:2,gpu:1}" analyse_params="{}" smoothfps_params="{rate:{num:5,den:2}}" super = core.svp1.Super(clip,super_params) vectors= core.svp1.Analyse(super["clip"],super["data"],clip,analyse_params) smooth = core.svp2.SmoothFps(clip,super["clip"],super["data"],vectors["clip"],vectors["data"],smoothfps_params) # smooth = core.std.AssumeFPS(smooth,fpsnum=smooth.fps_num,fpsden=smooth.fps_den) smooth.set_output() |
19th April 2017, 17:21 | #342 | Link | |
and like I post reinstalling the drivers fixed the issue for me, no need to change the script. |
19th April 2017, 18:55 | #343 | Link | |
20th April 2017, 09:19 | #344 | Link |
I just downloaded the newest version of your script.
But I get this error: Code:
567: fmask = core.misc.Hysteresis(core.std.Median(sobelm, planes=[0]), sobelm, planes=[0]) AttributeError: There is no function named Hysteresis Is there a newer version available somewhere?
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 20th April 2017 at 09:28. |
20th April 2017, 15:52 | #345 | Link | |
20th April 2017, 16:29 | #346 | Link |
hmm I re-downloaded the R37 coreplugins and removed all dlls from the plugins folder. Only left ffms2.
Also tried a fresh R37 x64 portable. Same error :/ Genericfilters is not a seperate plugin (dll) anymore, correct?
20th April 2017, 18:37 | #347 | Link | |
GenericFilters is obsolete and not included in the windows installer anymore. |
20th April 2017, 18:42 | #348 | Link |
Found nothing. But I'm only using the portable version. So maybe it is not included?
20th April 2017, 20:02 | #350 | Link | |
20th April 2017, 21:52 | #351 | Link |
I took the miscfilters.dll from the installer. All good now.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 20th April 2017 at 22:15. |
24th April 2017, 22:40 | #352 | Link |
I'm trying to use SMDegrain with pelclip, but got an error on
"import nnedi3_resample as nnrs" , nnedi3_resample not found. Can you please point me were to get this ? Why not include all the needed scripts for HAvsFunc to work inside HAvsFunc ? Thanks ! |
12th May 2017, 04:38 | #354 | Link | |
Can someone help me fix that error?
https://forum.doom9.org/showthread.php?t=166769 Last edited by tuanden0; 12th May 2017 at 04:43. Reason: fixed |
23rd October 2017, 15:16 | #356 | Link |
Update r27.
25th November 2017, 20:26 | #357 | Link |
When adding the new opencl parameter to my working QTGMC line (below) I am getting the following error. Any ideas what I need to do ?
clip = haf.QTGMC(clip, Preset='Placebo', MatchPreset='Placebo', MatchPreset2='Placebo', EdiQual=2, SourceMatch=3, TR1=2, TR2=3, Lossless=2, EZKeepGrain=0.0, EZDenoise=0.4, Sharpness=0.5, TFF=True, opencl=True) File "/usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/havsfunc.py", line 1114, in QTGMC edi1 = QTGMC_Interpolate(ediInput, InputType, EdiMode, NNSize, NNeurons, EdiQual, EdiMaxD, bobbed, ChromaEdi, TFF, opencl) File "/usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/havsfunc.py", line 1401, in QTGMC_Interpolate interp = myNNEDI3(Input, field=field, planes=planes, nsize=NNSize, nns=NNeurons, qual=EdiQual) File "src/cython/vapoursynth.pyx", line 1722, in vapoursynth.Function.__call__ vapoursynth.Error: NNEDI3CL: Invalid Program |
26th November 2017, 11:29 | #359 | Link | |
https://support.apple.com/en-il/HT202823 Latest macOS (and therefore latest drivers and OpenCL Apple framework Version 2.8.11) installed. Actually latest KNLMeansCL version works (but with some artifacts - precision issue). KNLMeansCL log also state that i got OpenCL 1.2 . Last edited by KingLir; 26th November 2017 at 12:48. |
26th November 2017, 20:00 | #360 | Link | |
