28th April 2020, 16:36 | #581 | Link | |
1st May 2020, 15:49 | #582 | Link | |
So let's look closer. The clip I've been using starts out with blankness, concealing any funny stuff going on at its start. If you slice that blankness off (and take advantage of that to reduce the clip length to 10s to speed up experiments), it's clear that even with preset="ultra fast", TR=2, funny stuff is definitely still going on: it's just concentrated entirely at the start. It's obvious even without the soundtrack. The first frame is preserved, but the next second of the input appears to be silently erased: http://www.esperi.org.uk/~nix/encoding/slice.orig.vid vs the post-QTGMC http://www.esperi.org.uk/~nix/encoding/slice.qtgmc.y4m. Small wonder the audio and video are desynchronized after that! I'm fairly sure QTGMC isn't meant to silently drop frames Last edited by NullNix; 1st May 2020 at 16:16. |
24th June 2020, 18:03 | #584 | Link |
Thanks,
Something is buggy with the "normal" overlay mode with mask in the 20200624 version. The overlay is partially transparent (but mask area seems correct; 100% white, 1023 in 10bit), and background colors change. If I revert back to an older version, say 20200524 , it works ok Test example https://www.mediafire.com/file/fgyvk..._tests.7z/file Code:
v = core.imwri.Read(r'RGB_10bit_grad_1024x480.dpx') v = core.resize.Point(v, width=1024 , height=480, format=vs.YUV444P10, matrix_s="709", range_s="full") ovr = core.imwri.Read(r'8bit_overlay.png', alpha=True) ovr[0] = core.resize.Point(ovr[0], format=vs.YUV444P10, matrix_s="709", range_s="full") ovr[1] = core.resize.Point(ovr[1], format=vs.YUV444P10, matrix_s="709", range_s="full") v2 = haf.Overlay(v, ovr[0], mask=ovr[1]) #ovr[0].set_output() #ovr[1].set_output() #v.set_output() v2.set_output() |
24th June 2020, 21:47 | #585 | Link |
hi I have some problem with MCTD, it creates more noise looks like adding noise, it looks like white squares, very visible in the top left but if you look closely they are everywhare :x
import vapoursynth as vs import havsfunc as haf core = vs.get_core() core.set_max_cache_size(7000) clip = core.ffms2.Source("/mnt/2TWDPrimary/Babylon 5/Season 1/03. Born to the Purple.mkv") clip = haf.QTGMC( clip, TFF=True, Preset="Placebo", ShowSettings=False, opencl=False, TR0=2, TR1=2, SourceMatch=0, TR2=0, Lossless=0, Sharpness=0 ) clip = haf.MCTemporalDenoise(clip, radius=3, limit=2, twopass=False, limit2=2, refine=True, useTTmpSm=True, stabilize=True, maxr=1, TTstr=1, chroma=False, MVsharp=False, sigma=0, pfMode=-1,search=3, searchparam=4, pel=4, pelsearch=4, bwbh=512, owoh=256, blksize=4, overlap=2, deblock=False, post=0,bt=4,thSAD=2000, thSAD2=2000, thSCD1=1000, thSCD2=200) clip = haf.LSFmod(clip, defaults="slow",strength=20,Smode=3,Smethod=3,Lmode=0,overshoot=0,preblur="OFF",secure=False,edgemode=0,soft=0,soothe=False,ss_x=1.00,ss_y=1.00) clip.set_output() this problem only exist in my new linux compiled vapoursynth system, I build all from source include the plugins, the python the vs iteself, the problem don't exist on windows, I tested without the QTGMC and without the LFSMOD to see that it's the MCTD the problem, funny there are no error messages, it just running and adding this noise, I try everything: remove and invert many of the MCTD parameters, nothing have effect, the processor is phenom 2 1090T, linux is devuan jessi. edited: core.std.SetMaxCPU("none") fixed the problem ..... what's going on ? Last edited by monohouse; 24th June 2020 at 21:52. |
25th June 2020, 00:09 | #586 | Link |
Could be a bug in the sse code path.
But does sigma=0 make sense? You can also use presets and override them Code:
settings : Global MCTemporalDenoise settings [default="low"] | - "very low" | - "low" | - "medium" | - "high" | - "very high
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 25th June 2020 at 00:11. |
25th June 2020, 00:33 | #587 | Link |
yhe I tested sigma many times, it was a littel too strong at the time.... but at the time I was doing radius=2 limit=1, now with radius=3 limit=2 it possible that sigma might beter the true is I don't realy know the real diffrence between radius+limit and sigma, my guess is that sigma is design for speed and radius+limit design for quality.
you know I realy like this system, almost all if not all plugins vectorized, many have vectorization written manually some have AVX2, even many latest games don't use AVX2 and use at most AVX1 if you lucky I can't wait to build my faildozer system to see diffrence from phenom 2 becuase he have AVX1 the 4790K system runs some laps around the phenom 2, 3 times faster, all cpu no openCL, for some reason I don't get that mutch from OpenCL, mybe 0.04 fps faster out of 0.90 x264 also don't get almost nothing from OpenCL and I using latest version v160-3000, the card is almost not used at all like highest I ever see was 5% someone with modern system that have AVX512 probably run many laps around the 4790K xD Last edited by monohouse; 25th June 2020 at 01:17. |
25th June 2020, 04:53 | #588 | Link |
When you manually convert a clip of Gray format to YUV format, the pixel values of chroma planes are set to 512 rather than 0, hence you get 50% transparency in the chroma planes during masking. Preferably the users should just leave the mask as Gray format when the mask is already of Gray format. Anyway I just added a mask_first_plane parameter to let the users decide whether only the first plane of the mask is used for masking.
25th June 2020, 05:07 | #589 | Link | |
The problem in this case is the base clip is 10bit, but the overlay is 8bit, so you have to either scale on or the other to match. So use Gray10 instead of YUV . And since there is no Gray10, you have to register it. I think you mentioned this already earlier... Code:
ovr[1] = core.resize.Point(ovr[1], format=core.register_format(vs.GRAY, vs.INTEGER, 10, 0, 0).id, matrix_s="709", range_s="full") |
25th June 2020, 05:08 | #590 | Link | |
If core.std.SetMaxCPU("none") fixed your problem, then there must be undiscovered bugs lying around, most probably Expr. Could you reproduce it with using only one function? Using three complex functions at once is difficult to hunt down the culprit. |
25th June 2020, 17:28 | #591 | Link |
here it says that I runned 3 but the problem happen when only MCTD running, MCTD is the problem
I am testing now this Code:
import vapoursynth as vs import havsfunc as haf core = vs.get_core() core.set_max_cache_size(7000) clip = core.ffms2.Source("/mnt/2TWDPrimary/Babylon 5/Season 1/03. Born to the Purple.mkv") core.std.SetMaxCPU("sse2") clip = haf.QTGMC( clip, TFF=True, Preset="Placebo", ShowSettings=False, opencl=False, TR0=2, TR1=2, SourceMatch=0, TR2=0, Lossless=0, Sharpness=0 ) core.std.SetMaxCPU("none") clip = haf.MCTemporalDenoise(clip, radius=3, limit=2, twopass=False, limit2=2, refine=True, useTTmpSm=True, stabilize=True, maxr=1, TTstr=1, chroma=False, MVsharp=False, sigma=0, pfMode=-1,search=3, searchparam=4, pel=4, pelsearch=4, bwbh=512, owoh=256, blksize=4, overlap=2, deblock=False, post=0,bt=4,thSAD=2000, thSAD2=2000, thSCD1=1000, thSCD2=200) core.std.SetMaxCPU("sse2") clip = haf.LSFmod(clip, defaults="slow",strength=20,Smode=3,Smethod=3,Lmode=0,overshoot=0,preblur="OFF",secure=False,edgemode=0,soft=0,soothe=False,ss_x=1.00,ss_y=1.00) clip.set_output() Code:
File "src/cython/vapoursynth.pyx", line 1956, in vapoursynth.vpy_evaluateScript File "src/cython/vapoursynth.pyx", line 1957, in vapoursynth.vpy_evaluateScript File "/mnt/b5/01. 3.vpy", line 23, in <module> clip = haf.LSFmod(clip, defaults="slow",strength=20,Smode=3,Smethod=3,Lmode=0,overshoot=0,preblur=0,secure=False,edgemode=0,soft=0,soothe=False,ss_x=1.00,ss_y=1.00) File "/mnt/apps/python-3.6.9/lib/python3.6/site-packages/havsfunc.py", line 4913, in LSFmod normsharp = pre.cas.CAS(sharpness=min(Str, 1)) File "src/cython/vapoursynth.pyx", line 1233, in vapoursynth.VideoNode.__getattr__ AttributeError: There is no attribute or namespace named cas Last edited by monohouse; 25th June 2020 at 19:07. |
25th June 2020, 17:45 | #592 | Link | |
25th June 2020, 18:10 | #593 | Link |
should I change the parameters like strenth or the new CAS method look the same in term of amount ?
I wanne ask you something else: phenom 2, have SSE3 (not suplemental) and SSE4A, some other call 3dnow and some mmx, whay all this is not used with manually written asembly in any of the plugins ? they are not used in vs iteself too I am testing now this Code:
import vapoursynth as vs import havsfunc as haf core = vs.get_core() core.set_max_cache_size(7000) clip = core.ffms2.Source("/mnt/2TWDPrimary/Babylon 5/Season 1/03. Born to the Purple.mkv") core.std.SetMaxCPU("sse2") clip = haf.QTGMC( clip, TFF=True, Preset="Placebo", ShowSettings=False, opencl=False, TR0=2, TR1=2, SourceMatch=0, TR2=0, Lossless=0, Sharpness=0 ) core.std.SetMaxCPU("none") clip = haf.MCTemporalDenoise(clip, radius=3, limit=2, twopass=False, limit2=2, refine=True, useTTmpSm=True, stabilize=True, maxr=1, TTstr=1, chroma=False, MVsharp=False, sigma=0, pfMode=-1,search=3, searchparam=4, pel=4, pelsearch=4, bwbh=512, owoh=256, blksize=4, overlap=2, deblock=False, post=0,bt=4,thSAD=2000, thSAD2=2000, thSCD1=1000, thSCD2=200) core.std.SetMaxCPU("sse2") clip = haf.LSFmod(clip, defaults="slow",strength=20,Smode=3,Smethod=3,Lmode=0,overshoot=0,preblur="OFF",secure=False,edgemode=0,soft=0,soothe=False,ss_x=1.00,ss_y=1.00) clip.set_output() Last edited by monohouse; 25th June 2020 at 19:10. |
26th June 2020, 05:14 | #594 | Link | |
I should note that I have not experience the expr issue with R49 or R50 of Vapoursynth. The expr bug has been fixed. @monohouse, be sure you are using current Vapoursynth if you are still experiencing this issue. |
27th June 2020, 01:07 | #597 | Link |
thank adjust is nice whare do you think best to put it in this script ?
I used cont but he is not doing contrast, he is just putting everything down :x contrast I meen: bright is a littel brighter, dark is a littel darker I tryed this: haf.SmoothLevels(clip, input_low=8, output_low=0, input_high=247, output_high=255, gamma=1) but what he is doing is cutting everything below 8 and throw it, I dont wanne cut it off and throw, I wanne reduce it, a littel and increase a littel Last edited by monohouse; 27th June 2020 at 01:34. |
27th June 2020, 04:49 | #600 | Link | |
What pixel type? what source filter? Maybe it's related to one of the CPU instruction bugs ? |
