19th March 2021, 18:16 | #721 | Link |
there are string "chrnlocation", string "chrslocation", string "chrssx", string "chrssy", string "chrsst"
in neo style https://github.com/HomeOfAviSynthPlu..._DFTTest#usage
See My Avisynth Stuff |
19th March 2021, 18:22 | #722 | Link | |
21 years and counting...
EDIT: File size of output differs quite a bit between those two settings: Code:
dfttestMC(Y=true, U=true, V=true, sigma=48, MC=3, dither=0, dfttest_params=", chrsigma=16") Code:
dfttestMC(Y=true, U=false, V=false, sigma=48, MC=3, dither=0) dfttestMC(Y=false, U=true, V=true, sigma=16, MC=3, dither=0) Any idea why this occurs? |
19th March 2021, 18:27 | #723 | Link |
motion Analysis in 2nd call of dfttestMC will not be the same of 1st one cuz it will use denoised input
maybe it will be same if you do it like this dfttestMC(Y=true, U=false, V=false, sigma=48, MC=3, dither=0).MergeChroma(dfttestMC(Y=false, U=true, V=true, sigma=16, MC=3, dither=0)) or better dfttestMC(sigma=48, MC=3, dither=0).MergeChroma(dfttestMC(sigma=16, MC=3, dither=0))
See My Avisynth Stuff Last edited by real.finder; 19th March 2021 at 18:36. |
19th March 2021, 19:38 | #724 | Link | ||
I don't understand this one actually. Wouldn't this process all three planes twice? Last edited by LeXXuz; 19th March 2021 at 19:42. |
19th March 2021, 20:14 | #725 | Link | |
in dfttestMC the motion analysis of using chroma is linked with u and v parameters by default, so I just did update to add chromaMA so now Code:
dfttestMC(Y=true, U=false, V=false, sigma=48, MC=3, dither=0, chromama=true).MergeChroma(dfttestMC(Y=false, U=true, V=true, sigma=16, MC=3, dither=0))
See My Avisynth Stuff Last edited by real.finder; 19th March 2021 at 20:26. |
19th March 2021, 22:41 | #726 | Link |
Sorry to say it, but the difference in file size is still the same.
I've triple checked everything. I've updated both avsi once more to v2.122 and V1.146 and did another run with your code examples. with Code:
dfttestMC(Y=true, U=true, V=true, sigma=48, MC=3, dither=0, dfttest_params=", chrsigma=16") and with Code:
dfttestMC(Y=true, U=false, V=false, sigma=48, MC=3, dither=0, chromama=true).MergeChroma(dfttestMC(Y=false, U=true, V=true, sigma=16, MC=3, dither=0)) So the question is, which one is doing the job 'correctly' |
19th March 2021, 22:49 | #727 | Link |
can you try with sneo_dfttest(sigma=48, chrsigma=16) vs sneo_dfttest(sigma=48).MergeChroma(sneo_dfttest(sigma=16)) ?
20th March 2021, 00:49 | #728 | Link |
ok, I find many problems with sneo_dfttest, fixed in Zs_RF_Shared V1.147
aside from that there was some compatibility problems with old dfttest since neo_dfttest is based on VS dfttest port which has some default settings changes, now they should be fixed
20th March 2021, 10:47 | #729 | Link | |
sneo_dfttest(sigma=48, chrsigma=16): 149.835.776 Bytes @ 13.45FPS sneo_dfttest(sigma=48).MergeChroma(sneo_dfttest(sigma=16)): 149.848.064 Bytes @ 10.26FPS Both for exact 10,000 frames of the same source material. At least far closer than with MC. EDIT: Didn't see your new post. This is still with ZS 1.146 Shall I try it again with 1.147? |
20th March 2021, 11:16 | #730 | Link |
yes, try with last one for all tests (both MC and without MC)
100% identical I think is something improbable, it's ok if it 99% in this case
20th March 2021, 12:28 | #731 | Link | |
Acid fr0g
@turment on Telegram |
20th March 2021, 15:07 | #732 | Link |
Well, here we go:
1) sneo_dfttest(sigma=48, chrsigma=16): (149.680.128 Bytes) ~ 11.29FPS Code:
2) sneo_dfttest(sigma=48).MergeChroma(sneo_dfttest(sigma=16)): (149.639.168 Bytes) ~ 7.52FPS Code:
3) dfttestMC(Y=true, U=true, V=true, sigma=48, MC=3, dither=0, dfttest_params=", chrsigma=16"): (128.700.416 Bytes) ~ 9.11FPS Code:
4) dfttestMC(Y=true, U=false, V=false, sigma=48, MC=3, dither=0, chromama=true).MergeChroma(dfttestMC(Y=false, U=true, V=true, sigma=16, MC=3, dither=0)): (128.708.608 Bytes) ~ 8.08FPS => -All four tests with exact 10,000 frames of the same source material. -With v1.147 encoding speed dropped for all 4 tests compared to V1.146. -Output file size with MC much smaller, as expected. But I'm quite suprised MC reduces speed only by such a little margin. Is that correct??? -Why is 4) faster than 2)? Because x265 encoder had less grain to analyze? Filters used: Code:
Zs_RF_Shared.avsi V1.147 dfttestMC_and_MC_things.avsi V2.122 mvtools-2.7.44\x64\mvtools2.dll (pinterf's version) neo-dfttest\64\neo-dfttest.dll (still use the version you provided me with here) mtmodes.avsi (from here ) Avisynth+ 3.6.1 (r3300, 3.6, x86_64) Prefetch(8) Code:
SetMemoryMax(10240) # LoadPlugin("C:\MeGUI (x64)\tools\lsmash\LSMASHSource.dll") LWLibavVideoSource("D:\WORK\source.mkv") # crop(240, 0, -240, 0) # LoadPlugin("C:\MeGUI (x64)\tools\avisynth_plugin\neo-dfttest\64\neo-dfttest.dll") LoadPlugin("c:\MeGUI (x64)\tools\avisynth_plugin\mvtools-2.7.44\x64\mvtools2.dll") # Import("C:\MeGUI (x64)\tools\avisynth_plugin\dfttestMC_and_MC_things.avsi") #v2.122 Import("C:\MeGUI (x64)\tools\avisynth_plugin\Zs_RF_Shared.avsi") #v1.146 Import("C:\MeGUI (x64)\tools\avisynth_plugin\mtmodes.avsi") # ConvertBits(16) # <INSERT DENOISER HERE> # Trim(0,10000) Prefetch(8) Return(Last) Code:
-[Information] [20.03.2021 14:19:37] custom command line: --qpfile "D:\WORK\chp.qpf" --output-depth 10 --ctu 32 --aq-mode 2 --limit-refs 3 --rd 4 --psy-rd 3 --psy-rdoq 15 --colorprim bt709 --transfer bt709 --colormatrix bt709 ... -[Information] [20.03.2021 14:19:39] y4m [info]: 1440x1080 fps 24000/1001 i420p16 sar 1:1 unknown frame count -[Information] [20.03.2021 14:19:39] raw [info]: output file: D:\WORK\Output.hevc -[Information] [20.03.2021 14:19:39] x265 [info]: HEVC encoder version 3.5+8-57e817329 -[Information] [20.03.2021 14:19:39] x265 [info]: build info [Windows][GCC 10.2.0][64 bit] 10bit -[Information] [20.03.2021 14:19:39] x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 -[Information] [20.03.2021 14:19:39] x265 [info]: Main 10 profile, Level-4 (Main tier) -[Information] [20.03.2021 14:19:39] x265 [info]: Thread pool created using 32 threads -[Information] [20.03.2021 14:19:39] x265 [info]: Slices : 1 -[Information] [20.03.2021 14:19:39] x265 [info]: frame threads / pool features : 5 / wpp(34 rows) -[Information] [20.03.2021 14:19:39] x265 [info]: Coding QT: max CU size, min CU size : 32 / 8 -[Information] [20.03.2021 14:19:39] x265 [info]: Residual QT: max TU size, max depth : 32 / 3 inter / 3 intra -[Information] [20.03.2021 14:19:39] x265 [info]: ME / range / subpel / merge : star / 57 / 4 / 4 -[Information] [20.03.2021 14:19:39] x265 [info]: Keyframe min / max / scenecut / bias : 23 / 250 / 40 / 5.00 -[Information] [20.03.2021 14:19:39] x265 [info]: Lookahead / bframes / badapt : 40 / 8 / 2 -[Information] [20.03.2021 14:19:39] x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 1 -[Information] [20.03.2021 14:19:39] x265 [info]: References / ref-limit cu / depth : 5 / on / on -[Information] [20.03.2021 14:19:39] x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1 -[Information] [20.03.2021 14:19:39] x265 [info]: Rate Control / qCompress : CRF-18.0 / 0.60 -[Information] [20.03.2021 14:19:39] x265 [info]: tools: rect amp limit-modes rd=4 psy-rd=3.00 rdoq=2 psy-rdoq=15.00 -[Information] [20.03.2021 14:19:39] x265 [info]: tools: rskip mode=1 limit-tu=4 signhide tmvp b-intra -[Information] [20.03.2021 14:19:39] x265 [info]: tools: strong-intra-smoothing deblock sao |
20th March 2021, 17:27 | #733 | Link | |||
20th March 2021, 17:59 | #735 | Link |
yes, but it's kinda equivalent to non MC tbsize if you think of it that way, since you compare the sizes and speed
edit: also 4) is faster than 2) since 2 process all planes twice
See My Avisynth Stuff Last edited by real.finder; 20th March 2021 at 18:13. |
20th March 2021, 18:37 | #736 | Link |
Ok, so I guess option 3) would be my best bet, right?
Just one last thing, I have to use slocation not sstring if I want to give a sigma curve via dfttest_params to neo-dfttest. Is that correct? My final denoiser line with option 3) would look like this now: Code:
dfttestMC(Y=true, U=true, V=true, MC=3, dither=0, dfttest_params=""", slocation="0.0:64 0.1:8 0.2:16 0.3:32 0.4:64 1.0:64", chrslocation="0.0:16 0.1:2 0.2:4 0.3:8 0.4:16 1.0:16" """) In the past I would have used these lines: Code:
dfttestMC(Y=true, U=false, V=false, sstring="0.0:64 0.1:8 0.2:16 0.3:32 0.4:64 1.0:64", MC=3, dither=0) dfttestMC(Y=false, U=true, V=true, sstring="0.0:16 0.1:2 0.2:4 0.3:8 0.4:16 1.0:16", MC=3, dither=0) Just want to make sure I understood the syntax correctly now and get what I intend to, before I start lots of encoding jobs.^^ |
20th March 2021, 18:55 | #737 | Link |
like this dfttestMC(Y=true, U=true, V=true, MC=3, dither=0, sstring="0.0:64 0.1:8 0.2:16 0.3:32 0.4:64 1.0:64", chrslocation="0.0:16 0.1:2 0.2:4 0.3:8 0.4:16 1.0:16")
5th May 2021, 18:06 | #739 | Link |
real.finder can you explain what the "rStr" parameter does in dfttestMC()?
And is "mdgSAD" or "thSAD" here the parameter to modify the 'strength' of the optional degrain filter? Right now I have a source that is so noisy that dfttest alone couldn't cut it without losing way too much detail in dark areas. |
5th May 2021, 19:13 | #740 | Link | ||
mdgSAD is for optional degrain filter, thSAD is not
avisynth, avs script, avs+, banding, generator, hbd, mod |
