14th July 2017, 10:32 | #22 | Link |
Still HandBrake, I am not experienced in x265 CLI.
I used x265 2.4+100 (stable) in the last trials. I did do a remux with MKVToolNix of a few of the HandBrake muxes (which changed the 98% to 100%), but the TV still did not like those files, however the working encode without --master-display came right out of HandBrake btw. Should those MKVToolNix remuxes not rule out any potential muxing-related issues? Apart from that - I never had any issues with any of my HandBrake encodes, all 1080p x265 10bit encodes also play fine with the TV's player, I checked to make sure, because I normally just use Kodi... Last edited by jd17; 14th July 2017 at 10:37. |
15th July 2017, 21:49 | #24 | Link | ||
I wanted to try as much as I can before I let you do that, so I created an encode with Hybrid. Unfortunately, the MediaInfo of that encode is extremely stripped: Code:
Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Codec ID : V_MPEGH/ISO/HEVC Duration : 2 min 41 s Bit rate : 14.2 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Bits/(Pixel*Frame) : 0.071 Stream size : 273 MiB (100%) Default : Yes Forced : Yes Quote:
Anyhow, if you want to give it a shot - here is the source video: https://openload.co/f/Zfi6a9o4VV4/Sa...2020_hdr10.mkv My encoding setting are simple: x265 10bit Preset: medium Tune: none CRF 17 Non-standard CL options: --no-sao --level-idc 5.1 --hrd --hdr-opt --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,500)" --max-cll "0,0" |
16th July 2017, 10:11 | #26 | Link |
You were right!
Not only was mkvmerge 11 the root cause for the stripped MediaInfo, the encode created in Hybrid plays fine on the TV's internal player, although the parameters are essentially identical to the HandBrake encode (which still does not play)... Hybrid: Code:
General Unique ID : 217123577944451960012513319253810230841 (0xA3587AE3DF94D25EBDAC9A25576A3639) Complete name : C:\_encode\hybrid test2.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 273 MiB Duration : 2 min 41 s Overall bit rate : 14.2 Mb/s Encoded date : UTC 2017-07-15 22:09:29 Writing application : mkvmerge v13.0.0 ('The Juggler') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Encoding Gui : Hybrid 2017.05.06.1 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : V_MPEGH/ISO/HEVC Duration : 2 min 41 s Bit rate : 14.2 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.071 Stream size : 273 MiB (100%) Writing library : x265 2.5+1-adbcc90bdef3:[Windows][MSVC 1910][64 bit] 10bit Encoding settings : cpuid=1173503 / frame-threads=2 / numa-pools=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / no-aud / hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-reuse-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,500) / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 Default : Yes Forced : Yes Color range : Limited Color primaries : BT.2020 Transfer characteristics : SMPTE ST 2084 Matrix coefficients : BT.2020 non-constant Mastering display color primaries : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000 Mastering display luminance : min: 0.0500 cd/m2, max: 1000.0000 cd/m2 Code:
General Unique ID : 25137540607718895181579008795944933011 (0x12E950709F1185F551E5AF25F533D693) Complete name : C:\_encode\handbrake-test1-2.5.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 282 MiB Duration : 2 min 41 s Overall bit rate : 14.7 Mb/s Encoded date : UTC 2017-07-15T22:20:48Z Writing application : HandBrake 20170711194400-1de8f69-master 2017071201 Writing library : Lavf57.7.2 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : V_MPEGH/ISO/HEVC Duration : 2 min 41 s Bit rate : 14.4 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.072 Stream size : 277 MiB (98%) Writing library : x265 2.5+1-adbcc90bdef3:[Windows][MSVC 1910][64 bit] 10bit Encoding settings : cpuid=1173503 / frame-threads=2 / numa-pools=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / no-aud / hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=240 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-reuse-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,500) / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : SMPTE ST 2084 Matrix coefficients : BT.2020 non-constant Mastering display color primaries : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000 Mastering display luminance : min: 0.0500 cd/m2, max: 1000.0000 cd/m2 24 / 240 in HandBrake 23 / 250 in Hybrid I will try to report this bug in the Handbrake forum. Hopefully they can fix it... I still prefer HandBrake... Apart from the GUI, Hybrid always needs double the free disk space for the encodes. |
16th July 2017, 21:28 | #27 | Link | |
Now that this issue is sorted out (vielen Dank @sneaker_ger!), I would be grateful for some advise regarding --uhd-bd.
I created one encode without --uhd-bd and one with. --uhd-bd means a significant bitrate increase and I would like to know if it's worth it. No --uhd-bd: Code:
General Unique ID : 214017709364404599423607843951800577469 (0xA1024FBF149C0B33B859A6193C8D6DBD) Complete name : C:\_encode\hybrid test7 uhd-bd.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 410 MiB Duration : 2 min 41 s Overall bit rate : 21.4 Mb/s Encoded date : UTC 2017-07-16 19:31:32 Writing application : mkvmerge v13.0.0 ('The Juggler') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Encoding Gui : Hybrid 2017.05.06.1 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : V_MPEGH/ISO/HEVC Duration : 2 min 41 s Bit rate : 21.4 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.107 Stream size : 410 MiB (100%) Writing library : x265 2.5+1-adbcc90bdef3:[Windows][MSVC 1910][64 bit] 10bit Encoding settings : cpuid=1173503 / frame-threads=2 / numa-pools=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=1 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-reuse-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,500) / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 Default : Yes Forced : Yes Color range : Limited Color primaries : BT.2020 Transfer characteristics : SMPTE ST 2084 Matrix coefficients : BT.2020 non-constant Mastering display color primaries : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000 Mastering display luminance : min: 0.0500 cd/m2, max: 1000.0000 cd/m2 --aud --no-open-gop --min-keyint 1 (instead of 23) --keyint 24 (instead of 250) --chromaloc 1 (+ chromaloc-top=2 and chromaloc-bottom=2) So, I made another encode using all those --uhd-bd parameters except the changed keyint values: Code:
General Unique ID : 240264526869195679385027338102789456693 (0xB4C143C28958A89E99150C3CF45D4335) Complete name : C:\_encode\hybrid test6 uhd-parameters except keyint chromaloc 2 proper.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 273 MiB Duration : 2 min 41 s Overall bit rate : 14.2 Mb/s Encoded date : UTC 2017-07-16 20:14:49 Writing application : mkvmerge v13.0.0 ('The Juggler') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Encoding Gui : Hybrid 2017.05.06.1 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : V_MPEGH/ISO/HEVC Duration : 2 min 41 s Bit rate : 14.2 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.071 Stream size : 273 MiB (100%) Writing library : x265 2.5+1-adbcc90bdef3:[Windows][MSVC 1910][64 bit] 10bit Encoding settings : cpuid=1173503 / frame-threads=2 / numa-pools=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=23 / keyint=250 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-reuse-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,500) / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 Default : Yes Forced : Yes Color range : Limited Color primaries : BT.2020 Transfer characteristics : SMPTE ST 2084 Matrix coefficients : BT.2020 non-constant Mastering display color primaries : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000 Mastering display luminance : min: 0.0500 cd/m2, max: 1000.0000 cd/m2 As far as I understood --keyint, limiting it to 24 means severely restricting x265 in it's capability, right? Hybrid says this: Quote:
16th July 2017, 21:38 | #28 | Link |
To be compliant with Blu-ray specs. Since you aren't creating a Blu-ray I wouldn't worry about it too much. In generel, higher --keyint results in increased seeking times because if you seek to a random position you have to decode all frames starting from the last keyframe. With 24 fps and --keyint 24 there's one keyframe every second. With --keyint 240 only every 10 seconds. So when seeking you will have to wait on average 10 times longer (if we simplify a bit to make seek time only decoding time). --keyint 24 increases the need for bitrate because redundancies between frames can only survive 1 second because in a typical movie we don't have a new scene every second. That wastes lots of bits. When we increase keyint the need for bitrate decreases but the savings diminish at some point. I think at about 4 seconds (at 24 fps roughly --keyint 96) you will have a sweet spot with a good compromise between seeking times and compression. Just do a few tests if you are interested or do a forum search. It was discussed in the past.
17th July 2017, 08:15 | #29 | Link | ||
I'm not planning to watch HDR demo videos all day. Quote:
I will do some testing. However, I think I'll have to find another demo for that because the Samsung HDR Wonderland has very long scenes - not representative of an actual movie. What about --min-keyint? Should I set that to 1 or leave at 0 (which is usually 23)? One more thing, is there any downside in using the remaining --uhd-bd parameters? --aud --no-open-gop --chromaloc 2 |
17th July 2017, 16:48 | #30 | Link | ||
--no-open-gop is not required for Blu-ray. Both are allowed. OpenGOP improves compression a bit. Can be problematic with some players e.g. in mp4 and makes editing more difficult. --aud is for compatibility. You shouldn't need to set it. If you don't encode for Blu-ray it is not required. If you encode for Blu-ray it will already be activated by --uhd-bd anyways (same with --min-keyint 1). |
17th July 2017, 17:09 | #31 | Link |
I am asking because even for a UHD Blu-ray encode I would not use --uhd-bd (because of what you told me about --keyint).
Instead I would manually only set the essential parameters that don't increase the bitrate unnecessarily. This is what I meant to say before... I am creating encodes with different --keyint values now to see where the sweetspot might be... |
17th July 2017, 17:22 | #32 | Link | |
What I also found is --uhd-bd indeed disables OpenGOP. I didn't know that and I don't know why it does that. OpenGOP is allowed on Blu-ray. So either it is an error or x265's OpenGOP implementation isn't compatible with Blu-ray. So maybe it is better to turn off OpenGOP for Blu-ray after all (i.e. set --no-open-gop). |
17th July 2017, 20:00 | #33 | Link |
OK, here it goes.
Encode test results with various --keyint values. I still used the "Samsung HDR Wonderland" demo as kind of a "worst case" scenario, because it has very long, almost static scenes. --min-keyint / --keyint Bitrate 1 / 24 (--uhd-bd): 21.4 mbit/s 1 / 48: 17.6 mbit/s 1 / 72: 16.6 mbit/s 1 / 96: 15.9 mbit/s 1 / 120: 15.0 mbit/s 12 / 120 (0 / 120): 15.0 mbit/s 1 / 144: 15.1 mbit/s 1 / 168: 15.0 mbit/s 1 / 192: 15.1 mbit/s 23 / 250 (default): 14.2 mbit/s It looks to me like the obvious sweetspot is at 1 / 120 (5 seconds) for this demo. I will later try to see if the "sweetspot" shifts when I use the "Exodus UHD HDR" demo, that is more action-packed, or rather action-y at all. |
18th July 2017, 10:11 | #34 | Link | ||
I created a few Exodus encodes as well last night, the difference is much subtler, as expected.
1 / 96 and 1 / 120 are quite similar, 96 only gets a minor bitrate bump. Even 1 / 24 is not too far off due to the very short scenes. However, I think I will stick with 1 / 120 to not waste bitrate on "slow" movies. Seeking / skipping should be OK. So, thanks to your help I think I found quite good settings to use on UltraHD Blu-rays - assuming and hoping it will be possible to encode those at some point... Basic syntax: Quote:
6th August 2017, 11:22 | #35 | Link | |
hello
How would you write the tweak for x265 of this encode?thanks Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : 36 Duration : 2 h 1 min Bit rate : 50.4 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.254 Stream size : 42.8 GiB (80%) Color range : Limited Color primaries : BT.2020 Transfer characteristics : SMPTE ST 2084 Matrix coefficients : BT.2020 non-constant Mastering display color primar : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000 Mastering display luminance : min: 0.0050 cd/m2, max: 4000.0000 cd/m2 Maximum Content Light Level : 10000 cd/m2 Maximum Frame-Average Light Le : 3647 cd/m2[/PHP] TWEAK_X265=--output-depth 10 --profile main10 --tune grain --level-idc 5.1 --colorprim bt2020 --transfer smpte-st-2084 --colormatrix bt2020nc --uhd-bd --hdr-opt Quote:
16th August 2017, 00:21 | #36 | Link |
I hope no one minds a lurker jumping in and asking a question on this topic.
I have a ProRes 4444 UHD HDR (NCLC=9,16,9) source file and am creating a set of HD/UHD files to be packaged for DASH distribution. The source is smpte2084 mastering display P3 at 4000 nits (G(0.265, 0.690),B(0.150, 0.060),R(0.680, 0.320),WP(0.3127, 0.3290),L(4000, 0.0005)). Typical stuff. Encoding with the following (HD example given, UHD versions don't scale) I'm getting a slight pink shift I'm told by the client (I don't have the ability to view the source with proper EOTF). Code:
ffmpeg -i INPUTFILE.mov -filter_complex '[0:v]scale=1920:-1:flags=+bicublin:sws_dither=ed[v]' -map '[v]' -c:v libx265 -pix_fmt yuv420p10le -preset slow -x265-params level-idc=5.0:high-tier=1:aud=1:sar=1:no-open-gop=1:scenecut=0:ref=4:me=3:merange=57:keyint=48:min-keyint=48:rc-lookahead=96:sao=1:cbqpoffs=6:crqpoffs=6:hrd=1:bitrate=5000:vbv-maxrate=5000:vbv-bufsize=7500:videoformat=5:range=limited:colorprim=9:transfer=16:colormatrix=9:hdr-opt=1:master-display='G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,5)':max-cll='2226,899' -an -dn -sn -y OUTPUTFILE.hevc Thanks for any ideas. Last edited by supergimp; 16th August 2017 at 19:18. |
25th October 2017, 22:14 | #39 | Link | |
You simply can't tune HDR encoding without an HDR reference display, or diagnose problems on the customer end without seeing their display. And you can't assume a customer display is accurate. Particularly if the display is in some sort of default Vivid mode, or hasn't been calibrated, or simply doesn't have a good tone mapper. There are a number of devices on the market that demonstrate a red shift in what should be gray-white. And the exact same file will look perfect on a calibrated reference display (I use the Sony Z9D). |
22nd December 2017, 15:26 | #40 | Link | |||
Tell me which command disables the Encoding settings?
In MediaInfo it is necessary that this information is not displayed. Quote:
for example Quote:
