Old 14th January 2008, 13:19   #221  |  Link
Beastie Boy
Beastie Boy's Avatar
Originally Posted by Klute View Post
"YV12 images for output must have a width divisible by 4 (use crop)!":-/
The error message is quite clear. Neither 582 or 319 are multiples of 4, so...
Beastie Boy is offline   Reply With Quote
Old 14th January 2008, 13:34   #222  |  Link
Klute
yes, i know. the problem is, that im searching for a way to encode lots of different files without having to change the script all the time.
version 1.14 at least fixed the problem that i had with the uneven height.
edit: ahhh, i know, now that the uneven height problem is gone, i can just convert to another colorspace... thanks for hinting me in the right direction
Klute is offline   Reply With Quote
Old 14th January 2008, 13:55   #223  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
How about putting something like
Crop(0,0,-(last.width%4),-(last.height%4))
at the end of your script?
I'd say cropping up to 3 pixels at the right and bottom side shouldn't be much of a problem...
now playing: [artist] - [track] ([album])
Leak is offline   Reply With Quote
Old 14th January 2008, 14:24   #224  |  Link
Klute
thanks
Old 14th January 2008, 21:54   #225  |  Link
IanB
Avisynth Developer
Only the width is restricted to mod 4, the height can be mod 2
Crop(0,0,-(last.width%4),-(last.height%2))
IanB is offline   Reply With Quote
Old 22nd January 2008, 13:50   #226  |  Link
cweb
cweb's Avatar
Today I tried opening a pal dv avi using ffmpegsource with the parameter atrack=-1. the frame rate is 100 instead of 25fps..
function dvsource(string name)
ffmpegsource(name,atrack=-1)
video=dvsource("video1.avi")
video=video.info()
video
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card
http://twitter.com/cwebdesign
cweb is offline   Reply With Quote
Old 22nd January 2008, 16:50   #227  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
You must have a very special avi file. Make sure to treasure it for it will bring you much happiness.
Old 23rd January 2008, 11:22   #228  |  Link
DarkZell666
aka XaS
DarkZell666's Avatar
And I ate an apple yesterday ...
@cweb : Unless you were interrupted while writting your post, I don't see the point either, did something actually go wrong ?
If so, what precisely ?
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS
DarkZell666 is offline   Reply With Quote
Old 23rd January 2008, 11:40   #229  |  Link
cweb
cweb's Avatar
It gave the wrong frame rate.. double the supposed amount.
However I noticed afterwards that I had *another* dvsource function in another include file, and it was calling *that* function instead of the one in the main avs file...
so sorry about that. ffmpegsource for a dv avi seems not to work like someone else had posted. I took the alternative of merging my dv avi's using virtualdub into combined avi's instead and I accessed them using avisource again..
Old 23rd January 2008, 15:13   #230  |  Link
DarkZell666
aka XaS
That info wasn't in your post originally (unless I've got early eye disease ? oO)
So you edited it, and somehow the "Last Edited by cweb at xx:xx:xx" message isn't mentionned at the bottom of your post.
wtf !?
Old 23rd January 2008, 15:50   #231  |  Link
cweb
cweb's Avatar
wtf !?
No I didn't edit the info about the frame rate.. it was there in the first place.
Old 23rd January 2008, 17:23   #232  |  Link
DarkZell666
aka XaS
... my apologies then
Old 23rd January 2008, 18:32   #233  |  Link
cweb
cweb's Avatar
No problem..
Old 14th February 2008, 17:42   #234  |  Link
ernstblaauw
ffAudioSource
In the first post, FFAudioSource is called 'experimental'. I used it to open a slightly corrupted MP3 file (MPASource did not manage to openit correctly), and it worked ok for me. Does it need more testing? Or is it just "not tested but implemented"?
However, I'm very happy with this plugin - I hope you'll develop this one further (if needed, of course :-). Thanks!
My website: www.ernstblaauw.nl
ernstblaauw is offline   Reply With Quote
Old 14th February 2008, 17:49   #235  |  Link
MPASource doesn't support mp3
Old 14th February 2008, 17:54   #236  |  Link
ernstblaauw
It does - for example DVD slideshow GUI uses it for loading mp3 files. See also http://avisynth.org/mediawiki/Importing_media, it is stated there.
Old 14th February 2008, 20:26   #237  |  Link
Myrsloik
Myrsloik's Avatar
It is highly experimantal. In this case experimental means "this may or may not work properly but I'm too lazy to find out myself so now I'm going to release it on the internet and do something else and see what happens". Not much happened so either no one uses it or it works well enough most of the time.
Future ideas if anyone wants to comment:
  • Make indexing a single separate step and index all streams present in a file at once (no idea what to do about audio with variable block sizes, maybe it will be fast enough anyway even if those have to be decoded)
  • Separate FFmpegSource into FFVideoSource and FFAudioDump (write as wave(64) files and then use wavsource to return it if necessary)
  • Add swscale (just because it's there, would only provide alternatives to colorspace conversion functions with some additional settings possible)
  • Compile with mlp/eac3 patches (if there's still any real demand)
  • Make it possible to set the number of threads libavcodec uses for decoding (note that most decoders aren't multithreaded anyway)
Last edited by Myrsloik; 16th February 2008 at 01:13. Reason: sneaky additions to the list
Old 14th February 2008, 20:30   #238  |  Link
ernstblaauw
For me it works well enough most of the time :-). Good luck with the 'road map' you just posted. This is really a great plugin!
Old 29th February 2008, 03:56   #239  |  Link
shita
Can you help me link to get ffplay.exe for win in ffmpeg project ? Thanks
shita is offline   Reply With Quote
Old 29th February 2008, 08:25   #240  |  Link
buzzqw
HDConvertToX author
@shita
http://ffdshow.faireal.net/mirror/ff...eg.rev11870.7z
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
