29th January 2011, 01:16 | #1022 | Link | ||
30th January 2011, 02:10 | #1023 | Link |
This sample gets very jerky if I specify fpsnum=24000 and fpsden=1001 using r426.
4th February 2011, 22:56 | #1024 | Link | |
warpsharpened
Also made a few builds while doom9 was down for a bit. I rolled back ffmpeg-mt to a December version which fixes the two issues people were having with it (I believe the issues have been addressed in the ffmpeg-mt src). ffms2-mt-r430.7z ffms2-mt-r430-avs64.7z Some vanilla ffmpeg builds if you want them (dunno why): ffms2-r430.7z ffms2-r430-avs64.7z |
6th February 2011, 09:54 | #1025 | Link | |
2.14 and r375 work fine, problem appears with 411 for the first time. (all mt) Last edited by sneaker_ger; 6th February 2011 at 10:02. |
6th February 2011, 11:37 | #1026 | Link | |
Excessively jovial fellow
e: pretty sure Plorkyeran broke it in r385. Last edited by TheFluff; 6th February 2011 at 11:42. |
12th February 2011, 00:31 | #1030 | Link |
FFMS 2.15 is now released; you can grab it from the Google Code page.
Changes since 2.14:
I've updated the Avisynth plugin documentation a bit; it should be easier to read and understand now. I've also updated the known issues part of it, so all actual known issues are listed there now. If you find a problem that isn't listed there, please report it, regardless of what I or other people have said or claimed about it in the past. Edit: ATTN the three of you who downloaded this before 00:35 GMT: your version doesn't handle zlib compressed streams in MKV correctly. Redownload it to fix the issue. Last edited by TheFluff; 12th February 2011 at 01:47. |
12th February 2011, 01:02 | #1031 | Link |
thanks a lot...
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note... Visit The Land Of Dracula (Romania - EU)! |
12th February 2011, 03:55 | #1032 | Link | |
Thanks for the update!
src/core/utils.cpp: In function 'void safe_aligned_reallocz(T*&, size_t, size_t)': src/core/utils.cpp:233: error: there are no arguments to 'min' that depend on a template parameter, so a declaration of 'min' must be available src/core/utils.cpp:233: note: (if you use '-fpermissive', G++ will accept your code, but allowing the use of an undeclared name is deprecated) src/core/utils.cpp: In function 'void safe_aligned_reallocz(T*&, size_t, size_t) [with T = uint8_t]': src/core/utils.cpp:262: instantiated from here src/core/utils.cpp:233: error: 'min' was not declared in this scope |
12th February 2011, 08:36 | #1034 | Link | |
warpsharpened
The vanilla ffmpeg builds I would imagine use whatever was the last revision before the files were posted. |
12th February 2011, 08:54 | #1035 | Link |
Ah ok! well, 2 months for FFMPEG = lots of changes, I think I'll use the standard one! Multithreaded ffms doesn't really affect me, I usually encode 2 videos at once which equals 100 percent CPU usage, speed wise its not noticeable since Staxrip defaults x264 etc to the lowest priority. Parallel encoding files seems more effective than multithreading, since there are still stages in the pipeline that are slowed down either by processing requirements or being unoptimised and/or single threaded.
12th February 2011, 13:47 | #1036 | Link | |
14th February 2011, 02:04 | #1039 | Link |
@TheFluff does this improvements go to x264's ffms too? (especially the timebase/timescale fix)...may be in the next release?
_
14th February 2011, 13:45 | #1040 | Link |
That depends on who compiles x264 and what version of FFMS they're linking against. JEEB usually uses the SVN HEAD so in his builds the changes should have been in for a long time, but I dunno about anyone else.
