29th December 2012, 12:23 | #2781 | Link | |||||
29th December 2012, 12:51 | #2782 | Link |
I think it may be because I pressed the "+" next to where it says Audio 1 in the One Click Encoder window? Could that have been the reason for 2 identical audio jobs?
Also, is there a way to make it add all of them to queue at once? (for those that are certain hdd space won't be an issue) EDIT: Fixed. Yeah I think that's why it was adding duplicates... |
29th December 2012, 13:45 | #2784 | Link | |
And two, every once in a while I may have a MPEG file that would stall while its being indexed due to some minor corruption (OTA caps that could usually be fixed by a quickstream fix in VideoRedo). So as you could imagine, the result would be nothing further being processed from that point on in the queue. Whereas, typically, before the update, I could just wait around a few minutes to make sure all the jobs were indexed. And from there on, I could start a secondary queue if need be (back to my first reason...) . |
29th December 2012, 15:02 | #2785 | Link | |
29th December 2012, 15:19 | #2787 | Link |
Yes, a newer build will be uploaded in the next days.
EDIT: Changelog of the at the moment implemented changes can be found here: http://megui.svn.sourceforge.net/viewvc/megui/megui/trunk/Changelog.txt Some local changes are missing |
30th December 2012, 12:22 | #2789 | Link | ||
Swallowed in the Sea
Index: packages/tools/hdbdextractor/HDBDStreamExtractor.cs =================================================================== --- packages/tools/hdbdextractor/HDBDStreamExtractor.cs (revision 2248) +++ packages/tools/hdbdextractor/HDBDStreamExtractor.cs (working copy) @@ -345,9 +345,9 @@ // Load to MeGUI job queue if (FolderSelection.Checked) - job = new HDStreamsExJob(new List<string>() { dummyInput }, this.FolderOutputTextBox.Text + "xxx", args.featureNumber, args.args, inputType); + job = new HDStreamsExJob(new List<string>() { dummyInput }, this.FolderOutputTextBox.Text, args.featureNumber, args.args, inputType); else - job = new HDStreamsExJob(input, this.FolderOutputTextBox.Text + "xxx", null, args.args, inputType); + job = new HDStreamsExJob(input, this.FolderOutputTextBox.Text, null, args.args, inputType); lastJob = job; mainForm.Jobs.addJobsToQueue(job); @@ -464,10 +464,20 @@ // create dummy input string for megui job if (feature.Description.Contains("EVO")) { - if (FolderInputTextBox.Text.ToUpper(System.Globalization.CultureInfo.InvariantCulture).Contains("HVDVD_TS")) - dummyInput = FolderInputTextBox.Text + feature.Description.Substring(0, feature.Description.IndexOf(",")); + if (feature.Description.Contains("+")) + { + if (FolderInputTextBox.Text.ToUpper(System.Globalization.CultureInfo.InvariantCulture).Contains("HVDVD_TS")) + dummyInput = FolderInputTextBox.Text.Substring(0, FolderInputTextBox.Text.IndexOf("HVDVD_TS")) + "HVDVD_TS\\" + feature.Description.Substring(0, feature.Description.IndexOf("+")); + else + dummyInput = FolderInputTextBox.Text + "HVDVD_TS\\" + feature.Description.Substring(0, feature.Description.IndexOf("+")); + } else - dummyInput = FolderInputTextBox.Text + "HVDVD_TS\\" + feature.Description.Substring(0, feature.Description.IndexOf(",")); + { + if (FolderInputTextBox.Text.ToUpper(System.Globalization.CultureInfo.InvariantCulture).Contains("HVDVD_TS")) + dummyInput = FolderInputTextBox.Text.Substring(0, FolderInputTextBox.Text.IndexOf("HVDVD_TS")) + "HVDVD_TS\\" + feature.Description.Substring(0, feature.Description.IndexOf(",")); + else + dummyInput = FolderInputTextBox.Text + "HVDVD_TS\\" + feature.Description.Substring(0, feature.Description.IndexOf(",")); + } } else if (feature.Description.Contains("(angle")) { From the log: Quote:
30th December 2012, 12:29 | #2790 | Link |
@Zathor: Is it possible to put only muxing jobs in higher priority (or normal at least) by default? It's always bothered me that muxing always goes hell slow when it's on "low" priority.
Like right now, I came back to my PC to see it was muxing a 1.23 GB file. The time elapsed was over 5 MINUTES and it was not even half way done. The moment I put it on below normal, normal, or above normal priorities, it zipped right through and finished it within a minute. I want to keep audio/video jobs on low, though. And, as it stands right now, I believe MeGUI remembers the priority of the last/current job, and when the status window of the next job pops up it will use the same priority of the last one that finished. It would great if there is a way, or if not, I'd like to put in a request for it. |
30th December 2012, 16:59 | #2792 | Link |
2253 [Queue] warn if intermediate files of an incomplete job are going to be deleted 2252 [Worker] if a job is aborted the corresponding worker will be stopped 2251 [OneClick] pgcdemux will only be used if more than one PGC is found 2250 [AVS Script Creator] avoid upsizing when resizing a cropped source [AVS Script Creator] added option to enable upsizing in the profile (disabled by default) [AVS Script Creator] added option to select the default mod value in the profile (mod16 by default) [AVS Script Creator] adjusted "Clever (TM) anamorphic encoding" so the new mod values are used [OneClick] obey the new AVS Script Creator settings 2249 [HD Streams Extractor] fixed handling of seamless branching EVO files 2248 [OneClick] warn if identical tracks are about to be processed 2247 [AVS Script Creator] hide "Aspect Ratio Error" when doing an anamorphic encoding fixed handling of the "Aspect Ratio Error" if dealing with an anamorphic input file 2246 [AVS Script Creator] enhanced readability of the "red parts" the "Aspect Ratio Error" only turns red if the value is bigger than the acceptable aspect error crop values will be used also for the upsize warnings 2245 [Queue] related jobs are highlighted when selecting a job 2244 [Queue] when deleting a job warn always if it is part of a related job series |
30th December 2012, 17:43 | #2793 | Link |
Hello Zathor,
thanks for all the work. I often use MeGui with the option Oneclick to bring avi (with audio ac3 or mp3) in mp4 (video x264 and audio aac 48kbps). Sometimes it doesn't work properly: 1. I noticed that when the audio in the avi was muxed with delay (positive or negative) Oneclick gives an error and was not able to extract the audio. 2. Sometimes all seems to go on well, but at the end (but not always) the muxed mp4 files was not in syncro though the avi was perfect. The one point I can get around with having the avi no delay in the audio track, but point 2.... I don't know. Now I'm using AutoEncoder, is it not the same thing... OneClick is better for me. Please sorry for my english. I wish you a good new year and thanks again. Last edited by TSoft; 30th December 2012 at 17:51. |
30th December 2012, 18:03 | #2794 | Link |
Hi Zathor, I have found a bug in the Http Proxy code.
If you check the Use Proxy option in settings but don't enter server details then you get an error the next time MeGUI is launched: Code:
MeGUI encountered a fatal error and may not be able to proceed. Reason: Invalid URI: The hostname could not be parsed. I could only fix it by editing the settings.xml file: Code:
<UseHttpProxy>true</UseHttpProxy> Code:
<UseHttpProxy>false</UseHttpProxy> Without knowing how you are implementing your call to the update server, I can't provide a full code sample but, as a starting point, to access the system proxy settings you can use: Code:
System.Net.CredentialCache.DefaultCredentials |
30th December 2012, 18:16 | #2795 | Link | |||
WebClient serverClient = new WebClient(); WebProxy wprox = null; ICredentials icred = null; if (meGUISettings.HttpProxyUid != null) icred = new NetworkCredential(meGUISettings.HttpProxyUid, meGUISettings.HttpProxyPwd); wprox = new WebProxy(meGUISettings.HttpProxyAddress + ":" + meGUISettings.HttpProxyPort, true, null, icred); WebRequest.DefaultWebProxy = wprox; serverClient.Proxy = wprox; |
30th December 2012, 18:18 | #2796 | Link | |
30th December 2012, 19:06 | #2797 | Link |
Zathor,
I just updated to version 2253 and the adjustments to the resizing are great. Thanks! But....... The calculations for the aspect ratio/error must be a little off at times. 16:9 PAL DVDs resized to 704x396 show an aspect error of 0%, which is correct, yet if you open a video of different dimensions, tell MeGUI the input aspect ratio is 16:9 and resize to 704x396 again, it shows a slight aspect ratio error. A very tiny one admittedly but 704x396 is still exactly 16:9 regardless of the input resolution. The one which stands out the most is when resizing 4:3 DVDs to 640x480. The aspect ratio error shown is 0.13%. Oddly enough I opened a 704x384 AVI and told MeGUI it's input aspect ratio was 4:3, and a 640x480 resize showed a 0% aspect ratio error. I've sometimes wondered in the past if the aspect ratio MeGUI adds to the script was just a little off..... A couple of little nitpicks if I may...... The anamorphic "to the selected mod" change works well, only using the undercrop and overcrop anamorphic options you can't actually select the mod because it's greyed out. I guess the "selected mod" setting is connected to the resizing so maybe it's not worth worrying about, but I'm OCD when it comes to consistency. The anamorphic options aside from "resize to" disable the resizing, but the resize fields sometimes turn red when you crop. Maybe fixing that is already on your to-do list? Anyhow..... thanks once more. |
30th December 2012, 19:40 | #2798 | Link |
While I'm here......
When you open a video via DirectShow MeGUI automatically adds frame rate conversion to the script, which I think is a good idea, but I've often wondered, why not do the same thing for ffmsindex? AVISource uses Assumefps instead, although maybe there's a good reason for that, but given ffmsindex can open all kinds of video including AVIs, I can't think of a reason why adding it's own frame rate conversion to the script would be a bad idea. I'd assume if the video is CFR then adding it would make no difference, but if it's VFR at least MeGUI could encode it without losing audio sync. Am I missing something? Cheers. |
30th December 2012, 20:20 | #2799 | Link | ||||
Thanks again for your feedback! |
31st December 2012, 00:40 | #2800 | Link | |
720x576 with an aspect ratio of 4:3 has a SAR of 16/15 which results in 768x576 in SAR 1:1. Therefore you have an slight error with 640x480. Instead an 704x384 4:3 file has a SAR of 8/11 resulting in 512x384 for square pixels - wich is the same as 640x480 and therefore 0% aspect ratio error. Adding AssumeFPS can cause problem with telecined video as FFMS will alter the frame rate. At least that is the reason I remeber. |
